wow, saggy grill fix...nice...I wish i knew about this before i got rid of the grill!
#1
I had a saggy Bonrath badgeless grille, but not anymoreBefore:
After:
All you need to do is:
*Remove the grille
*Screw 1 or 2 screws (at least 32mm long) through bumper here:
There already is 2 holes in the bumper that keeps the grille still, I drilled the screws between them. Closeup:
Now you can adjust you grille how much it sags with 2 screws.
When you´re satisfied with your adjustments, just put the grille back on.
Feel free to comment my english, it still sucks
#2
#3
this deserves a DIY/FAQ nomination.![]()
#4
Quote, originally posted by mozcar78 » this deserves a DIY/FAQ nomination. ![]()
indeed
PVW 12/09 | innovative diesel | maryland perf diesel | 678/1283@45psi
you can sell horsepower but you can drive torque
#5
i always tought grilles sagged from hot temepratures outside, not from their own weightElvir
#7
I just shoved a rubber stopper in the same spot...no more saggieness:![]()
#8
BTW, this was not my invention, I just wanted to share this. Rubber stopper works fine too![]()
#10
reporting to mod for a spot...
#13
i should try this out![]()
Audi b5 wiper motor FS http://forums.vwvortex.com/showthrea...FS-Wiper-Motor
club.broke.status.
b5 avant For Sale http://forums.vwvortex.com/showthrea...7#post80441937
#14
wait wait..so you're saying Bonrath DOES sag! i kknew it...and all those fools telling me no nooooonoooooo Bonrath never sags, your JOM will..HA..! suckas!good work..i think i'd jam a hockey puck or something in mine if i could
#15
ur the ****ing man![]()
#16
Finally, something to do with my Sunday.![]()
#17
Quote, originally posted by Jumanklaudienssi » I had a saggy Bonrath badgeless grille, but not anymore All you need to do is:
*Remove the grille
*Screw 1 or 2 screws (at least 32mm long) through bumper here:There already is 2 holes in the bumper that keeps the grille still, I drilled the screws between them. Closeup:
There already is 2 holes in the bumper that keep the grille still, I drilled the screws between them. Closeup:
Now you can adjust you grille based on how much it sags with 2 screws.
or maybe:
Now you can adjust you grille with 2 screws depending on how much it sags![]()
When you´re satisfied with your adjustments, just put the grille back on.![]()
Feel free to comment on my english, it still sucksGreat post, here are some fixes for the writeup..
Ajaa ei murheissaan , minun finnish on hirmuinen kanssa!
#18
I will never go badgeless cuz im proud to fly the VE emblem
I think this DIY rocks
