Page 1 of 7 1 2 3 4 5 ... LastLast
Results 1 to 35 of 226
Thread: Corrado parts in San Diego
  1. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    93 VR6 Corrado, 04 R32
    03-17-2006 07:40 PM #1
    Only wrecked Corrados used for this inventory... say no to parting good Corrados!!!
    This is mostly stuff that is left from this car:
    Pretty much all exterior parts were destroyed, as you can see. I do have a small potpourri bucket of leftover parts that I took pix of and posted here, but pretty much if it's a G60 item and it isn't listed, it was destroyed. ESPECIALLY if it was an exterior part.
    I do have some random VR6 parts too that are leftovers, as I've been building my current project.
    I am not parting a VR6.
    THESE ARE THE ONLY PARTS I HAVE AVAILABLE - if it's not listed here, it's not up for sale.
    Updated 5-13-13. Pix located at bottom.
    Corrado parts (both G60 and VR6):
    *Flash red Corrado exterior side view mirrors. No glass. Motors work perfectly. $50
    *Helios Pearl Blue Effect Corrado exterior side view mirrors. No glass. Motors work perfectly. $50
    *Rear license plate panel tub, two available. $30 each
    *G60/VR6 spoiler motor assembly with Pearl Blue or Flash Red (have both available) wing, perfect working order, no cracked plastic, no broken tabs or cable nipples, $150
    *G60/VR6 spoiler motor assembly, gears/motor/cables in perfect working order - no spoiler mount poles or slider assemblies, no wing, $50
    *Early style non-ABS brake light indicator, $20
    *Early style foglight switch, $20
    *Early style seat heater switch, $40
    *Early style rear defroster switch, $20
    *Mk2 style headlight switch - Corrado compatible, good backup to have. $15
    *Activ speaker system door amps, both sides. No corrosion on contacts. No speakers. $30
    *Early style door cubbies, both sides, $20 pair
    *Early style driver side window switch (dual switches), $20
    *Early style mirror control switch, $20
    *Early style HVAC vacuum control unit, $40
    *Early style ashtray, works perfectly. $20
    *Early style inner door latch trim, both sides. $20 pair
    *Early style OEM Cubby Guage Cluster with OEM VDO Oil pressure & Volt meters, $100
    *Center console, both upper and lower halves, some holes in upper part from previous armrest install. $20
    *Shifter console lower half, holes in passenger side from cupholders. $10
    *Passat center sunvisor, black, $20
    *Momo black super anatomical shift knob, threaded for Mk2/Corrado, missing lower bezel. Rough shape - scratched. $20
    *VDO oil pressure gauge, $20
    *VDO water temp gauge, $20
    *3-spot Audi gauge panel, $40
    VR6 parts
    *VR6 Headlights - DOT spec pair, excellent condition. All mounting tabs good, all adjusters work. Osram bulbs included. $150 for both shipped in lower 48.
    *Passenger side turn signal, cracked but sealed. Good temporary fix to get you by if yours is totally destroyed. $10
    *VR6 Corrado original style main intake hose (MAF to TB). I have two of them in excellent condition, no cracks or leaks. $40 each
    *VR6 Jetta (Mk3) main intake hose (MAF to TB). Smooth plastic style. $40
    *Zimmerman front 11.0" cross drilled rotors. 5 x100 bolt pattern. Still lots of life left... Most places won't resurface cross drilled rotors, so you'd need to bed in new pads using this procedure: http://www.stoptech.com/tech_info/wp_bedintheory.shtml
    $50 for the front pair.
    G60 parts:
    *G60 stock Mahle pistons, 1 used but good, 1 unused. Kept as spares. $40 each or $75 for both.[/I]
    *Carbon Fiber G60 radiator cover panel. Could use a bit of spit & polish, but considering it was laying at the crash site for several months, it looks great! $50
    *Carbon Fiber G60 alternator cover, needs some TLC, $50
    *G60 green top 260cc fuel injectors (complete set). Cleaned/flowed by Marren Motorsports & unused since servicing. $80
    *G60 charger cog belts (2 of them), $20
    *G60 stock boost hose, upper IC pipe to TB section, $20
    *G60 bypass kit (correct length short belt, upper bypass pipe), $40
    *G60 poly-V belt kit: one for stock pulley & one for 68mm pulley, $20
    *G60 hydraulic lifters, lightly used (>20k miles). $20
    *G60 Beru Silverstone spark plugs, used for only one week, set of 4 plugs. $10
    *G60 stock intercooler, no leaks, $40.
    *G60 stock intercooler duct, $10.
    *G60 air silencer box, halves sealed and portmatched for TEC 2RS charger. $10
    *G60 stock camshaft w/ sprocket, $20
    *G60 stock camshaft w/o sprocket, $15
    *G60 driver's side foglight, no cracks, $40.
    More yet to come, so check back.
