VWVortex.com - VR6 12v engineering project >> 275hp
    Page 1 of 96 123451151 ... LastLast
    Results 1 to 25 of 2387
    Thread: VR6 12v engineering project >> 275hp
    1. 05-17-2006 10:33 PM #1
      Hopefully that title grabbed some attention. We are looking for anyone who has ever managed to break the 250WHP/280CHP barrier with a 12v VR6.
      If anyone can provide links or references to any tuners or teams who have managed to better these numbers in ANY sort of NA configuration we'd like to know about it.
      Also, If any engineers with access to CFD (or similar) tools would be interested in helping out with an interesting project we have, please email us.
      May 8th, 2000
      Race car
      05-18-2006 10:33 AM #2
      Bill, check around for Bernd's 3.1L rabbit. That engine has had various top end set ups, both hydro and solid. I would contact him or Techtonics Tuning as Collin has a lot of time invested in the build as well as behind the wheel. You can talk to Anthony Dowd about his stock 2.8L bottom end engine in his race car. Also, WRD has been claiming high output from their car as well. All three mentioned are at or above 225whp with a 12v head.
      Good luck with the project. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    3. Member BennyB's Avatar
      Mar 27th, 2000
      Orono, ON, Canada
      81 Scirocco Mid-Engine VR6, 81 Scirocco, 05 Golf TDI, 00 Audi TT, 90 Corrado Racecar
      05-18-2006 06:06 PM #3
      i have access to ricardo wave, fluent and unigraphics NX 4. IM me
      Project Car: Mid-Engine VR6 MKI Scirocco -- Build Thread
      Retro Car: 1981 Scirocco --------------------- Daily Driver: 2014 Camaro SS 1LE
      Race Car: 1990 Corrado 16V ----------------- Bike: '83 Honda Nighthawk CB550
      Jalop Car: 2005 Brown Manual Diesel Jetta Wagon
      Family Fun: 1983.5 Westfalia Vanagon Camper
    4. Member BennyB's Avatar
      Mar 27th, 2000
      Orono, ON, Canada
      05-18-2006 07:53 PM #4
      ricardo is mainly 1-dimensional flow dynamics, and is useful for runner length tuning, power output estimation and temperature effects.
      fluent is good for port bowl shape and plenum design. I think it can do the mixing as well.
    5. Member foyboy's Avatar
      Feb 24th, 2005
      Aurora IL
      1998 GTI VR6, 2003 GTI VR6 24v
      05-19-2006 09:55 AM #5
      I work for Ricardo and know the product manager for the relevant software. What you guys actually after ?
    6. 05-19-2006 09:27 PM #6
      hmm I had "email for replies" set to on but it didnt work or I would have replied to some of this already.
      OK I'll reply from the top....
      >> race car?
      Yes. In addition to our SCCA engine programs We're developing a few different engines to compete in the new NASA configurations. NASA has changed to a power to weight formula where you can run almost anything you want. NA, Turbo, SC, you name it. We're especially interested in developing VW engines to compete in the GTS Challenge. A series currently dominated by Porsche and BMW. We're doing more than just VR6 btw.
      >> ive only heard of a few breaking 200
      WheelHP I assume you mean. 200 crank is easy. We're putting down just shy of 200 crank HP on a stock engine with only a CAI, custom ECU tune, careful blueprint, balance and bump in compression. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      >> How long do you think that motor would last with power like that.
      250 WHP will have very high compression (~14:1) so it will be little hard on the rod bearings. But it's still only 250. Should not be a grenade by any means.
      >> Didn't EIP claim their 3.1L's were good for 301hp?
      I's like to see that data if anyone can dig it up.
      Yup. I spent 45min. on the phone with the engine builder of that car the other night. Chris is a real nice guy. He gave us some good pointers and backed up a lot of what we already were thinking.
      That motor in fact is what this project is all about! They kept trying different configs and could never get past the 250WHP wall. They swapped intakes, heads, exhuasts, etc etc and nothing woudl get it past 250WHP. We want to break the wall. If we can find the problem, then we should be able to go WAY past it. There are 3L full race motors making 400CHP that are based on production castings.
      >> You can talk to Anthony Dowd about his stock 2.8L...
      Heard a lot about him. Where is he?
      Now we're talkin! IM on the way. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      >> 275 crank iam sure it can happen. basically thats dowd with a 3.1 high compression block.
