Page 1 of 2 1 2 LastLast
Results 1 to 35 of 40
Thread: Brake hard line lengths and other useful info for when replacing all your brake lines.
    Aug 5th, 2003
    Northport, NY
    87 GTI, 01 GTI, 98 Ranger
    05-30-2006 02:34 AM #1
    Recently I replaced all the hard lines on my car as one of them had rusted out and blew open, fortunately in my driveway as I was trying to find a leak and did a panic stop stab of the pedal. I found myself wanting to replace ALL the lines, as I had lost confidence in the rest of the lines. Time to fire up the ETKA. Not wanting to deal with the dealer or many other hard to find places with well overpriced brake lines. I found that http://www.ecstuning.com has a selection of lengths of preflared brake lines with the nuts on them. Not only that but they are pretty cheap too. The only problem is that they do not carry a line long enough to run from the master cylinder on back to the rear proportioning valve. I had to come up with an adapter to mate the brake union nuts together. Fortunately the brake line diagrams of the ETKA had this small unrecognizeable scribble. If you have ever seen the underdetailed drawings in the ETKA you know exactly what I mean. It was listed as "connecting piece" and the remarks said "M10x1" which I remembered was the thread pitch of the brake union flare nuts. Unfortunately this small necessary piece seems to be a dealer only part as I don't currently know any places that sell these. A few mechanic friends of mine acted as if they had seen them all the time on various import and domestic cars coming into their shops, but tracking down one of these little buggers seemed a feat to great to accomplish. I searched a few places I know of that have an online part number lookup. The only places I found it at were http://www.worldimpex.com and http://www.1stvwparts.com without contacting the nearest dealer.
    Brake lines from http://www.ecstuning.com
    Brake nut connector for connecting a 40 inch and 60 inch line to make the distance from the master to the prop valve (part # 411 611 789) http://www.worldimpex.com or http://www.1stvwparts.com
    UPDATE : The brake line connector part seems to be available from NAPA http://www.napaonline.com/Mast...Metal
    I also received an IM from BAP Import Parts located in Phoenix AZ letting me know they carry the connector piece.
    On to what you all clicked here for...
    Its best to draw out a crappy diagram for this
    All lengths are straight from ETKA in metric, it is up to you to convert mm to inches by using google or something. Example: 2440mm to in
    All measurments are for front wheel drive mk2 based in a left hand drive/right hand traffic setup.
    I'd like to add that the later, shorter measurements can probably be used just fine in the earlier cars, where it seems they just rounded up to make measuring easy.
    <1986 with rear proportioning valve
    Front Left 550mm
    Front Right 1300mm
    Mid Left 2350mm
    Mid Right 2450mm
    Rear Left 400mm
    Rear Right 1300mm
    Axle Left 600mm
    Axle Right 600mm
    <1986 without rear proportioning valve
    Front Left 550mm
    Front Right 1300mm
    Mid Left 2500mm
    Mid Right 3480mm
    Axle Left 600mm
    Axle Right 600mm
    1987 with rear proportioning valve
    Front Left 550mm
    Front Right 1300mm
    Mid Left 2350mm
    Mid Right 2450mm
    Rear Left 400mm
    Rear Right 1300mm
    Axle Left 600mm
    Axle Right 600mm
    <1987 without rear proportioning valve
    Front Left 550mm
    Front Right 1300mm
    Mid Left 2480mm
    Mid Right 3480mm
    Axle Left 600mm
    Axle Right 600mm
    1988 with rear proportioning valve
