VWVortex.com - 2.0 vacuum diagram
    Results 1 to 21 of 21
    Thread: 2.0 vacuum diagram
    1. 05-02-2006 08:28 PM #1
      Anyone have a good diagram of the 2.0's vacuum lines? All I found was VR6 ones, and an engine shot or two.
    2. 05-02-2006 08:57 PM #2
    3. 05-02-2006 10:57 PM #3
    4. Senior Member Dan J Reed's Avatar
      Jul 26th, 2004
      NJ - AKA - Earth's armpit.
      Too many
      05-02-2006 11:09 PM #4
    5. 05-02-2006 11:13 PM #5
      Thanks Dan [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    6. Member
      May 24th, 2008
      Woodbridge, VA
      2001 Golf GLS 2.0 AVH
      05-02-2009 05:56 PM #6
      Helpful pics.
      Dan in case you didn't know if you hit Alt + Print Screen with a program window selected you can screencap just that window. So instead of:
      Youd get just this:
      Without having to select which portion you want manually and trimming away the rest of the screen.
      Bumping to see how many views this thread has so I can guess how many other OCD people have suffered by seeing start menus.
      Modified by JDub8 at 6:00 PM 5-2-2009
    7. Semi-n00b
      Mar 30th, 2011
      moscow idaho
      96 jetta 2.0 Mk3 4 cyl,
      03-30-2011 11:51 PM #7
      dan what kind of tubing are you using in your car and where can i find some.
      ** sorry if this has been posted elsewhere but ive spent some time searching for it but have not found it.
    8. Junior Member
      Oct 30th, 2011
      Selbyville, DE
      97 GTI
      01-04-2012 03:29 PM #8
      I have been having an engine code related to my EVAP, on my purge regulator valve there is a hose that is hooked up nothing. I was thinking that maybe it is supposed to be hooked to something. or is it just a breathe valve? Anyone know?
    9. 01-04-2012 03:34 PM #9
      it should be hooked up to the canister and throttle body.
    10. Junior Member
      Oct 30th, 2011
      Selbyville, DE
      97 GTI
      01-10-2012 11:21 AM #10
      There looks like there could be a spot for a valve to go into my throttle body, but there is just a screw covering it up. I think ive seen some pics online of TB's having a valves sticking out of em....could i be getting an insufficient vacuum from my one hose not being connected to the TB?
    11. 01-10-2012 11:45 AM #11
      I was just going by what's shown in the diagrams posted. I know some TB's have an extra vacuum port and others have it blocked off from the factory. If you have a vacuum hose not connected to anything, then you have a leak and could have various idle/unmetered air issues. I did a quick search. Check the pic in this thread and it may help you:
      http://www.vwforum.com/forums/f14/2-...ponents-40760/
      #7 goes to the throttle body port and the purge valve hose. I think on later models there is sometimes an additional port on the TB that goes to a heated PCV valve on the intake tube.
    12. Junior Member
      Oct 30th, 2011
      Selbyville, DE
      97 GTI
      01-11-2012 02:11 PM #12
      check this TB on this ebay listing.
      http://www.ebay.com/itm/Throttle-Bod...#ht_1121wt_952
      Notice the valve coming out of the TB, the throttle body i have has a small bolt going through it blocking it off....im wondering if i can find a valve somewhere to put in there so I can hook the purge vacuum line back up.
    13. 01-11-2012 02:22 PM #13
      There should definitely be one vacuum port there. Some have two like this, but the bigger one is always there except for maybe some early OBD1 ones.
      http://www.ecstuning.com/Volkswagen-...ody/ES2143258/
      Sounds like someone broke it or blocked it off. You may be able to get some type of plastic connector to fit there or remove one from a junkyard. If someone just put a screw or bolt in it to block it off, it may not be the correct thread/pitch and they could have messed up the threads on the TB. You may have to replace the TB altogether.
    14. Junior Member
      Oct 30th, 2011
      Selbyville, DE
      97 GTI
      01-12-2012 10:11 PM #14
      normally there are no threads in there, so whoever put that bolt down into there must have just made some threads in there, my next day off im going to go into home depot and find something to fit in there half way. does anyone know by not having the purge vacuum line up what impact will it have on anything like MPG or emmissions related issues?
    15. Member
      Dec 23rd, 2001
      Los Angeles, CA
      2003 Audi A3 Wagon
      01-17-2012 02:17 PM #15
      What direction is the purge valve arrow suppose to point? towards the canister or towards the engine/.
    16. 01-28-2013 01:19 AM #16
      hey there, srry to jump in, i have a 95 passat gls 2.0, and i was wondering if this diagram works for my car? iv replace about 4 feet of air line now and still have a major issue, new to working on cars, but not new to vw
    17. Junior Member Jetta_dogg's Avatar
      Jun 27th, 2013
      Tacoma WA
      96 Jetta GL
      07-18-2013 01:17 PM #17
      Reviving and older thread here.....
      I am at work so do not have a pic, but, up by the brakes near the drive side of the windshield I have a T-connection with some vacuum tubes. The one that is going off to the right (drive side) is collapsed. Any idea with out a pic what this goes to? I looked at Dan's diagrams and didn't see it.
    18. 07-18-2013 01:51 PM #18
      Only things I know of in that area are the lines off brake booster that go to AC recirculation vacuum box in driver's fender or windshield washer fluid nozzle lines.
    19. Junior Member Jetta_dogg's Avatar
      Jun 27th, 2013
      Tacoma WA
      96 Jetta GL
      07-18-2013 02:43 PM #19
      Quote Originally Posted by zero. View Post
      Oh ok, that makes sense, thanks Zero!
    20. Junior Member
      Feb 22nd, 2015
      Sin City
      98 Jetta GLS - 2.0 ABA - Manual - 89K, 02 Jetta 1.8t
      02-22-2015 10:23 PM #20
      Quote Originally Posted by Dan J Reed View Post
      <IMG SRC="http://img79.imageshack.us/img79/8445/vac14at.jpg" BORDER="0"><p><IMG SRC="http://img148.imageshack.us/img148/2517/vac21id.jpg" BORDER="0"><p><IMG SRC="http://img143.imageshack.us/img143/6405/vac36qs.jpg" BORDER="0"><p><IMG SRC="http://img152.imageshack.us/img152/4295/vac47rh.jpg" BORDER="0"><p> <IMG NAME="icon" SRC="http://**********************/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/embeer.gif" BORDER="0">
      Dead imageshack links, as well as the link on Your page to this thread 2.0 Vacuum Diagrams
    21. Member Phreakwenci's Avatar
      Nov 27th, 2005
      Los Angeles, CA
      1986 Cabby
      09-11-2015 03:59 PM #21
      Can someone repost these images? Bought a cabrio for cheap with an electrical fire and all the hoses are melted.
