I'm still in the market for a good 1.8l Hydraulic follower engine.
#71
I have seen this car it is a good starting point for a GLX Jetta or a good canidate for a swap car....![]()
#72
#73
@Schrottplatzer: I have several 1.8L hydraulic engines, for which car do you need it? Carb or injection? 8.2, 9.0 or 10.0 compression ratio?
#74
It doesn't matter carb or injected--I have a Weber DFEV set up to slap on it. Higher compression is better. Where are you? What do you want for them? If the junkyard pulls through I'll be getting one from a Scirocco today, but they've given me the run around before.
#75
I still have a brand new 1.8 one in the basement, make me an offer (pics on Pg1)
#76
Dual down pipe set up, manifold, down pipe, and cat. Manifold has been cleaned up and painted with high temp silver. $175 for the entire set up. That's cheaper than just the down pipe when new.
#77
Various parts from JH Engine: Intake manifold, throttle body, exhaust manifold, injector lines, injectors...the list runs on. Engine was out of a Scirocco GTX Just ask--PM me.
#78
Does anyone sell or know s/o who sells a Mk4 or Mk5 R32?
#80
Hey guys,Can anyone source some rear glass for me? I need the rear glass for a 2000 Audi S3.
Thanks in advance!
#81
Vento parts found. Got them home on the Airlines for $50 bucks.![]()
Ben
(RotorBG)
Modified by RotorBG at 6:44 PM 8-7-2009
#82
Quote, originally posted by RotorBG » Vento parts found. Got them home on the Airlines for $50 bucks. ![]()
Ben
(RotorBG)
wow good job
inspiration = in·spi·ra·tion - The momentary sensation of stupidity
VRSociety #65
#83
yep i am selling the rabbit. i want close to 4,000.00 for it. let me know if interested. i will post picks tomorrow. i am in grafenwoehr. i am the second owner of this car and the car has 107,xxx K on it. it has no rust no dents paint is ok for 26 years old. i love the car but i am deploying in 19 days and want it to go to a good home. list of mods and parts
100mm drop coilovers
all of the 75' chrome for the whole car
new matted cross hair headlights
new 3-piece old timer grille
new small lip spoiler
perfect interior( non-smokers)
and a G60 motor for it the full swap everyting with a compressor canada charger pulled it less than 30 days ago from a running driving corrado.
i also have a decent set of 14" wheels that are 8inch in the rear and 7 in the front
let me know if anyone is interested?
Modified by Eurolife69 at 8:23 AM 8-13-2009
#84
Anyone selling an US-spec Mk3 Golf in good condition in Germany?
#85
FS: OEM 6disc changer from the MK5.$350obo
#86
anyone have a obd1 vr6 coil pack and or starter hit me up
VRSociety #65
#87
Need a 16V upper manifold for ITB project, must be GTI. Got the ITB's just need the manifold. Whole manifold is fine.
Thanks
#88
N75H valve $50 obo shipped
710N valve $30 obo shipped
4-bar FPR $40 obo shipped
Hub Centric Rings $20 obo shipped
14x1.50 30mm lug bolts with key $40 obo shipped
Modified by powdercrazy at 4:53 AM 8-30-2009
#89
who makes the 710N valve?
Modified by GEOTANGTI at 10:10 PM 8-31-2009
#90
its the valve that audi uses on the TT, its made by VW/Audi
#91
Looking to borrow a set of wheels and good tires for a day or so. You know what its for!![]()
Let me know if you have some old steelies laying around that I can borrow for a day. 4x100 bolt pattern
Edit: Got a set of junkyard wheels and new tires! http://forums.vwvortex.com/zerothread?id=4559826
Modified by MEDEL514 at 5:37 PM 9-24-2009
Go €uro, or go home!
Hyperlink to MY CARS
Straightaways are for fast cars, Corners are for fast drivers.
#92
make sure they are 15" steelies.. corrado brakes won't go behind anything smaller.
#93
I have some old school Recaro fabric, aprox. 10.94 yards and the fabric is 55'' wide.The price is $100 per yard plus shipping. The minimum to buy will be 1 yard, no less than that.
People interested in the fabric feel free to call (831) 406-1463
#95
Got some stock stuff from my 08' GTI lying around:
engine cover-$130 OBO
Stock springs-$30 OBO (about 3k miles on them)
premium 6 discs CD head unit-$150 OBO
GTI honey comb fogs and center grills-$40 OBO
PM me if anyones interested.
