and dont foget to add yourself to the 2006 race ladder
http://forums.vwvortex.com/zerothread?id=2469379
#1
time@mph/60ft/year model/turbosize@psi/tires/weight/name(screenname)/state
Example:
12.189@113.16/1.747/02gti/sh40@24/slicks/2500/rich(vdubed)/IL
This is a master list that will be updated.
You must also have proof if the time is questionable, timeslips/vids/witnesses.
You can post up any times 20sec to 9sec!
Also in your posts list you mods/shoutouts/dynos
So post your times, good luck and have fun!!!9sec:
- 9.700@156.66/1.49x/1991 Corrado/20v Turbo/2090 lbs/26X10 w/skinnies/wheelie bars/Joel Brown(Purple-Pill)/PA
10sec:
- 10.109@137.55/x.xxx/98golf/turbo/slicks/Marco(sem)/Can
- 10.36x@143mph/1.69/95 golf/2.0 20v/s362 turbo/26x8.5x13 M&H/(euroroccoT)
- 10.653@137.01/1.69/2002 GTI/1.8t/T3/T67P DBB/24.5x8.5x15 M&Hw/skinnies/Eddie Woolsey (EdsGTI,Force Fed Engineering)NY
- 10.743@121.54/x.xxx/95corrado/2.0NA/slicks/nate(the professor/race101)/KY
- 10.808@133.37/1.68X/95 GTI/SC61/1830/25X8.7 M&H/RICK(DIRTYMOFO)/MD
- 10.812@135.05/1.73x/92gti/gt3052/2450/slicks/billy(1.billyT)TX
11sec:
- 11.14x@124.52/1.64x/99a4/35r/3375#/205.60.15 falken/Gavin(gavin18t)/??
- 11.24x@129.xx/1.797/99GTI/SC-5031E/26x10.5 ET street/Psyko swede/SE
- 11.271@131.45/1.98/2002 gti 337 edition/T3T67/2950/24.5x8.5x15"wheels/fullstreettrimexceptfortires/Frank(Frankiebonez)
- 11.342@124.36/1.771/2001 MKIVJetta/1.8t/ 2871turbo+nitrous /3050#/24.5m&h/Sam(18bora)/NJ
- 11.468@121.65/1.581/00A42.0T/GT35r/034 SEM/XXXXlbs/ 225/45/17 BFG drag radials/Mike(Audi2ptzero)/CA
- 11.475@124.94/x.xxx/84gti/gt30r+autronic/slicks/xxxx/Drew(?)/??
- 11.502@121.72/1.763/03GTI20th/GT3071r@26psi/2800/24.5x8.5 MHs/Mike(PolskiHetzen)/IL
- 11.537@125.13/1.927/1983GTi/GT30R@24psi/2280/22x8" slicks/Andy(VariantStg3)
- 11.609@126.51/2.033/01gti/GT35r/26x8.5 M&H/Pat(junk t.i.)/NY
- 11.624@124.96/1.762/2002 gti/1.8t/gt3076r/2500#/24.5m&h w/rear skinnies/rich(vdubed)
- 11.640@121.41/x.xxx/82PU/???/slicks/xxxx/rolo(?)/PR
- 11.766@120.40/1.797/02gti/GT35R .82@24/regular 195/65/15 street tires/2800/Peter(O2VW1.8T)/NC
- 11.767@127.28/1.728/83 gti/20v/gt3582r/~1850#/24.5x9 MT's on Flystars + Flystar skinnys/Aaron(speeding-g60)
- 11.784@117.73/x.xxx/0320th/gt3071/slicks/xxxx/jeff(jc@douglas)/??
- 11.854@115.67/1.811/03GTI/GT28R@24+50/Slicks/2750/Ian(WhiteG60)/PA
- 11.91x@122.xx/1.71x/02 gti/aprstg3@23+75/slicks/2400#/tim(grocery gett3r)/ILLinoise....
- 11.947@121.22mph/1.793/2003 GTI/GT3076-15 .64 @27 psi/24.5x8.5x15 M&H/~2800lbs/Adam(axlekiller)/AL
- 11.973@118.82/1.765/2002 337/1.8t/gt30.40/3012#/26x8" hoosiers/frank(frankiebonez)/NY
12sec:
- 12.086@118.53/1.759/83 GTI/1.8T/T60-1 @ 23psi/2050#/23" M&H w rear skinny/Aaron(speeding-g60)
- 12.200@117.08/x.xxx/00golf/t3/t4+40/slicks/xxxx/billy(1.billyT)/TX
- 12.230@113.95/x.xxx/01gti/ko3+100/unknown/xxxx/Ric(?)/??
