Results 1 to 32 of 32
Thread: DIY: Steering Wheel AND Turning Signal Stalk Removal
  1. Member jrowny's Avatar
    Sep 11th, 2005
    Germantown, MD
    2001/VW/Golf 2008/VW/GTI
    04-06-2006 11:35 AM #1
    Someone asked me to post pictures of when I removed my steering wheel and turning signal stalk. So here is my submission to the DIY thread.
    Here's a link to the DIY: see below
    And just as a side note: I've cleaned my car and don't have blue vent pieces anymore, so don't yell at me for that.
    Modified by jrowny at 1:06 PM 1-8-2009
  2. 04-06-2006 11:36 AM #2
    precaution, tricky.
  3. Member jrowny's Avatar
    Sep 11th, 2005
    Germantown, MD
    04-06-2006 11:37 AM #3
    There ya go Biggy.
    Modified by jrowny at 11:40 AM 4-6-2006
  4. 04-06-2006 11:38 AM #4
    Quote, originally posted by jrowny »
    OH SNAP!!!
    Unfortunatly MS Paint doesn't have the same red underlining of words as MS Office.
    unfortunate.
  5. Member RavinJetta's Avatar
    Mar 31st, 2002
    San Diego
    2011 S4
    04-06-2006 12:23 PM #5
    Just wondering why you say the spline can only be removed 4 times? Good DIY though
  6. 04-06-2006 12:25 PM #6
    Cool. I need to realign me steering wheel.
  7. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    08-25-2006 04:21 PM #7
    couple things to add if you are removing the stalks. To get either of them off, you need a 3mm allen wrench to undo the silver locking collar. After this, they pull right off the steering column (with the wires unplugged). There is a small tab that needs to be pushed to the side on the front of the switches to seperate the two of them (its on the perimeter of the circular ring at 3o'clock).
    When installing the switches back on the column, you may be tempted to push them all the back, but the steering wheel must push down a small pin on the clockspring for the clockspring to turn freely, if you push the switches all the way back, this won't happen. So just test fit the steering wheel, make sure it is pushing down the pin, and the wheel turns without any resitance of clicking before reassembling everything.
    Dave
  8. Member jrowny's Avatar
    Sep 11th, 2005
    Germantown, MD
    08-25-2006 04:25 PM #8
    Quote, originally posted by rs4-380 »
    Thanks! I posted this up like 5 months after I took the pics so I didn't remember any of it.
    Modified by jrowny at 4:29 PM 8-25-2006
  9. 08-25-2006 04:34 PM #9
    The nut(sorta) that holds the steering wheel on is only supposed to be used 4 or 5 times according to the bentley manual. Not really sure why though.
    Oh, and I never disconnect the battery when working on airbags. It would take longer to disconnect the battery than it does to pull the bag, clock the wheel and reinstall it all.
  10. Member mwurman's Avatar
    May 15th, 2006
    Pepper Pike Ohio
    1999 Jetta 2.Slow 5 speed; 2003 Jetta GLX VR6; 2011 Jetta SE 2.5; 2009 CC Sport 6 speed 2.0T
    12-17-2008 06:07 PM #10
    hey the link wont work...can i access this any other way?
  11. Member Porpoise Hork's Avatar
    Jul 7th, 2006
    Houston
    08 GTI 4dr
    12-17-2008 06:16 PM #11
    your surprised? its a two year old thread..
  12. Member rabbitarmy's Avatar
    Nov 16th, 2006
    raleigh, nc
    1980 2.0T Scirocco
    12-18-2008 09:19 PM #12
    Quote, originally posted by david_594 »
    Because of the amount of locktite applied to the threads. add more & reuse if you like
  13. 12-19-2008 12:37 AM #13
    there's a problem with the link
    Edit: DOH, thanks for necroing a thread from 2006.
    Modified by mccula at 12:47 AM 12-19-2008
  14. Member mwurman's Avatar
    May 15th, 2006
    Pepper Pike Ohio
    12-19-2008 10:56 AM #14
    is there another one of these DIY's somewhere? i have a new stalk to put in and yeah, would be helpful
  15. Member jrowny's Avatar
    Sep 11th, 2005
    Germantown, MD
    01-08-2009 01:06 PM #15
    Since the link is broken and I lost the file, I'm going to rewrite it here.
    FORGIVE the blue interior pieces, it was my first car. Now it's my sister's car as I finally graduated college and have been rocking the MKV.
    Okay,
    Start by turning the wheel 90
    BE SURE TO DISCONNECT BATTERY
    I don't know what this picture is of
    here's the new thingie installed
    It's been two years since I did this so I forgot everything involved.
  16. Member Biggfrmchi's Avatar
    Jul 14th, 2008
    Berwyn. IL
    MK4 VR Jetta
    01-08-2009 10:40 PM #16
    Hey Im having problems with my stalk too? Its not weak but the problem is that when I turn either way the cancel goes on, turns the light off but the clicking stays on and even faster. It wont stop till I jerk the steering wheel or stalk. Some one told me it could be the relay for it but I need help bad.
    My most prized possession is your girlfriend's heart:thumb:
  17. Member first9t!'s Avatar
    Jul 13th, 2009
    South Hill, washington
    02 GTI 85 Slammed Volva
    01-28-2010 02:10 PM #17
    it could be the contact points on the stalk or the emergency light button. Its what makes the clicking noise when turning. Its only like $24 to replace it, so try that first. They were actually recalled so go into the dealership and give them your vin and see if it has been replaced before. mine had so I bought a new one. Didnt help so I am removing the stock right now and cleaning it up, will let ya know if it helped.
