Nice, I have actually been looking for a writeup on this method. I agree, the stock airbox is a pita to deal with when you just need to get to the MAF.
#1
Despite the fact that I got ****faced last night, and woke up drunk this morning at 6:40am to go to a scrap yard to look for parts in a snow storm/bloody cold weather, I still somehow managed to get this done, so its pretty easy. I think the hardest part was trying to understand the advanced mechanics of zipties in my retarded state of mind.First the schematic I came up with for the project:
Thanks to whomever picture that was.![]()
You need:
Regular tools, cutters, screwdrivers, etc.Zip ties, couple of em. I think I used about 5 or 6.
K&N filter with a 1" inlet. I used part no. 62-1410. $22.90
K&N Filter with a 70mm/2.75" opening. Part no. RU1520. - $55.00
I think this is the largest filter that would fit, being 7".1. Take out the entire air box. Unplug what ever lines you can that run around the airbox because they just get in the way. Find the 1" hose that runs to the sec. air injection pump, and remove the top flat plastic piece, pull it, pry it with a screw driver, it will come off but its a bit of a *****. Install the small air filter in its place. Tight fit, but it'll go in. Push it near the headlamp, and out of the way.
2. Take out the MAF from inside the airbox, and install the lower half of the box back in the car. Insert the MAF into the filter, and connect to main air duct. Dont tighten anything yet, make sure it fits first. Once it does take it out.
3. Remove the heat shield from the top half of the airbox, and fit it back to where it normally sits between the cat and the intake. At this point its good to have someone near you who knows how to use zip ties, or it could get difficult. (Thanks Art
). The shield has 4 holes, zip tie the bottom two holes to the hoses near each. Front hole will probably need two zip ties, this proved to be a pretty difficult concept for my hungover ass, but somehow I got it. For the top holes, re-attach the line that is mounted to the holes by using a nut and bolt on the front hole, and a zip tie on the rear. Dont need to do it this way, just get the shield in there so it doesnt move, what I did made sense at the time so I'll stick with it. No play what so ever, and it gets the job done.
4. Once the heat shield is secure, install the filter in place. It take a bit of moving it around to get everything to sit properly, but once it does its in there with out any play, so I didnt do anything else to secure the filter.
5. Re-attach everything, and youre done.
This really should not take too long, even though I spent a better half of the afternoon doing it. Sorry no IAT/MAF flow before and after logs because today I just didnt care, I was doing it anyways, car sounds much deeper now, and yes its got the BOV sound too, although not as loud as my GTI with an AEM CAI. Maybe I'll do a CAPS run tomorrow, but really the car doesnt feel any different, I did this for easy access to the MAF and because I hated working with the OEM box.
#2
#3
i did this last weekend, i bout a tenzo air filter for 20 dollars from a local performance shop and bought heat shield material for 5 at home depot.total intake cost 25.00
total retail intake cost 250-350
cost saved 225-325 dollars
#4
#5
oo i didnt see ure last picture.. u did the same thing with the shield as i did
#7
Do you need to put the lower half of the airbox back in? i want to do this mod but i want to put a u-bend and and a smaller air filter on the end of the MAF. what is the point to putting it back in? is it for airflow, or maybe wires that connect down there somewhere? I just got my car and havent dug into it yet.
#8
i just kept mine in and just took off the top half.. i didnt move the lower half of the airbox.. there is air flow going in to it but i think ud be fine if u took out the lower half.. i didnt really mess with it
#9
ya its definetely not necessary to leave the lower half in, theres no wires or anything, its not even anchored down
#10
is this a good mod? all i have is a apr stage 1 chip, and a diverter valve on the way... will the filters get wet? does it matter? any other mods I should do before this?
#11
i read an article on the wall at eip tuning and it was a test and they made an intake go to a filter then put the whole filter under water to prove that the water will not get far enough to ure engine and the test was a success and the water never got far enough to get to the engine.. soo i wouldnt be worried about the water
#12
I left the bottom half in there so I can use the oem ducting to draw in fresh air, and it also keeps everything nice and stable. Ther is no need to fabricate a bracket for the filter, and the shield is nice and tight, but definitly not necessary.SomkeU, dont expect much from this, and it shouldnt cause any problems, it wont get any wetter than the OEM one did.
On a side note, I unplugged the MAF and so far no crazy timing pull...gonna see how it runs for a week.
#13
thanks a lot guys...
after the diverter valve and this intake mod what should be my next project?