- 12.38x@120.60/2.123/05GLI/T25-GT3071R.64@28 psi/225-45/17 BFG DR's/3075/Nick(3071R-GLI)/FL
- 12.404@118.xx/2.01x/02GTi/GT35R@24psi/2750/235.60.15M&H DOT/peter(O2VW1.8T)/WA
- 12.418@117.39/x.xxx/01jetta/t3t4+70/unknown/xxxx/troy(?)/??
- 12.42x@106.8x/1.721/00gti/ko3s/light/slicks/chim(chim-chim18t)/NJ
- 12.512@118.31/x.xxx/02gti/t3t4/unknown/xxxx/steve(?)/VA
- 12.526@112.27/x.xxx/86golf/ko3+70/xxxx/unknown/trever(?)/??
- 12.573@104.73/x.xxx/97passat/gt30r/unknown/xxxx/teddy(?)/??
- 12.609@112.47/x.xxx/00gti/aprstg3/slicks/xxxx/nick(revo)/??
- 12.62x@114.xx/x.xxx/01SeatLeon20VT4/3076.63@21psi/225/40-18/3141lb/Jonas(efterZ)/Denmark
- 12.634@109.47mph/1.855/2003 GTI/GT3076-15 .64 @25 psi/24.5x8.5x15 M&H/~2800lbs/Adam(axlekiller)/AL
- 12.670@111.55/x.xxx/00jetta/gt28rs/xxxx/unknown/bryan(?)/??
- 12.685@108.44/x.xxx/0320th/DWs2@22/xxxx/24.5M&H/tommy(tommyc83)/IL
- 12.695@115.xx/2.008/02jetta/57trimt04e@25psi/slicks/2650/Tyson(poppy)/TX.
- 12.697@109.89/1.727/01A4/GT2871R@23psi/235-40-18/3300/Brandon(BranCKY3)/MI
- 12.709@110.54/1.89/00gti/aprstg3/BFG DR/2880/greg(little p)/MI
- 12.734@111.19/1.936/91 Jetta/t3.t4 60-trim .63/2500#/24.5x8x15 ET Drag/Brian Haenszel(haenszel)/VA
- 12.751@110.97/2.005/2002 GTI/ 1.8T/ T3S60/ 2800/ 17" BFG DRs/ Dustin Kemplin (dustygti82)
- 12.77x@111.39/1.98x/02jet/aprS3+/slicks/xxxx/bill(in2turbos)LA
- 12.817@118.77/x.xxx/01golf/gt28rs/xxxx/unknown/chris(?)/??
- 12.830@109.01/x.xxx/00beetle/ko3+100/xxxx/unknown/andrew(?)/??
- 12.833@114.10/2.155/05GLI/GT3071R@21 PSI/17" BFG DR/3020 #/xxxxx(3071R-GLI)/FL
- 12.839@108.53/x.xxx/03'377/aprstg3/xxxx/unknown/rich(?)/??
- 12.853@110.90/x.xxx/02gti/ko3+50/xxxx/unknown/joseph(krautfed)/AL
- 12.881@107.29/x.xxx/02jetta/DWs2@22/xxxx/24.5M&H/adam(adam20v)/IL
- 12.886@110.09/x.xxx/03gti/e50t3t4/xxxx/unknown/stephen(?)/??
- 12.923@114.72/x.xxx/83rabbit/t3t4/xxxx/unknown/john(?)/??
- 12.944@115.37/2.261/05GTI/GT2871R/2900#/18"ToyoProxes-4 300TW/Daniel( GT-ER )/PR
- 12.961@109.34/x.xxx/01gti/t3t4/xxxx/unknown/tom(?)/??
- 12.985@118.76/2.32x/02gti/gt28rs@23psi/225.45.17kuhmo/2700lbs/zach(igotaprestent4u)/OH
- 12.907@115.02/2.210/2003 20th/1.8t/gt28rs/20psi/3074 lb's/16" gforce sports/bill(mystery chip 1.8t)PA
- 12.997@104.38/x.xxx/00jettaauto/ko3+50/xxxx/unknown/jonathon(?)/??
