VWVortex.com - Reset Service Reminder
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 29
    Thread: Reset Service Reminder
    1. Member meanvw's Avatar
      Dec 31st, 2004
      van down by the river
      2015 GTI, 2007 GLI, 81 Rabbit pu
      03-14-2006 12:03 AM #1
      Service indicator can be reset without a VAG COM.
      Here's how:
      1. Keys out of ignition- press and hold in trip odometer reset button "0.0" on right hand side of display
      2. Still holding this button down, insert key into ignition and put to the on position without starting the car.
      3. Display will read "service now"
      4. let go of the "0.0" button and depress the "m" button on the left hand side of the display. this will re-set the service reminder. There is no confirmation on the display other than the words "service now" will disappear.
      You can confirm that the service reminder has been reset, or check how many miles/days remain until service at any time by taking key out of the ignition and holding in the trip reset "0.0" button for between 3 and 5 seconds. The MFD will display miles and hours until next service.
      VENOM is back for 2016! Looking for events in SE Wisconsin? Check out our Facebook page https://www.facebook.com/groups/venommotorsports/
    2. Member Aguilar's Avatar
      Jan 28th, 2006
      VA
      2.7tt F150, Mk7 GTI
      03-14-2006 07:58 AM #2
      Good info. Thanks!
    3. 03-14-2006 06:23 PM #3
      I assume it does scheduled maint. like 5000, and 10k service?
    4. Banned D S C's Avatar
      Mar 13th, 2006
      03-15-2006 01:50 AM #4
      Thanks Tomowski for this info!!!!!
      http://forums.vwvortex.com/zer...ostid
      Original discoverer. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Feb 11th, 2004
      Magdeburg, Germany
      '67 Ford Mustang Conv.
      04-06-2006 09:43 PM #5
      Side note...
      ...whenever you do it that way, all service reminder settings are set to "fixed intervals". This may not play a role for you guys, but for euro guys (like me) it plays a big role.
    6. 04-07-2006 09:51 AM #6
      Quote, originally posted by Theresias »
      Side note...
      So.... what's the other way then?
      Feb 11th, 2004
      Magdeburg, Germany
      04-07-2006 01:44 PM #7
      The other (real) way is using a diagnostic tool, like...
      VAG-COM > Select > 17 - Intruments > Adaptation - 10 > Channel 002 (Service Reminder)
    8. 04-07-2006 02:08 PM #8
      Thanks [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    9. Member quailallstar's Avatar
      Dec 2nd, 2001
      Ormond Beach, FL
      @LuvGermanCars
      04-23-2006 02:27 PM #9
      ahh this might be why mine is not set correctly...hmmmm
      2Ø16 Golf 7 Variant Highline R-Line Pure-Weiß 1,8 FSI « 2Ø11 Golf 6 2,0 6-Gang DPF 2,0 TDI BLUEMOTION Technologies™ Highline Candy-Weiß 5-Türen« Ø8 Golf 5 .:R32 Deep Blau Perleffekt 3,2 VR6 DSG 4-MOTION™ 3-Türen « Ø6 Golf 5 GTI 2,0 FSI DSG Tornadorot 3-Türen « Ø2 Indigo Blau Perleffekt Passat 3BG Trendline 1,8T 4-Türen. I Euro-spec OEM Mods
    10. 06-11-2006 12:43 AM #10
      Side note...
      So what do "fixed intervals" mean?
      I have approx. 7,000 miles on my car, if i reset the service indicator will the computer think that the next service is in another 5,000 miles (12,000 miles), or will it know that the next service is at 10,000.
    11. Member
      Feb 11th, 2004
      Magdeburg, Germany
      06-11-2006 08:20 AM #11
      US models normally use fixed intervals, couple of rest of world countries use flexible intervals, which means the interval is beeing calculated by the instrument cluster based on stuff like engine load, rpm, oil consupmtion/lever and other factors.
      If you are at 7.000 mi now and resetting your reminder, it will think the next service is in 5.000 mi at 12.000 mi. If you want to set it to the correct values (in 3.000 mi at 10.000 mi) you need a dianostic tool like VAG-COM.
