VWVortex.com - CEL: P0768 Shift Solenoid "D" Electrical
    Results 1 to 11 of 11
    Thread: CEL: P0768 Shift Solenoid "D" Electrical
    1. 08-21-2006 03:40 PM #1
      Does anyone know what and were exactly this part is? Thanks in advance!
    2. Banned
      Nov 24th, 2001
      08-21-2006 03:43 PM #2
      that sounds to be in the shift selector...that or it's a bad break light swtich...generic codes are too vague.....do your brake lights work?
      also, have you SEARCHED on that code?
    3. 08-21-2006 04:05 PM #3
      Yup. I've Googled it and searched here but all I get is a list of other DTC. My brake lights still work. Any other input would be appreciated. Thanks in advance!
    4. 08-26-2006 10:50 PM #4
      I just had a similar problem. The connection for this sensor I found to be at the base of the shifter. If you tear out the encasement, the sensors plug into the bottom of the shifter.
    5. Senior Member bluefox280's Avatar
      Dec 17th, 2003
      Broomfield, CO
      08-27-2006 11:15 AM #5
      Quote, originally posted by LaZyFLiP »
      Assuming you have an automatic transmission, correct?
      Is the car getting stuck in a certain gear?
      - Erik
      PatternDraftImaging.com - "...Where Engineering Discipline and Photography Merge as One..."
    6. Member quickautotech's Avatar
      Sep 3rd, 2003
      ATX and the Rockies
      2001 GOLF TDI 2DR 5SPD, 2010 Sportwagen TDI Blue Graphite pearl
      05-02-2007 05:30 PM #6
      I'm having the same problem with a 96 jetta clk auto, my car wont shift into 4th, is this a internal issue, hoping external so I can fix it and keep going. 50- 55 is top speed 4 me until I can fix it. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    7. 05-02-2007 05:58 PM #7
      Ok, my girl had this same issue... The response we got from the dealer was that it could be the solenoid wiring harness, or the valve body. now... upson inspection of her car, the wiring harness was bad. we replaced that, put the tranny back together and still had the code. the car was still stuck in gear. You will have to find a scrapped tranny and pull the solenoids from the valve body. VW will not sell you the solenoid alone. they will only sell you the $1400 valve body. check the wiring harness first. pickup some fresh tranny fluid and a new filter. and see where you are then. hope that helps [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    8. Member quickautotech's Avatar
      Sep 3rd, 2003
      ATX and the Rockies
      05-02-2007 06:20 PM #8
      What year was your girls car? So I have to take out the trans to replace them? I just had it taken out somebody throw a brick at me [IMG]http://*****************.com/smile/emthdown.gif[/IMG] F-----------K!!!!!!!
    9. 05-02-2007 06:21 PM #9
      im sent
    10. Member quickautotech's Avatar
      Sep 3rd, 2003
      ATX and the Rockies
      05-02-2007 06:54 PM #10
      IM returned...thanks
    11. Member quickautotech's Avatar
      Sep 3rd, 2003
      ATX and the Rockies
      05-02-2007 07:21 PM #11
      please see latest IM's [IMG]http://*****************.com/smile/emthup.gif[/IMG]
