Page 1 of 70 1 2 3 4 5 11 51 ... LastLast
Results 1 to 35 of 2416
Thread: SHOW ME your custom VRT set-ups
  1. 08-15-2006 03:02 PM #1
    please if you have the time, show me some custom VRT options for the 12V, please list all parts included in the set-up. And also please explain your overall experience as what kind of WHP you have gained.
    Im looking to make around 350 WHP with my 12V VR6
  2. 08-15-2006 04:27 PM #2
    Ditto on that, 350 would be ideal. Seen a sweet setup by a guy who went to C2, but he's going nuts with the HP.
  3. 08-15-2006 05:29 PM #3
    forced induction forum FTW.
  4. Member bdfeenie's Avatar
    Jan 26th, 2004
    PA
    '92 Cabby
    08-15-2006 08:40 PM #4
    Check my archived post in FI forum
  5. 08-15-2006 10:09 PM #5
    I guess I'll whore it out first (I have ever since I went FI )
    The rundown:
    Garrett T04E 60-1 .70/.58 water-cooled housing
    ATP exhaust manifold
    C2 Stg II software w/ 4" MAF housing
    42lb (440cc) Bosch injectors
    MSD 8224 Coilpacks and 8.5mm wires
    EIP 9:1 headgasket spacer
    C2 Quickflow intake manifold
    Turbosmart Sleeper Series BOV
    TiAL 38mm Wastegate
    SPEC Stg 3 6 puck clutch
    Peloquin LSD
    3" ATP Downpipe
    3" turbo back w/out cat
    Dr Gas oval pipe tip
    Walrbo 255lph inline fuel pump
    Treadstone Bar & Plate intercooler
    ARP Head Studs and rod bolts
    VDO boost gauge and 42DD A-piller pod
    Cost was rougly $8,000 and some change for everything.
    It put down 367whp/370tq @ 18psi on a ridiculously hot day here in AR where, I'm sure, the ECU was pulling all the timing it could and it turns out I had a small boost leak on a charge pipe, too (didn't find out until the next day when it blew off, lol)
    Old nasty downpipe
    My next step after some VF engine mounts is the Snow Performance water/methanol injection to get the timing pull back to 0*. I've been running it on 15psi every day but I barely ever get into above 5psi. It's just balls-ridiculous how fast 15psi is on the street. A 4th gear pull on the highway is much tamer than a 2nd gear pull on the streets but the power is consistent all the way to redline. I'm currently looking for a large turbine housing because the .58 spools way too fast and I wanna save the tranny until I can put some cryo'd gears in sometime next year.
    Modified by FMF at 7:15 AM 1-21-2007
    Modified by FMF at 7:16 AM 1-21-2007
    My Black Box | Kenwood X792 | Soundstream STL1.600D & 2.560 | CDT CL61a | RE SRX15 | Streetwires | TechFlex | PowerWerx
  6. 08-16-2006 11:13 AM #7
    nice setups
  7. 08-16-2006 11:52 AM #8
    Quote, originally posted by Balrok »
    My parts list and pics are listed in my sig. I've since stepped up to 630cc injectors and Snow Performance Water/Alcohol Injection. I'm currently only running distilled water and it has helped control the engine from knocking. I usually run anywhere between 12 psi - 20 psi on the street but have pushed 27 psi (by accident)
    I would like to get the car back on the dyno and see what numbers can be produced with the WAI setup.
    Modified by tekstepvr6 at 11:58 AM 8-16-2006
  8. Member Soupuh's Avatar
    Apr 28th, 2005
    Canton, OH
    94 Civic Coupe, 97 Civic Sedan, 01 VRT Jetta, 69 MGB roadster
    08-16-2006 03:43 PM #9
    Quote, originally posted by tekstepvr6 »
    I would like this as well.
    Hondas for DAYS...
  9. 08-17-2006 01:10 AM #10
    bump. please show more. do all of the custom set ups have to eliminate the engine covers? i love the way they look!
  10. 08-17-2006 08:21 AM #11
    No...you can keep the cover
    Here is my old 16psi kit .
    with custom plenum
  11. 08-17-2006 10:01 AM #12
    ^^^^^what kind of manifold is that??? looks cool
  12. 08-17-2006 10:09 AM #13
    Everything is home made .
  13. Member High Body slc's Avatar
    Aug 23rd, 2004
    North East CT
    b4 Passat tdi/glx wagon, 07 forester. 90 protege 4wd
    08-17-2006 06:45 PM #14
    T4 60-1,
    3inch stainless to borla 3inch in 3inch out and 3 1/2 inch tip,
    racecraft intake mani,
    #42 injectors,
    4 inch maf housing,
    c2 chip,
    dsr 256 cams,
    kenetics intercooler,
    peloquin lsd + rebuilt tranny,
    greddy type rs bov with recirculation kit,
    areomotive fpr,
    custom pipes + heat shield..
    Modified by High Body slc at 8:33 PM 8-17-2006
  14. 08-17-2006 08:01 PM #15
    Here is my wip..
