Page 1 of 2 1 2 LastLast
Results 1 to 35 of 59
Thread: For FAQ: Interior Hardwiring - Gauges Radar Detectors Neons Lights Boost Pressure Ipod 12v Dimmer
  1. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    06-20-2006 10:42 PM #1
    The following post will detail how to pick up +12v, switched 12v, dimmer and Ground inside the cabin of the car without hacking into wiring and compromising the OEM fusing system. This can be used for anything that requires 12v. Gauges, radar detectors, interior lights, ipod chargers, cell phone chargers, etc. etc. etc.
    First thing, decide whether you need switched 12v or +12v (always on). Most applications will choose to go with switched 12v so your device will turn off when you turn the car off. Some people may choose the capability of operating their device with the car off, and still some may need a switch 12v and +12v source.
    First off, disconnect the negative battery cable. You will save yourself headaches trying to find blown fuses after you short circuit something, because you will short circuit something.
    To start, you need to remove the plastic panel beneath the driver side dashboard, and the plastic fusebox cover on the drivers side of the dashboard. use Gary's interior disassembly DIY's to do this.
    ( --steps 43 to 48).
    Look up under the dashboard at the fuse panel. You will see several threaded connectors here. This is where you will get your 12v sources and ground. The stud marked 75x supplies SWITCHED 12v. The studs marked 30 (either one) will supply CONSTANT 12v. You can pick up a ground on the stud marked GND in the picture, that secures the fuse box to the bracket. Use appropriate sized crimp on ring terminals )found at any local autoparts/hardware store) to fit over the studs. PLEASE PLEASE PLEASE do not just dtrip the wire and stuff it under the nut, and then tighten the nut down. This is ghetto. Ghetto is bad. Ghetto and 12v can cause fires. Also, it is EXTREMELY recommended that you fuse your 12v source, whether it be switched or constant. You can do this with a simple in-line fuse holder, again available through any auto parts or hardware store. 10 amps fuses should be fine for any gauges, radar detectors, or chargers. For lighting just divide the TOTAL wattage by 12 and then move up to the next highest amp rating (ie total of 100 watts, 100/12 = ~8, so use a 10 amp fuse). The reason for fusing here, is because these feeds are protected by the metal fuses on the battery. Not only are these fuse more difficult to find then common AGC's or ATO's, but they have much higher ratings because the are main line fuses, which means that your device can possibly be damaged before these actual fuses blow. By using an appropriate sized dedicated fuse in your 12v line, you avoid this problem.
    To tap into the dimmer circuit for gauges, etc. Remove the wiring harness from the back of the dimmer switch (you meay need to remove the headlight switch to get room to move around). The blue/gray wire is the one you want to tap into for the positive side of your lighting circuit (with most bulbs it doesn't matter which is positive and which is negative though). I personally hate the crimp-lock style connectors, and prefer a butt splice connector (one side of the dimmer circuit and the feed for you lighting go in one side, strip the other side of the dimmer circuit longer then normal, double it over, and stick it in the other side), but it's up to you what you use here. Again, hardware store, or autoparts store can help you get what you need. For the negative side of things, there is no need to tap into the brown wire. Ground is ground, and you can just use the same stud on the fuse panel, or forget about running another wire, and just tap into the ground you already ran close to the device (again, no twisted wires and electrical tape please).
    To run wires/boost tubing to the engine compartment, you can use the existing grommet/hole above the accelerator pedal. If you have a drive by cable car (early 2.0s and a handful or VR's) this will be occupied by the accelerator pedal. Don't just knock out the grommet and lose it. Push it through from one side, and the slice a small cut in the middle of the rubber. Then run your wires/tubing trough the small slit, the rubber should provide a seal around your wire/tubing. The carefully push the grommet back into the hole (make take a couple of times before you can get it seated without pushing it through). Before feeding your wires through the grommet, wrap them in electrical/chafe tape for chafe protection. The blue/white wires and black tubing go through the grommet in this picture.
    Modified by rs4-380 at 10:49 PM 6-20-2006
    Dave
  2. Banned
    Nov 24th, 2001
    06-20-2006 10:46 PM #2
    we love you Dave!!
    ...a new DIY!!!
  3. 06-20-2006 10:46 PM #3
    You never post anything that is not a contribution to you
  4. Banned
    May 6th, 2004
    06-20-2006 10:48 PM #4
  5. Member Dubsport Inc's Avatar
    Oct 12th, 2002
    Edmonton
    '61 Beetle '04 A4 '08 Silverado
    06-21-2006 08:58 AM #5
    No disrespect but dimmer is gray/blue not blue/gray.
