***1.8t 1/4mile list ***
87K views 487 replies 153 participants last post by  Harry Sax
#1 ·
time@mph/60ft/year model/turbosize@psi/tires/weight/name(screenname)/state
Example:
12.189@113.16/1.747/02gti/sh40@24/slicks/2500/rich(vdubed)/IL
This is a master list that will be updated.
You must also have proof if the time is questionable, timeslips/vids/witnesses.
You can post up any times 20sec to 9sec!
Also in your posts list you mods/shoutouts/dynos
So post your times, good luck and have fun!!!
9sec:
9.700@156.66/1.49x/1991 Corrado/20v Turbo/2090 lbs/26X10 w/skinnies/wheelie bars/Joel Brown(Purple-Pill)/PA
10sec:
10.109@137.55/x.xxx/98golf/turbo/slicks/Marco(sem)/Can
10.36x@143mph/1.69/95 golf/2.0 20v/s362 turbo/26x8.5x13 M&H/(euroroccoT)
10.653@137.01/1.69/2002 GTI/1.8t/T3/T67P DBB/24.5x8.5x15 M&Hw/skinnies/Eddie Woolsey (EdsGTI,Force Fed Engineering)NY
10.743@121.54/x.xxx/95corrado/2.0NA/slicks/nate(the professor/race101)/KY
10.808@133.37/1.68X/95 GTI/SC61/1830/25X8.7 M&H/RICK(DIRTYMOFO)/MD
10.812@135.05/1.73x/92gti/gt3052/2450/slicks/billy(1.billyT)TX
11sec:
11.14x@124.52/1.64x/99a4/35r/3375#/205.60.15 falken/Gavin(gavin18t)/??
11.24x@129.xx/1.797/99GTI/SC-5031E/26x10.5 ET street/Psyko swede/SE
11.271@131.45/1.98/2002 gti 337 edition/T3T67/2950/24.5x8.5x15"wheels/fullstreettrimexceptfortires/Frank(Frankiebonez)
11.342@124.36/1.771/2001 MKIVJetta/1.8t/ 2871turbo+nitrous /3050#/24.5m&h/Sam(18bora)/NJ
11.468@121.65/1.581/00A42.0T/GT35r/034 SEM/XXXXlbs/ 225/45/17 BFG drag radials/Mike(Audi2ptzero)/CA
11.475@124.94/x.xxx/84gti/gt30r+autronic/slicks/xxxx/Drew(?)/??
11.502@121.72/1.763/03GTI20th/GT3071r@26psi/2800/24.5x8.5 MHs/Mike(PolskiHetzen)/IL
11.537@125.13/1.927/1983GTi/GT30R@24psi/2280/22x8" slicks/Andy(VariantStg3)
11.609@126.51/2.033/01gti/GT35r/26x8.5 M&H/Pat(junk t.i.)/NY
11.624@124.96/1.762/2002 gti/1.8t/gt3076r/2500#/24.5m&h w/rear skinnies/rich(vdubed)
11.640@121.41/x.xxx/82PU/???/slicks/xxxx/rolo(?)/PR
11.766@120.40/1.797/02gti/GT35R .82@24/regular 195/65/15 street tires/2800/Peter(O2VW1.8T)/NC
11.767@127.28/1.728/83 gti/20v/gt3582r/~1850#/24.5x9 MT's on Flystars + Flystar skinnys/Aaron(speeding-g60)
11.784@117.73/x.xxx/0320th/gt3071/slicks/xxxx/jeff(jc@douglas)/??
11.854@115.67/1.811/03GTI/GT28R@24+50/Slicks/2750/Ian(WhiteG60)/PA
11.91x@122.xx/1.71x/02 gti/aprstg3@23+75/slicks/2400#/tim(grocery gett3r)/ILLinoise....
11.947@121.22mph/1.793/2003 GTI/GT3076-15 .64 @27 psi/24.5x8.5x15 M&H/~2800lbs/Adam(axlekiller)/AL
11.973@118.82/1.765/2002 337/1.8t/gt30.40/3012#/26x8" hoosiers/frank(frankiebonez)/NY
12sec:
12.086@118.53/1.759/83 GTI/1.8T/T60-1 @ 23psi/2050#/23" M&H w rear skinny/Aaron(speeding-g60)
12.200@117.08/x.xxx/00golf/t3/t4+40/slicks/xxxx/billy(1.billyT)/TX
12.230@113.95/x.xxx/01gti/ko3+100/unknown/xxxx/Ric(?)/??
