VWVortex.com - FAQ - -= 1.8t Technical Forum Guide { FAQs | Tuning/Modification Assistance | Troubleshooting } =-
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 37
    Thread: FAQ - -= 1.8t Technical Forum Guide { FAQs | Tuning/Modification Assistance | Troubleshooting } =-
    1. 06-16-2006 11:14 PM #1
      The 1.8T forum turbo theory topic.Troubleshooting Guide:
      Symptom: Items to Check
      • Rough Running At Idle: MAF, Ignition Coil, Spark Plug, VAC Leak, O2 Sensor, TB, CTS
      • Missfires under Boost Flashing CEL: Ignition Coils, Spark Plugs
      • Running Rich: Boost Leak, MAF, O2 Sensor, Coolant Temp Sensor
      • Running Lean: VAC Leak, MAF, O2 Sensor, Fuel Filter
      • Low Boost: Limp Mode, MBC, BOV, DV, Boost Leak, N75
      • High Boost: MBC Setting, N75, Spark Plugs, Ignition Coils
      • Cold Start Problems: MAF, Spark Plugs, Fuel Pump Relay, CTS
      • Poor Gas Mileage: MAF, CTS, O2 Sensor, AIT Sensor
      • Cat Efficiency Below Threshold: Down pipe, CAT, Rear O2, RACE FUEL
      • No Start: Battery - ECU, Fuel Pump Relay, Ground
      • Start For 1 Second Stall: Immobilizer
      • Overheating: Waterpump, Thermostat, Head Gasket
      • Oil in coolant: Oil Cooler, head Gasket, Water Wetter
      • Dies While Driving: Timing belt, Boost Leak, MISC
      • Shorts To ground CEL: Fuel Pump Relay, Bad Grounds
      • Oil in your IC/IC piping: Check your PCV system
      __________________________________________________ ___
      FAQ Listing:
      1. Engine Codes
      2. 1.8t Acronyms/Lingo
      3. Engine Info
      4. Trasmission Info
      5. Part Numbers
      6. Fuse Numbers
      7. Upgrade Help | Mantanince DIYs | Product Evaluation Threads [IMG]http://*****************.com/smile/emarrow_left.gif[/IMG] A Must Read
      8. RossTech Vag-Com Info & Tips
      9. DTC Codes & Fixing Info/Tips
      10. Torque Specs
      11. BT Parts List
      Other:
      FAQ Additions/Corrections/Etc:
      -PM me to make additions/corrections/suggestions for the FAQ [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Modified by Boostin20v at 2:21 PM 12-18-2007
      Modified by iThread at 12:43 PM 8-27-2009
    2. 06-16-2006 11:17 PM #2
      1.8t Engine Codes
      How to find your Engine Code:
      Location on Head, Location on Block
      Picture shows location of code on head. Picture is of a transverse motor but the tab is in the same physical location of the block in a longitudinal setup.
      *Note: There are a few cases where no stamp will exist on the head. The first are the 2001 Jetta Wolfsburg Edition vehicles which were not stamped from the factory. The other case would be if the head was replaced as a result of some kind of engine mechanical failure (ie Timing belt with valve damage).
      US Market Volkswagen
      2000 Golf/Jetta: AWD
      2001 Golf/Jetta: AWW
      2002+ Golf/Jetta: AWP1997-1999 Passat: AEB
      1999-2001 Passat: ATW
      2001 Passat: AUG/AWM
      2002-2004 Passat: AMB
      1999-2000 Beetle: APH
      2001+ Beetle: AWV
      2002 Beetle Turbo S: AWP
      US Market Audi
      1997-1999 A4: AEB
      2000 A4: ATW
      2001 A4: AWM
      2002 A4: AMB2000-2001 TT 180hp: ATC,AJQ,APX,APP,ARY,AUQ
      2001-2004 TT 180hp: AWP
      2001-2002 TT 225hp: AMU,BAM
      2003-2004 TT 225hp: BEA
      VW/Audi Engine Info
      -058 Block: external water pump
      -06A Block: internal water pump
      -Displacement: 1.8L (1781cc)
      -Firing Order: 1-3-4-2
      -Cylinder #1 is next to the timing belt
      -All catbacks are 2.17"
      -Oil Capacity: 4.6qt (4.35L)
      -Head bolt size: 11mm AEB, 10mm all others
      -Engine Mount Assembly/Mounting Info
      • Engine dimensions for OE engines:
      • Bore size - 81mm (3.19in)
      • Stroke - 86.4mm (3.40in)
      • Rod Length - 144mm
      Volkswagen Engine Info
      Engine Code: AWD
      Model Years: 2000 (11/99 on)
      Compression Ratio: 9.5:1
      Horsepower (SAE Net): 150hp @ 5700RPM
      Torque: 155ft. lbs.@ 1750RPM
      ECU: Motronic ME7.5
      DP Size: 55mm (2.17")
      Turbo: K03
      OE Boost: .6 Bar (8.7psi)
      Engine Code: APH
      Model Years: 2000
      Horsepower (SAE Net): 150hp @ 5500RPM
      Torque: 155ft. lbs.@ 1950RPM
      ECU: Motronic ME7.5
      DP Size: 50mm (1.97")
      Turbo: K03
      OE Boost: .6 Bar (8.7psi)Engine Code: AWW/AWV
      Model Years: 2001 (07/00 on)
      Compression Ratio: 9.3:1 (Officially, though in practice its 9.5:1 as other 1.8t motors)
      Torque: 162ft. lbs.@ 1950RPM
      ECU: Motronic ME 7.5
      Turbo: K03s
      Engine Code: AWP
      Model Years: 2002+ (06/01 on)
      Horsepower (SAE Net): 180hp @ 5500RPM
      Torque: 174ft. lbs.@ 1950RPM
      ECU: Motronic ME7.5
      Turbo: K03s
      OE Boost: .8 Bar (11.6psi)
      Audi Engine Info
      Engine Code: AEB,ATW,AUG
      Model Years: 1997-2000
      Horsepower (SAE Net): 150 @ 5700 RPM
      Torque: 155 ft. lbs.@ 1750 RPM
      ECU: 97-99.5 Motronic ME3.8.2/ME5.9, 2000+ is Motronic ME7.1
      Turbo: K03
      Engine Code: AWM
      Model Years: 2001-2005
      Horsepower (SAE Net): 170 @ 5900 RPM
      Torque: 166 ft. lbs. @ 1950 RPM
      ECU: Motronic ME7.1
      Turbo: K03s
      Head Differences between Engine Codes
      * Size of intake/exhaust ports (image), AEB only US spec head to have larger ports.
