VWVortex.com - FYI - Readiness: Secondary Air & Evaporative Emissions
    Results 1 to 21 of 21
    Thread: FYI - Readiness: Secondary Air & Evaporative Emissions
    1. 07-01-2006 02:03 PM #1
      I realized as of today, my NYS inspection is up. I had a CEL for something I knowingly did, so I put things back to normal and cleared the codes. If you don't already know, your CEL's will clear when you clear the codes, but readiness tests all must be passed again in order for you to pass inspection. Normally, simply driving around for a few days will allow the ECU to re-test everything and reset readiness codes to 'passed'. However, I did not have the liberty of waiting.
      There is a procedure to pass all the tests using vag-com while sitting still, but MOST of the tests can be passed by a simple run around town.
      After driving the car about 5 miles, I checked and all readiness was passed except secondary air and evap emissions. I did some searching, and found the answer of how, with vag-com, you can easily pass these tests rather than drive for days for them to pass on their own (provided there are no problems).... so I thought I'd share my findings in a topic that would be easy for people to find if they search. This information is already out there, but it took alittle digging to find exactly what I needed - so here it is, for anyone that found themselves in my situtation:
      Passing Secondary Air Readiness:
      1. Turn car on, let idle. Vag-com -> Engine / Measuring Blocks
      2. Block 77 -> click GO
      3. Raise RPM to 2k and hold it there, and click Basic Settings
      4 Watch the channels, one of them should say Test ON, wait till it says Sys OK, or something like that. Readiness for secondary air should now be passed. Edit: Note- when you click basic settings while holding the revs, you will immediately drop back to idle, and no matter what you do with the gas pedal, nothing will happen. This, i'm assuming, is only pertaining to DBW 1.8t's like me.
      Passing Evaporative Emissions Readiness:
      1. Step one same as above
      2. Block 70 -> click GO
      3. Leave car IDLING, and click basic settings.
      4. Same as above. Once block 70 passed, repeat from step 2 using block 71.
      Once in basic settings, these tests took anywhere from 10 seconds to just under a minute to pass. Close measuring blocks / basic settings and verify in readiness that everything's cool, and you're ready to pass inspection.
      Modified by Illegal Gardener at 4:35 PM 7-1-2006
    2. 07-01-2006 02:17 PM #2
      Something I didn't know. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    3. 07-01-2006 02:55 PM #3
      adding to FAQ [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    4. 07-01-2006 03:24 PM #4
      Quote, originally posted by QuickK03Crap »
      awesome... hope it helps ya someday
      Quote, originally posted by Boostin20v »
      good stuff
    5. 07-01-2006 03:25 PM #5
      just got back from the inspection, everything went totally smooth.
      one more thing to note - you need to have NO CEL'S do do these readiness insta-tests. i remember reading that these tests will not run / run properly if you have an active CEL.
      rock on [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    6. 07-01-2006 03:38 PM #6
      great stuff guy [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      '03 4WD V6 5spd Tacoma-- gets dirty
      '09 GT Avalanche 2.0-- gets really dirty
      '03 GTI 1.8T BIG Turbo-- SOLD, some parts for sale
    7. Banned
      Apr 20th, 2006
      07-01-2006 08:47 PM #7
      useful! If your car doesn't immediatly fail the readyness code, you could pass this way.
    8. Member O2VW1.8T's Avatar
      Jul 9th, 2003
      2015 GTi 6speed
      07-01-2006 08:59 PM #8
      You dont have to leave the car idling for block 20. i believe
      02 GTi 1.8T haldex'd w/35r-SOLD 7.3@102mph 27psi on 93 octane--04 A4 1.8T converted to AWD also- SOLD--'11 JSW Tdi 6speed Manual- Gone--
      13' BMW 335i M-sport EBII
    9. Member RichB's Avatar
      Jun 7th, 2003
      Liverpool (Syracuse) NY
      2003 VW GTI 1.8T
      07-02-2006 01:35 AM #9
      Greta info, but there is one small inaccuracy in regards to NYS's VIP (OBD2) inspection program:
      2000 and up cars: Allowed to have 1 (one) readiness code not set.
      1996 to 2000 cars: Allowed to have 2 (two) readiness codes not set
      No need to force that last readiness code to be set.... especially if the test that the car runs to set that readiness flag might detect something wrong and throw a CEL.
      Of course, if your check engine light is ON you will fail, but you can pass with a soft code set in the ECU. For example, I had the somewhat common cat eff DTC set in my ECU (16804 - Catalyst System Bank 1: Efficiency Below Threshold P0420 - 35 - 10 - Intermittent as read by vag-com) set on my car (no check engine light lit) and my 03 GTI passed inspection a few weeks ago without any problem.
