VWVortex.com - Navigation system
    Page 1 of 22 1234511 ... LastLast
    Results 1 to 25 of 549
    Thread: Navigation system
    1. 02-22-2002 07:40 PM #1
      http://24.159.133.44/jetta/jetta1/je...ora4motion.jpg
      Does anyone have this installed in their car? If so how well does it work compared to an aftermarket setup (kenwood, alpine, pioneer etc.) Does the factory Nav system have voice direction (as in tell you when to turn)? If not do any of the other Nav systems have this option. http://24.159.133.44/jetta/jetta1/125971_9_full.jpg
      My Aunt's Acura Nav system turns down the radio and some female voice tells you when you are getting close to your turn/exit. It also turns you stereo down when you're receiving a phone call.
    2. 02-22-2002 07:43 PM #2
      You can't do it. The system is designed for using CD's with GIS data on them. And, since these discs are not available for the US, you can't make the system work here. Also, the audi cds are not compatible (thats what other people have said) either.
      Sep 9th, 2001
      Westminster, MD
      2014 Ford Raptor; 2010 Jetta TDI; 2012 BMW K1600GTL; 2005.5 VW Jetta TDI; 2001 BMW R1200C Phoenix
      02-23-2002 11:03 AM #3
      Well, we'll find out soon enough if the Factory NAV system works in the United states. I ordered my Navigation retrofit kit Friday and it should be here Wednesday. After all the research that I have done The only variable is the map databases, but I have a few tricks in mind to overcome that problem if it arises.
    4. Member coomoob1's Avatar
      Dec 10th, 2001
      Tampa area, FL
      2015 GTI MKVII Autobahn
      02-23-2002 11:20 AM #4
      Just make your own...probally much cheaper.
      Get an LCD and a nav system (like Pioneer, Kenwood, Alpine).
      Here's my LCD TV. I'm thinking about adding a Nav soon.
      Current: 2015 VW Golf GTI MKVII Autobahn
      Prior: 2013 VW CC 2.0 Sport Plus, 2010 CC 2.0T R-Line, 2007 Passat 2.0T Lux, 2004 Explorer Eddie Bauer (What was I thinking!?), 2001 GTI IV 1.8T, 1999.5 Golf IV, 1992 Geo Metro LS
      Sep 9th, 2001
      Westminster, MD
      02-23-2002 11:35 AM #5
      Defeats the purpose of a factory modification.....
    6. 02-23-2002 11:36 AM #6
      What that trim in that pic??? I like it! Looks almost smoked chrome. Anyone know?
    7. Member coomoob1's Avatar
      Dec 10th, 2001
      Tampa area, FL
      02-23-2002 11:38 AM #7
      That's the stick on plastic kind of trim. They sell them at places like http://www.wooddash.com.
    8. 02-23-2002 12:11 PM #8
      How much do those kenwood, alpine, pioneer systems run? Thanks
    9. Member coomoob1's Avatar
      Dec 10th, 2001
      Tampa area, FL
      02-23-2002 12:14 PM #9
      From $800 - $2,000 (new)....the price depends on shopping around. I've seen a used Pioneer system, with nav CD's, sell on Ebay for $500 before. I didn't have the cash at the time or I'd of bid $505.
    10. 02-24-2002 10:19 PM #10
      Where did you order the retrofit from? I'm interested in this for my S4 as well.
      I'm thinking that the system uses the same CDs as those used by the Audi system. Blaupunkt makes both systems. Why would the GIS data be any different for the two systems?
    11. 02-24-2002 10:46 PM #11
      Because most likely in europe the VW CD's are going to be cheaper and so the audi people can make more money.
    12. 02-24-2002 11:24 PM #12
      if i recall correctly, the euro VW system uses the same CDsas the US audi systems sooooooo, if u got the euro vw nav system, and somehow acquired the Audi discs(or buy em, they arelike $180/ea )
    13. Member
      Sep 9th, 2001
      Westminster, MD
      02-24-2002 11:50 PM #13
      AUDI Nav disks on ebay.... $45. Oh yee of little faith........
    14. 02-25-2002 12:18 AM #14
      just curious..............If that car is manual..........whay is there a digital guage in the cluster that indicates gears like in automatics...?
    15. Member
      Sep 9th, 2001
      Westminster, MD
      02-25-2002 09:58 AM #15
      The Car has the Factory installed NAV system, and the "High" insturment cluster. The cluster has the display that gives the "arrow" type directions also.
    16. 02-25-2002 10:05 AM #16
      Exactly the reason why I believe the US Audi discs will work in the VW Navi. It's all made by Blaupunkt.
    17. Member spaceman_spiff's Avatar
      Sep 7th, 2001
      WI
      '06 Jetta
      02-25-2002 10:39 AM #17
      another thing, is it just for show, or do they get lights for their feet, too?
      screw it, i'm moving to germany. they get all the cool toys...
    18. 03-04-2002 05:14 PM #18
      Eric,
      Keep us in the loop with the retrofit kit!
    19. 03-05-2002 12:12 AM #19
      Does anyone know of plans for VW to offer navigation in the USA as an option? I've searched the forum and can't find any indication.
    20. 03-05-2002 01:49 AM #20
      There's been talk of it, along with HIDs.
      I'd like to know if this works too. Although nobody's mapped the area I live in, I still think a factory nav system in a dub would be cool.
    21. Member
      Sep 9th, 2001
      Westminster, MD
      03-05-2002 11:43 AM #21
      My NAV system has arrived, I installed the headunit last night, Everything plugged in, I have a few minor coding issues. The FM is set to .1 increments, US is .2 and AM is set to 9Khz instead of 10Khz. The AUDI Discs DO NOT WORK, But I believe I came up with a solution. I'll keep everyone posted. I do the final wiring and the antenna install tonight. I brought the digital camera so I will take many pictures and document the install so others can repeat my success.
    22. 03-05-2002 11:45 AM #22
      Anxiously awaiting info.
    23. 03-05-2002 11:49 AM #23
      Will the maps for the Travel Pilot DX-N work?
      http://www.blaupunktusa.com/travelpi...ot_01_dxn.html
    24. 03-05-2002 11:50 AM #24
      this could be exciting... [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    25. 03-05-2002 02:42 PM #25
      [DROOL...]
      THIS would be one seriously sweet mod!!!
      If this can be done sucessfully, it would be the best thing to happen to a MK4 interior in a long time!!! (j/k)
      But seriously, that looks HOT!!! Does anybody know what else they can do? (the LCD screen part)