      * Use of tensioners (VVT or non-VVT)
      * Valve covers
      * Camshaft gear (06A vs 058)
      * Hall sensor/CPS Shutter window - AEB has 1 window, all others have 4
      Crank Info
      • 1.8T crankshaft guide - Thanks Bobq
      • 058 Old Style
        Came in the 058 external waterpump blocks only in longitudinal cars.(A4, Passat) These all have the “short”, small diameter snout. These cranks are all cast, and come with a toothed 60-2 wheel. There are 2 versions– the difference being the spigot on flywheel end.
        • Manual These have a pilot bearing pressed into the bulbous spigot on the flywheel end.
        • Automatic- This has a much flatter protrusion on the flywheel end and no provision for a pilot bearing.
      • 06A New Style
        These came in all 06A blocks with internal waterpump, both longitudinal and transverse. (Some codes AWD, AWW, AWP, AMB, AMU, AWM) These all have the “long”, large diameter snout. These cranks are cast or forged, and come with a windowed 60-2 wheel. There are 3 versions
        • Transverse manual/automatic- These are all forged and have provision for a pilot bearing to be pressed into the bulbous spigot on the flywheel end, but no bearing is installed.
        • Longitudinal manual- These are all cast and have a pilot bearing pressed into the bulbous spigot on the flywheel end.
        • Longitudinal automatic- These are all cast and have a much flatter spigot on the flywheel end and no provision for a pilot bearing.
      • Notes:
        • 058 and 06A cranks are not interchangeable- they must match the block.
        • Transverse applications can use any of the above listed cranks.
        • Longitudinal manual applications can use the transverse forged crank with the installation of a pilot bearing. They may also use the longitudinal automatic crank if an adapter is machined to accept the pilot bearing.
        • Longitudinal automatic applications can use the transverse forged crank, or longitudinal manual crank if the spigot on the flywheel is machined down to clear the torque converter.
        • Trigger wheels are physically interchangeable, but early "bar" style sensors can only go in early blocks.
        • The early toothed wheel is better for SEM applications
      • Cast Cranks
        • AEB,ATW,AMB, AWM
      • Forged Cranks
        • AWD,AWW,AWP
      Other Misc Info:
      • 2nd O2 sensor on AWD can be tapped for A/F gauge
      • AWP engines lack Fuse 6
      • AWD had slightly different fitting coilpacks, they use clips and allen keys to be secured.
      • The AEB engine code(non-dbw) has the largest intake ports and consequently is one of the most in demand head's to put on our cars.
      • APH engines have a "baby" K03 turbo--not same as Golf and TT
      • APH engines have the 2L exhaust
      • APH engines have a smaller Intercooler (even smaller than Golf part). Less air through turbo = less boost.
      • APH engines have Small Injectors, and 3 bar Fuel Pressure Regulator (sufficient for 150HP that’s it; maybe 160 max.)
      • Looks like Golf 1.8T is a "hardware 180 HP" motor. The NB 1.8T is a "hardware 150 HP" motor. (ie Making 180HP Golf=software change; making 180HP NB=changing above parts)
      • All AEB/ATW block are external water pump blocks, All others are internal
      • All valve covers are interchangeable (from any engine code to any engine code).
    3. 06-16-2006 11:22 PM #3
      1.8t Acronyms/Lingo
      AITAir Inlet Temperature Sensor –
      This is a small sensor located in the intake manifold just after the throttle body. It is responsible for monitoring the intake temperature. It can get coated with oil, and can affect gas mileage, and a loss of power. It is common to remove it and clean it with alcohol, or electronics cleaner.
      Boost Leak
      – View Block 032 with VAG Com. If Fuel Trims are Negative more than 5% in the load range there is a very good chance that there is a leak after the turbo. Visual inspection of clamps, hoses for a loose connection is the best way to look for leaks. A common place for leaks is at the entrance to the pancake pipe located in the passenger side fender. Also the small line on the DV can rip.
      CAI
      Cold air intake
      CTS – Coolant Temp Sensor –
      This part is prone to failure. 2002 and older vehicles had a bad coolant temp sensor from the factory that VW updated. It was a black sensor, and now the good one is referred to as a green top coolant temp sensor. Block 011 in the VAG COM can monitor coolant temp for erratic readings. This is a 7$ part. Do not change while engine is hot.
      Diode - What does the Diode Mod do?
      The MAP (manifold absolute pressure) sensor is what reads how much actual boost you are making It sends that signal to the ECU (engine control unit). Once the data that the MAP has collected has been sent to the ECU, it then compares it to the specified boost that the car is supposed to be making (this is one parameter a chip modifies among many others). If the ACTUAL boost is over the SPECIFIED boost then the ECU puts the car into LIMP MODE. This is an attempt to stop you from damaging the turbo or anything else.The DIODE(s) is connected to the correct wire(s) in the MAP sensor wiring harness. The MAP sensor sends signal to the ECU is voltage increments (so for 10PSI there is a corresponding voltage that is sent to the ECU when the MAP is reading 10 PSI).
      The MAP sends 4.7 volts to the ECU when it’s reading 17 PSI and 4.3 volts when it’s reading 11 PSI. Once the diode(s) (whichever size you chose) is connected to the correct wire(s), the MAP sensor continues to read the actual boost that the turbo is producing and sends the voltage signals to the ECU corresponding to the amount of boost its reading, UP UNTIL THE VOLTAGE THAT THE DIODE IS INTENDED FOR. (For example...if you have the 4.7v diode in the MAP will send the voltage signal to the ECU up until its sending 4.7v...once it hits 4.7 volts it will keep sending 4.7 volts instead of sending the ACTUAL voltage for the ACTUAL amount of boost the sensor is reading which would be greater then 4.7 voltages, which would ordinarily without a diode installed, send the ECU into limp mode).
      Therefore, it "tricks" the ECU into thinking it is only making 17PSI (because that is what the 4.7 volt diode clamps the MAP sensor at) instead of seeing what the turbo is actually making. Since the ECU is receiving signal from the MAP sensor showing that the turbo is only making 17 PSI (with the 4.7v diode in), which is what the specified boost is for a chipped ECU, THEN THE ECU WILL NOT PUT THE CAR INTO LIMP MODE - AKA, you can run as much boost as you want without hitting limp mode!
