VWVortex.com - DIY smoked fogs
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 65
    Thread: DIY smoked fogs
    1. 05-22-2006 07:08 PM #1
      did this today, so i thought i might as well do a little writeup on it. Its no Dan Reed but i tried .... enjoy.
      DIY smoked fogs
      You will need:
      High temp black paint
      Masking/painters tape
      A type of silicone glue/sealant (black would work best to get the full smoked effect)
      Razor blade
      Rubbing alcohol
      Screw driver(s)
      If one or both of your lenses in cracked when removing it will come off in two pieces
      1. Remove fogs from bumper…may be tricky. The first time I tried to get my fogs out I had to pull the bumper. Today I pulled my bumper because I was working on some other things. If you are pulling the bumper reach in where the turn signal is and detach the fog light harness before removing the bumper because the wires are very short.
      2. Loosen adjuster screw. It is a hex screw however I used a small flat blade screwdriver, be careful not to strip it. Loosen until the projector piece is separate from the lens piece.
      3. There are two clips on each side. Using a small screw drive lift then up very carefully because they will snap. Wiggle off until the 2 pieces are completely separated.
      This is the clip, you can see how it locks in with a tab
      4. Use a razor to go around the edge of the glass and cut the existing glue
      5. Use a screw driver and loosen the glass from the plastic, you may need to use the razor again. If it is being stubborn you may want to use a heat gun or hair dryer help loosed the glue. Be careful of the glass chipping.
      6. Remove glass. If your lens in cracked this is where it will split in two.
      7. Use rubbing alcohol to clean where you will be painting. While you are at it you may as well clean the glass too.
      8. Tape off the plastic housing so no paint will go in the creases where you will be gluing the glass back in
      9. Using high temp black paint evenly spray both pieces. Start with a light coat then do a second coat, or however many you feel it needs.
      10. Remove tape and wipe lens and where the glue will be going with alcohol.
      11. Using the silicone run a continuous bead all around the crease where the glass goes. (I did not remove the old glue because it had a shape to it the acted like a gasket.) If your lens is cracked put some glue in between the two pieces. (dont worry about it squeezing out, you can remove it when it dries.)
      12. Put glass back on and squeeze firmly. Run your finger along the edge to remove any extra glue and to seal the glass in completely (be careful of glass chips). If you have some sort of clamp that you can use to hold the glass in place that would work fine. I did not use a clamp or vice and it worked out fine. If you are using silicone, don’t worry if some glue gets on the lens, once it dried you can rub it off.
      13. Allow time to dry and set
      14. Admire your hard work
      updated with black silicone
      Modified by soccergk at 5:09 PM 8-7-2006
    2. 05-22-2006 07:15 PM #2
      15.) Profit
    3. 05-22-2006 07:17 PM #3
      not to shabby [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    4. 05-22-2006 07:20 PM #4
      Quote, originally posted by gregfromnh »
      15.) Profit
      true! send me your fogs ill hook you up
    5. Banned
      Nov 10th, 2003
      05-22-2006 07:21 PM #5
      hahahaha heather's got a new hustle
      they look perfect.
    6. Banned brobsrabbit's Avatar
      Jun 18th, 2005
      05-22-2006 07:23 PM #6
      Quote, originally posted by JRon24 »
      they look perfect.
      switchblade?
      did you take off your bumper to get the fogs off? just curious
    7. Senior Member Dan J Reed's Avatar
      Jul 26th, 2004
      NJ - AKA - Earth's armpit.
      Too many
      05-22-2006 07:28 PM #7
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] Not a perfect match, but damn close!
    8. 05-22-2006 07:28 PM #8
      Quote, originally posted by brobsrabbit »
      If you read you'd see that she did
      Good job Heather [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Take some more pictures of them too [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Modified by SSjetta at 7:30 PM 5-22-2006
    9. Banned brobsrabbit's Avatar
      Jun 18th, 2005
      05-22-2006 07:29 PM #9
      ahhh.. but not just to get the fogs off [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      reading iss gooood mmk [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    10. Senior Member III's Avatar
      Dec 14th, 2001
      05-22-2006 07:34 PM #10
      nice work [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    11. 05-22-2006 08:05 PM #11
      yea i didnt take the bumper off just for the fogs. however it is much easier if the bolts are siezed on. I replaced the harware with new non rusted bolts and nuts so next time removing the fogs will be easy
    12. Senior Member ClockworkChad's Avatar
      Mar 21st, 2003
      NY
      b6 a4 stg 3+
      05-22-2006 08:09 PM #12
      somebodys got too much free time since Quinny got out......
      they look good, did you buy the dummies or were those DIY also ?
    13. Member Am pM HooDluM's Avatar
      Jan 9th, 2003
      Spanaway, WA
      '06 X3, '75 Rabbit, '70 Datsun 521
      05-22-2006 08:17 PM #13
      very nice! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    14. 05-22-2006 08:26 PM #14
      Quote, originally posted by ChadMk3 »
      goingfast.org sells smoked dummies for just $25 shipped
    15. 05-22-2006 08:40 PM #15
      i did this mod too. same way you did it. looks good. heres my pics, although this was before i took em back apart and painted the whole plastic part. props for DIY
    16. 05-22-2006 08:51 PM #16
      what did you use to seal them up? ive gone through 3 products and nothing makes a good seal...
    17. Member n0izepollution's Avatar
      Jul 28th, 2002
      NNJ
      2015 gTi Autobahn
      05-22-2006 08:55 PM #17
      you should have used black silicone it would have brought out the smoked look alot better on the edge of the lense
    18. 05-22-2006 09:10 PM #18
      Quote, originally posted by n0izepollution »
      agreed. permatex makes a great sealant. in black or clear [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    19. Member FlyersFn32's Avatar
      May 14th, 2004
      Ephrata PA
      1991 Corrado VR6, 2004 Jetta 1.8t
      05-22-2006 09:49 PM #19
      Hey Heather good DIY. One question. Does painting the housing take away from any of the output? I was thinking of doing this to my fogs until I found a great deal on votex smoked long fogs on eBay. I still might end up doing it on one of my buddy's cars, thats why I ask.
    20. Member AFromCT's Avatar
      Aug 12th, 2001
      1995 Black 4-Door Golf
      05-22-2006 09:55 PM #20
      Cute fingernail. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    21. 05-22-2006 09:57 PM #21
      The only thing you guys are doing wrong is look around the edge of the lense. you can see grey, you need to paint where the lense meets the trim aswell. It will look way better.
    22. 05-22-2006 10:01 PM #22
      awesome DIY. ill be doing it this weekend.
    23. 05-22-2006 10:02 PM #23
      great write-up heather [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    24. Member FrostedDub's Avatar
      Jan 25th, 2005
      Laconia, NH
      1998 GTI (sold), 2003 WRX
      05-22-2006 10:03 PM #24
      Quote, originally posted by Am pM HooDluM »
      x2 [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Lower Level Customs
      Quote Originally Posted by csrgti View Post
      Don't even try to explain yourself it's not worth the effort.
      It's your car, your money and time for repairs and mods. Build and drive it to your liking.
    25. 05-22-2006 10:06 PM #25
      Quote, originally posted by Doolie »
      yea that is a good idea, i thought that if i painted it the glue would have a hard time sticking....next time ill use the black silicone [IMG]http://*****************.com/smile/emthup.gif[/IMG] i just had the clear laying around so i used that...oh well
