VWVortex.com - 2000 VW VR6 Jetta CEL - Code P1116
    Results 1 to 3 of 3
    Thread: 2000 VW VR6 Jetta CEL - Code P1116
    1. 08-01-2006 11:03 PM #1
      Hey all,
      Having an issue with my girlfriends Jetta. Its throwing code P1116 on a standard ODB-II reader. Obviously not a VAG reader and I was wondering if there is a common occurance with that code. I've read on these forums that occasionaly a standard reader will give you a false code.
      Should I just take it to the dealer and pay the money to get the real code read? I found one good hit on this forum:
      http://forums.vwvortex.com/zer...69581
      She is having the same issues with fuel consumption as noted there. Guess my question would be for your dub guys, should I go ahead and erplace the front O2, and if so, where would you suggest I pick one up at for the best price?
      Thanks
      Joshua
    2. Member PhReE's Avatar
      Sep 16th, 2004
      Taylorsville, UT
      2004 Turbo VR6
      08-02-2006 01:16 AM #2
      See here
      http://www.bentleypublishers.c...e.htm
      P1116
      O2 Sensor Heater Circ.,Bank1-Sensor1 Open
      Sounds like you need a new front 02. You have a 12v tho not a 24v, and I dont know if they use the same front O2 sensor but if they do its gonna be pretty expensive. I think the front 02 for a 24v is like $300-400 for the part. I am not sure if the 12v uses the same one though -- but since its a MkIV it is a wideband soooo I am guessing it is the same (or very similar sensor).
      Was that the only code?
      -James
      04 GTI Silverstone 24vT :: GT35r - TT 264/260 - Unitronic 630cc - Bosch 044 - Area51 SRI - Full 3" TB :: More in progress
      >> http://zingledot.myminicity.com/ | http://sourceforge.net/projects/imagizer2 <<
    3. 08-02-2006 06:24 PM #3
      Hey - thanks for the reply. I didn't realize it was in the wrong forum, thanks for the heads up.
      That was the only code.
      Whats the best place to look for a front o2?