13sec:
- 13.054@103.36/1.778/02Jetta/K03s(100oct)/2775 lbs/24.5M&H/Dipen(JettaDude101)/IL
- 13.079@107.21/1.757/01A4/GT2871R@20psi/225-50-16BFG's/3200/Brandon(BranCKY3)/MI
- 13.173@109/60ft/1986 Golf II 20VT/K04-023@22psi/track slicks/2204/Gonçalo(HidRo)/Cascais - Portugal
- 13.24x@102.42/1.856/05GTI/ko4-023(GIACko4-20,93octprog)/2800?/24.5M&H/David(SloGLS)/IL
- 13.28x@106.xx/x.xxx/02SeatIbizaCupra20VT4/k0423@23psi/205/40-17 Toyoproxes r888/2650/Casper(300bhpCupra)/Slovenia
- 13.298@102.26/1.758/1991 Gti/ko3s GIAC X+93oct/23x8.5 M&H/2500/Mike(spdfrek)/IL
- 13.404@101.71/1.822/01NB/gt28r@20psi/kdw2's/3000ish/lean(bluesleeper)/TX
- 13.42x@113.20/2.422/02gti337/REVOgt2871r.64@20psi/18'' kuhmo MX/3015/ricky(vw1990corrado)/MA
- 13.461@107.14/1.680/90Gtx/ko3s SDS Standalone +94oct/street tires/Richard(focalpoint)/Ontario,Canada
- 13.556@106.xx/2.2xx/03GTI/GT2871R@22/18streets/3250/JR(Thebox)/NJ
- 13.590@116.08/2.501/95golf2dr/t3t4.86(sds)/17"toyos/Dylan(16vplus4)/CAN
- 13.626@107.19/2.281/02Gti/t3s60@20psi/michelin mxv4+ /2580/Travis(sivart)/GA
- 13.6@108 on stock Ko3s. (25 lb boost)/(jetta32687)
- 13.747@102.82mph/2.313/2001 Jetta/ko3s@~18psi(apr100oct)/bfg/xxxx/Scott(Papaskot)/NY
- 13.794@98.53/1.8/'02GTI/1.8t/k03s/17psi oldschool GIAC chip/30XXlbs/15"BFG's (UniDub)FL
- 13.808@103.21/2.259/02 337/20VT K04-23/3000ish/225-40-18" all-seasons/Eddie (nuther337)
- 13.899@101.15/2.185/04gti/k03sX+91prog@21-22/nitto nt555/2900/sonny18t/AZ
- 13.947@102.77/2.303/2004 GLI/1.8T/K04-23/fullweight/225-40-18 street tires/Derek(loudgli)
- 13.984@103mph/2.4/2005 Jetta GLI/KO3S @ 27psi/16" Falken 512s/3030lbs/Mike(SAVwKO)/OH
- 13.993@97.64mph/2.112/2004 GTI /K03S@20psi/225/50/15 bfg drag radials/stock - rear seats/(Atlantoniusiii)/NC
14sec:
- 14.00x@102.xx/2.6xx/03gti/ko4-001revostg2/street tires/josh(fenix420)/WA
- 14.08x@99.8x/2.2xx/04 gti/ko3s (revo 3-bar)/205-55-16 stock conti's/xxxx/Erik(Erik04gti)/MD
- 14.0xx@105.9/2.spin/2005 GTI 1.8T/gt28rs@25psi/$80 sears tires/themadskater905/md/nc(themadskater905)
- 14.0xx@99.98/2.3xx/03 Jetta/Ko3S, 20PSI/Wanli S1099/3200/(Khaos)OR
- 14.0xx@99.5x/2.258/02GTI/k03sGIACx+/Azenis Sport RT-215s/2800/Jeff(4ceFed4)/NJ
- 14.101@100.5x/2.209/03GTI/K03s(Revo)/2525#/BFG drag radials/Nick(Nick_1.8T)/??