      -courtesy Spooled_AWP
      • Quick run down:
      • 4.3v diode will clamp at 11psi
      • 4.7v diode will clamp at 17psi
      • 5.1v diode will clamp at nothing as its over 5v
      Diode is said not to work on the 20ths
      PCV- Positive Crankcase Ventilation.
      This system redirects combustion blowby into the intake of the engine to be 'burnt off'. As an engine operates, high-pressure gases are contained within the combustion chamber and prevented from passing into the crankcase (containing the crankshaft and other parts) between the side of the piston and the cylinder bore by piston rings which seal against the cylinder. However, some amount of gas always leaks past the piston rings into the crankcase.
      DV - Diverter Valve
      A pressure release system for turbos. It's purpose is to prevent compressor surge, and reduce wear on the turbocharger and engine. Diverter Valves ventilate back into the intake before the turbocharger. Blow off valves (BOV) relieve the damaging effects of compressor "surge loading" by allowing the compressed air to vent to atmosphere
      N249 - Boost Pressure Control Valve
      This electronic valve is supposed to smooth out the Diverter Valve control at partial throttle.
      ECU - Electronic Control Unit
      The ECU is responsible for nearly all functions on the car. If the ECU is suspected as a bad part, you need to use a scan tool such as a VAG com to attempt to communicate with the ECU. If you can’t communicate with the ECU, then the ECU needs replacement. Check all electrical connections. Check your Fuses for blown fuses. Whatever killed the ECU might kill the new one.
      ECU removal procedure - http://www.goapr.com/VW/suppor...a.pdf
      IC - Intercooler
      An intercooler, or charge air cooler, is an air-to-air or air-to-liquid heat exchange device used on turbocharged and supercharged (forced induction) internal combustion engines to improve their volumetric efficiency by increasing intake air charge density through nearly isobaric (constant pressure) cooling.
      Immobilizer (ECU Swapping Info)
      Audi:
      All vehicles equipped with an immobilizer by 2002. Only exception is that some TTs in 00 had an immobilizer.
      Volkswagen:
      All vehicles equipped with an immobilizer in 2000.The immobilizers is a theft prevention measure. If you swap an ECU without matching up the ECU and the cluster, it will start briefly and then die repeatedly flashing the immobilizer light on the dash (looks like a car outline with the base a key). There are 2 kinds of immobilizer. Immo II used on pre 2002, and Immo III used on 2002+. Immobilizer and ECU info can be found on the VAG COM Site.
      Immo2
      Immo3
      If swapping an engine into a car without an immobilizer/cluster, you can get software for swaps from many chip tuners that remove the immobilizer from the ECU.
      Limp Mode
      These cars are designed to protect themselves from engine damage. If the engine boosts too much, or the engine does not get enough fuel it will go into a limp mode where boost is limited to protect the engine. It limits boost by controlling a solenoid on the wastegate line (N75), by closing the electronic throttle or by opening the DV valve. If you are experiencing a limp mode the best thing to do is get the car scanned for codes and to see what is wrong. Look at fuel trims for signs of running lean, and to look for MAF problems, or O2 sensor problems. To look for potential boost problems log Block 115 and you can see the specified Vs actual boost. If you exceed the specified then there is a good chance that you will go into this limp mode. Stock specified is a max of 14 psi for a 2002+ car.
      MAP - Manifold Absolute Pressure sensor
      is located in the OE SMIC end tank. There are two different sized MAP sensors, and VW didn't make the transition based on years but cars from all years might have either the small or large version (rumor has it the small version didn't come around till ~2003). When your upgrading your intercooler to a larger SMIC or FMIC and need to specify which MAP sensor your car is running the only fool proof way to check which sensor your car has. If you are making custom piping and need a MAP sensor flange check out 42nd Draft Design for a universal solution.
      Rule of Thumb appears to be:
      2002 and earlier cars = large MAP
      2003 and later cars = small or large MAP
      AEB vehicles do not have MAP sensors, they have BARO sensors instead.
      MAF - Mass air flow meter
      Click here to check if your MAF is bad. Mass air flow meter is used to measure the air going into the engine. It is located on the outlet of the airbox, and housed in a cylindrical tube. The ECU reads the MAF signal, and injects fuel in proportion to the airflow. There are a few different ways the MAF can fail. The MAF can get coated with oil, and will not read properly. This is common if it happens right after installing a CAI, or a K&N filter. It can be cleaned out with 99% isopropyl alcohol, or a quality electronics cleaner. Remove the sensor from the housing and clean the sensor element.
      MAF sensors also go bad due to too much airflow. On a car with a larger turbo the airflow is so high that the MAF element will get burned out from the excess air flow. It is common to increase the size of the housing to prevent this (other modifications required).
      To check for a BAD MAF the best way is with a VAG com. Block 002 show air mass from the sensor. At idle the air flow should be 2-4 grams/second. With a wide open throttle run to redline the reading should show up to 170 g/s on a chipped car. Look for jumpy readings in the MAF, which can indicate a problem. More details here http://www.ross-tech.com/vag-c....html if you suspect your MAF is bad, one way to test it is to unplug the MAF, often if the MAF is giving false readings and upsets the fueling. If you unplug it, the ECU will ignore the MAF and run off of baseline tables. Be careful, as a boost leak or a vacuum leak can be miss-diagnosed as a bad MAF, because they will throw off the readings on the MAF. (Air sneaks around the MAF).
      Quote, originally posted by WhiteG60 »
      Basically the problem with MAF's is that VW and some/all of the OEMs run the PCV back into the intake tract or you're running a K&N filter or another cotton/gauze/oil filter and a film builds up on the MAF element because of the oil from the PCV or from the filter. If you run a catch can, and run a paper or foam filter, and make sure the intake tract is dry you will most likely have a very very reliable MAF. Most MAF failures are not even failures. Its the element being dirty/oily. If people would clean them with alcohol or the CRC MAF cleaner at the FIRST SIGN of it being dirty, or hell, even if you just do it every time you change your oil or during your maintenance regiment, you'd be hard pressed to ever have to replace it.
      MBC - Manual Boost Controller
      Often people want more boost from their car, and use a MBC. While MBC’s can get you more boost they will cause a jerky part throttle driving, and can cause over boost, often put the car into a limp mode. The way a MBC works is by bleeding off air from the wastegate control line. A wastegate is a mechanical flapper valve in the turbocharger that opens to allow exhaust gas to sneak around the turbo. By bleeding off air from the line, the wastegate opens less, more exhaust goes through the turbo, and you get more boost.
