VWVortex.com - Eaton guys represent...
    Page 5 of 55 FirstFirst 12345678915 ... LastLast
    Results 101 to 125 of 1351
    Thread: Eaton guys represent...
    1. Member need a vdub's Avatar
      Jan 16th, 2005
      Peoria AZ
      Corrados for days
      02-28-2007 02:54 PM #101
      Just an external Walboro. Already have 440cc and SDS of course.
      For powder and ceramic coatings email me.
      avpcoating@gmail.com
    2. 02-28-2007 05:26 PM #102
      by the way I have a eaton m90 I am selling it in 100 dlls
    3. 02-28-2007 05:30 PM #103
      Quote, originally posted by need a vdub »
      fed by the in-tank pump?
      surge tank?
    4. Member need a vdub's Avatar
      Jan 16th, 2005
      Peoria AZ
      Corrados for days
      03-01-2007 01:06 PM #104
      You are correct. Just found out my injector circut is not getting power After that I will be up and running.
    5. 03-01-2007 10:39 PM #105
      I have a Kit FS
      Battery will need to moved as well as carbon can.
      http://forums.vwvortex.com/zerothread?id=3104891
    6. Member G60Scuzz's Avatar
      Nov 13th, 2003
      DoogieLabs, CO
      90/Corrado VR, 84 Vanagon EG33
      03-06-2007 03:33 PM #106
      Wow I totally did not notice this thread was back from the dead I actually sold my eaton kit in favor of something different... Sorry guys however it will be missed
      - Doogie
      I got tired of making build thread after build thread for my projects, so I made a website instead:
      http://www.doogielabs.com
      My YouTube Channel
    7. 03-07-2007 06:33 AM #107
      Quote, originally posted by G60Scuzz »
      that's ok.. we'll all continue to enjoy ours for you
      -nate
    8. Member need a vdub's Avatar
      Jan 16th, 2005
      Peoria AZ
      Corrados for days
      03-07-2007 02:27 PM #108
      Mine is up and running. (starter fluid and new gas) Hooking up wide band over the week then will be dynoing soon.
    9. 03-07-2007 06:47 PM #109
      sweet ... mine.. well.. more parts arrived in my apt.. new needle bearings for the m90.. new alternator & WP pulley for the engine.. block will be going to the machine shop this weekend *i hope*.. barring any other unforseen difficulties
      now, just need a fuel rail, maybe some new injectors... and some elbow grease & time...
      -nate
    10. Member
      Jun 17th, 1999
      West Michigan, USA
      1998 Jetta VR6 (bone stock daily driver), 1982 twin screw Cabriolet, 94 Mazda B3000 4x4
      03-09-2007 02:20 AM #110
      Any Eaton dyno runs ?
    11. 03-09-2007 07:59 AM #111
      Quote, originally posted by Peter Tong »
      so far, the only charts that have been posted (that i've seen) were the old joezx6 kit ones w/the m62, and mine from last spring (i htink they're referenced in this thread.. maybe not), with an m90 & a poor setup
      -nate
    12. Member need a vdub's Avatar
      Jan 16th, 2005
      Peoria AZ
      Corrados for days
      03-09-2007 01:07 PM #112
      I am working on finding a good shop to dyno. I am booking 2 1/2 hours for both my eaton and Vortech VR [IMG]http://*****************.com/smile/emthup.gif[/IMG] Looking like 2-3weeks MAX and I will have #'s up here.
    13. Member G60Scuzz's Avatar
      Nov 13th, 2003
      DoogieLabs, CO
      03-09-2007 02:59 PM #113
      I would like to see some close up pics of your guys's setups, see whats different and so on.
      - Doogie
      My YouTube Channel
    14. 03-09-2007 05:06 PM #114
      i'll see what i can find.. think most of my pictures went out with the last hard drive
      -nate
    15. Member need a vdub's Avatar
      Jan 16th, 2005
      Peoria AZ
      Corrados for days
      03-09-2007 06:10 PM #115
      Here are mine again. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      And in case it ever wants to blow up I am prepared with something else.
    16. 03-09-2007 06:53 PM #116
      just put the biggest snail you can fit (cut out the hood) on and worry about it later,plumb that big mama into the eaton inlet mang.
      who cares if the air filter is on top of the roof
    17. 03-09-2007 06:54 PM #117
      i wouldnt hold my breath... was just looking on ebay - some of those M90's have well over 100K on them.
    18. 03-09-2007 10:50 PM #118
      Here's a long awaited twincharged dyno plot
      Compare that plot to this one, when there was no m45 in series.
      Peak boost came in about 600-800 rpm sooner and peak power and torque are about the same with similar amounts of boost (peak at 17-18psi and degrading to roughly 15psi by the end of both pulls). It only partially shows the radical improvement in response under all normal driving conditions. We also threw a set of 440cc injectors in there to keep them from going static just before 6k as below.
    19. 03-10-2007 08:43 AM #119
      Quote, originally posted by jwatts »
      That's pretty friggin cool! glad to see it made it on the rollers & was perfectly happy!
      -nate
    20. Member need a vdub's Avatar
      Jan 16th, 2005
      Peoria AZ
      Corrados for days
      03-12-2007 09:38 AM #120
      That is a nice dyno. What boost is the eaton running?
    21. Member swingwing205's Avatar
      Jun 13th, 2001
      Knoxville, TN
      03-12-2007 09:44 AM #121
      Man, your set up looks so similar to mine it's not funny, except that I didn't have to cut the G charger bracket and that my air intake is in the same place as the stock airbox was (I'm NOT using the stock airbox, but a mandrel bent pipe and a P flow).
      Beautiful work BTW. If you're ever in TN look me up, we'll compare notes....
      Modified by swingwing205 at 6:46 AM 3-12-2007
    22. 03-12-2007 10:15 AM #122
      Quote, originally posted by swingwing205 »
      Can you post some pix??
      Has anyone done this on a 9A 16v?
    23. 03-12-2007 12:18 PM #123
      Quote, originally posted by OhioBenz »
      already in the works
      -nate
    24. Member need a vdub's Avatar
      Jan 16th, 2005
      Peoria AZ
      Corrados for days
      03-15-2007 08:55 AM #124
      I just saw the PSI on those dynos... I was expecting a lil closer to 200WHP..
    25. Member swingwing205's Avatar
      Jun 13th, 2001
      Knoxville, TN
      03-16-2007 04:56 PM #125
      No pics yet. A buddy of mine is wanting to throw one of my kits onto is 9A 16v, and I've already done the prelim research to do it. Not going to be hard at all, and the best part is that the alternator gets to stay in the front of the motor, not having to relocate it will be sweet indeed....
