VWVortex.com - complete vr6 torque specs
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 29
    Thread: complete vr6 torque specs
    1. 03-26-2006 04:00 PM #1
      these specs are from shop-key, which is software from snap-on that most repair shops use. they get the specs right from volkswagen, so these numbers are correct. the first numer is ft-lb the second number is newton meter. at the bottom the first is in-lb and the second is newton meter.
      ftlb-nm
      a/c bracket to engine bolt 22-30
      axle shaft to trans drive flange bolt 33-45
      cam bearing cap bolt 15-20
      cam sprocket bolt 74-100
      clutch cover bolt 15-20
      connecting rod bolt 22-30 then 1/4 turn
      main bearing cap bolt 22-30 then 1/2 turn
      head bolt
      step1 30-40
      step2 44-60
      step3 1/4 turn
      step4 1/4 turn
      engine bracket(front) 44-60
      engine bracket(to body) 33-45
      engine to trans 10mm 44-64
      engine to trans 12mm 55-80
      exhaust manifold to head 18-25
      flywheel to crank 44-60 then 1/4 turn
      intake manifold 18-25
      intermediate shaft sprocket 74-100
      oil pan bolt 15-20
      oil pressure switch 18-25
      oil pump cover bolt(short) 18-25
      power steering bracket bolt 18-25
      pressure plate bolt 15-20
      starter mount bolt 18-25
      timing belt tensioner nut 15-20
      torque converter to carrier plate 22-30
      water pump pulley 15-20
      water pump to engine 15-20
      inlb-nm
      fuel rail bolt 89-10
      timing belt idle bolt 89-10
      valve cover retaining nut 89-10
      water pump to housing 115-13
      oil pump cover bolt (long) 89-10
      hope this helped some of you out. let me know if it does, if anyone is interested in clearances let me know.
      Modified by nutbox11 at 4:02 PM 3-26-2006
      Modified by nutbox11 at 4:04 PM 3-26-2006
    2. Banned SVTDanny's Avatar
      Aug 7th, 2005
      Winchester, VA
      03-26-2006 06:59 PM #2
      89 Ft/lbs on a valve cover nut? I don't think so.....
    3. Member vwnobby's Avatar
      Nov 1st, 2001
      NJ
      '07 Audi A4 S Line / '97 Jetta GLX (sold) / '88 Jetta GL (sold) / '96 FZR600 (for sale)
      03-26-2006 07:09 PM #3
      I think you read it wrong (djsheijkdfj).
      nutbox11 has it listed as 89 in/lbs.
      inlb-nm
      Modified by vwnobby at 7:10 PM 3-26-2006
    4. Banned SVTDanny's Avatar
      Aug 7th, 2005
      Winchester, VA
      03-26-2006 07:12 PM #4
      Doh!
    5. Member izzo's Avatar
      Mar 19th, 2004
      ɐᴉɹɐƃlnq
      '96 Fiat Puntamera diesel
      03-26-2006 07:36 PM #5
      Thanks. Quite useful!
    6. 03-27-2006 03:04 PM #6
      yeh its inlb, sorry about that.
    7. 03-27-2006 04:43 PM #7
      nice [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    8. 04-01-2006 04:54 PM #8
      bump
    9. Member maxslug's Avatar
      May 22nd, 2005
      sf
      now: n55 135i then:mk3 3.0 vrt,mk2,CQ
      04-05-2006 12:56 PM #9
      sticky/faq. this is priceless for my rebuild... thumbsup!
      I'm the host of the GTI-VR6 List and Wiki and I drove in the 24 Hours of LeMons at : Altamont:2006, 2007, 2008 Fernley:2009 and Sears Point:2010 with Boxwrench Garage -- in the first ever Saab in Lemons
    10. 04-05-2006 05:45 PM #10
      glad i could help
    11. 04-09-2006 09:55 AM #11
      bump
    12. 04-10-2006 05:22 PM #12
      thank!!
    13. 04-10-2006 06:10 PM #13
    14. 04-16-2006 04:10 PM #14
      bump
    15. Senior Member mujjuman's Avatar
      Jul 29th, 2004
      New York
      2001 VW Jetta VR6, 2006 VW Jetta 2.5
      12-04-2006 12:59 AM #15
      wow thanks [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      mujjuman
    16. 06-27-2007 05:49 PM #16
      bump
    17. Member Roadhog_'s Avatar
      Feb 25th, 2007
      Montana
      1993 VW Corrado
      06-27-2007 09:47 PM #17
      I made it a little easier to read. If anyone wants the excel file I will upload it.
    18. Member SmartAssRacingTeam's Avatar
      Jan 8th, 2003
      Colorado Springs
      1996 GTI
      06-27-2007 09:59 PM #18
      Dammit! This would have been a whole lot more helpful than turning my Bentley black. It may come in helpful in the future though. Thanks for posting it up.
    19. 07-02-2007 10:14 PM #19
      nice work roadhog
    20. 01-24-2009 11:45 PM #20
      Quote, originally posted by maxslug »
      x2 ..thanks!!!
    21. Member
      Aug 10th, 2006
      Baltimore, MD
      02 Golf VR6, 84 Rabbit GTi, 98 fully bagged, shaved S10-Sold
      05-11-2009 10:12 AM #21
      will this be the same on the mk4 12v
    22. Member Norwegian-VR6's Avatar
      Feb 6th, 2002
      Norway
      96 Golf VRT, 09 Vw Passat 4Motion 2.0TDI Highline
      05-11-2009 04:34 PM #22
      VERY NICE INFO!
      1996 Golf MK3 GT35R 12V 02M Lugtronic Turbo. http://forums.vwvortex.com/showthrea...er-VR6-T/page4
      2009 Passat b6 2.0TDI 4Motion Highline
    23. Member
      Jan 28th, 2009
      Syracuse, NY
      various old audi crapboxes
      05-11-2009 05:57 PM #23
      bookmarked!
    24. 01-11-2010 09:01 PM #24
      Keeping it in m wacthed topics
    25. Member freight's Avatar
      Sep 13th, 2008
      Eganville
      mk3 golf
      01-13-2012 02:44 PM #25
      thanks, this has helped me out a few times
