Page 1 of 2 1 2 LastLast
Results 1 to 35 of 62
Thread: DIY: GOLF G*L*I monster mat install. Or, I drive a WHAT?!?!?!
  1. Global Moderator iThread's Avatar
    Sep 27th, 2005
    06-15-2006 09:37 PM #1
    Apperently I drive a GOLF GLI:
    Ok, on to the DIY.
    They're pretty easy to install. If you're comftorable using a pneumatic impact wrench you should have no problems doing this install.
    You'll need scissors or a sharp razor blade to disconnect the mats from their hanger that they were shipped with. Simpily cut the tab and set the mats aside.
    You're going to have to disassemble your old mats and remove them from the car before installing the new ones. It's pretty straight forward but I took some pics just to make it easier.
    Go and open the drivers side rear passenger door and locate the mat that was supplied from the factory. It should be on the floor in front of the rear seat with a portion under the drivers seat.
    Using your hand pull up on one of the corners of the mat and lift it up and towards you. This should allow you to remove it from the car.
    Next, take the new mat and grasp it from the top.
    Slide it under the front seat as shown and it should fall nicely into place.
    Repeat this for the other side.
    The fronts are a little tougher because of the mat restraints shown here
    You'll notice a small "tab" that is preventing you from lifting the mat out of the car. To remedy this use your fingers to rotate it clockwise (counter clockwise works too)
    You want to rotate it until it's 90 dregrees from it's original location.
    Next lift up on the corner of the mat
    Again pull up and towards you and you'll be able to remove it from the car.
    Taking the new mat, grasp the top of it
    and slide it into place.
    The bottom half should line up like this and the restraints should be poking through the holes in the mat like thus
    Again, using your fingers rotate each of the tabs so they're back in the position they were in when the old mats were installed.
    The drivers side mat will also have the restraints and they're removed the same way. When you have released them pull up on a corner of the mat and pull up and towards you to remove the mat.
    Grasping the top of the new mat slide it into place making sure it does not interfere with any of the pedals.
    Next set the restraints back to their original position.
    That's it you're done!
    To make sure it's properly installed check with your fast for it's approval:
    And some installed pics:
    Modified by thread at 6:44 PM 6-15-2006
  2. 06-15-2006 09:39 PM #2
    i would have never figured that out...lol..jk....i guess there are some people that dont right??
    nice golf gli!!!
  3. 06-15-2006 09:47 PM #3
    That is freaking hilarious!
    Quote Originally Posted by 20aeman View Post
    No, the real enthusiast vehicle would be the RX8. It combines V12 Lamborghini gas mileage with Hyundai Genesis 4cyl. performance.
  4. Member Tourenwagen's Avatar
    Dec 28th, 2002
    NJ
    13 CW G6
    06-15-2006 09:49 PM #4
    Im confused. I think you left out some steps. Can you be more specific?
  5. 06-15-2006 10:25 PM #5
    BRILLIANT!!!!!!
    where is the obligatory guinness(insert your beer) after such a physically grueling install?
  6. Member ZoomBy's Avatar
    Jan 2nd, 2005
    Connecticut
    2013 MKVI GLI - Manual / 1998 MKIII Jetta GLX VR6 - Manual
    06-15-2006 10:34 PM #6
    are any tools or cutting into wiring required?
  7. Global Moderator iThread's Avatar
    Sep 27th, 2005
    06-15-2006 10:37 PM #8
    Quote, originally posted by ZoomBy »
    Nah, I chose not to install the optional neon.
  8. 06-15-2006 10:54 PM #9
    thanks for the write-up
    Everybody has a plan till they get punched in the mouth
    1986 535i | 1995 M3 | 2002 337 | 2005 MCS | 2006 GTI | 2007 GTI | 2008 R32 | 2006 CAYENNE S | 2012 GOLF R | 1991 964
    GONE | PRESENT
  9. Member ZoomBy's Avatar
    Jan 2nd, 2005
    Connecticut
    06-15-2006 10:54 PM #10
    WHOA WHOA WHOA, how dare you say neon, in a VW forum
    haha
  10. 06-15-2006 11:56 PM #11
    Good job man. But you fogot you have to grease up them tabs good otherwise they are going to rattle like hell when cornering hard.
  11. Member SnowboarderX216's Avatar
    Jun 7th, 2004
    Lancaster, PA
    12' Volkswagen GTI, 12' Ford Escape
    06-15-2006 11:59 PM #12
    nice
    just out of curiousity why do you have a "fast" when you got a Golf? thought they only game with GTI's
    Had/Have 1999.5 Jetta | 2006 GTI | 1991 GTI | 2004 A4 | 2008 R32 | 2012 GTI | 2012 Escape
  12. Global Moderator Dan Halen's Avatar
    May 16th, 2002
    Dougal County
    2006 GLI, 2008 Rabbit
    06-16-2006 12:02 AM #13
    Nice job, Wisenheimer.
    Looks like I'm the last moderator to get them, thanks to the dealership that didn't order them when I placed the order.
    S'alright, the one I should have ordered from to begin with shipped them today.
    Nothing insults the common man more than infringing on his right to be a dumbass. - PassSedanGLX
    Ride In: 2006 Plat Grey GLI .:. 2008 Sage Green Rabbit
    Ride On: 2010 Trek 2.1 .:. 2011 Fisher Cobia
    MkV Forum New User Information .:. MkV FAQ & DIY Guide
  13. Global Moderator Dan Halen's Avatar
    May 16th, 2002
    Dougal County
    06-16-2006 12:03 AM #14
    Quote, originally posted by SnowboarderX216 »
    nice
    ... what?