      Great details on MBC here - http://www.boostvalve.com/tech/1.8T-DBW.html
      And general Turbo/Wastegate details here http://www.streetracersonline....e.php
      N75
      The N75 is an electronic solenoid valve that the ECU uses to control boost. It is located in the intake hose near the back right side of the engine. It has 3 connections.
      1. Connects to charge pipe = pressure source
      2. Connects to wastegate actuator
      3. Connects to intake hose – bleed line.
      The ecu will pulse this valve at a high frequency to bleed air off from the wastegate line. It does this based on throttle position and engine load. If the valve, or any of the liens connected to it have leaks then there can be severe boost regulation problems. It’s function is similar to the MBC above. To get more boost people often swap in different N75 valves. These different valves simply have a different response characteristic, and will act different when given the same signal by the ecu. They can get more boost, less boost, or even a big boost spike by swapping N75’s.
      TB - Throttle Body
      The throttle on most of these cars is drive by wire, it is an electronic throttle with a wire attached (only the earliest 1.8T were not drive by wire). Most common TB problem just requires adaptation, or cleaning out with carb cleaner. This procedure shows how to do a TBA. TBA can improve idle, and part throttle operation. http://www.ross-tech.com/vag-c....html. To clean the TB remove it, and spray inside with carb cleaner. Wipe out the residue that gets built up in there. NEVER port a TB on a 1.8T it won’t idle properly.
      Modified by Boostin20v at 11:39 AM 8-5-2008
    4. 06-17-2006 12:11 AM #4
      Engine Info
      Technical Data
      Large vs Small Port
      - The AEB is the only US OE large port head, see first section for what models the AEB was available in.
      Port size differences (AEB vs all other US spec engine codes):
      * Intake ports - 54x26mm vs 43x26mm
      * Exhaust Ports - 36mm vs 33mm
      Head Swapping - Large Port/AEB head on Small Port Block and the reverse
      All 20v heads are interchangeable!
      • Large port heads have no provision for the combi valve, thus you're secondary air injection pump not properly functioning and will throw a CEL. CELs can be avoided with resistors or better yet some chip tuner's code will ignore the errors and not display the CEL.
      • On engines with VVT you can swap the VVT solenoid into a non-VVT head without issue.
      • AEBs use 1 window cam trigger wheels, if your putting the AEB head on a small port post 2000 motor be sure to use the 4 window trigger wheel from the original headCam pulley must match the short block. Putting a large port AEB head on a post 2000 06A block must retain the OE cam pulley, the 058/AEB pulley will not seat the timing belt correctly.
      ECU Tuning [aka Chips, Flashes, etc]
      A chip is the most common modification for the 1.8t. Of the various companies offering chips each are going to offer a significant power increase over stock. Selecting the right chip for you can sometimes be a tough decision so you have to thing about what fits your needs.
      Most chip tuners will offer a 5 hour trial of their software, try as many as you can. If you cant try the software try to get a ride in as many different chipped cars as possible. This will help you get a feel for each chip and its power delivery.
      What chiptuners do to your ECU. courtesy of Andy Smith
      Chip Tuning Guide Where, When, How, Why
      Chips/More Chips
      APR/More APR
      GIAC/More GIAC
      Neuspeed/More Neuspeed
      Revo/More Revo
      Unitronic/More Unitronic
      Upsolute/More Upsolute
      APR/GIAC/REVO
      APR Website | GIAC Website | Neuspeed Website | REVO Website | Unitronic Website | Upsolute Website | Eurodyne Website
      How can I find out if my car is chipped?
      The easiest is to use a boost gauge or RossTech's VAG-COM to monitor the boost levels of your vehicle. If the boost is greater than OE spec the vehicle does have some type of boost modifying modification. Check for a diode mod MAP clamp, MBC or chip.
      My car has more boost than stock but no diode or MBC, how can I tell what Tuner's chip I have?
      The easiest is to contact the various chip tuners and supply them with your VIN to see if they have records of your vehicle. Another is to try the various tuner specific end user tools to switch chip tunes like APR's EMCS, REVO's SPSS and GIAC's Flashloader. If you can change the programming of your chip using one of these tools you likely have a chip tune from that particular company. If none of the above works you're unlikely to ever find out 100%.
      High Flow or No Catalytic Converter Issues
      Use of a high flow after market catalytic converter or the complete removal of the unit from your exhaust can cause the rear O2 sensor to trigger the CEL light of code P0420. This error typically means that the cat if you've got one is not working at the level the ECU expects. What can you do about it? Some tuners offer "Test Pipe" files for "Off Road use only", this programming ignores the error and does not trigger the CEL. Another means is the use of a spacer to move the rear O2 sensor further from the exhaust gas flow (Read this thread for instructions).
      *NOTE* - The OEM cat is NOT a restrictive point and can be cut and welded onto even a 3" pipe for use in any custom or purchased exhaust.
      K04 Model Numbers
      k04-001 = direct bolt on to transverse motors
      k04-015 = direct bolt on for longitudinal motors
      k04-020/022/023 = turbo from audi TT 225hp - requires TT manifold and other parts (for transverse setups)
      k04-025 = turbo from rs4 mainly used for s4 upgrade
      Official K04-001 Information Thread
      Official K04-02x Information Thread
      Old Ko4-02x thread
      K04 model Info/Fitment Guide
      Cams
      99% of the people interested have yet to reach the point of need, 99% do not have access to the needed tuning adjustments required for true gains.
      Cat Cams/More Cat Cams
      Eurospec Sport Cams/More Eurospec Sport Cams
      Schrick Cams/More Schrick Cams
      Coil Packs/Ignition Coils
      • Testing for a bad coil (without Vag-Com)
      • -With the engine running, pull the suspect bad coil's wiring harness connector off the coil or pull the coil off the spark plug. If no changes happen to the idle of the motor its a bad plug, if it does change its likely ok.
        Testing for a bad coil (with Vag-Com)
      • Log Blocks 015, and 016. This will be a misfire counter. Drive the car or let it run, and look for misfires. If you have a bad coil you will see the counter increase on a cylinder. If you have only one counting up then it’s probably a bad coil. Turn off engine and take that coil out and swap it with another coil. The cylinders read left to right 1,2,3,4 when looking at the engine from the front. Use the VAG again to see if the misfires have also swapped to another cylinder. If it moved, then you have a bad coil. Replace it. If they do not move, then you likely have a plug problem.