      Minimum Mileage to Service
      fixed Service Intervals (8.000 km OR 5.000 mi - w/o Longlife)
      flexible Service Intervals (15.000 km OR 9.000 mi - with Longlife)
      Maximum Mileage to Service
      flexible Service Intervals (30.000 km OR 19.000 mi - with Longlife)
    12. 06-12-2006 07:41 AM #12
      You just saved me a trip to the dealer (and a $70 oil change)! Thanks alot!
    13. 11-08-2006 09:55 AM #13
      When I do this, channel 002 says "ERROR Channel 02 Not Available"
      I've never seen anything on my MFD about servicing my car and I've tried the reset procedure and all it did was reset my trip miles.
      Does my car have the service "thing?" Can I enable it with my vag-com?
    14. 11-11-2006 06:44 PM #14
      To the top.
      I still have the problem described above ^^^
    15. Member madfella's Avatar
      Oct 5th, 2005
      TX, AZ, NM, CA, NM, AZ, TX...
      91 GLI | 98 WBE Jetta | 06 Jetta | 07 GTI | 08 WFE Jetta | 12 GLI | Current: 11 Routan | 13 DE GTI
      11-12-2006 02:11 AM #15
      X2
    16. 11-12-2006 09:44 AM #16
      Awsome thanks! My 5k just came on
    17. 12-08-2006 09:03 AM #17
      So - now that I have coded my instruments to Europe anyway - can I enable the flexible intervals? Since I am probably just the type that would benefit from notification of need for an earlier service (my foot constitutes about 60% of my total body weight )
    18. 12-13-2006 10:37 AM #18
      I've got 13,500 miles now and I STILL haven't seen ANY sort of service light.
      When I try to change things via Vag-Com I get "When I do this, channel 002 says "ERROR Channel 02 Not Available"
      Wonder what the deal is....
    19. Senior Member syntrix's Avatar
      Aug 20th, 2000
      Little Rock, AR
      indeed!
      12-13-2006 05:26 PM #19
      Quote, originally posted by (mkV)Jetta2.0t »
      It's channel 002.
      Did you type it in? Did you use the scroll arrows? If you didn't do one of them, try it
      If not, did this get posted in the vag-com forum? What does it say on your cable? What version of vag-com are you using?
      MOEW: ٩(●̮̮̃•̃)۶ Zomg Zombies ٩(-̮̮̃-̃)۶ ٩(-̮̮̃•̃)۶ ٩(×̯×)۶ ¯\(°_o)/¯
      If you have a problem with anything I do here, feel free to call me on my cell to discuss at anytime: (781)452-2079 LEAPRZ
    20. 12-13-2006 05:37 PM #20
      Quote, originally posted by syntrix »
      It's channel 002.
      I'm running the latest version of Vag Com with the MicroCAN cable. I'm actually IN the car right now as I post this.
      I'm in the Instruments controller, clicked adaptation, then typed in "002" for the channel and I get "error: channel 002 not available.
    21. 12-13-2006 05:46 PM #21
      Just to show you, here is a screenshot:
    22. 01-26-2007 04:39 PM #22
      maybe this is specific to certain packages? not sure, i dont have a MKV yet, im still driving the MKIV. otherwise i would try also.
    23. Member
      Feb 11th, 2004
      Magdeburg, Germany
      01-27-2007 08:44 PM #23
      Actually it's not specific - it's a series of instrument cluster that simply do not have service reminders at all - so also no channel 002 to reset them. The production codes plate says the car should have 'em, but the car itself does not - we saw that a couple of times now and I bet your instrument cluster component field contains the supplier code 3HL.
    24. 01-30-2007 03:18 AM #24
      thanks
      great info
    25. Member buddahvw's Avatar
      May 4th, 2004
      Las Vegas
      2015 Porsche Boxster, 2010 VW Golf TDI
      01-30-2007 11:13 AM #25
      it is in the owners manual,
      or at least it is for the A3
