VWVortex.com - '86 Jetta Dash Light
    Results 1 to 18 of 18
    Thread: '86 Jetta Dash Light
    1. Member CaptainDestructo's Avatar
      Jun 27th, 2006
      Portland, OR
      2013 Jetta S
      07-26-2006 02:23 PM #1
      The dash light on my '86 Jetta is out. The clock light works, and when I adjust the brightness it works on the clock. All the fuses are fine. I am pretty sure it's just the bulb.
      I don't want to mess up the enitre dash trying to get to it. What's the easiest way to change the bulb? I'll take another look at it this evening and see if I can figure it out, but if anyone knows, that'd be great.
    2. 07-26-2006 02:27 PM #2
      you have to take the eight screws from your bezel out( 1 behind your headlight switch,1 behind the the middle lower blank, 3 behind the heater control, and 1 if its still there where your radio is then two that go up where your cluster is) then just the two screws that hold the cluster in
      Modified by A2HeliosGLI16v at 10:30 AM 7-26-2006
    3. Member CaptainDestructo's Avatar
      Jun 27th, 2006
      Portland, OR
      2013 Jetta S
      07-27-2006 12:40 AM #3
      Ok, so I got that part off, and I was able to get the whole thing loose (with the odometer and stuff), do you know how I would go about finding the bulb and replacing it? I couldn't seem to figure it out. Thanks for your help.
    4. Geriatric Member VegasJetta's Avatar
      Jan 26th, 2003
      SoPo, Maine
      01 XJ 4.0, 13 TCH, 87 Honda TRX250, 82 Honda UrbEx, 85 Honda ATC70, 91 Yamaha YSR50
      07-27-2006 01:09 AM #4
      there are 2 bulbs on the back, on the top, in the white part of the cluster. you cant see them in this picture, but they are right on the other side of the cluster on the top.
      Quote Originally Posted by JacksSenseOfRejection
      Here's a fun fact: if someone is hitting you with a metal pipe, stay down.
    5. Banned knappy's Avatar
      Apr 6th, 2005
      07-27-2006 01:13 AM #5
      ^ I need that cluster.
    6. Member 8V Fury's Avatar
      Jul 26th, 2003
      Sacramento, California
      1994 vw golf sport, 1990 vw jetta coupe
      07-27-2006 01:27 AM #6
      I went with this
      during the day:
      night selection 1:
      Quote Originally Posted by Ron@RMAMotorsport View Post
      real deal<p>After spending two months in the mk3 forum it drove into the woods and set fire to itself.
    7. Member CaptainDestructo's Avatar
      Jun 27th, 2006
      Portland, OR
      2013 Jetta S
      07-27-2006 02:11 AM #7
      Awesome. I will look at it tommorrow. I really appreciate your help, and I will let you know if I have any problems.
    8. Member CaptainDestructo's Avatar
      Jun 27th, 2006
      Portland, OR
      2013 Jetta S
      07-27-2006 09:25 PM #8
      Ok, so I got the cluster out, and took the bulbs out. I went to my local napa auto parts, but wasn't really hoping for much. They didn't have any. Where can I get these lights?
      On the base of the bulb, it says "Osram" with "12/1.2" underneath that. I googled it, and came up with this:
      http://www.topbulb.com/find/Pr...45572
      Is this the same bulb? It looks like it, but the picture is really small.
    9. Member Cyrus #1's Avatar
      Sep 29th, 2005
      Edmonton, AB
      2000 Jetta TDI, 1990 Jetta 8v
      07-27-2006 09:27 PM #9
      That appears to be the correct bulb from the tiny picture.
    10. Member CaptainDestructo's Avatar
      Jun 27th, 2006
      Portland, OR
      2013 Jetta S
      07-27-2006 09:36 PM #10
      It's only $3 each, so I will go ahead and purchase two. Thank you again for your help, I really appreciate it.
    11. Member Bigdonny's Avatar
      Jan 26th, 2006
      Oshawa, ON Canada
      1997 Golf GL 4 door 2.slow Auto
      07-27-2006 10:38 PM #11
      You can get those bulbs from the stealership as well.
    12. Member CaptainDestructo's Avatar
      Jun 27th, 2006
      Portland, OR
      2013 Jetta S
      07-27-2006 11:07 PM #12
      I just ordered two off that one site, total incl. shipping came to about $13. But thanks for the advice.
    13. Member evilrobot0's Avatar
      May 15th, 2004
      Groton, CT
      1990 Jetta GLI 16V, 1992 Jetta GL ABA (In progress)
      07-28-2006 12:48 AM #13
      ordered 12 of them from my dealership last year. $1.75 a piece. Oh, and there are 3 of them in the cluster, you should put 3 fresh in wile you have it out, otherwise your clock may burn out right after you put it all back together. (had it happen before, now if i see a MK2 with even 1 cluster bulb out i replace all 3)
      /Bill
    14. 07-28-2006 01:07 AM #14
      I have the same problem... I changed the 2 lights at the top and they still dont work.. all fuses good... I may have to go to the white face guages any of you gurus have any ideas /
    15. Member MK2SnowPilot's Avatar
      Sep 8th, 2005
      Keswick, Ontario
      99 Golf Wolfsberg Edition (to be parted out soon), 2 X MK6 Jetta 2.Slo
      07-28-2006 02:23 AM #15
      OMG did you make that yourself? Where did you get it 'cause I'm in love!
      Quote, originally posted by 8V Fury &raquo;
      I went with this
      during the day:
      night selection 1:
    16. Member GutlessLump's Avatar
      May 19th, 2006
      Shasta County
      07-28-2006 02:27 AM #16
      Quote, originally posted by LewsCabbyTherin &raquo;
      i got em on eeeeeeeeeeeeeeeebaaaaaaaaaaaaaaaaaaayyyyyyyyyyyyy
      im even bored and found them for you and they have a super pimp carbon fiber bezel thingu
      http://cgi.ebay.com/ebaymotors...wItem
      i have a set, personally, i ****ing hate them
      Modified by GutlessLump at 10:33 PM 7-27-2006
    17. Member MK2SnowPilot's Avatar
      Sep 8th, 2005
      Keswick, Ontario
      07-28-2006 02:54 AM #17
      Cool - now I just need the canadian version....
      KmPH works better up here... Damn backwards american system!
    18. Member 8V Fury's Avatar
      Jul 26th, 2003
      07-28-2006 11:28 PM #18
      I have had many people give me props and also people think they are stock.
