sooo anything new?
#106
Nothing new this week - I'll be on vacation for a week, once that's done my evenings and spare time will be fully devoted to getting this done.
#107
sooo anything new?
................................................www. CHECKCOLLISION .com
#108
GET SOME!!!!!
#109
Well here's some shots of the pistons in the block, the crank as well. Things are coming along with the project - still shooting for an end of August install.Pistons in block
Bottom end with oil pump in place
Close up of knife edging on crankshaft with ARP main studs and rod bolts.
You can see the drilled journals which is for further weight reduction of the crank
Modified by WolfGTI at 11:53 AM 9-28-2006
#110
Looks like it is coming along, looking forward to the finished project...![]()
#111
^^x2![]()
#113
This post has been successfully reported to a moderator.
#114
Quote, originally posted by independent77 » This post has been successfully reported to a moderator.
Uh huh.
#115
hey Mendra, if your car randomly vanishes one day, chances are i might have "borrowed" it. haha
#116
Come wearing kevlar, my bedroom window is over the driveway, I don't miss from it.![]()
#117
Well folks, this weekend the motor gets situated into the car for intake and header mockup - look for pics on Sunday.
#118
Subscribed. Fap fap fap fap fap fap fap ........
#119
Well after some little delays - you'd be amazed this swap has parts from every watercooled engine VW has sold in the US - 8v, 16v, VR6, TDI and 20v.Here's some more shots -
Head
Head
Block in car
Oilpan
Looking up into the motor on the lift.
#120
Hey, I still have that header for you. There is just no chance I am going to make it out in the evening to meet up, baby boy is proven to be quite a handful in the evening/night. It's here at the house if you want to make a run to come get it some time.![]()
#121
What frame is this going in?What are you doing for ITB's?Want to buy my set up?![]()
#122
i have a 1999.5 Mark 4 jetta with the 2.0 AEG jont, but what kind of 16v will bolt directly to my stock block, if any??
#123
Quote, originally posted by Wizard-of-OD » ![]()
It's going into a 4 door mk3. I already have 4 - 45mm ITB's - I used to run my 8v on them, but of course the 8v couldn't utilize them fully, this 20v should.
#124
Oh, you used to have an 8v? I think i saw your car on the dyno at NGP. I had the green corrado that was going on after yours with Kevin B. tuning it. Setup looks good man. Keep it up
#127
Sick project.Just how do you verify power gains on a dyno when every part comes from a different motor?
Seriously though, a great avenue to explore.
#128
nice work,bro. you surely do your research and homework. It shows!!![]()
so ..make sure of 2 things ...
1- we need more pics
2- we need a video with SOUND!
oh. what'd you cook today?![]()
#129
Quote, originally posted by WolfGTI » Yes I remember you - how's the rado working ? parted out the vrturbo and did a 20v setup. in the works right now.
#130
[/QUOTE]
how much did that crank work set you back??? and does drilling out the crank journals compromise the crank strength????
#131
Quote, originally posted by dhutchvento » Looking up into the motor on the lift. how much did that crank work set you back??? and does drilling out the crank journals compromise the crank strength????
The crank is not a stock machined piece. It's an after market forged 4340 Eurospec crank. It's their lightweight racing crank, the drilled journals do not comprimise the motor in a naturally aspirated motor however on a boosted motor I'd get the non drilled version of this crank. IIRC the crank was in the $1200 range.
#132
I just creamed my pants.Start it already!
Mendra, if you EVAR have to sell this car, I WILL be taking off your hands.
#134
Well it's not going to be completed this weekend![]()
- the DCOE flange for the ITB's is not perfectly centered for the ITB's so a new flange will have to be made. Other than that it's a go.
#135
supper set up for N/Abut how about going with a hoolset hx35 turgocharger on that block with that head
I was courious cuz I am doing a build on my 99.5 audia4q
where would you get that euro spec cranck from?
I was wondering wich 2.0l engine would be the best for the 99.5 aeb head?
#136
Quote, originally posted by audituner06 » supper set up for N/A but how about going with a hoolset hx35 turgocharger on that block with that head
If you're doing it in a A4, you're pretty much stuck with the AEB block as the tall deck aba is going to have a few issues being squeezed into the Audi's engine bay. Also, the AEB is a good block. Just need a 2l crank, rods and pistons.
#137
i am gonna lose sleep thinking about this beauty, save me the frustration, and double/triple/quadruple check your timing before you bolt down this magnificent head, you will have to sell organs to buy those pistons again.
#138
your absolutely correct sir
FTP
#139
Some more pics.Pic of the stock 20v exhaust manifold bolted on to the MK3 downpipe - lines up perfectly.
Engine with Valve cover in car
Test fitment of aftermarket rad/fan assembly
Stock Cams vs my Kent Cams
Stock Intake Cam vs Kent Intake Cam
Stock Exhaust Cam vs Kent Exhaust Cam
Modified by WolfGTI at 9:20 PM 9-28-2006