      No. It's not that simple. Bernd's 3.1L was 14:1, with big everything and 288* cams. (cause 300* didnt work) There is a reason the VR6 has a problem getting past 250WHP and we intend to find out why. Since many of you have done basic tuning and testing of components, it's time we change gears and apply some modern engineering tools to investigate what's going on.
      >>Also don't forget thermal coating any parts
      BTDT. It helps but it's not the answer to the big question.
      >> Also try custom cams
      Cam design may play a roll in this. Our engine man has designed a VR6 cam that is a bit different than most out there. If it works, we can have CAT do a bunch for the masses. However most of you probably wont want a 300* cam that wont idle
      >> Eurospec sells 3.2L blocks
      But they dont build race motors. Just bolting parts together (No offense) is fine for a street motor, but we do our own engine building for a reason.
      Help ;-) I'll be IM'ing you too.
      >> why a 12v when the 24v is out?
      Good question. 2 answers. A) It's a challenge. Something that nobody has managed to do although many have tried. B) We all know the 12v VR6 is cheap and plentiful and if we can break the wall, then I'm sure many will be happy.
      >> the head doesn't allow for valves a whole lot bigger then stock
      I call the readily available +3mm valves quite a bit larger but we're not sure they need to be that big.
      This is not going to be something we pull off in 3 weeks time. This is going to take all summer at least. We'll be posting our results on our website and occasionally in here.
      If we had a real budget for this we'd just go to Mahle Motorsports (ex Cosworth) and say "fix it", but this is a lower priority experiment. So if any engineers out there (students?) want to help out by loaning us a little brain power and CPU time, we'd love to hear from you.
      Modified by Bildon Motorsport at 6:28 PM 5-19-2006
    7. 05-19-2006 09:35 PM #7
      Oh, PS - a short runner "log" intake is not the answer. While a log or ITB setup may be in our final solution, that alone has been tried and again didnt break the 250 mark.
      resonance, reversion, harmonics, pressure waves... the answre is in there somewhere.
    8. 05-20-2006 10:19 AM #8
      Sounds like a great project. Def. hook up with the Ricardo guy as that may be the best way to uncover why the engine can't get past the 250 mark.
      You can have him build you some flow models of the intake and exhaust system to see if you can uncover a flow problem either on
      the intake or exhaust side. This can def. help you tremendously with
      any porting you plan on doing.
      Not that you want to spend all the research money but the CAE tools can even help you with the combustion and injection modeling. You
      could design your own piston combustion surface and play around with different injector locations...But now you are talking big money!
      I do a lot of FEA stress analysis, but have done some CFD work in the past, all for auto manufacturs so I'd be happy to share anything I know. The Ricardo connection is a great source though so make sure to get foyboy to help you out.
    9. 05-20-2006 03:54 PM #9
      i know of a secret company building stroker cranks... they only have one left which i was planning on buying. the block is a 3.0L and the crank makes up for .2L displacement so it will be a 3.2L. custom crank, custom rods, and custom pistons. you could go with a bigger piston like a custom 85mm 13-1 compression deal and have a 3.4L 12v....
      he told me they made 240whp on pump gas with a schrick intake manifold and a big valve head. i dont know if its true for sure yet. i dont know if i want to drop a little over 4 grand on a N/A short block though.
      give me a call if you want to collaborate. 732 407 3384 keith-
    10. 05-21-2006 05:19 PM #10
      Does anyone have access to a 3D scanner who could produce a point cloud of a VR6 intake if we were to provide them with a physical cross section of the ports?
      Can anyone provide any CAD files or drawings (links?) of 12v VR6 cylinder heads?
    11. Member BennyB's Avatar
      Mar 27th, 2000
      Orono, ON, Canada
      05-21-2006 05:39 PM #11
      this is what I already had scanned:
      When I did these, I was only concerned with external dimensions. I'll see if I can get the CMM again to scan the ports.
      Modified by BennyB at 5:49 PM 5-21-2006
      May 8th, 2000
      Race car
      05-23-2006 09:53 AM #12
      Quote, originally posted by Bildon Motorsport »
      Sorry, I didn't see that you posted this earlier.
      Anthony's screen name is 95GLX.
      I know a great deal about this car but it is just best to contact him.
      Looking forward to seeing how your project pans out. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    13. 05-23-2006 11:06 AM #13
      Thanks BillyVR6 I shot him an IM.
      To all, this is going to be a long project. We will not be able to update this thread on a frequent basis. It would be great if we could keep the forum "noise" level to a minimum so that in the end the thread has more substance than most.