        Coil Info:
      • On some cars the ignition coils have problems and they will pop up out of the cylinder head and lose contact with the plug, make sure your spark plugs are torqued to 22 ft-lbs when changed.
      • All coils are interchangeable as long as they have the correct number of pins. There are two styles of coils, 3pin (Found on AEB motors, and others of that era) which require external igniter and 4pin (Found on all recent motors 2000+) where the igniter is built into the coil itself. Depending on your engine code some trimming to the coil may be needed to push the coil all the way into the valve cover.When swapping to the bolt down coils from push down coils use M6x1.00x25 or M6x1.00x30 screws
      Spark Plugs
      • OE Plugs: NGK PFR6Q - .032" gap
        For Stock Cars - .032" gap:
      • NGK BKR6E/6962
      • Autolite 3923
      • Denso Iridium IK20
        For Chiped Cars - .028" gap:
      • NGK BKR7E/4644 (formerly 6097)
      • Autolite 3922Denso Iridium IK22
      >Tightening torque 30Nm (22 ft-lb)
      >Tightening torque for Coil Packs 7ft lbs
      Upgrading Pistons/Rods
      AEB, AGU, AJQ, APP, APX, BAM, AMU, AUL, APX, AWD and APH engine codes have 20mm wrist pins, all others have 19mm wrist pins.
      AEB and AWD (all 20mm wrist pin motors??) had 16v style rods (144mm long, 20mm wrist pins). The pauter 16v rods drop right into the stock pistons for those 2 engine codes without requiring modification.
      All aftermarket pistons have 20mm wrist pins and mate to any aftermarket rod, pauter, eagle/scat, crower, manly etc etc.
      All of the later cars have 19mm wrist pins and tapered wrist pin areas so the 16v style rods dont drop in. Pauter makes a modified rod with a tapered wrist pin area and re bushes them to 19mm. They are the same price or a little more then the regular rods depending where you get them.
      For engines with 19mm wrist pins the only option to keep stock pistons is pauter tapered rods
      Oils
      FAQ: VW/Audi 502.00 and 505.01 Approved Oils
      Any 502.0 spec oil VW 502.0 Oil Chart
      FWIW the Valvoline 5w30 is not a 502 rated unless you buy the Synpower 5w30 which is 502/505 (according to the label). Also the popular GC 0w30 is not on there despite the 502 label because VW only regards a 5w30 with 502 or a 0w40 with 502 as suitable alternatives to the 5w40.
      Oil Filter Confessions...the Big Kahuna
      What is VVT?
      VCT or Variable Cam Timing. Synonymous with Variable Valve Timing. The VCT in later 1.8T's is simply for emissions purposes. It has only two states - normal and massive overlap. The overlap is used to draw exhaust gasses back into the cylinders at startup.
      DV vs BOV
      - These cars are designed for recirculated valves (ie a Diverter Valve/DV)
      - A DV with a diaphragm will have the quickest response compared to those with a piston, though diaphragms can rip/fail which requires replacement while a piston can just be relubed
      - A BOV can be used as long as it is closed at idle (not true of most)
      Injectors
      Use the size your software was designed for. If your software wasnt designed for a larger injector size then you will get no gain and even possibly cause issues as a result.
      Vac Diagrams
      AWD
      Quote, originally posted by All Data »
      1 - Vent line
      From gravity valve at fuel tank See "Fuel Tank, Removing and Installing" item no 8. See: Fuel Tank\Service and Repair
      2 - EVAP canister
      With Evaporative Emission (EVAP) canister purge regulator valve -N80-
      3 - Turbocharger
      4 - Check-valve
      For EVAP canister system
      5 - Pressure unit
      For Boost Pressure Regulation Valve
      6 - Deceleration shut-off valve
      7 - Wastegate bypass regulator valve - N75
      Valve is activated (pulsed) by the Engine Control Module (ECM)
      Checking activation: See Output Diagnostic Test Mode (DTM), activating. Refer to "On Board Diagnostic". See: Computers and Control Systems\Testing and Inspection
      8 - Brake booster
      9 - Check-valve
      For brake booster
      10 - Air filter with Mass Air Flow (MAF) sensor - G70 -
      11 - Pressure control valve for crankshaft housing ventilation
      12 - Combination valve
      For Secondary Air Injection (AIR) system
      Checking. See: Emission Control Systems\Air Injection\Testing and Inspection
      13 - Fuel pressure regulator
      14 - Check-valve
      15 - Recirculating valve for turbocharger -N249-
      16 - Secondary Air Injection (AIR) solenoid valve -N112-
      17 - Crankcase ventilation
      18 - Check-valve
      19 - Charge air pressure sensor -G31- / charge air cooler
      20 - Secondary Air Injection (AIR) pump motor - V101 - *
      Checking function. See: Emission Control Systems\Air Injection Pump\Testing and Inspection
      21 - Vacuum reservoir
      AWW/AWP
      Turbocharging System, Overview
      1 - Vent line
      From gravity valve at fuel tank.
      2 - EVAP canister
      3 - Turbocharger
      4 - Check-valve
      5 - Pressure unit
      8 - Brake booster
      9 - Check-valve
      For brake booster
      14 - Check-valve
      18 - Check-valve
      Hydro Lock Info
      Click Here
      Displacment Upgrades (2.0 20v, 20/20, etc)
      Official Displacement Increasing Thread
      Stroker Kit Info
      20v Hybrid For 9A/3A/PG/PM/ABA Engines
      20v Hybrid For AEG, AZG Block
      20v Hybrid For ALH Block
      20/20 For OE 1.8t Block (AWD/AWW/AWP/etc)
      A/C and/or P/S Delete Belt Size (transverse applications)
      No P/S and No A/C - 35"
      No A/C - 44-45.5" (OEM Belt 06A 145 933 D (1120mm/44") or NAPA/UAP belt 25-060441 for 44.75" or 25-060439 for 45.5")
      (above data works with BOTH OE pullies and ECS's lightened/underdriven pullies)
      1.8/2.0 20v OE Naturally Aspirated Info
      125hp 1.8 20v - AGN engine code, European Only VW Golf/Jetta, Audi A3
      135hp 2.0 20v - ALT/ADR engine code, European Only VW Passat, Audi A4
      features:
      Higher CR
      Modified by eggroller at 3:01 PM 8-10-2009
    5. 06-19-2006 12:53 AM #5
      Transmission Info
      Upgraded Clutchs
      If you haven't noticed most of the 1.8t drivers are upgrading their clutches after a year. The stock clutch just isn't up to the task of chipped HP and Torque. A basic upgrade is a stock VR6 clutch which is slightly larger and a lightweight flywheel. The autotech set up is very popular right now and combines thier 10lb flywheel, the starter gear, and a Sach's VR6 clutch kit. This type of set up will hold a good amount of power. Basically if you plan on a chip, and bolt on's this is what you want. Stock like driveability with some extra holding power. If you're shooting for more power then you want to look into either a stage 2 or 3 kit which will include both a beefier clutch disk and pressure pate. brake in for a new clutch is between 500-1000 miles...not highway miles either. Neuspeed also offer's clutch kit's. They have a sport and race kit, the sport features a full faced disc where the race kit has a 4 puck disc.