    SOLD parts:
    SOLD!! *Passenger side DOT headlight, has a small chip. $50
    SOLD!! *Driver side DOT headlight, glass good but broken inner adjuster. $40
    SOLD!! *Driver side turn signal, typical hairline cracks but otherwise in great shape. $20
    SOLD!!!*G60 AC compressor. Very good shape, working perfectly when removed. Sanden SD-709 Model 7425. $100
    SOLD!!!*15" Speedlines from 93 Corrado SLC, 5x100 bolt pattern, 43mm ET.
    New tires put on these less than 2000 miles ago. Kuhmo Ecsta AST 205/50/15.
    Wheels are straight and true, tires perfectly balanced. I didn't clean them when I took these pix - what you see is what you get. Nice lightweight tough aluminum Speedlines with practically new tires. All four wheels have the proper Speedline center cap. $400 picked up in San Diego.
    SOLD!!!*Black leather 93+ Corrado front seats, $250 for the pair
    SOLD!!!*90mm Euro front lip chin spoiler. sides repaired & has a small section notched. $100
    SOLD!!!*70mm Spoonfedtuning front lip chin spoiler - brand new, uninstalled, unused. Same profile as 90mm Euro spoiler, just shorter - perfect for low cars! Flexible urethane will hold up better than factory ABS. Bought it before I realized my old 90mm spoiler was still intact after my wreck, don't need it. $175-
    SOLD!!!*50mm US spec front lip chin spoiler, scratched but otherwise in good shape. $40
    SOLD!*Girling G60 2-piston front brake calipers. Direct bolt on for both G60 and VR6 Corrados. Painted red, will include SS brake lines for G60 (VR6 has different length lines). $100
    SOLD!*Mk4 38mm piston aluminum rear brake calipers & carriers with ECS SS conversion brake lines to work on Corrado, Mk2, or Mk1. Painted red. $75
    SOLD!*H&R Race Springs, $100
    SOLD!*Early style Carbon Fiber door pull covers, $100
    SOLD!!!*TRW tie rods (both sides), $40
    SOLD! *US-spec Corrado steering wheel, excellent condition, $50
    SOLD!*Early style ABS/brake light indicator, $20
    SOLD!!!*Early style headlight switch, $40
    SOLD!!*Early style turn signal assembly, both halves. Needs new connectors spliced on. $20
    SOLD!!*Driver side Activ speaker cover, $40
    SOLD!*Early style dash vents: all driver side, both center vents. $20
    SOLD! *Early style HVAC slider/control lever.
    SOLD!! *Sansui CD deck. Untested. $30
    SOLD!!!*Early style black sunroof motor cover panel, $30
    SOLD!!! *Late style sunroof assembly, Flash Red roof, works perfectly, $100
    SOLD!*rear speakers w/ mesh, both sides $50
    SOLD*Black leather door cards and rear side panels, early style. Complete with switches & Activ amps/speakers/speaker covers in excellent condition. $300
    *Black leather back seats with center armrest. $200
    *Door cards, rear side panels, rear seats, rear armrest. $400
    SOLD
    SOLD!!*Eurosport G60/Mk2 front upper stress bar. Old style - will not work with Digifant Mk2, only G60. $70
    SOLD!!*G60 ISV, perfect working order, $40
    SOLD!*G60 Samco upper main intake hose, blue silicon, $40
    SOLD!!*G60 stock boost hose, silencer to lower IC pipe section, $20
    SOLD!*G60 outer CV joints, under 5k miles, $40.
    SOLD!*G60 A/C compressor, $50
    SOLD!*G60 stock Mahle pistons (three), 2 used but good, 1 unused. Kept as spares. $40 each or $100 for all three.
    SOLD!*Early style HVAC panel. Light works. $20
    SOLD!*Late style (93+) turn signal stalk assembly, wire harnesses cut - will need your old connecters spliced on. $40
    SOLD!!!*Recaro powered seat motors, both sides, $40 pair
    Brendan Prout
    04 R32 114k miles
    93 VR6 Corrado 182k miles
    90 G60 Corrado 304k miles - RIP 2/12/11
  2. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    04-21-2011 03:23 AM #2
    bringing this back to life! Updated parts list. More still to come.
    Brendan Prout
    04 R32 114k miles
  3. Member petethepug's Avatar
    May 25th, 2001
    So Cal
    Orig Owner 90 G60 & 02 Allroad 6Sp Man w/ 3rd Row Seat
    04-21-2011 11:29 AM #3
    Hey Brendan,
    Does the e/s gauge cubby have the plastic caps for the screw recesses and the metal mounting tabs to mount in the dash recess?
  4. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    04-21-2011 01:02 PM #4
    Quote Originally Posted by petethepug View Post
    Hey Brendan,
    It has one of the plastic screw covers, and it has plastic mounting tabs for mounting. Not the original metal ones, but tiny plastic L-bracket replacements.
    The panel does have a red LED warning light installed in the middle of it between the guages, will post pix later today. It was the "armed" light for my NOS system.
    Brendan Prout
    04 R32 114k miles
  5. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    04-22-2011 01:56 PM #5
    ttt
    Brendan Prout
    04 R32 114k miles
  6. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    04-23-2011 01:20 PM #6
    bump
    Brendan Prout
    04 R32 114k miles
  7. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    04-24-2011 03:19 PM #7
    To clear up confusion, the Active speaker covers pictured here go with the complete door cards.