      Yah those Atomic heads make good power for a reason
    14. 05-23-2006 11:19 AM #14
      We will be doing research and modelling through the next few months. After our modelling and analysis has yielded enough data we will then begin to design parts and finally we will begin machining and assembly. I would not expect to see an engine on the dyno for at least 3 months probably longer.
      Anyone here have any experience or access to the 4stHEAD software package?
    15. 05-23-2006 09:55 PM #15
      Quote, originally posted by billyVR6 »
      If not, then yeah... 270whp has already been had from a bored out naturally aspirated 24v.
      Who was that and was that on a 2wd or 4wd dyno?
      Isn't 251.5 WHP on 4wd dyno pretty good for a N/A 3.2, 24V on pump gas?
      As far as the 12 valve project and over 250 WHP/275 crank, where to start?
      I think my best dyno was 229 WHP, maybe 231, I really don't remember, have to do some archive searches. I think the last time i dynoed was March 2005 at NGP when i was home on leave and finally swapped the bottom end out with another 2.8L.
      I didn't have the right fuel with me either so the dyno session was just to make sure I had a clean map and to find my shift points. I went directly to the track after that!
      Mods at the time:
      Stock 2.8L bottom end.
      Schrick 268 cams.
      CCH big valve head-big intake, big exhaust, mm?, lots of porting.
      Stock exhaust manifold, never port matched as it should be.
      OEM crank pulley.
      DTA Fast Pro 8 engine management.
      42/40mm ITB's by Grant Motorsports.
      MKIV H.G.?, I might have used the carboard one, have to look.
      VP Red race gas!
      5w-30 Mobil one oil!
      Bosch FR8LDC spark plugs!
      Ford blue top injectors, 19lbs i believe.
      That's it!
      So, i need to make 19-21 more horsepower for you! I have a few ideas that are pretty darn simple and will probably work. I never did get the best tune on this set up, 235-240 should be achievable staying with the 2.8. Heck, just a blueprint/balance should net half that.
      What is the wall with the 12 valve? The fact that no one ever had or was willing to really put the money, time or effort into really developing this engine beyond bolt-ons and things that can be marketed easily!
      anthony
    16. 05-24-2006 11:45 AM #16
      >> the pistons and connecting rods (and other parts if you are really anal)
      Replace "anal" with "professional"
      >> So all the rods would have the same mass
      Yes, all components are balanced so that the engine spins freely with little vibration and reduced harmonics. In addition all components are checked for dimensional accuracy (blueprinting). Machining everything to optimize the function, efficiency and therefore power output.
      >> Never heard of anyone paying for this to be done
      Every real race engine is balanced and if it is a stock based engine it is blueprinted.
      >> Hence why noone with a VW these days seems to do it
      There are hundreds of VWs racing and rallying in the US alone that have properly built engines.
    17. Member Halpem's Avatar
      May 15th, 2002
      Bellflower, Ca.
      81 Callaway Rocco, 06 Oettinger GTI, 90 R36 AWD Corrado
      05-27-2006 12:28 PM #17
      Do you have any software where in mind? I have access to getting almost any software due to where I work, I notice the UK has many companies doing or atleast sell it.
      I was looking at this one , http://www.optimum-power.com/blair.htm
      http://www.directopedia.org/di...shtml
      Modified by Halpem at 6:33 PM 5-29-2006
      Transmission Repair and Parts - CalTrans - California Transmission Products - 714-953-9282
      VAG-COM Ross Tech Help - Need Your car Scan,
      AP Auto Interiors - www.apautointeriors.com - Need a Seat fix, Convertible Tops, Headliners and more.
    18. 05-31-2006 01:52 AM #18
      Quote, originally posted by ojnrice »
      I have mine blueprinted and balanced bith times, i would never put an engine together that wasn't I will have to post my dyno results whe i get my chip. i am hoping for 240. i have
      12.5:1 CR
      3.0
      268 cams
      beyond bigvalve head 35.8 ex 42 in
      2.5 catless exhaust
      A/C deleted
      lightened crank pulley
      MK4 Head gasket
      Titanium Retainers
      Lightweight lifters.
      etc...
      way to much money
      and to make sure I hit 300whp
      100 direct port NOS
      will be using EIP3.0 cam chip, because they are the only people that make one, and I am not a fan of EIP.
      I hope you clay this engine before you run it. Also, with all the work done and the fact that you plan on running the spray on this set up I would go stand-a-lone for engine management and would even think twice about it. Otherwise, this will be another built VR6 motor that will end up on the garage floor with bent valves or burnt piston rings!
