VWVortex.com - MKV Spring Color Codes Thread
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 46
    Thread: MKV Spring Color Codes Thread
    1. Global Moderator John A's Avatar
      Feb 19th, 2001
      Outside Philly
      2015 Prius, 1985 Porsche 944
      04-11-2006 09:12 PM #1
      We did this in 'suspension' with the mkiv's, but I think everyone here is capable and mature enough to leave it here to start as it'll get more replies, and more replies = more samples, and better info.
      Every recent VW spring has a color code on it. After extensive research, we were able to determine spring rates for quite a few of the availble color codes. If we get enough info and spend some time on it, we can create a similar chart for the MKV chassis.
      (for anyone curious, here is part of the work on the old chart: http://www.peterpyce.com/Shine...s.jpg ) VWVortex user 'pyce' was instrumental in organizing the original MKIV effort.
      Let's start this off with the basics:
      - Model
      - Trim (package 0,1,2, etc...)
      - Manual or DSG
      - Stock wheel size
      - Build Date
      - Front spring color code
      - Rear spring color code
      So here's my info:
      - GTI
      - Package 1
      - Manual
      - 17"
      - 01/06
      - Red / Red / White / White
      - Blue / Yellow / Yellow / Yellow
      Once we get enough info and can figure out the rates -- then it becomes easier to know what can swap in and out to stay 'oem' and still perhaps change the ride characteristics. If you don't have all of the info, get it -- and then post. [IMG]http://*****************.com/smile/emthup.gif[/IMG] Once we get it rolling I can move it to 'Suspension.'
    2. Global Moderator John A's Avatar
      Feb 19th, 2001
      Outside Philly
      04-14-2006 06:55 PM #2
      not even a single reply.
    3. Global Moderator iThread's Avatar
      Sep 27th, 2005
      Portland, Or
      67 Bug, 92 Miata, 12 Golf R, 15 eGolf
      04-14-2006 07:05 PM #3
      Quote, originally posted by John A »
      Forgot to crawl up into my attic last night. Too busy playing with the new kittly my wife adopted.
      I'll get to it this weekend.
    4. 04-14-2006 11:35 PM #4
      alright, just happened to have mine around and easy enough to get to. i'm curious to know whats going on also. here are my specs:
      -'06 GTI
      -package 1
      -manual
      -came with 18" huffies, but i believe the oem size was 17" and they swapped the huffies on before delivery.
      -where can i find build date?
      -red/red/lavender(or maybe its white?)/lavender
      -blue/yellow/yellow/yellow
      Modified by freezermink at 8:42 PM 4-14-2006
    5. Member vdubnut_mike's Avatar
      Aug 13th, 2002
      Bellevue, WA
      13 GLI, 72 Cortez, 13 Smart EV, 82 F150
      04-15-2006 04:13 AM #5
      Quote, originally posted by freezermink »
      -'06 GTI
      -package 1
      -manual
      pkg 2 18's same colors as above.
      red/red/white/white (or lavender/lavender)
      blue/red/red/red
    6. Member rracerguy717's Avatar
      Apr 8th, 2003
      NYC northern suburbs
      06 VW GLI
      04-15-2006 06:11 PM #6
      06 GLI
      package 2
      manual
      18" Huff
      03/ 06
      red /red /white / white
      blue / green /
      updated mis read colors
      Modified by rracerguy717 at 7:14 PM 4-15-2006
      Read below about mine and other fsi stage 3 owners bad experience and poor results with APR and there Stage 3 Kits. http://forums.vwvortex.com/showthrea...ge-3-dyno-runs
      Quote Originally Posted by jhines_06gli View Post
      I'd say you have nothing to worry about, but then again.....you are driving a modified VW. You have EVERYTHING to worry about!!!
      -J. Hines
    7. Member Tourenwagen's Avatar
      Dec 28th, 2002
      NJ
      Non-VW
      04-15-2006 06:44 PM #7
      Im color blind so I took a pic of mine
      06 GLI Package 2
      17" wheels
      DSG Tranny
      Modified by 20VTLimey at 11:49 PM 4-15-2006
    8. Global Moderator iThread's Avatar
      Sep 27th, 2005
      Portland, Or
      04-15-2006 07:02 PM #8
      06 GLI Pkg 2
      DSG tranny
      17" Rims (well, when I got it)
      8/15/05
      red / red / white / white
      blue / green
    9. Member svander's Avatar
      Oct 31st, 2003
      Seattle Metro
      '11 S4
      04-15-2006 09:04 PM #9
      Quote, originally posted by thread »
      06 GLI Pkg 2
      DSG tranny
      8/15/05
      blue / green
      Ditto here. Same options, same springs.
    10. Member
      Oct 5th, 2000
      05-18-2006 01:19 AM #10
      Just installed my KONI shocks and springs today. Here is my OEM spring code info.