12.38x@120.60/2.123/05GLI/T25-GT3071R.64@28 psi/225-45/17 BFG DR's/3075/Nick(3071R-GLI)/FL
12.404@118.xx/2.01x/02GTi/GT35R@24psi/2750/235.60.15M&H DOT/peter(O2VW1.8T)/WA
12.418@117.39/x.xxx/01jetta/t3t4+70/unknown/xxxx/troy(?)/??
12.42x@106.8x/1.721/00gti/ko3s/light/slicks/chim(chim-chim18t)/NJ
12.512@118.31/x.xxx/02gti/t3t4/unknown/xxxx/steve(?)/VA
12.526@112.27/x.xxx/86golf/ko3+70/xxxx/unknown/trever(?)/??
12.573@104.73/x.xxx/97passat/gt30r/unknown/xxxx/teddy(?)/??
12.609@112.47/x.xxx/00gti/aprstg3/slicks/xxxx/nick(revo)/??
12.62x@114.xx/x.xxx/01SeatLeon20VT4/3076.63@21psi/225/40-18/3141lb/Jonas(efterZ)/Denmark
12.634@109.47mph/1.855/2003 GTI/GT3076-15 .64 @25 psi/24.5x8.5x15 M&H/~2800lbs/Adam(axlekiller)/AL
12.670@111.55/x.xxx/00jetta/gt28rs/xxxx/unknown/bryan(?)/??
12.685@108.44/x.xxx/0320th/DWs2@22/xxxx/24.5M&H/tommy(tommyc83)/IL
12.695@115.xx/2.008/02jetta/57trimt04e@25psi/slicks/2650/Tyson(poppy)/TX.
12.697@109.89/1.727/01A4/GT2871R@23psi/235-40-18/3300/Brandon(BranCKY3)/MI
12.709@110.54/1.89/00gti/aprstg3/BFG DR/2880/greg(little p)/MI
12.734@111.19/1.936/91 Jetta/t3.t4 60-trim .63/2500#/24.5x8x15 ET Drag/Brian Haenszel(haenszel)/VA
12.751@110.97/2.005/2002 GTI/ 1.8T/ T3S60/ 2800/ 17" BFG DRs/ Dustin Kemplin (dustygti82)
12.77x@111.39/1.98x/02jet/aprS3+/slicks/xxxx/bill(in2turbos)LA
12.817@118.77/x.xxx/01golf/gt28rs/xxxx/unknown/chris(?)/??
12.830@109.01/x.xxx/00beetle/ko3+100/xxxx/unknown/andrew(?)/??
12.833@114.10/2.155/05GLI/GT3071R@21 PSI/17" BFG DR/3020 #/xxxxx(3071R-GLI)/FL
12.839@108.53/x.xxx/03'377/aprstg3/xxxx/unknown/rich(?)/??
12.853@110.90/x.xxx/02gti/ko3+50/xxxx/unknown/joseph(krautfed)/AL
12.881@107.29/x.xxx/02jetta/DWs2@22/xxxx/24.5M&H/adam(adam20v)/IL
12.886@110.09/x.xxx/03gti/e50t3t4/xxxx/unknown/stephen(?)/??
12.923@114.72/x.xxx/83rabbit/t3t4/xxxx/unknown/john(?)/??
12.944@115.37/2.261/05GTI/GT2871R/2900#/18"ToyoProxes-4 300TW/Daniel( GT-ER )/PR
12.961@109.34/x.xxx/01gti/t3t4/xxxx/unknown/tom(?)/??
12.985@118.76/2.32x/02gti/gt28rs@23psi/225.45.17kuhmo/2700lbs/zach(igotaprestent4u)/OH
12.907@115.02/2.210/2003 20th/1.8t/gt28rs/20psi/3074 lb's/16" gforce sports/bill(mystery chip 1.8t)PA
12.997@104.38/x.xxx/00jettaauto/ko3+50/xxxx/unknown/jonathon(?)/??