      02J to 02M swap
      Complete Parts List w/ Part Numbers
      Helpful Install Information
      Modified by Boostin20v at 2:26 PM 6-26-2006
    6. 06-19-2006 12:53 AM #6
      VAG OE Part Numbers
      Engine
      • Coolant Temp Sensor (CTS)
      • Early Dark Green (replaces blue CTS): 059 919 501Late "Green Top" (replaces black CTS): 059 919 501 A
      • PCV Parts
      • PCV Overview for Transverse Motors (ETKA Diagram) - PDF
      • Suction Pump: pn 058 133 753 B (image)
      • PCV Valve: pn 035 103 245 A (image)
      • PCV Hose (Y-shapped connects valve cover, lower breather port and intake): pn 06A 103 221 BH (image)
      • PCV Hose (from lower crank case vent to Y shaped hose) pn 06A 103 213 AFPressure Regulator Valve on Intake piping: 034 129 101 B (same on all motors)
      Fueling
      • Fuel Injectors
      • 06A 906 031 S (AWD, 317.46cc/min@45psi, 369cc/min@60psi)
      • 06A 906 031 AB (APH, 281.78cc/min@45psi)
      • ??? ??? ??? ?? (AMB, 281cc@45psi, 324.84cc@60psi)06A 906 031 BA (AWV/AWP, 317cc@45psi)
      • FPR
        037 133 035C (AWV, 3bar)
      • Coilpacks
      • 06B 905 115E (AWD - Bolt Down)
      • 06B 905 115R (AWW/AWP)N 101 174 03 (Allen bolt for bolt down coil, 8 per set needed)
      • OE Oil Filters
      • 06a 115 561 B (Transverse Oil Filter)068 115 561 B (Longitudinal Oil Filter, larger one specified by TSB, usable on the transverse motors)
      Oil Pan
      06A 103 601 AA (06A block hybrid oil pan)
      Gaskets
      • Head Gaskets
        European 83mm bore - 06A 103 383 AF
      • Intake Manifold Parts
      • 06B 133 555 H (Injector Seat)
      • 06A 906 149 Injector Seal O-rings (set of 4)058 129 717 D Intake Manifold Gasket
      Sensors
      • Mass AirFlow sensor (MAF)
      • 06A 906 461 A (for 2.0, but seems to work with AWD)
      • 06A 906 461 D (AWD/AWW)
      • 06A 906 461 L (AWP)Latest revision is LX
      • MAP Sensor
      • 038 906 051 Large038 906 051 B Small
      • Air Temp Sensor
      • 00-03 (including 337) 0 280 130 08503+ 06N 905 379A
      N80 Purge Valve
      0 280 142 354
      Y pipe under intake manifold (AWD?)
      058 133 753B
      Cam Chain Adjuster
      058 109 088 E (List is ~$700!)
      Diverter Valve
      06A 145 710 N (TT/NB Turbo S)
      N249 (Diverter Valve Selenoid)
      028 906 283N (NB Turbo S/???)
      4.0 bar Fuel pressure Regulator
      078 133 534 C
      Head Bolts
      06A 103 385 A (AWD, APH)
      Exhaust Manifold Gasket
      058 253 039 G
      Coilpack Replacement Harness
      1J0 971 658 L
      Transmission
      VW "High-Performance" 75W/90 Transmission Fluid
      G 005 100 A1
      02J 2nd gear grind fix ... parts off "moclov"'s invoice:
      [2] - G-005-100-A1 - oil, .5 litr
      [1] - 00076 - brake klee
      [1] - 02J-311-239-J - synchr hub
      [2] - 02J-311-247-C - synchr ring
      [1] - 02J-311-261-K - 2nd gear
      [1] - AMV-188-200-03 - seal comp
      [3] - G-005-100-A1 - oil, .5 litr
      02M 2nd gear grind fix ... parts off "genxguy"'s invoice:
      [1] - 02J-311-251-J 1st gear
      [1] - 02J-311-261-L 2nd gear
      [1] - 02J-311-239-J synchr hub
      [2] - 02J-311-247-C synchr rng
      [2] - 02J-311-277-A synch ring
      [2] - 02J-311-279 Outer ring
      [1] - 02A-311-531-K reversgear
      [2] - G-005-000 Oil-1 litr
      Modified by Boostin20v at 8:30 AM 5-1-2009
    7. 06-19-2006 12:53 AM #7
      Fuses
      Downloadable PDF
      1. Washer nozzle heaters, glove compartment light, memory seat control module (10A).
      2. Turn signal lights (10A).
      3. Fog light relay, instrument panel light dimmer switch (5A).
      4. License plate light (5A).
      5. Comfort system, cruise control, Climatronic, A/C, heated seat control modules, automatic day/night interior mirror, control module for multi-function steering wheel, control unit in steering wheel (7.5A).
      6. Central locking system (5A).
      7. Back-up lights, speedometer vehicle speed sensor (VSS) (10A).
      8. Open
      9. Anti-lock brake system (ABS) (5A).
      10. Engine control module (ECM): gasoline engine (10A); diesel engine, Model Year 2000 > (5A).
      11. Instrument cluster, shift lock solenoid (5A).
      12. Data Link Connector (DLC) power supply (7.5A).
      13. Brake tail lights (10A).
      14. Interior lights, central locking system (10A).
      15. Instrument cluster, transmission control module (TCM) (5A).
      16. A/C clutch, after-run coolant pump (10A).
      17. Open.
      18. Headlight high beam, right (10A).
      19. Headlight high beam, left (10A).
      20. Headlight low beam, right (15A).
      21. Headlight low beam, left (15A).
      22. Parking lights right, side marker right (5A).
      23. Parking lights left, side marker left (5A).
      24. Windshield and rear window washer pump, windshield wiper motor (20A).
      25. Fresh air blower, Climatronic, A/C (25A).
      26. Rear window defogger (25A).
      27. Motor for rear windshield wiper (15A).
      28. Fuel pump (FP) (15A).
      29. Engine control module (ECM) gasoline engine (15A); diesel engine (10A).
      30. Power sunroof control module (20A).
      31. Transmission control module (TCM) (20A).
      32. Injectors: gasoline engine (10A); diesel engine (15A).
      33. Headlight washer system (20A).
      34. Engine control elements (10A).
      35. 12 V power outlet (in luggage compartment) (30A).
