VWVortex.com - What is the diference between and automatic and manual crank.
    Results 1 to 14 of 14
    Thread: What is the diference between and automatic and manual crank.
    1. 08-10-2006 05:17 PM #1
      What is the diference between an automatic and manual crank. Ive found that the audi auto is different than a manual. Can anyone tell me what the difference is and if vw had the same difference in the golfs?
      thanks.
      Modified by JSPORT-SCR32 at 2:19 PM 8-10-2006
      Modified by JSPORT-SCR32 at 5:34 PM 8-10-2006
    2. Member WhiteG60's Avatar
      Aug 19th, 2001
      Gilbertsville, PA
      1980 VW Scirocco, 2004 Audi A6 S-Line 2.7T
      08-10-2006 08:28 PM #2
      In a golf, they are identicle. no differences.
    3. 08-10-2006 08:35 PM #3
      what about an audi..... what is the difference
    4. Member WhiteG60's Avatar
      Aug 19th, 2001
      Gilbertsville, PA
      08-10-2006 08:37 PM #4
      the snouts are different on at LEAST the AEB motors,not sure about the rest of the longitudinal motors.
      Sep 24th, 2003
      Rhode Island
      08-10-2006 10:02 PM #5
      Quote, originally posted by WhiteG60 »
      Not the snouts, the flywheel end is different. The Auto cranks aren't machined for throw out bearings, and don;t have as pronounced a register sticking out (so as to clear the converter)
      What this means-
      Any crank manual or auto crank will work in a transverse VW (assuming they came in the same style block, 058 or 06A)
      You can use an auto crank in a manual transmission Audi IF you make an adapter to hold the throw out bearing.
      You cannot use a manual crank in and auto UNLESS you machine down register to clear the converter.
      Performance and replacement parts, engine building www.qedpower.com
      bobqzzi@cox.net
    6. 08-11-2006 12:36 AM #6
      added link to this thread in the FAQ [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    7. Member 1.8TRabbit's Avatar
      Nov 15th, 2004
      Garage in the Rockies
      82 Rabbit 1.8L, 84 Rabbit GTI 20vBT, 86 Audi 4000Q, 96 Audi A4Q V6, 02 Audi A4 1.8T,06 BMW 325I
      11-11-2006 03:41 PM #7
      Quote, originally posted by bobqzzi »
      What this means-
      Little out dated thread but you can use the auto bottom end Vw Motors with a manual tranny setup.
      Dwight D. Eisenhower: “If you want total security, go to prison. There you’re fed, clothed, given medical care and so on. The only thing lacking… is freedom.”
    8. Banned
      Apr 20th, 2006
      11-11-2006 03:55 PM #8
      Thats what he said
      Except auto crank will not work with an audi (longitudal) transmission without an adapter.
    9. Member 1.8TRabbit's Avatar
      Nov 15th, 2004
      11-11-2006 11:37 PM #9
      Quote, originally posted by 801pete »
    10. 11-11-2006 11:42 PM #10
      Just wondering boostin 20v how do you people become moderators?
      this is a serious question. no i am not making any stab at you in any way, and no i am not asking this because i would like to be a moderator, which im thinking is a title given to someone due to their amount of posts.
    11. 05-04-2007 09:37 AM #11
      can you use a crank from a auto (passat) with a vw manual trans?
    12. Member demonmk2's Avatar
      Mar 18th, 2006
      Charlotte
      KITT 2000
      01-29-2012 06:48 PM #12
      just throwing this out there, on the audi AEB's if you have an auto crank you can drill out the center sleeve thats pressed in and us a v6 maual pilot bearing and it will work!
      Any VWs made after 92 are usually only good for drive train donors.
    13. 01-30-2012 12:05 AM #13
      You must be atleast a level 20 necromancer to be able to reserect this thread from the dead!!
      Canadian Immo 2 and 3 defeat service, PM for more information.
      Vag-Com Scanning available in London area, Hex+Can.
    14. Member demonmk2's Avatar
      Mar 18th, 2006
      Charlotte
      KITT 2000
      02-08-2012 06:06 PM #14
      I am