    Front Left 550mm
    Front Right 1300mm
    Mid Left 2350mm
    Mid Right 2440mm
    Rear Left 400mm
    Rear Right 1300mm
    Axle Left 600mm
    Axle Right 600mm
    1988 without rear proportioning valve
    Front Left 550mm
    Front Right 1300mm
    Mid Left 2480mm
    Mid Right 3470mm
    Axle Left 600mm
    Axle Right 600mm
    1989 with rear proportioning valve and rear disc
    Front Left 535mm
    Front Right 1290mm
    Mid Left 2350mm
    Mid Right 2440mm
    Rear Left 390mm
    Rear Right 1230mm
    Axle Left 465mm
    Axle Right 465mm
    1989 with rear proportioning valve and 180mm drums
    Front Left 535mm
    Front Right 1290mm
    Mid Left 2350mm
    Mid Right 2440mm
    Rear Left 390mm
    Rear Right 1230mm
    Axle Left 565mm
    Axle Right 565mm
    1989 with rear proportioning valve and 200mm drums
    Front Left 535mm
    Front Right 1290mm
    Mid Left 2350mm
    Mid Right 2440mm
    Rear Left 390mm
    Rear Right 1230mm
    Axle Left 575mm
    Axle Right 575mm
    1989 without rear proportioning valve and 180mm drums
    Front Left 535mm
    Front Right 1290mm
    Mid Left 2480mm
    Mid Right 3470mm
    Axle Left 565mm
    Axle Right 565mm
    1989 without rear proportioning valve and 200mm drums
    Front Left 535mm
    Front Right 1290mm
    Mid Left 2480mm
    Mid Right 3470mm
    Axle Left 575mm
    Axle Right 575mm
    1990-1992 (up to VIN ending with 1GL990000) with rear proportioning valve and rear disc
    Front Left 625mm
    Front Right 1290mm
    Mid Left 2350mm
    Mid Right 2440mm
    Rear Left 390mm
    Rear Right 1230mm
    Axle Left 465mm
    Axle Right 465mm
    1990-1992 (up to VIN ending with 1GL990000) with rear proportioning valve and drums
    Front Left 625mm
    Front Right 1290mm
    Mid Left 2350mm
    Mid Right 2440mm
    Rear Left 390mm
    Rear Right 1230mm
    Axle Left 565mm
    Axle Right 565mm
    1990-1992 (VIN ending with 1GM000001 and up) with rear proportioning valve and rear disc
    Front Left 625mm
    Front Right 1290mm
    Mid Left 2350mm
    Mid Right 2440mm
    Rear Left 390mm
    Rear Right 1230mm
    Axle Left 635mm
    Axle Right 758mm
    1990-1992 (VIN ending with 1GM000001 and up) with rear proportioning valve and drums
    Front Left 625mm
    Front Right 1290mm
    Mid Left 2350mm
    Mid Right 2440mm
    Rear Left 390mm
    Rear Right 1230mm
    Axle Left 745mm
    Axle Right 875mm
    1990-1992 (up to VIN ending with 1GL990000) without rear proportioning valve and drums
    Front Left 625mm
    Front Right 1290mm
    Mid Left 2480mm
    Mid Right 3555mm
    Axle Left 565mm
    Axle Right 565mm
    1990-1992 (VIN ending with 1GM000001 and up) without rear proportioning valve and drums
    Front Left 625mm
    Front Right 1290mm
    Mid Left 2480mm
    Mid Right 3555mm
    Axle Left 745mm
    Axle Right 875mm
    Modified by L33t A2 at 11:24 AM 5-31-2006
    : Tornado Red '87 GTI 8vT, Toreador Red '98 Ranger XLT
    : Rave Green '01 GTI GLS
    '01 Catera, '90 GLI 16vT, '94 850 Turbo, '90 Golf, '89 Golf, '90 Mustang LX, '91 Jetta, '88 9000S, '86 Jetta, '91 Continental
    Aug 5th, 2003
    Northport, NY
    05-30-2006 02:53 AM #2
  3. Member Jezztor's Avatar
    Nov 9th, 2002
    Gauteng, South Africa
    05-30-2006 03:40 AM #3
    FANTASTIC THREAD, James! Put this in holistah's DIY also... This info is brilliant.
  4. 05-30-2006 06:38 AM #4
    When I had the steel lines replaced on my Jetta, the dealer made the steel lines out of 2 coils of Genuine VW brake line, and bent them into shape, matching the original lines perfectly. Comparing the lines on my GLI to those on the Flair which are original, it's hard to tell the difference.
