for canada.bestpricecarparts.com. Placed my order on a monday evening, my parts were at my door the next day! Great prices too
#1
http://www.BestPriceCarParts.com Golf II/Jetta II Classified Forum Sponsor.Shipping daily from locations all over USA and Canada.
Welcome to the http://www.BestPriceCarParts.com mini online catalogue exclusively for your Mk 2. Here we will outline some of the common products sold. If you do not see it here please visit our web page and if you can not find it on our web page please e-mail customerservice@BestPriceCarParts.com or phone.
Mini Online Catalogue for Mk 2.
BrakesDisc
Front Solid - 321 615 301 – As low as $10.99 US, $10.99 CA
Front Vented – 321 615 301C – As low as $17.99 US, $18.99 CA
Rear - 357 615 601 - As low as $18.99 US, $16.99 CAPads
Front Solid - 1H0 698 151 - As low as $30.99 US, $40.99 CA
Front Vented – 191 698 151G - As low as $23.99 US, $29.99 CA
Rear - 1H0 698 451F – As low as $30.99 US, $32.99 CACaliper
Front L - 1H0 615 123A – $46.99 US, $51.99 CA
Front R – 1H0 615 124A - $46.99 US, $51.99 CA
Early Rear L – 191 615 423A - $103.99 US, $200.99 CA
Early Rear R - 191 615 424A - $103.99 US, $200.99 CA
Late Rear L – 535 615 423 - $98.99 US, $123.99 CA
Later Rear R - 535 615 424 - $103.99 US, $139.99 CAParking Brake Cable
Drum Early 1765mm - 191 609 721 – $14.99 US, $15.99 CA
Drum Late 1545mm - 191 609 721E - $12.99 US, $15.99 CA
Disc Early 1845mm - 191 609 721D – $8.99 US, $13.99 CA
Disc Late 1625mm - 191 609 721F - $17.99 US, $21.99 CADrums
180mm - 191 501 615B - $27.99 US, $29.99 CA
200mm - 1H0 501 615A - $41.99 US, $46.99 CAShoes
180mm – 867 698 525X - $21.99 US, $21.99 CA
200mm - 1H0 698 525X - $30.99 US, $29.99 CA
Shoe Hardware - 171 698 545 - $14.99 US, $15.99 CA
Wheel Cylinder - 6N0 611 053 - $10.99 US, $11.99 CA
Stock Suspension FrontWheel Bearing Kit - 357 407 625 - $32.99 US, $ 34.99 CA
Control Arm
Bushing Front - 357 407 182 – $3.99 US, $2.99 CA
Bushing Rear - 191 407 181D - $6.99 US, $8.99 CA
Complete Control Arm with Bushings - 191 407 151B – $51.99 US, $43.99 CABall Joint
Early – 191 407 365A - $12.99 US, $14.99 CA
Late - 357 407 365 - $13.99 US, $13.99 CA
Lock Plate - 191 407 175 - $2.99 US, $2.99 CAStrut
Mount - 191 412 329 – $16.99 US, $16.99 CA
Strut Insert - 200 413 031A - As low as $39.99 US, $45.99 CA
Strut Assembly – 1H0 413 031A – As low as $61.99 US, $59.99 CACV New
CV Axle L 100mm - 191 407 271K - $87.99 US, $107.99 CA
CV Axle R 100mm - 191 407 272BD - $87.99 US, $107.99 CA
CV Axle L 90mm - 191 407 271Q – $87.99 US, $107.99 CA
CV Axle R 90mm - 191 407 272AE - $87.99 US, $107.99 CA
GNK CV Joints – As low as - $61.99US, $75.99 CAStock Suspension Rear
Shock - 191 513 033D – As low as $33.99 US, $43.99 CA
Shock Mount Kit - SM5070 - $13.99 US, $19.99 CA
Wheel Bearing Inner - 311 405 625F - $8.99 US, $9.99 CA
Wheel Bearing Outer – 1GM 405 645 - $6.99 US, $8.99 CA
Wheel Bearing Kit - 191 598 625 - $28.99 US, $32.99 CAExhaust
Stainless Cat Back System - From $283.99 US, $551.99 CA
Catalytic Converter 9A&PF - 165 131 701C $142.99 US, $149.99 CA
Catalytic Converter RV - 191 131 701HX - $131.99 US, $167.99 CA
Header Pipe Dual – 1H0 253 091CM - $177.99 US, 279.99 CA
Header Pipe Single - 191 253 091AP - $61.99 US, $64.99 CA
Centre Muffler - 165 253 409A - $47.99 US, $66.99 CA
Rear Muffler - 165 253 609F - $65.99 US, $83.99 CA
Electrical and IgnitionStarter Manual - From - $85.99 US, $114.99 CA
Starter Automatic - From - $110.99 US, $139.99 CA
Alternator 65 Amp - From - $99.99 US, $139.99 CA
Alternator 90 Amp - From - $109.99 US, $133.99 CA
Alternator Brush Assembly - From - $10.99 US, $7.99 CATune Up
Cap - From - $8.99 US, $9.99 CA
Rotor - From - $3.99 US, $4.99 CA
Plugs - From $3.99
Wires - From - $19.99 US, $24.99 CADistributor PF&RV - 037 905 205K - $175.99 US, $280.99 CA
BodyGrill - 165 853 653E 01C - $64.99 US, $106.99 CA
Trunk Lock Assembly - 165 827 571C - $62.99 US, $119.99 CA
Window Regulators from - $16.99 US, $9.99 CA
Power Window Switch - 191 959 855 - $15.99 US, $16.99 CADoor Handles
Front L - 191 837 205A - $10.99 US, $6.99 CA
Front R - 191 837 206A - $9.99 US, $6.99 CA
Rear L - 193 839 205 - $32.99 US, $4.99 CA
Rear R - 193 839 206 - $16.99 US, $3.99 CAOffical Buyer - Seller Thread
LOOK HERE BEFORE YOU BUY ANYTHING ON VORTEX !!http://forums.vwvortex.com/zerothread?id=2284254
All pricing is effective April 24, 2006. Pricing is subject to change without notice.Modified by BestPriceCarParts.com at 7:40 AM 9-13-2006
Modified by BestPriceCarParts.com at 8:11 AM 10-9-2006
#2
#3
#4
#5
finally ****ing vividcrap got dumped![]()
ⓄⓈⒹ #25
WTB: Vibra-Technics motor mounts, corrado VR6 air box (no sai connection), Wolfsburg style momo horn button.