- 14.118@106.42/2.345/00Passat/GT2871R@17psi/3560/225 45-17/Andy(VariantStg3)
- 14.155@104.65/2.419/00golf4dr/gt3076R .63@15/205/65/16 street tires/3200~/ Peter (Tdipower4me)/NY
- 14.160@98.31/2.154/04autogti/ko3s/stock16's/xxxx/lax1492/MD
- 14.1xx@98.xx/2.2xx/01Jetta/ko3s/hankook k106/xxxx/xxx(rep ny)/ NY
- 14.203@97.10/2.179/01gt/KO3 giiac/snow tires/XXXX/ (mark hamill)NY
- 14.300@96.34/2.217/2003 Beetle/1.8T/K03s/?/Michelin Pilot sport 18" (20psi)/Matas(r0nd3L)IL
- 14.310@98.06/2.30/02 GTI/1.8t/K03s @ 15psi/3000#/195/65/15(Island20v)
- 14.3xx@98.xx/2.2xx/02GTI/K03sRevo/18"RCs/xxx(BboyRonnie)/AZ
- 14.5xx@98.5x/2.5xx/02Jetta/k03s/street/2800/tom(forcefedjetta)/ma
- 14.812@93.38/2.269/0320thI/stock tires/3128lbs/name(greasygizno)/NJ
- 14.815@95.72/2.288/o3GTi/ko3s 16psi/bfg kdw/3xxx/Ryan(ryanvw)/WindsorOntario Can
- 14.831@91.733/2.226/02 GTI 337/K03S @ Stock Boost/18" Sumitomo HRTZ/Stock Weight/Mistamike17/KY
- 14.884@96 02 gti ko4-01 on 18"street tires(lardstax)
- 14.89x@86.2x/2.256/01GTI/stock KO3/stock weight ~3000#/195/65-15 Potenza RE950/Rossi(flat4ever)/??
- 14.908@110.39/3.2XX/02jetta auto/t3/t4/cooperZeons/ryan (Cptmorgemaker)/IN
- 14.96x@93.82/x.xxx/03Jetta/K03Sx+/Michelin/xxxx/ Kamikaze2Dope/CA
15sec
- 15.015@92.33/2.4xx/01Jetta/K03S@~21psi/Bridgestone Potenza G009(bald)/3200/Jeff(ColoradoSoul03)/OH.
- 15.1xx@91.xx/2.160/2002 337/1.8t/ko3s BONE STOCk/ BBS RC's Kumhos/Jayce(ullbsory1.8t)
- 15.23x@90mph/01GTI/KO3@7psi/street/stock/corollinout/MD
- 15.377@93.92/2.669/2004 GLI 1.8T/K03S@<16PSI/Dayton(Bridgestone) Daytona/NY(true2liter)
- 15.472@88.81mph/2.342/20thAEGTI/K03s Stock PSI/Cooper tires/3XXX/Luke(Wolfs01burg01)/FL
- 15.592@92.66/2.509/0320thAE/k03s(APR 93oct)/3xxx#/225/40-18Fuzion 18x8.5 ASA AR1's/G.J.(gtfli1)/IL
- 15.961@89.49/2.703/05gti/stock/3100#ish/225x45x17" Hankook Rs2 Z212/Andy(meangreen18t)/??
Modified by vdubed at 11:05 AM 10-13-2008
http://www.dubwerks.com Proudly serving N IL ans SE WI for over a decade, your source for stock repair and perfomance parts and service!
Chicagoland and greater Milwaukees Aurthorized GIAC and C2 dealer!
847.573.9691 19121 W Casey Rd Libertyville IL 60048
Come check out our new location!http://www.facebook.com/dubwerks
#2
#3
14.812@93.38/2.269/20thAE/stock tires/3128lbs/NJMods: x+,TIP,V-Flow,stock exhaust
#4
added!
#5
you do not specify mk4 or other so here is rick benners in a mk 3
8. 11.530@128.57/1.837/95 GTI/SC61/25X8.7 M&H/RICK(DIRTYMOFO)
www.APtuning.comwww.Lugtronic.comwww.Specclutch.com
0-166mph in 8.9 seconds-----> http://youtu.be/o8_hgLqzo9g
0-161mph in 8.9 seconds-----> http://youtu.be/O8X6EzeAGPA
#6
13.24x@102.42/1.856/2005GTI/1.8t/ko4-023(GIACko4-20,93octprog)/2800?/24.5M&H/David(SloGLS)Slow a$$ ko4's
#7
I should be making somw passes on sunday...... we'll see
01 GTI 1.8T big turbo ghost...
02 Jetta GLX
VW/AUDI MASTER GUILD WRENCH
#8
Quote, originally posted by purple-pill » you do not specify mk4 or other so here is rick benners in a mk 3
and i have to add yours also!![]()
what state is rick from?