      - 2006 Jetta 2.5 (Canadian car)
      - No Packages
      - Manual 5-speed
      - 15" steel wheels with hubcaps
      - August 2005 build date
      - Blue / Blue / Orange / Pink
      - Orange / Orange / White
    11. Awaiting Email Confirmation
      May 22nd, 2006
      07-28-2006 09:24 PM #11
      hate to necro-bump, but can anyone confirm color codes on their 06 EU GTI front/rears?
      What about week 22+ 07 NA?
      Modified by Dillinja at 6:39 PM 7-28-2006
    12. 08-08-2006 03:20 AM #12
    13. Member svander's Avatar
      Oct 31st, 2003
      Seattle Metro
      '11 S4
      10-30-2006 07:54 PM #13
      It appears 07 GLIs are starting to show up lowered at dealerships.
      Below is a post from jagerpower, a new '07 Deep Black GLI, 6MT, Pkg #2 owner whose springs are most certainly color coded differently than the 06 "jack-o-sky" stock springs.
      Quote, originally posted by jagerpower »
      here are the requested pics of the springs, these were a pain in the a.. but i managed to get them. it's one blue dot and two yellow ones.
    14. 11-02-2006 10:49 PM #14
      4dr GTI
      Pack1
      DSG
      17"
      Redredwhitewhite
      blueorange
      is that standard for 4drs?
    15. 11-30-2006 01:10 PM #15
      Quote, originally posted by svander »
      Bump with question.
      Does anyone have the part numbers for the lowered 07 GLI springs yet?
      I was thinking if I install the OEM 07 GLI lowered springs on my 06, it will be less likely for the dealer to notice the difference and void the warranty.
    16. 12-01-2006 12:40 AM #16
      i've attached some etka pages from both euro and us spec gti's in case anyone wants to reference the colors with part numbers in this thread:
      http://forums.vwvortex.com/zerothread?id=2956056
    17. 12-10-2006 10:37 AM #17
      2007 Jetta Wolfsburg
      none
      Tiptronic
      16" Standard Alloys
      10/06
      Lavendar(pink)/Lavendar(pink)/white/white
      white/orange/orange
      Come on lets get more posts for this thread! I'm curious how other Jettas and Rabbits are sprung. You can see the front colors easy and the rears you can get by reaching a small digital cam up under the car from the front of the rear tires. You may need several tries on the rears. Jacking would probably help.
    18. Member gonzo08452's Avatar
      Apr 16th, 2006
      yorba linda, ca
      02 BMW 325I 5spd/ 97 Jetta/ 2012 Acura TSX wagon / 2000 BMW 323I 5spd
      12-10-2006 08:08 PM #18
      will the new GTI's have the blue/yellow/yellow as well?
    19. 12-10-2006 08:34 PM #19
      2005.5
      Package 1
      Tiptronic
      16in
      03/2005
      stock
      stock
      if I may add purchased in july 2005, currently at 16,300k miles
    20. 12-17-2006 10:25 AM #20
      All right, here's mine:
      - TDI
      - Special Edition (mix of package 1 &2)
      - DSG
      - 16"
      - 10/06
      - Pink / Pink / White / White (top of wheel well 26 3/4" from ground)
      - White / Yellow / Yellow (top of wheel well 27 3/8" from ground)
      The rear is almost a full 1/2" higher than the front...WTF? I look like a GD 4x4! especially with the 16".
      Maybe Santa will bring some nice H&R sports
    21. 12-19-2006 02:54 PM #21
      So any reason why there are so many different combinations of spring rates for one make of car? Seems a little to me.
    22. 12-19-2006 02:57 PM #22
      - GTI
      - Package 2
      - DSG
      - 17"
      - 11/06
      - notsure - blue/orange i think.
    23. 01-05-2007 08:11 PM #23
      Euro springs:
      -Blue/Red/Green/Green (1K0 411 105 GK)
      -Blue/Pink/Yellow (1K0 511 115 EC)
      Modified by natural1 at 9:05 PM 1-5-2007
    24. 03-12-2007 11:28 PM #24
      I assume these numbers for your GTI? Just making sure, wanted to order jetta ones.
      Thanks
      Modified by vwcrzy at 10:30 PM 3-12-2007
    25. 05-14-2007 02:55 PM #25
      Quote, originally posted by inomis »
      none
      Tiptronic
      16" Standard Alloys
      10/06
      white/orange/orange
      I lucked out on seeing the rears..just crawled under the back. It would appear we are psychic spring brothers:
      2007 Jetta 2.0T
      very late model
      17" stock Avignons
      front: pink, pink, white, white
      rear: orange, orange, white
      ...or is that white orange orange? do we read ascending or descending the spring?
      Modified by matt23 at 1:15 PM 5-14-2007
