Page 2 of 2 FirstFirst 1 2
Results 36 to 41 of 41
Thread: DUAL PLENUM MANIFOLD HOLLAA
  1. 04-26-2006 08:31 PM #36
    Quote, originally posted by ABA Scirocco »
    Flowbench testing manifolds is of limited value, it can show some potential problems with a manifold but not all because in a plenum type manifold under running conditions, there is a lot of interaction between runners and these are conditions that can not be replicated on a flowbench.
    i was also thinking the same thing.....particularly with intake pulse reflection and dynamics that only an operating engine can test
    but if flowbenching is cheap enough...its still worth a shot
  2. 04-26-2006 09:08 PM #37
    To put it another way, a manifold that performs poorly on a flowbench will most likely perform poorly on an engine but a manifold that performs well on a flowbench will not necessarily perform well on an engine.
    A flowbench is useful for determining how restrictive a manifold is, whether or not the flow through each runner is fairly balanced although that is somewhat effected by the interaction between runners and the plenum so it's only good for showing gross imbalances.
    Modified by ABA Scirocco at 9:13 PM 4-26-2006
  3. 05-08-2006 01:55 PM #38
    awsome stuff here
  4. Member baldoner01's Avatar
    Jan 8th, 2010
    1994 Volkswagen Vento 1.9 TD AAZ
    10-13-2010 02:55 AM #39
  5. Member syracusegli's Avatar
    Jan 21st, 2005
    syracuse, NY
    twin charged mk1 cabby
    10-14-2010 10:31 PM #40
    you would be better off getting exact dimensions and put it through CAD, a good program will show you flow and cylinder volume
    Quote Originally Posted by 2mAn View Post
    go crash into a hybrid
    For all things Metal ---> www.roguemetalworks.com
  6. Member arethirdytwo's Avatar
    Apr 4th, 2007
    Austin, TX
    '07 335i Sedan, '04 R32, '82 300D, '95 Jetta
    08-26-2012 01:03 AM #41
    Nice