      36. Fog lights (15A).
      37. Terminal (86S) on radio, Instrument cluster (10A).
      38. Central locking system (with power windows), luggage compartment light, remote/fuel tank door, motor to unlock rear lid (15A).
      39. Emergency flashers (15A).
      40. Dual tone horn (20A).
      41. Cigarette lighter (15A).
      42. Radio (25A).
      43. Engine control elements (10A).
      44. Heated seats (15A).
      Fuse arangements in fuse bracket/battery:
      S162. Glow plugs (coolant) (50A).
      S163. Fuel pump (FP) relay/glow plug relay (50A).
      S164. Coolant fan control (FC) control module/coolant fan (40A).
      S176. Relays panel interior (110A).
      S177. Generator (GEN) (90 Amp.) (110A).
      Generator (GEN) (120 Amp.) (150A).
      S178. ABS (hydraulic pump) (30A).
      S179. ABS (30A).
      S180. Coolant fan (30A).
      Modified by Boostin20v at 2:32 PM 11-19-2008
    8. 06-19-2006 12:53 AM #8
      DIY Info/Forum Member Created Tips and Suggestions
      Must reads for the first time 1.8t modder
      Turbo Tech - BT/High Performance and the 1.8t
      Complete Idiots Guide To Basic Modding For 1.8T
      THE Stock turbo tuning guide...your source for what it takes!
      Vacuum system issues
      How to Check for Vac Leaks
      VW Specific Tools:
      Zelenda
      Maintenance DYI Threads:
      DIY: 1.8T Coilpack and Spark Plug Change
      DIY cam positioning sensor (hall sensor)
      Cylinder Head & Camshaft Removal + Re-Installation
      DIY: How to do a Compression Test
      Coil Pack Overlay TSB Info
      Coil Pack Overlay Harness Install
      Ultimate Timing Belt DIY!
      DIY: Transverse Timing Belt, water pump, thermostat
      Information on Plastic Propeller Waterpump VS Metal Propeller Waterpump, Plus Timing Belt DIY (Video)
      Thermostat Replacement
      Alternator Swap
      Coolant Temp Sensor (CTS) Replacement
      AWP RPM Pickup (not connection at coils)
      Pressure testing your intake
      DIY- Cleaning Engine Bay
      Performance DYI Threads:
      Official ATP Eliminator Turbo Thread
      Lemmiwinks: The Guide
      Boostvalve Dual Stage MBC Install
      Clamping the Map Sensor aka "Diode Mod"
      Water/Methanol Injection: Install, Test & Tune Part 1
      Water/Methanol Injection: Install, Test & Tune Part 2
      DIY: Oil/Coolant Lines for Tubular Exhaust Manifold
      Vortexer Opinion How to Mod Guides
      DIY: Cleaning up Engine bay...Removing SAI, N249, PCV, EVAP
      The "How to get X+ to work with your BT setup" Guide!
      Solution to the rear O2 CEL (P0420)
      Product Testing:
      Official 1.8t Intake Manifold Flow Bench Test Results
      Info Threads:
      Fixing Misaligned Accessory Belt Tensioner
      PCV Airflow Design
      Diagrams for 1.8t
      OE Wideband o2 sensor wiring color codes
      *** The MKIV How-To, FAQ, and Do-It-Yourself Guide ***
      Great info on the K04 Turbo Upgrade - K04-02x Upgrade Discussion
      How To - Installing OEM rings and new rods
      FYI: ATP GT28RS H/W Kit purchasers, read this first... install tips and tricks inside
      Turbo Compressor Maps overlayed with 1.8t motor specs
      Modified by Boostin20v at 3:52 PM 3-26-2009
      Modified by SilverSLC at 9:53 PM 4-11-2010
    9. 06-30-2006 11:13 PM #10
      OBDII Code Look-up Websites
      -PlanetVAG.com
      -TroubleCodes.net
      -OBD-Codes.com
      • P0171 Fuel Trim, Bank1 System too Lean (vacuum leak, possible bad MAF)
      • P0420 Catalyst System Efficiency Below Threshold (Bank 1) (Rear 02 Sensor Reading Incorrect)P1297 Connection turbocharger - throttle valve pressure hose (Check your DV hoses)
      Modified by Boostin20v at 9:50 PM 10-31-2008
    10. 07-12-2006 09:00 AM #11
      Torque Specs
      • Intake Manifold - 7 ft/lbs
      • Valve Cover - 10 ft/lbs
      • main bearings - 65nm + 1/4 turn (stretch bolt)
      • rod bolts - 30nm + 1/4 turn (stretch bolt)
      • head bolts - (stretch bolt)
        • step 1. 40nm
        • step 2. 1/4 turn
        • step 3. 1/4 turn
      Modified by Boostin20v at 8:39 AM 6-30-2008
    11. 10-18-2006 05:28 PM #12
      BT Parts List
      • Turbocharger Specific Part Needs
      • GT Series Turbo
        • Coolant Fittings: M14x1.5mm to -6an or banjo style (for both turbo and block fittings)
        • Oil Lines: need GT Series flanges w/gaskets, each uses 2 M8x1.25mm bolts for mounting
        • Feed Line Note: Requires an inline restrictor to fit a -4an line (mount restrictor on turbo). Fitting for feed line on oil filter housing is M12x1.5mm or M10x1.0mm depending on port used.
      • T Series Turbo
        • Coolant: If not watercooled you need a M14x1.5mm plug for the block and a cap for the coolant feed Y line
        • Oil: need T Series flanges w/gaskets, each uses 2 8x1.25mm bolts for mounting
        • Feed Line Note: Requires an inline restrictor to fit a -3an line (mount restrictor on turbo). Fitting for feed line on oil filter housing is M12x1.5mm or M10x1.0mm depending on port used.