    HTH
    Richard
  6. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    06-21-2006 09:04 AM #6
    Quote, originally posted by Dubsport Inc »
    no comment
    Dave
  7. Member dieselgti's Avatar
    Apr 24th, 2003
    Wethersfield, CT
    07 Audi A3 3.2Q S-Line
    06-21-2006 09:12 AM #7
    Nice work!
  8. 06-21-2006 09:17 AM #8
    always giving back to the community...
  9. 08-27-2006 03:31 AM #9
    is the dimmer wire voltage controlled by the dial that is used to dim the dash lights or is the one that automatically dims when you lock the car?
    thanks. useful diy btw; i like ur wiring a lot more than shoving the wires into the fuse panel solution.
  10. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    08-31-2006 10:57 AM #10
    Quote, originally posted by aslaveofaudio »
    the dimmer circuit voltage (instrument panel, switches, radio, climate control lights) is controlled by the dimmer switch. The overhead lights (which dim when locking the car) are controlled by an entirely different circuit.
    Dave
  11. Member dremhmrk2's Avatar
    Sep 19th, 2003
    Fort Lauderdale FL
    2001 Mojave GTI GLX
    08-31-2006 11:12 AM #11
    Great Thread
    "Turning right in fifth gear from the left hand lane into the wrong end of a one-way street while indicating left, if at all."
    All the custom, none of the cool.
    "Trying to be the cool kid is so cool." - MkIV Scene
  12. 09-01-2006 12:24 PM #12
    Dave, thanks for the thoroughness!
    Can I use that blue/grey dimmer wire for the illumination wire coming out of my HU (Pioneer DEH 7800MP). I assume it'll get it's grounding via the HU.
  13. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    09-01-2006 05:06 PM #13
    Quote, originally posted by 03GLXVR6Jetta »
    yep, but you should already have a dimmer wire in the stock radio wiring plug. No need to go and splice at the dimmer switch.
    Dave
  14. 09-13-2006 02:17 PM #14
    You can also tie into the dimmer wire at the ashtray - one screw and it's out, nicely located in the center of the car for just about any mod, if you use LED's, they don't put strain on the circuit, I used this location for a custom aftermarket (lighted) cupholder I mounted next to the hand brake since the afterthought in the dash should NEVER be used.
  15. 09-28-2006 09:44 PM #15
    Quote, originally posted by rs4-380 »
    whats the color of the HU Illumination cable ?
  16. Member BUJonathan's Avatar
    Mar 2nd, 2004
    Chicago, IL
    2004 VW R32
    09-28-2006 11:19 PM #16
    I thought there was no provision dimming in the MKIV DD monsoon harness?? I thought dimming along with turning off the stereo was done through the CAN line?
    One other question: When tapping into the Power Center (75x) under the dash for accessory power on an aftermarket head unit, is it neccessary to still install an inline fuse, since the stereo has 10 AMP fuse in the back??
    Consider me slightly ignorant on the "best practices" of automotive wiring.
  17. 11-02-2006 05:33 PM #17
    dumb question i know, but how do you fuse something, is there a diy on it?
  18. 11-02-2006 05:35 PM #18
    Quote, originally posted by Galacius29 »
    splice in an inline fuse on the power side, not the ground side obviously.
    http://42draftdesigns.com/electrical_fuses.htm
  19. Member redfred18T's Avatar
    May 28th, 2004
    MA
    2013 Golf R, 1991 Miata
    11-02-2006 06:25 PM #19
    that's an excellent diy, I wish I knew that like 2 years ago
    I still think I will put it to good use
  20. Member jhirsch123's Avatar
    May 6th, 2004
    2003 Jetta GLS 1.8T
    11-06-2006 08:46 PM #20
    Can someone tell me what size eye ring to use to tap into the 75X? I'm using 14 gauge wire but can't quite tell and would like to know before I take the dash apart
    Great thread
  21. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    11-13-2006 05:35 PM #21
    Quote, originally posted by jhirsch123 »
    Great thread
    I want to say you should be fine with a 3/8" (id) ring terminal.
    Dave
  22. 04-30-2007 12:32 PM #22
    good stuff
  23. Member dremhmrk2's Avatar
    Sep 19th, 2003
    Fort Lauderdale FL
    2001 Mojave GTI GLX
    04-30-2007 12:37 PM #23
    I wish I didnt use crimplocks on my dimmer wire, but I didnt see any other solution... I would love to make a splitter coming out of the dimmer, sort of like a repair wire but with 2 wires coming out so I could then route one to a fuse/distribution block. Right now I have a tree coming off my dimmer switch, for the W8 and my perfect match LEDs
  24. 04-30-2007 12:48 PM #24
    From the dead like whoa.
