VWVortex.com - Need 2003 Jetta radio wire color codes. Everything but the speakers.
    Results 1 to 14 of 14
    Thread: Need 2003 Jetta radio wire color codes. Everything but the speakers.
    1. 06-07-2006 12:05 AM #1
      Anyone have the color code and pin number breakouts for the 2003 VW radio wiring harness?
      I've got the pinouts for all the speakers.
      What are the rest of them?
    2. Member kwalton's Avatar
      Sep 3rd, 2001
      Baltimore, Md
      2016 Jetta GLI 2014 Tiguan
      06-07-2006 11:53 PM #2
      red/white is you constant 12v
      brown is you ground
      you will have to get your ignition from the power center above the dead pedal. black/yellow lead.
    3. 06-08-2006 12:26 AM #3
      thanks, what are the rest of them?
    4. 06-08-2006 12:31 AM #4
    5. Member kwalton's Avatar
      Sep 3rd, 2001
      Baltimore, Md
      06-08-2006 01:02 AM #5
      do not do anything with the rest of the wiring. that is all for the can-bus system for the cars computer. i assume that you are putting in a radio. did you already cut the harness?? if not, get an adapter (metra 70-9003) it will save you a lot of time.
    6. 06-08-2006 02:18 AM #6
      no room for a harness, looking for the antenna lead, and trying to figure out which can bus cable is what
      have a single wire fault that keeps resetting my auto window up
    7. 06-13-2006 02:57 AM #7
      How difficult is it to get power from the ignition line in the power box? This has been frustrating me so much that I just want to go pay the money to have somebody else do it.
    8. Member NC2002GTI's Avatar
      Jun 29th, 2002
      NC
      '16 OW Golf R, '04 Beetle Conv. HPA conversion, '89 240SX SR20DET
      06-13-2006 10:26 AM #8
      Depending on how much you'd like your new radio to function like the old one, there's a better wire to use for "ignition" connection. In the steering column igntion harness you can find a fairly thin brown wire with a red stripe that is your "key-in" or extended accessory wire. Using this wire will allow you to play your radio by turning the key one click foward and also allow it to keep playing after you turn off the car until you remove the key from the cylinder. You can locate it by removing the steering column plastic and it will be in the harness plugged in to the back of the ignition cylinder.
    9. 06-13-2006 10:40 AM #9
      Thanks... is there something I can buy to easily tap into the wire? I haven't played with wires in a long time and it makes me a bit nervous playing in the steering column, as things up there can be a little expensive to replace.
    10. Member NC2002GTI's Avatar
      Jun 29th, 2002
      NC
      06-13-2006 10:51 AM #10
      That's actually a good question. My first car that i tried to do this way i soldered the connection, because i wanted it to be as good of a connection as possible. The problem was, the insulation on those wires don't seem to be very heat resistant and that wire + my constant wire managed to melt together and power up my accessories . Scared me for a moment, then fixed it with no further problems. The next time i removed a 1/2 inch section of insulation and did the "thread & wrap technique" where you make a tunnel in the target wire, put your new wire through it and then wrap the new wire around the target, closing the hole. No heat involved and almost as good.
      It sounds like you're looking for a "T-tap" that allows you to just clamp a connection on to your target wire. They are the easiest, but i don't recommend using them. If you're not familiar with wire sizes it's easy to use the wrong one, and i've seen many cases of the friction connection they make deteriorating after 1.5 years or more and becoming intermittent.
    11. 06-13-2006 08:51 PM #11
      just run a wire to any of the B+s on the back of the fuse panel
      anyone have the wire colors
    12. 06-14-2006 01:06 AM #12
      Actually I found that someone had previously tapped into the grey wire on the CD changer connection. That did the trick. Thanks for your help.
      Now, for the next questions. I want to get a PIE AUX adapter. Can I get one that will connect to the CD changer connection in the trunk? Also, on the back of the headunit, there appear to be two connections, one for the CD changer... what's the other one for?
    13. 06-14-2006 01:58 AM #13
      yeah they make one that connects in your trunk, but make sure you order the right one.
    14. 06-15-2006 01:42 PM #14
      Ah... I found the USA SPEC VW-AUX connector with two aux inputs. It plugs into the CD changer in the back. Fortunately I'd already run an AUX cable up to the front, so now my Satellite radio and iPod can be used. Yay. Now I just have to go back in and take out that FM modulator that's keeping my headunit from going back in.