    I *may* have another set in storage that i'll put up for adoption, but I don't know for sure yet. Will post up later this week after I have some time to dig and see what is still in there that I don't need going forward. Am basically clearing out all my early interior & G60 related stuff, since I just bought a 93 VR6
    Brendan Prout
    04 R32 114k miles
  8. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    04-25-2011 12:58 PM #8
    Monday bump!
    Brendan Prout
    04 R32 114k miles
  9. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    04-25-2011 09:30 PM #9
    TTT
    Brendan Prout
    04 R32 114k miles
  10. 04-26-2011 07:04 PM #10
    pm sent
  11. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    04-26-2011 07:49 PM #11
    PM replied!
    Brendan Prout
    04 R32 114k miles
  12. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    04-27-2011 12:11 AM #12
    Black leather interior sold~
    Brendan Prout
    04 R32 114k miles
  13. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    04-27-2011 02:38 PM #13
    bump
    Brendan Prout
    04 R32 114k miles
  14. Member VWHACK's Avatar
    Jan 10th, 2001
    South Orange County, Ca
    2013 RS5, 2010 Audi Q7 V8, 2008 R32
    04-27-2011 04:08 PM #14
    I need the Supercharger shim, has 3 bolt holes. Kinda looks like a banana.
    Goes behind charger and mounting bracket on the outlet side.
    I'm sick and tired of being right all the time
    http://www.pacificgerman.com/
  15. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    04-27-2011 04:31 PM #15
    The charger shim that was on the car sold with the complete motor/tranny/charger/ecu/harness swap, but I may have another in storage. Will post back with anything I find that I have up for adoption.
    Brendan Prout
    04 R32 114k miles
  16. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    04-28-2011 01:55 AM #16
    I do not have that charger shim. But I found a bunch of other parts and posted them above!
    Brendan Prout
    04 R32 114k miles
  17. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    04-28-2011 12:04 PM #17
    ttt
    Brendan Prout
    04 R32 114k miles
  18. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    04-29-2011 02:43 AM #18
    bump
    Brendan Prout
    04 R32 114k miles
  19. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    05-01-2011 05:25 PM #19
    more added!
    Brendan Prout
    04 R32 114k miles
  20. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    05-04-2011 05:06 AM #20
    Steering wheel sold & shipped!
    Brendan Prout
    04 R32 114k miles
  21. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    05-04-2011 01:49 PM #21
    ttt!
    Brendan Prout
    04 R32 114k miles
  22. 05-04-2011 11:37 PM #22
    I would like to buy the following:
    *Early style headlight switch, $40 (have a few of them)
    what do I need to do?
    A
  23. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    05-06-2011 01:02 AM #23
    one headlight switch & early ABS/brake light indicator sold!
    Brendan Prout
    04 R32 114k miles
  24. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    05-06-2011 12:24 PM #24
    bump!
    Brendan Prout
    04 R32 114k miles
  25. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    05-06-2011 01:21 PM #25
    Found one driver side Activ speaker cover!! Available for adoption.
    Brendan Prout
    04 R32 114k miles
  26. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    05-06-2011 11:42 PM #26
    Found a few more goodies! Up on the list!
    Brendan Prout
    04 R32 114k miles
  27. Member Hemingway'sToe's Avatar
    Feb 13th, 2009
    FtC, CO
    1990 VW Corrado G60
    05-07-2011 02:30 AM #27
    I could use some coolant hoses. Specifically the lower radiator hoses. (from rad to coolant pipe and from coolant pipe to wasser pump)
    Let me know!
  28. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    05-07-2011 02:32 AM #28
    Coolant hoses went with the motor swap, sorry.
    Brendan Prout
    04 R32 114k miles
  29. Member Hemingway'sToe's Avatar
    Feb 13th, 2009
    FtC, CO
    1990 VW Corrado G60
    05-07-2011 02:36 AM #29
    Quote Originally Posted by g60racer View Post
    bummer, can't find that lower one anywhere...
  30. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    05-08-2011 08:41 PM #30
    Mother's Day bump!
    Brendan Prout
    04 R32 114k miles
  31. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    05-10-2011 06:30 PM #31
    bump! May have a 90mm front spoiler for sale shortly...
    Brendan Prout
    04 R32 114k miles
  32. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    05-12-2011 03:29 PM #32
    a few VR6 goodies added!
    Brendan Prout
    04 R32 114k miles
  33. Member Tk2g60's Avatar
    Aug 26th, 2010
    Eastern PA
    1993 vr6 Corrado, 04 Frontier crewcab/ 2000 vr6 jetta(sold), 1991 g60(sold); 93 BMW 318ti(sold)
    05-12-2011 03:50 PM #33
    The tie rods u have for sale are for a g60 or vr6?
  34. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    05-12-2011 07:12 PM #34
    Tie rods are G60.
    Brendan Prout
    04 R32 114k miles
  35. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    05-13-2011 11:25 AM #35
    ttt!
    Brendan Prout
    04 R32 114k miles