    Jul 3rd, 2003
    Montreal, Quebec
    '92 Jetta Alpine White,and two Japanese daily drivers
    05-30-2006 08:34 AM #5
    Quote, originally posted by Jezztor »
    x2
  6. 05-30-2006 06:38 PM #6
    Great Job this helped me out alot
  7. Member tikipiki's Avatar
    May 17th, 2005
    Long Island, NY
    89 Golf 4dr 8v, 90 Golf 2dr 8v, 90 Golf 4dr 8v, 92 Golf 4dr 8v, 92 Golf 4dr odb2 2.0, 97 Impreza
    05-31-2006 03:22 AM #7
    Hey, Great info, I am about to replace my hard lines too.
    I think I found a cheaper coupler, well theres two that I think will fit correctly. They're from napa or napaonline.com. I searched for brake line on the search and under non vehicle specific section is where I found this.
    It is part number: (I had the wrong part #, the old one was for the non-bubble flare, here is the correct part #) BK 641-5020
    At http://www.napaonline.com or your local napa shop. That part number is for one part and I don't gurantee it will fit but from the specs on the site I think it will. There was another one on there also with the same basic size specs but I think the outside casing was different and there was a small price difference. These are also about $3-$4 instead of $15-$20 so they may be or poorer quality or just priced better. I am going to go the ecstuning route on the lines because I don't feel like flaring all the lines myself and try this napa coupler. They also have like 7 pages of hard line to choose from too so take a look there too if anyone needs anything. Thanks for the great information L33t A2, you made my day a whole lot better when I saw this post
    Modified by tikipiki at 6:58 PM 8-4-2006
    Aug 5th, 2003
    Northport, NY
    05-31-2006 03:41 AM #8
    great to hear
    Aug 5th, 2003
    Northport, NY
    05-31-2006 03:46 AM #9
    that connector fitting seems like it should work, if you choose to use it, please report back with your findings, that would be great if theres a cheaper solution
  10. Member Broke's Avatar
    Aug 13th, 2001
    Columbus, Ohio
    86 GTI 2.0L, 88 Scirocco 16V, 2010 F150 STX
    05-31-2006 03:58 AM #10
    Quote, originally posted by digifant_gli »
    That is what I did when it was time for new lines... http://www.thediygroup.com/flare2.htm
    Broke
    020 trans info pages - www.BrokeVW.com
    NEW 0.7619 5th gears for the 020
    NEW 020 reverse gears
    '86 GTI 8V 2.0L -'88 Scirocco 16V - '10 F150 4x4
  11. 06-05-2006 08:20 PM #11
    Why are the rear brake lines on the different VIN numbers different lengths on these....???
    Front Left 625mm
    Front Right 1290mm
    Mid Left 2350mm
    Mid Right 2440mm
    Rear Left 390mm
    Rear Right 1230mm
    Axle Left 565mm
    Axle Right 565mm
    Front Left 625mm
    Front Right 1290mm
    Mid Left 2350mm
    Mid Right 2440mm
    Rear Left 390mm
    Rear Right 1230mm
    Axle Left 745mm
    Axle Right 875mm
    Just curious because I am going to be doing mine soon and as far as I knew all of the rear beams were the same.
    my VIN ends in G7NM003935 so I would use the 745 and 875 lengths..??
    Modified by MBRACKLIFFE at 6:38 PM 6-6-2006
  12. Member MK2SnowPilot's Avatar
    Sep 8th, 2005
    Keswick, Ontario
    97 Golf K2, 99 Golf Wolfsberg Edition
    11-23-2006 01:32 PM #12
    Bringing this back from the dead for a similar question:
    Which damn ones should I use?
    My VIN ends with: G6MW084898
  13. 11-23-2006 01:35 PM #13
    Sticky needs to happen.
    Quote Originally Posted by Pineapplegti ! View Post
    Brand enthusiasts are idiots.