#6
Quote, originally posted by Mortal_Wombat » finally ****ing vividcrap got dumped Thansk for the
but Vivid Wonders is still the MK2 Discussion Forum Sponsor
#7
lol i was drunk and hopefull![]()
ⓄⓈⒹ #25
#8
im about to buy some brake pads and rotors for the front of my 91 gti 8v, does it matter if i buy solid or vented?is this correct fitment for my gti?
Qty Brand Sku Description Retail Price Core Total
AAA
BR N1010-10678 Brake Pad Set Metal Master 68.28 25.99 0.00 25.99
AAA
BR N1000-19885 Brake Disc 41.21 20.99 0.00 41.98
Core Charges: 0.00
Subtotal: 67.97
Shipping - UPS Ground Residential: 0.00
Total Weight ( 21.66 pounds ):
CA residents pay 8.25 %: 0.00
Order Total: 67.97
Modified by lynx8489 at 2:36 PM 1-4-2007
#9
should gett the pads the correspond to your rotors if you have solid rotors get solid pads they are thicker - if you have vented rotors you need vented pads
vented pads will work on solid rotors but not the other way around - but theres no point jsut look at your rotors and see what you have
#10
Quote, originally posted by Tobias » should gett the pads the correspond to your rotors if you have solid rotors get solid pads they are thicker - if you have vented rotors you need vented pads
vented pads will work on solid rotors but not the other way around - but theres no point jsut look at your rotors and see what you havemakes sense, thanks!
#12
Ordered a valve cover gasket set and a cooling flange from you guys for my 16V![]()
#14
H20H2000-69812 00-69812is this the part for a MK2 Jetta 1.8 gas 8v?
thx.
#15
Quote, originally posted by colinward » H20H2000-69812 00-69812 is this the part for a MK2 Jetta 1.8 gas 8v?
thx.
is that how you looked it up? that looks like the toilet bowl down pipe for single outlet manifolds. Just look parts up by selecting your vehicle and then the website will only show parts that fit your car
#17
Quote, originally posted by Couper1TEP » you guys wouldnt happen to have window seals?
sorry no, that is a dealer only item.
#18
I'm interested in ordering a few things, but a little curious about something. Why is the price for a RL door handle listed so much higher than the others?
#19
Quote, originally posted by 92mkII » I'm interested in ordering a few things, but a little curious about something. Why is the price for a RL door handle listed so much higher than the others? Prices are just made based on the cost of the part that the supplier charges us... I don't have a real answer for you but that is the reason. Possibly it could be that they have old stock on the opposite side door handles and that they are trying to get rid of them so they can charge more for the new ones.
#20
Looking for a heater box for a 1992 gti.
#21
Edited while order gets sorted out.Modified by c-p at 7:41 PM 6-26-2008
Modified by c-p at 8:49 PM 6-26-2008
Modified by c-p at 6:03 AM 6-27-2008
Modified by c-p at 6:14 AM 6-27-2008
#22
IM'd, I need help logging in, it wont let me![]()
#23
Yeah not to bad of a site anyone else know of some sites to get great deals on vw parts?
#24
I'm placing an order in the next few days, still gettin my list together...so far they have beat the price of any other place I have found by over 20.00 shipped..I'm getting all suspension parts..
#26
how did this end up in the stickies?
Looks IMC based.... is it?
Thanks for calling. Your call is very important to me. If you would like to reach me by phone now, please hang up now. If you would like to reach me by phone later, please hang up later. If you would like to speak with a person, please press ten. ..... I'm sorry I do not understand one zero. Please hang up now or later if you cannot press ten.
#27
If i want to buy a left front and right front door handle will it come with two sets of different keys? can someone explain how i can get two door handles but one set of the same keys pleasee !
#28
niot the palce for the question..... start a thread.... rekeying door locks is easy.
#29
#30
im starting an original bulid of my 1989 gli 16v and im trying to find certain parts and im have a hard time. it had the small bumpers on and i put the big bumpers on and i need the wheel well flares and a grille badge. any info will be helpful
#32
This company is awesome! ordered my parts wednesday night, and they were here friday afternoon.
Great prices too![]()
#33
Need rr bumper bracket, door latch and trunk lock assy. wmco@midcoast.com
#35