    Garrett GT3540R .82 A/R
    Kinetic Turbo Manifold
    20 Squared Tuning 3" downpipe
    3" Cat back to TT dual borla system. (soon to be updated to full 3" back)
    Custom wastegate reroute
    30# injectors, C2 30# software.
    Schimmel SRI
    7.5PSI non-intercooled. (Intercooler awaits in my living room.)
    Runs like a raped ape, very stable too.. Looking forward to higher boost pressures. I'm guestimating 220-230hp to the wheels right now, it's how the VR6 should have felt in stock form.
    Yes, I'm running a Kinetic manifold with a 4" intake and I still have my A/C system in the car. It's tight.. literally.
    Modified by xanthus at 5:09 PM 8-17-2006
  15. Member mocas's Avatar
    Aug 31st, 2005
    Mississauga
    04 GLI 24V
    09-26-2006 09:08 AM #16
    Nice setups. Xanthus really like how your setup looks nice and clean
  16. Member Soupuh's Avatar
    Apr 28th, 2005
    Canton, OH
    09-26-2006 10:12 AM #17
    fyi i made 220 whp at 4.5 psi, unintercooled, stock exhaust on a t3/4, so i bet you're making a lot more than that on that turbo
    Hondas for DAYS...
  17. Member mocas's Avatar
    Aug 31st, 2005
    Mississauga
    04 GLI 24V
    09-26-2006 12:11 PM #18
    holly crap 220whp with only 4.5 psi thats impressive.
  18. Member hiatussk8rs's Avatar
    Jul 29th, 2003
    Los Angeles
    VF STAGE 2 2003 GTI VR6
    09-26-2006 12:50 PM #19
    nice set ups cant wait till mine is done
    VF Stage 2 24v VR6 ------ Big Turbo .:R32 Swap in the making
  19. 09-26-2006 03:34 PM #20
    Built by Sleepers Performance in Hamden, CT. Tuned by Jeff Atwood.
  20. 09-26-2006 08:22 PM #21
    I like this thread.
    Nice ride Marc.
  21. 09-26-2006 08:25 PM #22
    I was inspired by your setup,
  22. Member mocas's Avatar
    Aug 31st, 2005
    Mississauga
    04 GLI 24V
    09-27-2006 10:02 AM #23
    Hey herbehop your setup looks sweet what kinds of coilpack is that? Looks like the buick grand national coil pack.
  23. 09-27-2006 10:58 AM #24
    was gonna make a thread like this but dont have to now lets see some more engine bay pics.
  24. 09-27-2006 12:44 PM #25
    I wish mine had that much bling. Do you have any track/dyno #'s from it. What does your system consist of?
  25. 09-27-2006 01:01 PM #26
    Quote, originally posted by mocas »
    It is, its the Accel one.
    Quote, originally posted by AlwaysInBoost »
    no #s yet since it just got finished last thrusday.
    Main stuff...
    T4 60-1 P-trim ,non hifi, .81 a/r
    Tial 38mm WG
    ATM Manifold
    C2 Shortrunner
    Schimmel A/W Setup with a few modifications. (Hobbs switch and constant on switch, I can choose which to use from in the car)
    C2 8.5:1 headspacer
    630cc injectors
    Jeff Atwood Tune.
    Full 3" Exhaust
    thats the meat of it. bunch of other stuff too.
    Modified by herbehop at 1:38 PM 9-27-2006
  26. 09-27-2006 01:16 PM #27
    So all you guys running the C2 software have to route the bov back in ????
    Thanks
  27. 09-27-2006 01:26 PM #28
    Quote, originally posted by mk1vr6 »
    Thanks
    That is correct. You still hear it though.
    If you release metered air on a Maf equipped car its always going to do weird stuff, C2 sofware or anything else.
  28. 09-27-2006 01:32 PM #29
    Not worried about the sound but thanks
  29. 09-27-2006 01:37 PM #30
    like he said the unmetered air that is let out will cause the car to have "Rich" spikes.
  30. Member MKippen's Avatar
    Nov 6th, 2000
    Seattle, Wa, USA
    2010 CC
    09-27-2006 01:39 PM #31
  31. 09-27-2006 01:44 PM #32
    Quote, originally posted by EternalXresT »
    I know the purpose but didn't know if C2 required it.
    Thanks
  32. Member dreadlocks's Avatar
    May 24th, 2006
    Denver, CO
    0xMK6.MK4.T2
    09-27-2006 01:56 PM #33
    video: http://www.youtube.com/watch?v=G5S3H6euCUs
    or my sig for details
    Diesel - 2013 Golf 4DR TDI w/6MT & Tech Package
    GolfKart - 2001 GTI 3.0L 12v VR6 Turbo w/6MT
    Shagwagen - 1975 BayWindow 2.0L Fuel Injected Westfallia w/4MT
  33. 09-27-2006 03:35 PM #34
  34. Member bdfeenie's Avatar
    Jan 26th, 2004
    PA
    '92 Cabby
    09-27-2006 11:07 PM #35
    The C2 still runs ok with an open BOV, as long as you unplug the upper O2. Doesn't necessarily purr like a kitten, but is tolerable. Re-routable is definitely the best option.
    http://forums.vwvortex.com/zerothread?id=2704019