13sec:
13.054@103.36/1.778/02Jetta/K03s(100oct)/2775 lbs/24.5M&H/Dipen(JettaDude101)/IL
13.079@107.21/1.757/01A4/GT2871R@20psi/225-50-16BFG's/3200/Brandon(BranCKY3)/MI
13.173@109/60ft/1986 Golf II 20VT/K04-023@22psi/track slicks/2204/Gonçalo(HidRo)/Cascais - Portugal
13.24x@102.42/1.856/05GTI/ko4-023(GIACko4-20,93octprog)/2800?/24.5M&H/David(SloGLS)/IL
13.28x@106.xx/x.xxx/02SeatIbizaCupra20VT4/k0423@23psi/205/40-17 Toyoproxes r888/2650/Casper(300bhpCupra)/Slovenia
13.298@102.26/1.758/1991 Gti/ko3s GIAC X+93oct/23x8.5 M&H/2500/Mike(spdfrek)/IL
13.404@101.71/1.822/01NB/gt28r@20psi/kdw2's/3000ish/lean(bluesleeper)/TX
13.42x@113.20/2.422/02gti337/REVOgt2871r.64@20psi/18'' kuhmo MX/3015/ricky(vw1990corrado)/MA
13.461@107.14/1.680/90Gtx/ko3s SDS Standalone +94oct/street tires/Richard(focalpoint)/Ontario,Canada
13.556@106.xx/2.2xx/03GTI/GT2871R@22/18streets/3250/JR(Thebox)/NJ
13.590@116.08/2.501/95golf2dr/t3t4.86(sds)/17"toyos/Dylan(16vplus4)/CAN
13.626@107.19/2.281/02Gti/t3s60@20psi/michelin mxv4+ /2580/Travis(sivart)/GA
13.6@108 on stock Ko3s. (25 lb boost)/(jetta32687)
13.747@102.82mph/2.313/2001 Jetta/ko3s@~18psi(apr100oct)/bfg/xxxx/Scott(Papaskot)/NY
13.794@98.53/1.8/'02GTI/1.8t/k03s/17psi oldschool GIAC chip/30XXlbs/15"BFG's (UniDub)FL
13.808@103.21/2.259/02 337/20VT K04-23/3000ish/225-40-18" all-seasons/Eddie (nuther337)
13.899@101.15/2.185/04gti/k03sX+91prog@21-22/nitto nt555/2900/sonny18t/AZ
13.947@102.77/2.303/2004 GLI/1.8T/K04-23/fullweight/225-40-18 street tires/Derek(loudgli)
13.984@103mph/2.4/2005 Jetta GLI/KO3S @ 27psi/16" Falken 512s/3030lbs/Mike(SAVwKO)/OH
13.993@97.64mph/2.112/2004 GTI /K03S@20psi/225/50/15 bfg drag radials/stock - rear seats/(Atlantoniusiii)/NC
14sec:
14.00x@102.xx/2.6xx/03gti/ko4-001revostg2/street tires/josh(fenix420)/WA
14.08x@99.8x/2.2xx/04 gti/ko3s (revo 3-bar)/205-55-16 stock conti's/xxxx/Erik(Erik04gti)/MD
14.0xx@105.9/2.spin/2005 GTI 1.8T/gt28rs@25psi/$80 sears tires/themadskater905/md/nc(themadskater905)
14.0xx@99.98/2.3xx/03 Jetta/Ko3S, 20PSI/Wanli S1099/3200/(Khaos)OR
14.0xx@99.5x/2.258/02GTI/k03sGIACx+/Azenis Sport RT-215s/2800/Jeff(4ceFed4)/NJ
14.101@100.5x/2.209/03GTI/K03s(Revo)/2525#/BFG drag radials/Nick(Nick_1.8T)/??
14.118@106.42/2.345/00Passat/GT2871R@17psi/3560/225 45-17/Andy(VariantStg3)
14.155@104.65/2.419/00golf4dr/gt3076R .63@15/205/65/16 street tires/3200~/ Peter (Tdipower4me)/NY
14.160@98.31/2.154/04autogti/ko3s/stock16's/xxxx/lax1492/MD
14.1xx@98.xx/2.2xx/01Jetta/ko3s/hankook k106/xxxx/xxx(rep ny)/ NY
14.203@97.10/2.179/01gt/KO3 giiac/snow tires/XXXX/ (mark hamill)NY
14.300@96.34/2.217/2003 Beetle/1.8T/K03s/?/Michelin Pilot sport 18" (20psi)/Matas(r0nd3L)IL
14.310@98.06/2.30/02 GTI/1.8t/K03s @ 15psi/3000#/195/65/15(Island20v)
14.3xx@98.xx/2.2xx/02GTI/K03sRevo/18"RCs/xxx(BboyRonnie)/AZ
14.5xx@98.5x/2.5xx/02Jetta/k03s/street/2800/tom(forcefedjetta)/ma
14.812@93.38/2.269/0320thI/stock tires/3128lbs/name(greasygizno)/NJ
14.815@95.72/2.288/o3GTi/ko3s 16psi/bfg kdw/3xxx/Ryan(ryanvw)/WindsorOntario Can
14.831@91.733/2.226/02 GTI 337/K03S @ Stock Boost/18" Sumitomo HRTZ/Stock Weight/Mistamike17/KY
14.884@96 02 gti ko4-01 on 18"street tires(lardstax)
14.89x@86.2x/2.256/01GTI/stock KO3/stock weight ~3000#/195/65-15 Potenza RE950/Rossi(flat4ever)/??