    VWoA decided to mail one to each MkV moderator, despite the fact that we all drive GLIs.
    ... a "goodwill gesture," if you will.
  14. Member SnowboarderX216's Avatar
    Jun 7th, 2004
    Lancaster, PA
    06-16-2006 12:05 AM #15
    very nice
  15. 06-16-2006 12:55 AM #16
    How much does the dealer charge to install? I am not mechanically inclined.
  16. 06-16-2006 12:58 AM #17
    hehe belive it or not...takeing the inserts out that you use to like clamp the new mats down is a biatch!
    I dont know if u all know what im talking about, but i had to do this to my R32 matts....the clips wouldnt fit in the hole...so i had to change them out....It was a pain....by the time i was one, i felt less of a man then i started
    Damm thoose inserts!
  17. Global Moderator Dan Halen's Avatar
    May 16th, 2002
    Dougal County
    06-16-2006 01:01 AM #18
    Quote, originally posted by DimceR32 »
    Yeah. I had two sets of carpet for my previous Jetta- a 2002 set and a 2004.5 set (fasteners were different) and then had about five various sets of floormats beyond that. I became very used to swapping mat tabs.
  18. 06-16-2006 01:04 AM #19
    lol. awesome!
    I actually had one defective rotating lockdown on my Jetta that had to be fixed at the first tuneup because it wouldn't rotate
  19. Global Moderator iThread's Avatar
    Sep 27th, 2005
    06-16-2006 02:11 AM #20
    nice
    I don't have a golf, I have a Jetta GLI. For whatever reason the mats come labelled as Golf GLI mats
    This is my car:
  20. 06-16-2006 02:57 AM #21
    I'm sorry, I don't understand. What tools are required for this??? Is this a "mod"??
    Man... time for bed. You've got too much time on your hands Chris.
  21. 06-16-2006 08:53 AM #22
    for you Chris:
    Num Num
  22. 06-16-2006 09:06 AM #23
    At least you have something for your tab to turn onto. One of my mats came missing that on each side of the mat. Just rubber with the hard plastic missing. Still haven't gone in to get a new one.
    Modified by Mike Gordon at 6:13 AM 6-16-2006
  23. 06-16-2006 09:45 AM #24
    If I install the mat mod, will VW void my warranty?
  24. 06-16-2006 11:35 AM #25
    Quote, originally posted by thread »
    This is my car:
    That is one f'ing gorgeous GLI, man.
  25. Senior Member mujjuman's Avatar
    Jul 29th, 2004
    New York
    2001 VW Jetta VR6, 2006 VW Jetta 2.5
    08-08-2006 05:42 AM #26
    nice tails! thanks for the DIY tho
    mujjuman
  26. 08-08-2006 06:23 AM #27
    Tight. This is a definite add to the DIY and FAQ and LMAOBBQ.
  27. Member GaBoYnFla's Avatar
    Oct 2nd, 2005
    Florida
    2011 Audi TTS
    08-08-2006 07:14 AM #28
    Quote, originally posted by BRM10984 »
    You mean VWoA is monitoring this forum? I've never modified anything on my car-just for the record!
    It's me, it's Earnest T!
    2011 Audi TT S
    Black on Black
    Clear bra, H&R Sport Springs, Magride, Neuspeed 25mm front and rear sway bars
  28. Member Slipstream's Avatar
    Feb 8th, 2002
    Omaha, NE
    5.0L, 10 cylinders
    08-08-2006 09:51 AM #29
    Quote, originally posted by Smitty the Engineer »
    Just the powertrain portion of it.
    07 rabbit | 08 jetta | seventwosix | flickr
  29. Member rambag3's Avatar
    May 17th, 2006
    Long Island
    Current vehicles Audi A3 2.0T FWD 04 ninja 250 RIP 2010 Honda Accord Ex-L - and 2006 SV1000s
    08-08-2006 10:18 AM #30
    ... what?
    I think I speak for us all when I say, I hate you :.Jealous:
    I tell them to tackle the concrete at walking speeds and re-think their position.
  30. 08-08-2006 10:25 AM #31
    wow...very detailed instructions...
  31. Member wpg2.0T's Avatar
    Sep 10th, 2003
    A4 B8 Avant S-Line. Garnet Red. Nav etc.
    08-08-2006 10:30 AM #32
    Hope you started this project early in the Morning so that you natural daylight for the entire install time!
    Cheers.
    If I wasn't here I would be somewhere else!
  32. Member Time for a GTI's Avatar
    Apr 25th, 2006
    MA
    '12 Golf R
    08-08-2006 10:32 AM #33
    Well aren't you guys freakin special
    I'm going to try to breed them...demonic bunnies
    Modified by Time for a GTI at 10:33 AM 8-8-2006
    FS: Golf R OEM HPFP
    Scotch. It's time.
    if i got my ass kicked every time I went to a particular bar, i'd own it, and ruin anything in my path.
  33. Member 08CandyWhite's Avatar
    Jan 31st, 2003
    Westminster, CO
    '12 GTI 4DR MT
    08-08-2006 10:40 AM #34
    Quote, originally posted by Time for a GTI »
    No matter how many times I see that picture, I don't get tired of it!
    @08candywhite on Instagram
  34. Moderator dashrendar's Avatar
    May 2nd, 2004
    Little Rock, Ar
    '00 Jolf 1.8T, '02 Jetta 1.8T
    08-09-2006 09:07 PM #35
    |ScArE BeAr MafIa|Low.Life.Society|WetDub|726|XBOX GT:DrNotSoHorrible
    Quote Originally Posted by UberDub18t
    Dash invented the double