#9
11.856@115.72/1.811/03 GTI/GT28R@24/Slicks/2750/Ian(WhiteG60/PA
#10
OH I thought this was for this season....11.851@118.43/1.831/01gti/2871r/24.4x8.5 M&H/Pat(junk t.i.)
edited 60 foot
Modified by Junk T.I. at 5:55 PM 8-24-2006
02 Jetta GLX
#11
Quote, originally posted by Junk T.I. » OH I thought this was for this season.... That's what I thought. But...
12.637@111.31/1.805/2003 GTi 20th A.E./GT3071r@23psi/3000?/24.5x8.5 MHs/Mike (Hetzen)
#12
Quote, originally posted by WhiteG60 » 11.856@115.72/1.811/03 GTI/GT28R@24/Slicks/2750/Ian(WhiteG60/PA Damn I have slips that rock your 60ft but I'm slower by like 3 tenths to the 330. I think its the 02m.
#13
updated!
yeah this list is for all time. the race ladder in the drag forum is only for 2006
so whatever anyone has done years ago(as long there is enough info)
will be added![]()
#15
add me
18. 12.404@118.xx/2.01x/2002 GTi/1.8T/GT35R@24psi, pump gas/2750/235.60.15 M&H DOT slicks/peter(O2VW1.8T)
02 GTi 1.8T haldex'd w/35r-SOLD 7.3@102mph 27psi on 93 octane--04 A4 1.8T converted to AWD also- SOLD--'11 JSW Tdi 6speed Manual- Gone--
13' BMW 335i M-sport EBII
#16
in case this slips the the bottom of the forums, there is a link to it in the FAQ![]()
#17
add me12.985@118.76/2.32/02gti/gt28rs@23psi/225.45.17kuhmoallseasons/2700lbs/zach(igotaprestent4u)/ohio
#18
I'm not going to post up numbers yet cause on saturday I'm going to the track again for the first time wih the GT2871R so God help me..lol.
2005 E55 AMG: 507whp/556wtrq with bolt ons.
#19
AVR stock looking Golf MK4 1.8T
11,24 @ 129Mph
#20
Quote, originally posted by foffa2002 » AVR stock looking Golf MK4 1.8T
11,24 @ 129Mphyou should reformat the info in the one specified in the first post
#21
11.24@129mph/11.797/99GTI/Precision SC-5031E/26x10.5 ET street/Psyko swede
#22
Old info (last updated 4/14/05 from VWSport1.10.109 @ 137.55mph, Marco Preiano, 1998 Golf CL, Built Motor 20v 1.8T - Race Car - Canada - Info SEM
2.10.743 @ 121.54mph, Nate Romero, 1995 Corrado, All Motor 2.0l 20v - Race Car - USA - Info Race 101
3.10.812 @ 135.05mph, Billy Tylaska, 1992 GTI, Stock AEB 1.8T - Street Car - GT3052 + Haltech - USA
4.11.475 @ 124.94mph, Drew Scheafer, 1984 GTI, Stock AWP 1.8T - Street/Race Car - GT30R+ Autronic - USA
5.11.640 @ 121.41mph, Rolo Santa, 1982 VW Pickup, 20v 1.8T - Puerto Rico
6.11.784 @ 117.73mph, Jeff Clark, 2003 20th AE GTI, Stock AWW 1.8T - FullRace Manifold GT3071R + Revo BT - USA
7.11.851 @ 118.43mph, Pat Brown, 2001 GTI, Built AWW 1.8T - ATP GT2871R + Revo BT - USA
8.11.854 @ 115.67mph, APTuning/Driver Ian Case, 2003 GTI, Race/Street Car - Stock AWW 1.8T - APR Stage 3 + 50 Shot - USA
9.12.027 @ 115.27mph, Sam, 2001 Jetta, Stock AWW 1.8T - Street Car - APR Stage 3+
10.12.200 @ 117.08mph, Billy Tylaska, 2000 Golf, Stock AWD 1.8T - T3/T4 Turbo + 40shot - USA
11.12.230 @ 113.95mph, Ric Fish, 2001 GTI, Stock AWW 1.8T - K03 + 100shot - USA
12.12.418 @ 117.39mph, Troy Casteel, 2001 Jetta, Stock AWW 1.8T - ATP T3/T4 + 70shot - USA
13a.12.456 @ 110.48 mph, Andrew Lloyd, 1983 GTI, Stock AEB 1.8T - GT30R 19Lbs (Microtech)
