Re: Since you're answering questions... (John@enfig)
I'm researching for a friend with a beetle.
I'm wondering where's her connection to the CD changer (probably the trunk).
Can I also have a list of your product that can plug into that port so that i don't have to remove her headunit?
Re: Since you're answering questions... (Mud_Shui_Ah)
i have the vw oem setup in my car, and have one or two little niggles, the first is that when i jump tracks using the standard buttons it always jumps 2 tracks at a time. The current playlist also plays a half second of the current track twice, and then changes playlist.
Other than that i love the device, the sound quality is great!
Is there any way of doing a firmware update to the ipod adapter, and would that fix the niggles?
Regards,
Matt
I'm interested in getting an iPod interface for my wife's 2007 Eos with the premium radio/ 6 disc-in-dash changer. Will any of the adapters work with it? TIA http://****************.com/smile/emthup.gif
This thread is exactly what i was hoping to find!
I have a 2006 B6 Passat, with Navi/Satellite/Dynaudio and the 6cd changer in the glove box..
IDEALLY, I'd like to integrate my ipod with the following conditions (in order of priority):
1) Have a direct digital connection from my ipod to the stereo
2) Maintain full control of the ipod itself
3) Not have to disconnect the 6cd changer
4) Have control of the ipod thru the car stereo
5) Not have to disconnect the satellite radio
Is it possible to install the ipod with all of the above 5 things? And what equipment would i need?
If not, what's the next best alternative (while giving consideration to the order of priority of the above conditions)?
Thank you SO MUCH for any info you might have!!
AGAIN-- BIG ups to Christian and Enfig. I know they are right up the coast from me, but 2 times, same day processing, next day arrival of products..! http://****************.com/smile/emthup.gif
I know this is labeled the "VW" Ipod guide, but I need to find the right parts for my 2004 A4 with Symphony and factory satellite. Need something to control and charge the ipod. Any suggestion? Thanks
Dan, maybe this, it's like what I got for my MKV.... so you'll know how to install it..
Hey I have a 2001 Jetta that has the radio in it just like the one a couple posts up. However I also have the VW Cd player mounted directly above the radio. Does the CD player plug into the Changer outlet on the radio? In my case, what would be a good economical way for me to play my ipod in my car?
I'm looking into doing just a normal mini-jack input (no iPod for me). Is this product the appropriate one? The Blitzsafe V.3A? Hooking into the trunk input for an '03 GTI with the stock Monsoon h/u.
If so... does anyone have install pictures from running the cable from the trunk to the front seat? Suggestions as to where to tuck it, etc?
for you, the pie VWr pcpod2 works great and allows you to keep your factory add on CD player
you'll acess the ipod by pressing the "select" button once you're in the cd changer mode of your radio http://enfigcarstereo.com/shop....html
that will work just fine, and you won't need to remove your radio
use these to adapt it to a 3.5mm headphone jack http://enfigcarstereo.com/shop....html
note: you night want to use a rca patch cord to lengthen the audio leads becuase they have to be run from the trunk, or a behind the radio aux input might be easier http://enfigcarstereo.com/shop....html
functionaly there is no difference between the trunk connection, or the behind the radio connection, just the connection ends are different
Thanks John! Is any grounding necessary for the trunk connection? I've seen a few posts mentioning some sort of buzzing problems when plugged into the trunk input.
hi! eor has the following oem stereo: http://cgi.ebay.com/ebaymotors...wItem
which setup would you recommend for it? i'm not running a changer or satellite nor do i plan to, but i would like to work the ipod from the head unit, if possible.
love,
eor
no, grounding isn't nesssiary, however the longer audio lines required to bring the interface the trunk can sometimes introduce audio noise (its pretty rare that they do)
97 mk3 oem tape deck with cd changer control...do you make a kit that'll work with that setup?
most likely we don't have anything for your radio if your radio speaks "clarion" to the changer, however if you have have a bose headunit, or a headunit out of a 98+ car whe have audio inputs or ipod interfaces
Need help, please. I went through Crutchfield (sorry, John), and ordered a Peripheral ipod adapter. Here's my mess:
I have a 2003 VW Jetta Wagon with Monsoon.
I wanted one that didn't connect in the trunk (they screwed that up; told me to buy peripheral, charging me for the tools to take out the stereo; but they did not give me enough tools -- only 2.) So, they are sending me two more, but then in talking with tech support, the guy told me that it needs to be connected through the trunk.
So, I started to do that today. I thought I found the connection for the cd changer in the back on the driver's side. It was flatter, and rectangular. However, all of the harnesses I recieved from crutchfield are fatter, boxier harnesses. Some of them: VW1, VW2, VW3, which I assume are supposed to fit all the models of Jetta in recent years.
So, what gives? Should it connect in the back of the stereo? Do I need ANOTHER harness? Is the connection elsewhere, hidden in the back of my car? (I doubt it, as this connection was RIGHT THERE)
Many thanks
No. Wait. I figured it out. Crutchfield did send me what I needed. I needed the vw3 attachment (I did not have #1). THe sales guy did know, but two tech support people did NOT know. The Peripheral guide is also out of date, and makes no mention of the necessary harness; in fact, it says that the harness is not yet made.
I was researching through discountcarstereo.com and they have great instruction and images -- that's how I finally figured this crap out. They had a link to the harness matrix.
Also, so what they did do wrong (besides bad advice) was send me only two removal keys. So, once I get those, I should be good to go.
SO, here's a question: how do I route the cable from behind the stereo out into the car with my 2003 Jetta?
Ummmm, what do these items mean/stand for? Are they model numbers of connections for VW's? What type and year of VW do these parts connect to?
Personally, I have a 2002 VW Golf with the radio only (monsoon). It has the connection to a trunk mounted CD changer. I would like to know what would allow me to do the following;
1. connect directly to the back of the stereo
2. allow for skipping & fast forwarding of the tracks from the stereo face plate (and keep the Ipod charged)
3. be able to keep the CD changer and use it when the Ipod isn't attached
I would think that this should be achievable, but no one has submitted anything that says it is.
Also, does it matter what version of Ipod I have? If I go out and buy a newer 80Gig one, will I still be able to use this set-up and still be able to use my Nano?
Last thing I want to know, which is the most reliable unit? The one that works the best through the existing stereo system for controlling the Ipod?
Quote, originally posted by Christian@enfig »
I am going to fill this thread with all the info needed to choose the proper interface with your iPod.
1. Blitzsafe - VW/AUX DMX V.3
Blitzsafe - VW/AUX DMX V.3A
Blitzsafe - VW/AUX DMX V.5
P.I.E - VW-AUX
P.I.E - VWR-AUX
P.I.E - VW02-AUX
2.Blitzsafe VW/MLink1 V.3
Blitzsafe VW/MLink1 V.3A
Blitzsafe VW/MLink1 V.5
Related Threads
Ask a question
Ask a question
VW Vortex - Volkswagen Forum
84.4M posts
1.5M members
Since 2001