    Klutch Republik - Live Fast , Drive Hard
    SCCH Cylinder Heads & Suspension Components
    OSD #16
  14. Member MK2SnowPilot's Avatar
    Sep 8th, 2005
    Keswick, Ontario
    11-23-2006 02:36 PM #14
    Totalling up the lengths I can buy enough pre-cut lines to re-do everything for about $60...
    Anyone know which range my VIN falls in?
  15. Member Pat3022's Avatar
    Nov 17th, 2003
    westminster, MD
    an old BMW
    02-10-2007 03:50 PM #15
    If i'm buying the straight sections from nappa what size fittings and diamater line?
    Moving sale! Mk3 stuff for sale, need everything gone.
    http://forums.vwvortex.com/search.php?searchid=30881772
  16. Member Pat3022's Avatar
    Nov 17th, 2003
    westminster, MD
    an old BMW
    02-10-2007 04:08 PM #16
    the guy that replaced mine the last time used one that is too small. It's leaking where the hard line screws into the master cylinder and where that same line connects to the flex line. now i have to replace but don't know the right size
  17. Member Burnitwithfire's Avatar
    May 14th, 2005
    Quebec, Canada
    2010 Hyundai Accent 1992 Mazda Miata
    02-10-2007 04:30 PM #17
    Quote, originally posted by vr6swap »
    3/16" stainless hardline is available from Classic Tube ( http://www.classictube.com) and Inline Tube (www.inlinetube.com).
    A sales rep from Classic Tube tells me that they can cut / flare hard line to customer's measurements, for the price of parts plus a nominal shop charge for the cutting / flaring.
    The estimate I got from them was aproximately 160.00 shipped for 8 hardlines, totalling 383", cut and flared, including fittings.
    Note that this is NOT pre-bent line, you have to handle that yourself.
    Modified by vr6swap at 1:18 PM 11-23-2006
    160 is a pretty damn good price for SS lines, cut and flared with fittings! Great thread BTW, very useful!
    Quote Originally Posted by SAV912 View Post
    Going to church is bland. Eating vanilla ice cream is bland. Dating somebody from your local Ayn Rand book club is bland. This car makes all of those things seem as exciting as doing 12 lines of cocaine. With Katie Perry. While she's on fire...in Times Square. And you're naked.
  18. Member Pat3022's Avatar
    Nov 17th, 2003
    westminster, MD
    an old BMW
    02-10-2007 04:41 PM #18
    Use this site to convert mm to inches or feet http://mg-jewelry.com/mmtoinches.html
    this thread should be stickied somewhere
    there are different types of flares, also. VW's use bubble flares.
    In the pic above the "bubble flare" is on the right. Not to be confused with the "double flare" which is on the left.
    Modified by Pat3022 at 6:34 PM 2-10-2007
  19. Member German_Aesthetic's Avatar
    Oct 4th, 2007
    95 2.0, 97 subie 2.2 wagon
    11-27-2008 08:42 PM #19
    I bought some lines from ECS and they weren't painted. I went to Autozone and the lines were painted that green OEM color. go to autozone and get your lines there. I bought the 2 couplers at Napa. I bet the zone has them too. Autozone is great. Around here in central CT, I like them better than pep boys, napa, advance auto parts. As for german parts, germanautoparts.com. immediate turnaround, 1 day shipping. I like.
  20. Member s-rocc's Avatar
    Nov 26th, 2001
    reassembled in a garage, pa
    bunch of old german junk
    11-27-2008 10:35 PM #20
    great thread, something i will be doing soon.
  21. Member
    Aug 5th, 2003
    Northport, NY
    12-09-2008 10:02 PM #21
    im glad people are finding help through this
  22. 03-02-2009 11:18 PM #22
    i was going to do all stainless... but this just seems SO much easier..
    in for the info.