14.908@110.39/3.2XX/02jetta auto/t3/t4/cooperZeons/ryan (Cptmorgemaker)/IN
14.96x@93.82/x.xxx/03Jetta/K03Sx+/Michelin/xxxx/ Kamikaze2Dope/CA
15sec
15.015@92.33/2.4xx/01Jetta/K03S@~21psi/Bridgestone Potenza G009(bald)/3200/Jeff(ColoradoSoul03)/OH.
15.1xx@91.xx/2.160/2002 337/1.8t/ko3s BONE STOCk/ BBS RC's Kumhos/Jayce(ullbsory1.8t)
15.23x@90mph/01GTI/KO3@7psi/street/stock/corollinout/MD
15.377@93.92/2.669/2004 GLI 1.8T/K03S@<16PSI/Dayton(Bridgestone) Daytona/NY(true2liter)
15.472@88.81mph/2.342/20thAEGTI/K03s Stock PSI/Cooper tires/3XXX/Luke(Wolfs01burg01)/FL
15.592@92.66/2.509/0320thAE/k03s(APR 93oct)/3xxx#/225/40-18Fuzion 18x8.5 ASA AR1's/G.J.(gtfli1)/IL
15.961@89.49/2.703/05gti/stock/3100#ish/225x45x17" Hankook Rs2 Z212/Andy(meangreen18t)/??
http://****************.com/smile/emgift.gif
Modified by vdubed at 11:05 AM 10-13-2008
See less See more
5
#27 ·
Re: ***1.8t 1/4mile list *** (Boostin20v)
Quote, originally posted by Boostin20v »
so only those posted with all the requested info will be updated in the "master" list in the first post
i will add them! i would just like to know more about the run/car/setups.
i know i wont get all the info because 50-70% of the cars on that list dont exsist anymore
#29 ·
incorporating both list together! so check the list if anyone has more info on the cars from the vwsport list please let me know. thanks
#31 ·
we lost Joel's run
yeah i havent gotten to the 2006 race ladder guys yet.
#34 ·
Re: ***1.8t 1/4mile list *** (FrankiEBoneZ)
updated!
man all those 12sec runs http://****************.com/smile/emthup.gif
#36 ·
Re: ***1.8t 1/4mile list *** (one.eightT03)
post up the times in your sig and you in! http://****************.com/smile/emthup.gif
#37 ·
Re: ***1.8t 1/4mile list *** (vdubed)
Quote, originally posted by vdubed »
those arent anything to be proud of..in 2 weeks i might have something to be proud of though http://****************.com/smile/emthup.gif
#38 ·
Quote, originally posted by one.eightT03 »
LOL... good luck. http://****************.com/smile/emthup.gif
#42 ·
Re: ***1.8t 1/4mile list *** (grocery gett3r)
Quote, originally posted by grocery gett3r »
11.91@122/1.71/02 gti/apr stg3@23+75/slicks/2400#/tim, (grocery gett3r) illinoise....
good deal i couldnt remember all the info on that run and a +75 http://****************.com/smile/emthup.gif
#43 ·
come on, i know more 1 person has ran 13s and 14s
#44 ·
There is something I'm not getting about these two runs:
# 11.854@115.67/1.811/03GTI/GT28R@24+50/Slicks/2750/Ian(WhiteG60)/PA
# 11.91x@122.xx/1.71x/02 gti/aprstg3@23+75/slicks/2400#/tim/(grocery gett3r)/ILLinoise....
Ian did worse 60' than Tim yet Tim did a worse time but trapped 7 mph MORE.
#45 ·
Re: ***1.8t 1/4mile list *** (GT-ER)
Quote, originally posted by GT-ER »
if we had a breakdown of both runs to see what really is going on would help. prob depends on where in the 1/4 they sprayed.
#46 ·
Didn't think of that. http://****************.com/smile/emthup.gif
#49 ·
Re: ***1.8t 1/4mile list *** (SloGLS)
my KO3s time
13.26@104/2.08/2002/Stock KO3s@17psi on pump/205/50/15 DR/2450/peter(O2VW1.8T
#50 ·
ian had a custom gearset.