    Quote Originally Posted by Capt. Obvious View Post
    Do you not f*ck your girlfriend because you want her to be in better condition for her next boyfriend?
  18. Member Skinner's Avatar
    Oct 11th, 2005
    SoFLA and Tampa, FL
    2001 Jetta VR6 GLX
    01-28-2010 02:13 PM #18
    blast from the past
    SixDigitClub
    (FiSHBOWLSTAtUS) ><(((*>
    Suede is Played
    ♥ Mila
  19. Member first9t!'s Avatar
    Jul 13th, 2009
    01-28-2010 04:44 PM #19
    just got done, no clicking at all yet. Will let you know tomorrow
  20. 02-26-2010 09:11 PM #20
  21. Member
    Jul 14th, 2003
    2000 Jetta GLS 2.0 Black
    03-16-2010 11:06 PM #21
    I just had the local mechanic replace my ignition switch (I should have done it myself, I know!). In the process, he removed my steering wheel and did not put it back on straight.
    I also no longer have a turn signal that cancels itself when wheel is centered.
    Are there any tricks to fixing turn signals that don't automatically cancel?
  22. Member
    Jul 14th, 2003
    03-20-2010 01:58 PM #22
    Would the comfort turn signal upgrade include a new mechanism to cancel the signal, or do I still need to investigate a problem with a the control lever?
  23. Member euro_driver's Avatar
    Feb 18th, 2006
    T DOT
    Golf 1.8T
    04-27-2010 10:16 PM #23
    Appreciate the thread. Just changed my stalks today. Very helpful.
    Btw talked to a Vw mechanic, he said that there was need for battery disconnection. Only he did say while the disassembling and assembling make Sure not to turn the ignition on.
    Modified by euro_driver at 10:21 PM 4-27-2010
  24. Member euro_driver's Avatar
    Feb 18th, 2006
    T DOT
    Golf 1.8T
    04-27-2010 10:26 PM #24
  25. Member
    Aug 11th, 2008
    Vancouver, Not Canada
    mk4 Hoopty, e39 540i
    10-18-2010 06:49 PM #25
    reviving this, because i bought a used one and only need the cruise stalk and the used one came with a non half-screen display wiper stalk (make sense?) without the computer control buttons, but can't get the two sides separated. any advice?
    edit: n/m got it
  26. Member SLK350's Avatar
    May 7th, 2009
    Kingston Area, Ontario
    '90 16v GTX
    10-18-2010 10:05 PM #26
    Quote Originally Posted by guitarer1229 View Post
    edit: n/m got it
    Well thank you for re-opening this!
    I have the problem of no headlights, only high beams when my headlight switch is on, I replaced the switch to no avail. I was told by a vw mechanic that the problem would be in the turn signal stalk as it controls high beam/ low beam engagement. Would the problem be, do you think, in the stalk itself, or in the wiring?
  27. Member
    Jul 14th, 2003
    10-20-2010 09:14 PM #27
    ATPTourFan
    Re: FV-QR (ATPTourFan)
    Turns out the mechanic did not re-install the clock spring with the wheel perfectly centered. Therefore it would not auto-cancel the turn signals.
    I had to replace my clock spring due to an airbag fault, but the turn signal issue was mechanic error.
    Here's a youtube video for getting the damn airbag to pop off. It's not obvious until you see this video.
  28. Member stwaven's Avatar
    Feb 21st, 2011
    albany, ny
    2001 jetta 1.8t
    02-25-2011 12:20 PM #28
    Quote Originally Posted by david_594 View Post
    wtf? quit using adjustable wrenches
  29. n00b
    Aug 16th, 2004
    Fredericksburg, VA
    2003 Mitsubishi Evo 8
    12-05-2011 09:37 AM #29
    Thank you for posting that video!
    2002 Jetta GLS 1.8t
  30. n00b jettaberry's Avatar
    Jan 2nd, 2012
    Chapel Hill, NC
    2002 Jetta MK4 TDI
    01-02-2012 10:14 PM #30
    Thanks for the instructions, just what I needed to replace my turn signal stalk and get my hi/lo beam control back.
    Here are a few more photos to add to the OP's to help with the replacement.
    Here is the double-ground on the airbag:
    A view of the release wire on the airbag posts:
    I used a 3/8" hex drive to remove the steering wheel nut instead of a spline tool:
  31. Member JuanGLS's Avatar
    May 24th, 2011
    Denver, CO
    2002 2.0 jetta, 2006 2.5 jetta
    01-28-2013 06:03 PM #31
    Is it possible to take it apart the stalk and clean it?
  32. Member JuanGLS's Avatar
    May 24th, 2011
    Denver, CO
    01-29-2013 06:28 PM #32
    I have replaced the hazard switch/relay and just took out the turn signal stalk and cleaned out all the metal peices that were built up. When I put it back together it was the same problem. Non stop clicking. Any other ideas or should I try buying a new turn signal stalk. Please help out.
    8v society #55
    FS: mk4 parts http://forums.vwvortex.com/showthrea...5#post81512695
    FS: Brand new (boxed) Avant Garde m310 machined gunmetal grey http://forums.vwvortex.com/showthrea...10-(new)-5x100