  23. Banned Crubb3d Rymz's Avatar
    Dec 25th, 2006
    NWNJ
    90 Jetta moneypit VR6, 2007 Rabbit shtbox
    06-07-2009 12:25 PM #23
    bump for EXTREMELY useful info, thank you OP
  24. Member DubbinChris's Avatar
    Dec 15th, 2005
    Columbus, OH
    85 Ur Quattro, 88 Fox Wagon (sold), 90 Golf, 83 Q Sedan TD, 88 QSW (soon tdi), 85 Q wgn, 03 A4 Avant
    09-13-2009 01:57 AM #24
    I wonder if this is the right union as well. It's cheaper than Napa too.
    http://northernautoparts.com/P...15953
    They do sell hard lines as well but it looks like you cant' just buy one or two of each length that you need.
    http://northernautoparts.com/P...=2630
    Modified by DubbinChris at 1:59 AM 9-13-2009
  25. Member sin bar's Avatar
    Jan 12th, 2008
    sin bar ga
    wagoon.
    06-14-2011 10:16 PM #25
    a useful thread.
  26. Member twinrado's Avatar
    Jun 23rd, 2005
    Roseville (St.Paul)
    Corrado, Audi A6, Passat
    06-15-2011 02:22 AM #26
    Again, does anyone have the inside and outer diameter's of the tubing because I plan on placing an order for some tubing.
    There's no such thing as too much of anything but to little results in the need for more.
  27. Member twinrado's Avatar
    Jun 23rd, 2005
    Roseville (St.Paul)
    06-22-2011 10:26 AM #27
    bump
  28. 07-20-2011 07:40 PM #28
    What's the trick for getting the threads to catch? I'm trying to connect the original line back to both the hydraulic hub and the master cylinder..
  29. Member red86GLI's Avatar
    Oct 20th, 2011
    Boston, MA
    '86 GLI
    12-12-2011 12:48 AM #29
    Midas banged my front hardlines out in an hour for $44. sweet.
  30. Banned Ajaxpowder's Avatar
    Oct 9th, 2010
    AB, Canada
    1992 Golf GL
    12-12-2011 01:40 AM #30
    Huge ups!
  31. 02-08-2012 01:36 AM #31
    Awesome thread.
    FWIW, I just replaced my drivers front hard line (early MK2), and used THIS 20" DIY line from Autozone. The original length as stated in the first post is 550mm or ~21.6", but I cheated the bend from the MC to the frame rail just a little to make up the difference. You could easily use the 30" length too and just use the excess to tuck the line out of the way.
    Part Number: PAEX-320 (20")
    Alternate Part Number: AZE320
    Part Number: PAEX-330 (30")
    Alternate Part Number: AZE330
    The website says that their stores normally stock these, but what I found is the inventory is always off. I even called and provided the parts numbers, and was assured they had them in stock, but when I got there none of the lines were in the right spots at three different stores. Get them to actually read the tags on the lines, and not just the hanger slot they're in.
    Hope that helps someone.
  32. Member
    Aug 5th, 2003
    Northport, NY
    02-26-2012 10:01 PM #32
    Quote Originally Posted by Electronaut View Post
    Awesome thread.
    I'm glad people are still finding this thread to be helpful
  33. Senior Member Big Dac With Fries's Avatar
    Feb 1st, 2002
    Spatula City
    6000 SUX
    02-27-2012 08:40 AM #33
    If you're in Canada, and are looking for the nicer epoxy coated (green) line, check out Part Source. I bought a roll of it when I was doing the brake lines on my MK2.
    It's not cut to length, but that's why they make a flaring tool and cutter.
    Want to roll your fenders or Lamin-X your lights in clear or yellow for THE ABSOLUTE CHEAPEST PRICE IN THE GTA? IM me!
    "I was thinking about what a friend had said, I was hoping it was a lie."
  34. Senior Member ratdub's Avatar
    Jan 16th, 2005
    hamilton township, nj
    mk6 GTI & SD f250
    03-25-2012 10:54 PM #34
    i'm going to bump this up b/c it is very useful info
  35. Member Estacaco's Avatar
    Oct 9th, 2010
    Dryden, Ontario. Canada
    92 Jetta TD, 90 Golf 1.8L, 93 Golf 1.8L
    03-25-2012 10:56 PM #35
    Very useful. Helped in redoing my rear brake lines last November. If you're having trouble sourcing flare nuts to make your own line you can usually salvage them from your old lines.