      Anthony
    19. 05-31-2006 08:48 AM #19
      Quote, originally posted by EuroVeeDub »
      What does it mean to "clay" the engine?
      it means once everything is built, since the only way to achieve high power is with high compression. high compression = small clearance for valve to piston(due to the redesign of the piston). people put clay on the pistons and assemble the motor/cams and all. and spin the motor to see where the valve is hitting to make sure there is enough clearance between valves and piston.
      i hope that helps you understand.
      Racing Improves the breed..
      "I have fought the good fight, I have finished the race, I have kept the faith"- 2 Timothy 4:7
      CrossroadsLI
      MY ALL MOTOR BUILD THREAD
    20. 05-31-2006 10:28 AM #20
      >> 12.5:1 CR
      Custom pistons? or did you machine the tops off the "close side" ?
      BTW, we plan to get a 2.9L bone stock motor with our custom Motronic tune onto the the dyno again this week to verify our earlier numbers. Will publish them after the test. The custom Motronic VR6 programs are doing well. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    21. Banner Advertiser Jefnes3's Avatar
      Aug 17th, 2001
      Connecticut
      05-31-2006 11:03 AM #21
      will be using EIP3.0 cam chip, because they are the only people that make one.
      Not True.
      I could easily tune that set-up. (IM me for references)
      Trouble is, most folks want/expect a ~canned tune to
      run a custom set-up.
      -Jeff
      UnitedMotorsport.net
      Email UnitedMotorsport
      Just because you copy our work, does not make you capable of what we are.
    22. 05-31-2006 11:56 AM #22
      >> 12.5:1 CR
      custom Ross Racing Pistons
      12.5:1 is not that high, i did not need to clay, if you go above 13 that is when you start to get a big dome.
    23. 05-31-2006 03:50 PM #23
      We consulted with Jeff on Motronic tuning. He knows his stuff. Stop messing around with generic guesswork and give him a call.
      Doesn't have to be, depending on how you got your compression.
      I have seen bent rods & valves on engines because they decked the block and/or ran the mk4 thin gasket and/or installed a high lift cam that would normally clear on an OE engine. This can happen at CR's lower than 12.5.
      There can easily be little clearance on the "short side".
      Progress on the VR6 engine "modelling" has continued. I'd like to thank BennyB for really helping out with this. He has been putting together the first model (OE VR6) in Ricardo's Wave application. It still needs a lot of work to get it to the point where we can begin to draw assumptions but that work continues and in the end we should have a model that will allow virtual "modding" ...far cheaper than porting 5 sets of heads to get it right [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      As you can see the model is already showing an approximately correct HP curve for the VR6.
      Please dont make any comments about the details of the RPM range vs HP curve. This is a work in progress!
      The current model has only the basics roughed in. Recent refinements include; Proper injector location, refinement of port dimensions for lower intake, friction and heat transfer multipliers, etc.
      Work yet to be done includes Exhaust dimensions. The intake models including tubing and filters, need some more refinement. Camshaft profiles for OE, street and full race cams will be added.
      Port flow data will be obtained with either flow bench testing or CFD analysis (or both). This is an area that we plan to investigate extensively as the odd shaped VR6 ports may prove to have some surprises.
      We are still progressing and we have no real groundbreaking news to report yet. All in good time...
      PS - If anyone else has access to software or equipment that could help with this project in any way, please contact us at sales @ bildon We can exhange parts for time if interested.
      Modified by Bildon Motorsport at 1:10 PM 5-31-2006
    24. Member eurotekms's Avatar
      Feb 10th, 2002
      USA
      05-31-2006 10:27 PM #24
      Lucky enough never to tap, but also thought it'd be wise to keep the cams stock.... although a custom set is being spec'd out.
      x
    25. 06-20-2006 01:40 PM #25
      Update....
      Took a brief break from this project to do some other work and get a race and some testing in. But it's time to do a bit more work...
      Over the next few weeks we'll be measuring the intakes and exhausts in more detail to improve the model. We'll also begin some porting and adding that data to the model. Finally we will be destroying some intakes and a cyl head to get cutaway measurements.
      Both stock and full race ports will be examined. Flow bench data (both before and after porting) will be captured and added to the model.
      If anyone has a damaged cylinder head that they would like to donate to the cause, we will pay for all shipping and give the donor a $50 gift certificate for any parts purchased through Bildon.com [IMG]http://*****************.com/smile/emthup.gif[/IMG]