  25. 05-02-2007 02:09 PM #25
    I'm going to be hooking up a power inverter (175watt), at this same place as the pictures above... it has the lighter jack hook up now. I am going to be cutting the wire and adding an inline fuse (15 amp). If I need to extend my power and ground lines, beyond the inline fuse, what gauge line would I need?
  26. Member McFly.'s Avatar
    Feb 24th, 2007
    3rd gens
    05-22-2007 09:50 PM #26
    useful
    Get Low
    Illstatic
  27. 06-16-2007 07:00 PM #27
    Flawless! Thanks so much for this! I am a novice and had never installed an XM Radio (Delphi Roady XT) or anything with direct power. The directions were perfect! I successfully installed a direct-line power kit and FM Direct Modulator purchased from myradiostore.com.
    The interesting part was that when I pulled out the older Delphi Roady2, the installer had tapped the ground from the ventilation switches and tapped the power from the radio harness, using the "ghetto" wrapping-the-wire and then taping it up. I assume that method would not be recommended.
    The full removal and re-installation took me a little over 3 hours, with most of the time removing and re-installing the trim paneling.
    Thanks again!
  28. 08-09-2007 03:36 PM #28
    subscribing to hardline my passposrt 8500 X50 this weekend
  29. Member MK4WolfsburgJetta's Avatar
    Mar 17th, 2008
    321 Florida
    01 Wolfsburg Jetta
    03-18-2008 11:11 AM #29
    Is there any way to turn off the motor, but keep the gauges on untill you remove the key from the igniton? Just like a CD player. Thanks all help appreciated!
    Water/Meth Install
    2001 Wolfsburg, APR 93 Tune, k03s Turbo, High Flow Mannifold, Turbo Inlet Pipe, FMIC, Down Pipe, 3" Exhaust, Apexi Avc-R @ 20psi, Diode Modded, Water/Meth Injection - 2 nozzel, 4bar FPR, Advanced Timing, BOV, Stage 2 Clutch, Lightweight Flywheel.
  30. Member MK4WolfsburgJetta's Avatar
    Mar 17th, 2008
    321 Florida
    01 Wolfsburg Jetta
    03-18-2008 04:11 PM #30
    Found it! You can tap into your switchable 12v source on the CD player. When you turn off the key everything stays on till you take it out, and its a super clean wire job.
    Water/Meth Install
  31. Member Macks04GLI's Avatar
    Jul 20th, 2007
    Somewhere, OH
    04-03-2008 08:29 AM #31
    Do you have a pic of where you found the switchable 12v on (i'm assuming) the factory radio?
    '10 Frontier Crew Cab 4x4 - daily kid hauler
    '04 GLI - sold
    '08 Passat Wagon - traded
    '94 Corrado SLC VRT Sherry Red Widebody
    '96 D21 Hardbody, Bagged and Dropped scrapper
  32. 04-25-2008 04:46 PM #32
    i'm trying to figure out which wire to use for the amp remote turn wire. the one from the stereo i accedentlay ripped out. i'm gonna be hooking it up to a switch.
  33. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    05-01-2008 08:43 AM #33
    Quote, originally posted by BADBOYJT »
    it you are going to be hooking it up to a switch I would feed the switch with ignition switched 12v, that way if you forget to turn off the switch, the amp will still turn off when you turn off the car.
    Dave
  34. Member dubjager's Avatar
    Dec 8th, 2004
    Atlanta
    '91 964, '93 E34, '05 GTI
    05-01-2008 09:50 AM #34
    sweet, very helpful!
  35. Member gtiiiiiiii's Avatar
    Mar 6th, 2004
    Houston
    09 370z | 1986 944 Turbo
    06-19-2008 09:00 PM #35
    Quote, originally posted by Macks04GLI »
    Yeah I really would like to know this also. I'm installing a parrot blue tooth kit and need a 12v switched ignition source. I'd prefer to just splice into one rather then hooking up a terminal end.
    -Drew
    2006 Lotus Elise
    2009 370z - Stillen CAI, Fast Intention CBE / LTHs, os giken LSD, Cobb AP
    1986 944 Turbo - T4 .50 trim @ 23 psi | 2006 GTI - APR K04 sold
    2002 A4 3.0Q
