Lift it baby!!!
#142
Lift it baby!!!
#143
As I found out today - if the cams were any bigger - they wouldn't fit in the head without work, plus the retainers that hold down the camshafts would have had to be machined as there's barely clearance as the pictures show.
Modified by WolfGTI at 9:19 PM 9-28-2006
#144
wow i cant wait to hear that thingare you plannin on usin the same throttle bodies as before?
................................................www. CHECKCOLLISION .com
#145
Quote, originally posted by urogolf » ![]()
Yes I will be using the same ones.
#146
is this running yet? bring it down to philly next week if it is. i want to check it out.
#147
Tlak about a close fit!!!!
Quote, originally posted by WolfGTI » As I found out today - if the cams were any bigger - they wouldn't fit in the head without work, plus the retainers that hold down the camshafts would have had to be machined as there's barely clearance as the pictures show.
NGP Racing * Facebook * AIM: nateNGP
APR North American Distributor of the year *2005*2006*2007*2009*2010*
Sales Specials
2010 U.S. Rallycross 2wd Class Champions w/ Quantum Rally Sport
#148
Quote, originally posted by WolfGTI » I am curious! What timing belt and tensoiner combo did you use?
SsTuNE.com
C2motorsports Flash Dealer
audi4u@optonline.net
http://www.youtube.com/audi4u
395whp/325wtrq MKV Rabbit
#149
Belt is a 158 Tooth Conti Curvelinear II profile, still working on finalising the tensioner setup.
#150
Ok keep up the good work. Great Thread!![]()
SsTuNE.com
#151
Try to source an AWP valve cover.Did you purchase the Autotech IM shaft gear as well?
#152
The valve cover I have is polished, plus I bought the aluminim cover plates to allow me to fit the 16v wires from 034EFI already so I'll be sticking with this valve cover - thanks though. Yes I did order and purchase the Autotech IM shaft gear.
#153
Progress update - timed the crank/cam/distributor today. Then cranked over the motor by hand 2 times. Turned over freely - but peeking down the intake ports; it's scary the clearances in there when the piston comes up. Should have the ITB flange done by Fri evening (I hope) will update when that is done. Radiator is mounted, most of the coolant hoses are hooked up / fabbed.
#154
what engine management and trigger setup will you be running?
#155
MegaSquirt - using the hall sensor in the distributor.
#156
are you done yet? jeez.I told you you'd beat me.
DCI Eastside- "mmm... it does go well with the chicken. Delicious again, Peter."
<--Mermaid BBQ Company--> For best taste, use on food.
#158
Quote, originally posted by WolfGTI » MegaSquirt - using the hall sensor in the distributor.
So your staying with the distributor or going coil packs?![]()
#159
Quote, originally posted by Wizard-of-OD » So your staying with the distributor or going coil packs? ![]()
I am staying with the distributor for now - maybe in spring I'll toy with getting coil packs.
#160
Looking good, Mendra... Can't wait to see some more progress.![]()
#161
So the delay has been related to the intake - finally got it fabbed today. Then commenced the 3 hours of grinding and porting to make everything as nice as possible. Car will be started Monday due to weekend social engagements (wedding of best friend). Stay tuned - in the meantime here are some pics.External Mocal oil cooler mounted.
MK4 2.0L lower hose to go across to radiator spout
Lower end of downpipe
Race-Shop Joe porting the welded intake.
Horns
More horns
Even more horns
Parting shot
Modified by WolfGTI at 11:29 PM 10-6-2006
#162
Quote, originally posted by WolfGTI » Car will be started Monday due to weekend social engagements (wedding of best friend). Hey, that's me.
Good luck getting it running next week. I'll be thinking about you as I sit in my lounge chair on a Dominican beach sipping my Coco Loco.
#163
what is the plan for a crankcase vent? since there is a block off plate on the block and IIRC the head doesn't have a vent?
#164
Quote, originally posted by mack73 » what is the plan for a crankcase vent? since there is a block off plate on the block and IIRC the head doesn't have a vent? Vent is throught the head - look at this pic.
#166
#167
So nice of you to change the thread title Mendra............pics look awesome.And travis is right, this will be a legend.
#168
Quote, originally posted by WolfGTI » Project ABE
#169
So the motor was started up yesterday. It runs - no bent valves or odd noises. However it seems with the compression I am running, I will need to vent both the block and the head (separately), because once the motor builds up pressure under load it is seeping oil from the oil seals. Will report back after the block is vented.![]()
#170
Nice! I know from recent experience that first starts are tough. This project looks great!
#171
ABE sounds like a 1.8T
#172
Hell yeah!!!![]()
Venting the block shouldn't be an issue, it will get all sorted out.
How big was yourwhen that bad boy was fired up??? X10.
#173
Quote, originally posted by billyVR6 » Hell yeah!!! ![]()
I was smiling, but also a little worried that because of the clearances. Now that we have the fan wiring and the motor isn't tearing itself apart I am a little happier. Tuning this thing is going to be harder than sorting out the 8v, I can see it. I'll keep updating. PS - A1Crazy has video, if he makes an mpeg i'll link to it.
#174
Well, you have one foot in the door as Joe knows Nate fwell enough, could get you in the right direction as your build up is very similar to his first generation 20/20 engine. Maybe we can cash in a favor for helping yank and tear down the tranny to make the next round at Atco a few years ago.![]()
#175
Update - drove the car home - appears the breather in the blockoff plate solved the oil seal seepage. Now the tuning begins.