#96
I need a set of 16'' or 17'' 5x100 wheels to put winter/all season tires on. My 18s have summer tires on them and im not wanting to pay any fines that ive heard about over here. Steelies, Long Beaches, rx-iis, W/E you have I can make it work as long as its a 16'' wheel as its the smallest that will clear my 20th brakes.Thanks
BT Imola Yellow 20th
#97
I ve got brand new klima kompressor directly from factory. The price is 675USD (450eur), price can be negotiate. Prices in dealerships are around 1200-1500USD (850 do 1000eur). This kompressor 1K0.820.859.F , will fit:2004-2010 Audi A3/S3/Sportback
2008-2010 Audi A3 Cabriolet
2004-2007 Audi TT/TTS Coupe/Roadster
2004-2010 Octavia
2008-2010 Superb
2010-2010 Yeti
2004-2010 Altea
2006-2010 Leon/Leon 4
2005-2009 Toledo2004-2010 Caddy
2006-2010 Eos
2004-2009 Golf/Variant/4motion
2005-2009 Golf Plus
2006-2010 Jetta/Syncro
2006-2010 Passat/4motion/Santana
2009-2010 Passat CC
2009-2010 Scirocco
2008-2010 Tiguan
2003-2010 Touran
#98
In the market for a motor...need 120-150 hp. post up what you got. i got about 500 dollars to work with. maybe a "little" more depending upon the motor.sorry prefer 16v mk2 era or g60. thanksModified by NurburgringVW at 11:48 PM 10-14-2009
Modified by NurburgringVW at 11:52 PM 10-14-2009
#99
There are so many possibilities when you just mention...motor. Your best bet is to go 16v and if you can get a KR motor you will be set. Stay MK2 era 16v, 4 cylinders and you should fit your budget. When you look into forced induction than things go a little higher. If you could swing a G60 swap than I think you would be satisfied with the power output. Don't let your mind wonder about going VR6. You will be falling into a money pit. But...I may one available. hehe. good luck.![]()
#100
*** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION ****** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION ***
4-SALE IS A:
Airride Suspension for VW GOLF/RABBIT/GTI 5Article Description
- built by H.A.S. Bullock-Style Germany
- Airlift
- yellow koni shocks
- 2*11 Liter Aluminium-Air-tanks
- remote control
- Viair Manometer
- including all except air-hoses (to much work to get em all out)
- produced, mounted and approved by TÜV and HAS Bullock-Style Limburg
- used, but gooooooood condition (bought in 2k6, cruised 25t kilometers since that day
- no damages
- i have been to bullock style every year to do the mainentance and cleaning of the technic
- i was always careful with the airride, cleaned the airbags etc.
I´m selling the suspension because of project change. i want to use my golf as a daily driver and i want to built up my bug. that´s why i want to get rid of the airride and use the money 4 the bug. that doenst mean i am unsatisfied in any way with the suspension - never!!!This was the best idea i ever had. Drives smooth, never had problems, good stuff and a great service ob Bullock-Style that did everything about that.
Driving tests or something like that are possible of course. contact me via mobile phone nr. 0163 288 44 38 - pns are also ok, but i dont have the time to check my inbox every day.
Pics:
... sorry it´s still in my car ... i will remove it, if i got an OK from you.
OR we remove it together and we get my new suspension in at your garage.
Price:
1499 € or your best offerCost for Delivery:
if it should be delivered, i will use DHL, HERMES, UPS or GLS. So the prices will be 1:1 what they want me to pay. This costs will be added to the price for the suspension!Contact:
via PN or mobile-phone (number up there ^^)
i am living in 76726 germersheim (thats between mannheim and karlsruhe)Cheers,
basti*** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION ****** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION ***
Modified by basti-FSI at 11:18 PM 10-14-2009
#101
2.0 8V (engine code 2E) cylinder head polished with heavy duty valve springs 100 bucks
BBM 16v crank pulley (never used) 100 bucksMk1 radiator with integrated resevoir (never used) 100 bucks
Mk1 radiator used for engine run up after swap, not drvien 80 bucks
Bosch 90a alternator ABA (new never used) 150 bucks
MSD 6A (bought used) 70 bucks
MSD 8980 (bought used) 70 bucks
must pick up
0171 387 5315
Modified by hick at 9:30 PM 10-15-2009
#102
Quote, originally posted by projectracerabbit » us spec mk2 jetta, still fs.
motor not included, unless you want to pay for it.THIS IS A PROJECT CAR!
I drove it from vegas to maryland before I shipped it, but got some broken lights windshield (rock chips) on the way.
reg as a Diesel.
I get back to town in may, come take a look, make offer, drink a beer
if you are really interested, my wife can show the car. currently taking up my garage.http://s12.photobucket.com/alb...6.jpg
pictures of the car in question. I will be parting it out when I get back.
if any one wants any parts or pieces let me know
Modified by projectracerabbit at 8:37 AM 3-26-2009ok, I am now getting a divorce and need some cash. still have the car, need to get rid of it.
some one want some parts? make me an offer for the whole car if you want.
IDiesel!
I can get CUSTOM EURO PLATES
37.89 AVG MPG over the life of the car in Germany!
#103
It's a daily and a little rough. You can drive it or use it for a VR-6 swap.
#104
Still searching for a set of 16/17'' Wheels to run for the winter. Steelies, Montreal's, Long Beaches. etc. As long as they are 16s they will fit over my 20th AE brakes with my current spacer setup.Also I'm looking for the following items as well:
OEM Rear Bumper (US or Euro Spec) IN good shape
OEM Rear Valance (perfer the no cutout) In good shape
OEM Catback exhaust
OEM Jetta Front End (US or Euro Spec)
OEM Leather Seats (Trade for my Recaro's)There's more stuff im looking for im sure, I just cant remember right now.
#105
Quote, originally posted by basti-FSI » *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION ****** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION *** AIRRIDE SUSPENSION ***
4-SALE IS A:
- Airlift
- remote control
- Viair Manometer
- no damages
Pics:
Price:
unbelieveable noone is showing some interest in my suspension!?!? Price Drop -> 1100 Euros
