VWVortex.com - torque specifications for wheel bolts
    Results 1 to 21 of 21
    Thread: torque specifications for wheel bolts
    1. 05-05-2006 05:08 PM #1
      Does anyone offhand know the proper foot lbs. of torque for the wheel bolts?
      5x100 Jetta GLI (18" BBS from factory)
      Was in a jam on a Sunday and had them mount and balance winter wheels and new tires at Pepboys. ( I know) It was so tight. I had a decent size rachet and the bolt would not loosen. I put a 2-3 foot bar over the rachet handle and bolts were on so tight that it broke the mechanism inside the rachet. WTF?
      Is it possible to brake the rachet if the wheel is torqued at the right specification?
    2. Member kcn0113's Avatar
      Jul 27th, 2005
      Minneapolis, MN
      ‘15 GTi (previously ‘01 Jetta WBE)
      05-05-2006 05:08 PM #2
      87 ft/lbs. That's really weird that it broke, you said you used a torque wrench to loosen the bolts?
      forever fascinated™
    3. 05-05-2006 05:09 PM #3
      impact wrench used by shops != the torque you need at all. never let them tighten it down with impact wrenches. ever.
    4. 05-05-2006 05:22 PM #4
      I can't remember what they used, not sure if I even watched them do it. But you can get a torque stick for an air gun.
    5. 05-05-2006 05:24 PM #5
      My mechanic worked 30 years for volkswagen. He says he only torques the wheel bolts to about 40 ft/lbs as the spec 87 is wayyyy tighter than necessary. Saved my a~~ once when my wheel lock got stolen....
    6. 05-05-2006 05:27 PM #6
      Quote, originally posted by aces »
      40 sounds about right, my vw guy says 60. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    7. Senior Member bluefox280's Avatar
      Dec 18th, 2003
      Broomfield, CO
      05-05-2006 05:30 PM #7
      From the Bentley bible:
      * lug bolts @ 89 ft-lbs (120 Nm).
      - Erik
      PatternDraftImaging.com - "...Where Engineering Discipline and Photography Merge as One..."
    8. 05-05-2006 05:32 PM #8
      and i'm sure your mechanic has a knowledge about preload in bolts and the effect of dynamic loading on the wheel bolts that surpasses the engineers at volkswagen. brilliant.
    9. 05-05-2006 05:41 PM #9
      Quote, originally posted by bigmak »
      Sarcasm I don't think I'd be able to feel a difference manually between 60 and 90???
    10. 05-05-2006 05:43 PM #10
      I read somewhere one here that VW specs were 89ft/lb. That's what I have torqued mine to since. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      And don't use a torque wrench to losen bolts. Use the braker bar in the spare wheel well. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Modified by sixty7mustang22 at 4:44 PM 5-5-2006
    11. 05-05-2006 06:04 PM #11
      Quote, originally posted by sixty7mustang22 »
      To clarify I broke one of these trying to take the wheel bolts off:
    12. 05-05-2006 06:07 PM #12
      Quote, originally posted by Farfrhomdun »
      use a real breaker bar, not a ratchet.
      notice how the head is not geared in rotation, it's a TON stronger.
    13. 05-05-2006 06:08 PM #13
      OK. That makes me feel better. Torque wrenches aren't cheap.
      Still for future reference to anyone...don't use a torque wrench to lossen bolts.
    14. Member Kei78's Avatar
      Oct 8th, 2001
      Canada
      05-05-2006 08:49 PM #14
      wow, i say go to a different mechanic then...
      I just round mine up to 90ft/lbs...
    15. Member Kei78's Avatar
      Oct 8th, 2001
      Canada
      05-05-2006 08:50 PM #15
      again...just like the previous guy...youll need to find a **new** vw guy...
    16. Member gti dreamn's Avatar
      May 18th, 2002
      Ohio, for now...
      '04 GTI
      05-06-2006 02:34 AM #16
      Really???
      Why does my VW dealer recommend 95 ?
      I've heard of 88 (or 87), but when I mentioned those numbers to the service mgr, he said they can't do that and must tighten to 95.
      I have the 17" Arietta (15 spoke) made by Borbet.
      SAABSAABSAAB__ You know you're getting old when 4-doors, a manual transmission and "Sport" in the name gets you excited about a car
      SAABSAABSAAB___--> Golf Sportwagen/Accord Sport/Mazda6 Sport/Civic Hatchback Sport. ___#savethemanuals
      SAABSAABSAAB__ >>> Go FROGS !!! <<<
    17. 05-06-2006 02:46 AM #17
      so.. anybody coming into this thread (as well as myself) is still asking themselves.. WHAT IS THE RIGHT TORQUE??
      haha, is there a yay or nay? or do i go anywhere from 40-95ft. lbs. thats seems like a fairly wide range for something as important as keeping your wheels on your car.. while you're driving .... fast
    18. 05-06-2006 03:02 AM #18
      all vw's 90 ft lbs..
    19. Banned
      Mar 7th, 2004
      05-06-2006 03:05 AM #19
      Quote, originally posted by VRGetT &raquo;
    20. Senior Member bluebora20v's Avatar
      Jun 14th, 2001
      Bay
      2000/VW/MK4 Jetta
      05-06-2006 03:05 AM #20
      Quote, originally posted by bluefox280 &raquo;
      - Erik
      READ ERIK'S POST. Overtorqueing lugs is bad. Undertorqueing lugs is bad.
    21. 05-06-2006 03:21 AM #21
      Quote, originally posted by bluebora20v &raquo;
      yes, this i know. i was lookin for something a little more than 40ft-lbs and less than 95ft-lbs... again, quite a wide range.
      so yea, i think i'll stick with the manufacturers recommendation, aka: 89ft-lbs
      Modified by Doug_1.8t at 11:23 PM 5-5-2006