13.12.512 @ 118.31mph, Steve Soeder, 2002 GTI, Stock AWP 1.8T - T3/T4 + Revo BT
14.12.526 @ 112.27mph, Trever Reinholt, 1986 Golf, Stock 1.8t - KO3sport + 70shot
15.12.557 @ 102.98mph, Chim-Chim, 2000 GTI, Stock AWD 1.8T - K03 Sport (No Nitrous)
16.12.573 @ 104.73mph, Teddy Leszczynski, 1997 Passat, AEB 1.8T - ATP GT30R
17.12.609 @ 112.47mph, Nick Revo, 2000 GTI, Stock AWD 1.8T - APR Stage 3
18.12.670 @ 111.55mph, Bryan Howarth, 2000 Jetta, Stock AWD 1.8T - ATP GT28RS + APR K03 Chip
19.12.685 @ 108.44mph, Tommy Carmody, 2003 GTI, Stock AWP 1.8T - Dubwerks Kit + GIAC
20.12.709 @ 110.54mph, Greg Peruski, 2000 GTI, Stock AWD 1.8T - APR Stage 3
21.12.817 @ 118.77mph, Chris Boyd, 2001 Golf, Stock AWW 1.8T - GT28RS
22.12.830 @ 109.01mph, Andrew ATP, 2000 Beetle, Stock APH 1.8T - K03 + 100shot
23.12.839 @ 108.53mph, Rich Righetti, 2003 GTI 337, Stock AWP 1.8T - APR Stage 3
24.12.853 @ 110.90mph, Joseph Bellamy, 2002 GTI, Stock AWP 1.8T - K03 + 50shot
25.12.881 @ 107.29mph, Adam Lynch, 2002 Jetta, Stock AWP 1.8T - Dubwerks Kit + GIAC
26.12.886 @ 110.09mph, Stephen Meli, 2003 GTI, Stock AWP 1.8T - Tyrol Sport Kit (Innovative E50 T3/T4)
27.12.923 @ 114.72mph, John Pastore, 1983 Rabbit (MK1),Stock AEB 1.8T - ATP Stage 3 T3/T4
28.12.961 @ 109.34mph, Tom Vortsman, 2001 GTI, Stock AWW 1.8T - T3/T4
29. 12.997 @ 104.38mph, Jonathon Revelo, 2000 Jetta, AWD 1.8T - Automatic - K03 + 50shot
#23
updated!
please check the state and county codes and make sure that they are right. thanks.yeah i wish that the vwsport list had more info
maybe some of the guys on there will chime in with more info![]()
#24
haha...i just saw that i added a 11.797 60ft
Please edit
#25
Quote, originally posted by foffa2002 » haha...i just saw that i added a 11.797 60ft
Please edit
lol
thats slow
what is the 60s?1.797?
Modified by vdubed at 9:54 AM 8-25-2006
#26
Quote, originally posted by vdubed » yeah i wish that the vwsport list had more info ![]()
so only those posted with all the requested info will be updated in the "master" list in the first post
#27
Quote, originally posted by Boostin20v » so only those posted with all the requested info will be updated in the "master" list in the first post
i will add them! i would just like to know more about the run/car/setups.
i know i wont get all the info because 50-70% of the cars on that list dont exsist anymore![]()
#29
incorporating both list together! so check the list if anyone has more info on the cars from the vwsport list please let me know. thanks![]()
#30
we lost Joel's run9.700@156.66/1.49x/1991 Corrado/20v Turbo/2090 lbs/26X10 w/skinnies/wheelie bars/Joel Brown(Purple-Pill)
#31
Quote, originally posted by Boostin20v » we lost Joel's run 9.700@156.66/1.49x/1991 Corrado/20v Turbo/2090 lbs/26X10 w/skinnies/wheelie bars/Joel Brown(Purple-Pill)
yeah i havent gotten to the 2006 race ladder guys yet.
#32
5. 11.640 @ 121.41mph, Rolo Santa, 1982 VW Pickup, 20v 1.8T - Puerto RicoI've seen this car is person ( years ago )...Makes me proud.
#33
#34
updated!
man all those 12sec runs![]()
#35
i wish i was part of this list
