VWVortex.com - How much should it cost to replace oxygen sensor?
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 29
    Thread: How much should it cost to replace oxygen sensor?
    1. 08-21-2006 02:38 PM #1
      About a month ago I took my 2001 GTI to the dealer for the egg smell and check engine light. $430 later they said a spark plug wire had been arching and needed repair.
      Over the weekend, got the check engine light and the egg smell again. Took it in this morning. While they are not charging me for the diagnostics, they are charging me $190 to repair a DIFFERENT spark plug wire and $505 to replace the O2 sensor!
      First, how could they not check all of the other spark plug wires a month ago? Second, does it make sense that the 02 sensor being bad would cause the problems. From what I've read here, it could be the cat converter?
      Advice greately appreciated.
    2. 08-21-2006 02:39 PM #2
      1.8T? depends on the 02 sensor.
      if it's got tits or tires, it's going to give you problems.
      w140 s500 | e46 M3 slicktop | w211 e500 estate
    3. 08-21-2006 02:48 PM #3
      2001 GTI GLX.
    4. 08-21-2006 02:50 PM #4
      Oh, and the car has approximately 55,000 miles. Mostly city driving.
    5. Former Advertiser
      Mar 31st, 2005
      08-21-2006 02:57 PM #5
      so vr6?
    6. Former Advertiser
      Mar 31st, 2005
      08-21-2006 02:58 PM #6
      they also would have replaced all the spark plug wires as i dont think you can buy them in singles...
    7. 08-21-2006 03:00 PM #7
      Interesting. The service guy told me that since each spark plus is singular they each have their own wire. Last time, it was spark plug 4 that had a bad wire and this time it is spark plug 3. I just wonder why they would not have checked all of them when they were under the hood the last time.
    8. Member GLIDrummer's Avatar
      Mar 14th, 2006
      LI, NY
      2015 Golf R
      08-21-2006 03:00 PM #8
      I've also heard that the rotten egg smell is usually related to the cat being bad... $505 sounds like a bit much for an 02 sensor... 55k, no warranty?
    9. 08-21-2006 03:01 PM #9
      good lord dude... 02 sensors are 50 bucks each and a set of plug wires run anywhere from 40-120$.
    10. 08-21-2006 03:02 PM #10
      how long do you think it would take to replace?
    11. 08-21-2006 03:02 PM #11
      and the sulfur smell you smell means the car is running too rich. Could be from a bad sensor telling the car to burn mor gas than air but it could also mean a dead cat.
      Dead cat's are under GOVERNMENT WARRANTY up till 80k.
    12. 08-21-2006 03:03 PM #12
      sadly, i did not purchase an extended warranty. my warranty was for 2 years or 24k miles
    13. 08-21-2006 03:03 PM #13
      replacing an 02 sensor is pretty much unscrewing a sparkplug-ish connection with an open eneded wrench and unplugging a wire harness connection and then replacing in reverse.
      I did it myself on my 2000 VR in under 15 minutes.
      Go to http://www.ecstuning.com for new o2 sensors for cheap.
    14. 08-21-2006 03:08 PM #14
      Yes, sorry, it is a VR6
    15. 08-21-2006 03:37 PM #15
      your getting raped. cant you get under the hood and check the wires?
    16. 08-21-2006 04:01 PM #16
      sadly, i am completely car ignorant. i know enough to feel that i am getting taken for a ride, but not enough to explain to the service guy.
    17. 08-21-2006 04:03 PM #17
      1. buy 02 sensors
      2. go to dealer
      3. tell him to install the sensor at .5 hours of labor
      4. pay bill
      5. kick him in the nuts
    18. 08-21-2006 04:22 PM #18
      i second step 5
    19. 08-21-2006 04:42 PM #19
      VW just called and said the part was $220.80 and that labor was $270something. They said they have to take off the whole exhaust to replace the part?
      I looked at the DIY section on this form and it did not look like the whole exhaust came off?
      Help?!
    20. Banned
      Nov 24th, 2001
      08-21-2006 04:59 PM #20
      the bottom line, is that we can only do some much to help you from here, the Internet.
      the DIY's are usually written very well, and are easy to understand from a "shade-tree" mechanics point of view.
      if you are still at a loss, then maybe you need to suck it up and pay someone else to do the work...whether it be the Dealer or a trusted VW Independent.....knowledge and ability DOES have a worth; and that is how these people make their living/lively-hood.
      don't knock them for YOUR inadequacies.
    21. 08-21-2006 05:02 PM #21
      Quote, originally posted by djlray17 »
      Help?!
      Yeah, what larry said BUT, just know they are bending you over backwards. 220 for an 02 sensor is ****ing crazy crazy overpriced.
    22. 08-21-2006 05:06 PM #22
      You are being taken to the cleaners. Can you find another local VW service place? You don't necessarily have to go to the dealership. There must be plenty of VW mechanics around your area. Look in the phone book.
    23. 08-21-2006 05:09 PM #23
      larry, i didn't realize i was knocking them - just trying to gain insight and turned to the most knowledgable group i could think of regarding VWs on the internet.
      i am sucking it up and paying someone else for my inadequacies, but thank you for shining your enlightenment upon me and making me realize i'm nothing more than a complaining baby. because of your fund of wisdom, i've learned that i should always trust those that we pay for service because this is how they make their living.
    24. Banned
      Nov 24th, 2001
      08-21-2006 05:13 PM #24
      I am not trying to enlighten anyone...it's just that I am tired of seeing threads where others bash those that make their living working on cars....including but not limited dealer techs....there are good and bad everywhere, and if you are not willing to ask a question, then you will never learn.
      your questions are very valid, but not necessarily well thought out. I am not knocking you here either. Sometimes it's easier to just ask, then to go and research, then ask an informed question.
      my hope is that I have enticed you into taking some time to learn for yourself, rather than let someone just blurt out an answer with no knowledge behind it.
    25. 08-21-2006 05:45 PM #25
      thanks, larry. i did try to engage the tech in a conversation and asked what i thought were appropriate questions. i do respect my mechanics and do understand that this is their living. i was feeling frustrated because it would seem to me that they would have checked all of the other spark plug wires when they were under there last month. when the tech responded to me with, "well, you need to understand that each spark plug is a separate unit with a separate wire. we don't check each wire when only one fails." hearing that just made me feel a little dumb because from my perspective it seems so obvious.
      it is also frustrating to me when i read that many people here commong experiences, which lead me to believe it may be the cat convertor beginning to blow and the VW tech says, "oh no. it can't be that." again, i freely admit that it is my own ignorance that leads me to this place!