        **Note: If you using ATP or Old style PagParts exhaust manifold you can use the ATP hardware kits for oil/coolant lines.
        Required Parts
      • Exhaust manifold
      • Down pipe (if manufacturer of manifold offers a matching down pipe get it)
      • Turbo Inlet (will depend on manifold/turbo for configuration)
      • New exhaust manifold gasket
      • (4) M10x1.5mm bolts for mounting turbo to manifold (On the ATP T25 flange manifold for internal wastegate turbos the bolts are 8X1.25mm)
      • Correct chip tuning or standalone
      • Appropriate sized FPR
      • Correct Injectors
        • Good guide to sizing: (search for bobqzzi’s detail flow data for accurate calculations if needed)
        • 440cc:330whp max
        • 580cc:380whp max
        • 630cc:430whp max
        • 750cc:500whp max
      (compiled by EdsGTI)
      Modified by Boostin20v at 10:47 PM 3-24-2009
    12. Moderator vanaman's Avatar
      Aug 26th, 2003
      OhiO
      97 Jetta GLX, 99 Cabrio, 03 Sierra SLE, 97 tracker, 84 ATC200X, 78 CB750F, 66 S90
      02-07-2010 08:51 PM #13
    13. Moderator vanaman's Avatar
      Aug 26th, 2003
      OhiO
      03-02-2010 01:14 AM #14
      DIY: a complete guide to convert your chipped 1.8T to run on E85 FlexFuel ethanol (in 4 easy steps)
      http://forums.vwvortex.com/zerothread?id=4782217
      Modified by vanaman at 8:21 AM 3-2-2010
    14. n00b
      Nov 16th, 2012
      Cornwall, UK
      2001 Audi S3 8L
      02-03-2013 12:32 PM #15
      Quote Originally Posted by Boostin20v View Post
      sure?
    15. Member
      Feb 21st, 2013
      Pembroke Pines , FL
      2002 Jetta 1.8t GLS
      03-31-2013 11:20 PM #16
      Engine Info
      Technical Data
      Large vs Small Port
      Chips/More Chips
      APR/More APR
      GIAC/More GIAC
      Revo/More Revo
      APR/GIAC/REVO
      K04 Model Numbers
      Old Ko4-02x thread
      Cams
        Coil Info:
      Spark Plugs
      • NGK BKR6E/6962
      • Autolite 3923
      Oils
      What is VVT?
      DV vs BOV
      Injectors
      Vac Diagrams
      AWD
      1 - Vent line
      2 - EVAP canister
      3 - Turbocharger
      4 - Check-valve
      5 - Pressure unit
      8 - Brake booster
      9 - Check-valve
      For brake booster
      14 - Check-valve
      18 - Check-valve
      AWW/AWP
      1 - Vent line
      2 - EVAP canister
      3 - Turbocharger
      4 - Check-valve
      5 - Pressure unit
      8 - Brake booster
      9 - Check-valve
      For brake booster
      14 - Check-valve
      18 - Check-valve
      Hydro Lock Info
      Click Here
      Stroker Kit Info
      features:
      Higher CR
      diagram pictures no longer work, does anyone have them?
    16. Member velocitychris's Avatar
      Jul 16th, 2011
      Winnipeg, Manitoba
      04-11-2013 09:53 PM #17
      Quote Originally Posted by Soflanick View Post
      Would like to have someone repost diagrams, too.
      2013 S4 :: Lava Grey :: 6spd :: Sport Dif :: V710
      2001 TT - 225 Quattro coupe :: Silver/Black :: 6spd :: IE Stroker : Infinity ECU : STaSIS BBK : Defcons : Haldex Comp Controller : MadMax DV : MadMax Control Arms : turning into a Targa Rally car
      Previous 2009 A4, 2005 A4, 2004 S4
    17. Member V=D'ubber's Avatar
      Mar 16th, 2011
      Bergen
      2013 GLI
      01-03-2014 12:59 AM #18
      FAQ Listing:
      1. Engine Codes
      3. Engine Info
      4. Trasmission Info
      5. Part Numbers
      6. Fuse Numbers
      10. Torque Specs
      11. BT Parts List
      Other:
      (On the no start category u should put crank sensor or to make sure the emmo key on the cluster Isent flashing .wouldn't you say ? )
    18. Former Advertiser
      Sep 16th, 2013
      01-09-2014 11:06 AM #19
      Quote Originally Posted by V=D'ubber View Post
      Agreed, but Stu hasn't been the moderator here for YEARS
    19. Member ejg3855's Avatar
      Sep 23rd, 2004
      Rochester, NY
      1993 UrS4
      01-09-2014 11:15 AM #20
      Quote Originally Posted by Jeff@GTS Performance View Post
      And Greg should be able to edit Stu's posts. the ole id=27 days!
      CUSTOM TUNING - IMMO DEFEAT - AWD DYNO - FABRICATION - MACHINED/DESIGNED PARTS
      NOW OBD FLASHING MK6/MK7 2.0T
      BREAKOUTMOTORSPORTS
    20. Former Advertiser
      Sep 16th, 2013
      01-09-2014 11:34 AM #21
      Quote Originally Posted by ejg3855 View Post
      Id=27
      Greg CAN edit Stu's posts, but I doubt he will. This Faq has been superseded, and Greg doesn't like to censor, or modify information here.
    21. 07-12-2014 12:06 PM #22
      This is such a valuable tool!
      Just a shame that the links are (all?) broken and not working anymore.
      Maybe some have info and re-link?
    22. Member Eric16v's Avatar
      Feb 17th, 1999
      God's country
      1988 Jetta 2 dr, 1993 UrS4, 2002 jetta wagon, 2002 2.7t Allroad
      07-14-2014 02:34 PM #23
      Is there anyway to get some of the link in here updated or is there an updated thread for the FAQ?
    23. Member Dave926's Avatar
      Mar 30th, 2005
      Rhode Island
      1989 Helios GLI 1997 Mk3 ****box
      07-14-2014 07:43 PM #24
      Theres some good stuff stickied at the top
    24. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      07-15-2014 01:29 PM #25
      Quote Originally Posted by Eric16v View Post
      If you're volunteering, just copy and paste edited versions of the above faq into replies right here and I'll edit them into the original posts and give you credit for the work
      My Build
      Welcome to the world of racing! Budgets are ALWAYS exceeded, deadlines are never met, end-goals never reached, and wives always unhappy... it's all worth it though!
