VWVortex.com - My car randomly locks and unlocks itself
    Results 1 to 17 of 17
    Thread: My car randomly locks and unlocks itself
    1. 08-26-2006 03:51 AM #1
      The title says it all. My car will lock and unlock itself ramdomly. It's been doing this for about a day until I reached under the dash and unplugged the keyless entry module. Is this normal?
    2. 08-26-2006 01:02 PM #2
      Could something else be on this frequency?
    3. 08-26-2006 01:25 PM #3
      So let me guess, you go out to your car and you unlock it, then like 30 seconds later it relocks itself?
    4. 08-26-2006 05:44 PM #4
      hahahaha happens to me like once a month, i lock it put my keys in my pocket and walk away then honk! i just stoped paying attention
    5. 08-26-2006 07:11 PM #5
      mine will lock itself if i pop the trunk without unlocking doors first, close trunk and a few seconds later... lock.
      good stuff.
    6. Member mk3 Ginster Gti's Avatar
      Jul 4th, 2006
      Westchester, NY
      76 Rabbit
      08-26-2006 08:36 PM #6
      if i open mine it will lock it self and beep like 30 seconds after i open it,.. also when i open my car with just the key and open the door the alarm goes off.. does any1 know why it does this?? and my alram blip doesnt blink can some1 help
    7. Member jrbscooch56's Avatar
      May 20th, 2006
      Media
      mk3 Jetta wolfsburg
      08-26-2006 09:02 PM #7
      why dont you first try to disconnect the battery come back in 15 minutes and reconnect it....
      Idk if that will help though...
    8. Senior Member
      Sep 22nd, 2002
      Oakland
      I own a wish-list. In four shades of blue.
      08-26-2006 09:07 PM #8
      Quote, originally posted by mk3 Ginster Gti »
      sounds like two problems. 1) your door contact switch is intermittently failing, and 2) your latch mechanism has a bad switch in it. When you do a double-turn of the key, does the central locking pump open all the doors, or no?
      For the OP, there's a chance you just have some cracked and shorted wires in the boot that goes into your door.
      My car
      and its identity crisis
      I dodged a bullet there. Note to self: cease fire.
      “If everything seems under control, you're just not going fast enough.” — Mario Andretti
    9. 08-27-2006 02:23 AM #9
      What happens is i'll lock it then it will unlock a few times possibly pop the trunk arm itself every once in a while randomly whenever the best is when i'm driving and the alarm starts going off.
    10. 08-27-2006 02:24 AM #10
      Yeah double turn unlocks all the doors
    11. Member GL Rican's Avatar
      Aug 16th, 2006
      New Haven
      FA5
      08-27-2006 02:28 AM #11
      yeah mines does it too like wen i have the hatch open i hear the honk and i just unlock it again and go on with life....
    12. Member notso2slo's Avatar
      Apr 30th, 2006
      Btown USA
      1996 Catalina Blue GTI
      08-27-2006 02:32 AM #12
      yah, the vaccuum pump will activate if the door switch is still bad.. this happeend to a friend of mines, he couldn't unlock the car... you probably need to replace the door lock mechanism.. the whole thing that attatches to the latch. Spendy, but it usually works.
      Also, check your ground wires... that causes problems sometimes.
      facebook.com/thetitleist
      Function over form! But it doesn't hurt to look good...
    13. Member notso2slo's Avatar
      Apr 30th, 2006
      Btown USA
      08-27-2006 02:34 AM #13
      Quote, originally posted by Flip_mode »
      Mine did this too, but so often the battery on my remote died.. I believe it is a defectice remote, in my case at least... try taking the remote off your keyring for a while.
    14. 08-27-2006 03:05 AM #14
      do you wear your keyless entry on a clip on your belt loops? if so then you might be sitting on it, for it to lock and unlock your car, also after 30 seconds it usually locks itself
    15. Member Chockomon's Avatar
      Aug 19th, 2005
      '13 Golf R, '00 Cabrio VR6 & '90 Corrado G60
      08-27-2006 03:06 AM #15
      check your grounds in your doors
      2013 Golf R - VWR Intake - Unitronic Stage 2HPFP - SPM TurboBack Exhaust - Autotech Fuel Pump - More to Come
      All mods have been approved and endorsed by Accidental L8 apex
    16. Member mk3 Ginster Gti's Avatar
      Jul 4th, 2006
      Westchester, NY
      76 Rabbit
      08-27-2006 03:39 PM #16
      when i put my key in and turn it 2wice it only opens the driver side door and when i open the door the alarm goes off.. and my frineds opens both doors and opens and closes his sunroof.. mine does do that ..
    17. Senior Member
      Sep 22nd, 2002
      Oakland
      08-27-2006 03:45 PM #17
      Yours is easy: either it's a broken wire going to the microswitch in the lock/latch, or the switch itself is bad. The mechanical parts are working, but the electronics aren't. If the same is true of your passenger door lock, there may be something else going on.
      My car
