VWVortex.com - LS vs LT: which GM engine do you prefer
    The Car Lounge
    Results 1 to 10 of 10
    Thread: LS vs LT: which GM engine do you prefer
    1. 03-31-2006 03:57 PM #1
      engine, not their application, not the vehicles they are in... but ENGINE.
      which do you want, for more power, refinement, etc.
      http://forums.vwvortex.com/zerothread?id=2530446
      vs
      http://forums.vwvortex.com/zerothread?id=2483187
    2. 03-31-2006 03:59 PM #2
      I don't expect this to be very evenly matched.
    3. Banned
      Jul 30th, 2004
      Fancy in the Not fancy, CT
      03-31-2006 04:00 PM #3
      This is no brainer....NO?
    4. 03-31-2006 04:04 PM #4
      Quote, originally posted by VdubChaos »
      there are a lot of people who actually swear by the LT due to it not being an aluminum block... and some people say it can handle more power. but im not an expert
    5. 03-31-2006 04:07 PM #5
      When you go CRAZY CRAZY CRAZY, they even out, but bolt ons, turbos, strokers, the LS1 will have the advantage.
      Pump 25 psi through any V8 and youll see near the same results.
      The LS port design is better.
      LS tunes easier
    6. Senior Member JustinCSVT's Avatar
      Oct 3rd, 2004
      Atlanta, GA
      2015 VW GTI 5-door
      03-31-2006 04:09 PM #6
      The LSx engine just makes more power...period. You get an LSx engine and LTx engine with similar mods or engine sizes and it is pretty much guaraunteed that the LS will make more power. The design is far ahead of the LT engines.
    7. 03-31-2006 04:11 PM #7
      I have an LT1 but I would go with the LS if I could. The aftermarket support is wonderful compared to the LT engines. Right now (or even back when the LT engines were all the rage) if you want forced induction on an LT you have very limited options, especially in California. The LTs are difficult engines to make decent horsepower out of without a large amount of cash too.
    8. 03-31-2006 04:12 PM #8
      LS baby! it's all aluminum, so you don't unsettle the weight balance that much when you swap it into cars that came with 4-cylinder engines.
    9. Member WOT's Avatar
      Oct 18th, 2003
      seattle wa
      1997 B4 Passat TDI
      03-31-2006 04:18 PM #9
      the LS1 is lighter than a lot of iron 4cyls and tons of 6yls.
      LS's seems to be a MUCH better engine than LT's.
    10. Member 3WheelGTi's Avatar
      Aug 29th, 2001
      Huntington Woods, MI occasionally
      2003 Porsche 911 C4S, 2009 BMW 335i, 2016 Chevrolet Traverse, 1982 VW Rabbit
      03-31-2006 06:52 PM #10
      My LS1 sounds a LOT better than an LT1. Advange...LS.
      And then I could rattle off a half dozen other reasons.