      Happy Motoring,
      RichB
      2003 VW GTI 1.8T 5spd (A Few Mods)
      2008 Scion xB Daily Driver (Mostly Stock)
    10. 07-02-2006 11:39 AM #10
      ya know, i saw some people mention that, but i didn't want to chance it. that's good to know [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      btw, getting on the parkway this morning, cop standing in the middle of the on ramp checking reg / inspections.
    11. Member RichB's Avatar
      Jun 7th, 2003
      2003 VW GTI 1.8T
      07-02-2006 12:04 PM #11
      Quote, originally posted by Illegal Gardener »
      Up here (I am assuming you are downstate in either Westchester or on the Island) they were doing the same thing about a month ago on the intersate entrance just down the road from me ... they were also checking for seat-belt use too.
      When I found the soft code last month and I had my inspection comming up very soon, it motivated me to do a bunch of reading/research about the NYS VIP inspection program! My info is straight from NY State gov't websites and from talking to the Tech who did my inspection (I watched the whole process - I also read through a on-line training program I found before about doing the OBDII inspection with the inspcetion computer and stuff!).
      Happy Motoring,
      RichB
    12. 07-02-2006 12:32 PM #12
      yes, that's exactly what they did down here (the island)... nice way to make money i suppose.
      good to know, as it could have saved me alittle trouble.... but hey, now everyone knows how to reset their ecu, drive around the block, vag a couple things and have 100% readiness [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      that is especially good to know for the people who have busted evap canisters and can't pass the evap readiness - i saw a wealth of threads about that.
    13. Member transient_analysis's Avatar
      Jan 28th, 2003
      San Diego
      2003 Silverstone 1.8t GTI daily, 1969 BMW 1600 project
      07-02-2006 03:23 PM #13
      good info IG..
      I'm just currious though..
      Did fixing the readiness bits change the way your car behaves??
      Does it idle better? Run stronger? make girls remove clothing?
      stock turbo 1.8t.. damn 2-year CA smog.. :/
    14. 07-02-2006 08:14 PM #14
      my girlfriend hates my car. however good or bad it runs makes no difference on how much clothes she takes off.
      these readiness codes make 1,000,000% no difference on how your car runs, only how well it can pass emissions
    15. Member
      Sep 15th, 2005
      Silver Spring, MD
      '02JETTA (SOLD) '00TTQ (SOLD) '90 C2 964
      07-25-2006 11:54 AM #15
      Quote, originally posted by transient_analysis »
      doesn't every 1.8T "BT or not" do that?
    16. 10-19-2008 05:12 PM #16
      i put my secondary air pump and everything back in my car and have the fallowing codes... p1118, p0238, p0106... is it possible to clear these codes somehow? they all seam to be electrical...
    17. Member
      Dec 28th, 2000
      DFW, TX
      2001 GTI GLS 1.8T
      10-24-2008 11:47 AM #17
      I had this problem after clearing codes, and all of them came back after driving home from the inspection place except secondary air. When I tried to access Block 77, it can't connect. I'm not sure how to proceed from there.
    18. 01-03-2012 06:08 PM #18
      Up from the dead, but has anyone run into a situation where the test for these two systems just won't run? My tests for this just sit forever. At one point, it said "'abort", but usually it just says "test on" and doesn't budge. No codes, and output tests are all positive.
      '11 Routan SE (black), '01 Jetta GLX VR6 5spd (silver)
      FE ///Motorsports VCDS Hex-Can, if you need help.
    19. Member jhirsch123's Avatar
      May 6th, 2004
      NJ
      2003 Jetta GLS 1.8T
      01-11-2012 12:23 PM #19
      I have the same error with my Vag-Com. "Abort"... I just found this thread searching for the solution so it's good to see someone else had this problem recently.
      It seemed to happen right after I upgraded to version 11 from 10.6 or so... I've written Ross-Tech and we'll see what they say. In the meantime, I'm going to try to do it manually like you have written here... I'll post what I hear from Ross Tech.
    20. Junior Member dubwithdrawals's Avatar
      Oct 6th, 2008
      livingston, ny
      99 mk4 jetta 2.slow
      12-17-2014 08:49 AM #20
      couple errors here. 1 the secondary air and evap are done at idle when setting with scanner. 2 cars that are 2000 MY are still allowed 2 monitors not to be set, 2001 and up are only allowed one to not be ready
      99 mk4 jetta 2.0 5sp lookin to trade or sell has 200k on the clock my dd runs great no rust no sunroof
    21. 10-23-2015 08:32 AM #21
      Quote Originally Posted by Illegal Gardener View Post
      Sorry for the topic bump ,
      My car is BFQ 1.6L 8v ...
      When I look readiness , only secondary air injection "failed or incomplete" I did this procudere that you describing but always "Test off" ! it is not skip to "Test On" ...What Am I do ?
      btw :Sorry for my English ...