Modified by SmokeU at 4:00 PM 3-19-2006
#14
Quote, originally posted by SmokeU » ![]()
Modified by SmokeU at 4:00 PM 3-19-2006after i put this and my forge 007 DV in i got the Awe-tuning A-pillar boost guage which is sick as hell.. looks soo tight at night time... right now im workin on polishing my manifold and cleaning up the engine more
#15
Quote, originally posted by :Stever-Strike: » after i put this and my forge 007 DV in i got the Awe-tuning A-pillar boost guage which is sick as hell.. looks soo tight at night time... right now im workin on polishing my manifold and cleaning up the engine more
soooo tight
#16
turbo nasty what does unplugging the MAF do? from what i've heard this mod will make the engine sound lower/deeper, make the DV make the pssssh sound, and not give me much extra hp.... is this right?
#17
Sounds right. I unplugged the MAF because my is shot and is giving a low reading, throwing things off, retarding my timing, etc. Unplugged the ECU uses the default maps, so far its looking better.
#18
I took the entire airbox out cuz I put in a U tube. I only have one filter no smaller one. I kow a lot of peopel think using an open filter is bad for many reasons but I have had no problems in the last 3 years of having one. Yes you can hear the engine and the turbo better with this on.
#20
I just did this mod today actually after reading about other people doing it, there really isnt that much added hp or what not, but your turbo and bov are much louder, and you can hear the intake sucking air. I also noticed, its much more fuel efficient than running a stock air box. It only took me about 20min to do, most of the time was trying to figure a way to get the airbox out with all the wiring around it. Question, did anyones engine light go on from unplugging the intake manifold sensor?
#21
This intake mod goes excellent with the heat shield from blinktekdesign.com
Heres a pic of my final installation:
The shield does work in blocking hot exhaust manifold/turbo heat
#22
I have had this done for a while now and i noticed a huge difference. My car is auto by the way. The biggerest difference is on the highway. My car no longer needs to downshift to pass.
MM954 Hater #88
#23
anyone do this with an itg filter?
Im sure its the same thing just wondering if anyone has done it?
#24
That looks pretty clean, I may end up going with that too.
#25
followed through with this mod... not so happy with it. Idle is way off and runs ruff as hell. unplug the MAF and it runs fine just BS stock ecu maps. any cure to this problem?
1998 Audi A4 1.8t, K04, APR Stage1, Borla Cat-Back exhaust.
#26
I did mine I used a Bomz racing cone filter part # 56 - 0177 that i got for free! and i also have the heat shield from blinktekdesign.com![]()
Modified by Audi SA4 at 7:03 PM 5-27-2008
#28
I just did this mod this morning. Was easy and clean looking. I didn't use
K & N filters, I used Autozone Spectre 3" Chrome Cone filter # 246353 ($24.99) and Spectre Breather # 228293 ($11.99) and these are stock filters, they are just like K & N and use K & N's oil and cleaner. Thanks for this mod and everything else on this site.
#30
I bought both filters and then heat shield from Blinktek.
It sounds simply awesome with the addition of Labree HFC I installed last week.However i cannot find the 1" hose to the sec air injection pump.
Does a 1999 AEB even have one?
#31
my 99.5 has no secondary air pump
#32
I removed the bottom of the air box and replaced it with the followiing
I need batteries for my camera but I will take a photo tonight
Modified by Jkilla71 at 12:53 PM 8-26-2008
#33
Quote, originally posted by 19michael78 » I didn't use K & N filters, I used Autozone Spectre 3" Chrome Cone filter # 246353 ($24.99) and Spectre Breather # 228293 ($11.99) So just the k&n look-alike from autozone? How's that working out for you?
I used one in a pinch a one point and it was terrible. The mesh around the filter element couldn't stand up to the engine bay. Replaced it with an AEM dryflow with much better results.
VAG COM services available, send a PM | Join the VWVortex Folding@Home team... save the world | Current Rides: 2010 S4 Prestige, 1999 TJ 4.0 Sport | Old Rides: 2001.5 A4 1.8TQMS GTRS, 1997 TJ 4.0 Sport, 1990 Corrado g60 StageIV | Lounging in a field with 726 sweater cows
#34
Modified by Jkilla71 at 5:28 PM 9-4-2008
Modified by Jkilla71 at 5:29 PM 9-4-2008
#35
That's not unlike the Colorado Airbox mod the passat b5 kids love... they run 2 or 3 hoses out of the bottom of the stock airbox to that same area.Is it having any impact on the temp of the air coming into the engine? Can you block it off and data log then log again with it open to see?
