VWVortex.com - 4x100 to 5x205 adapters???
    Results 1 to 16 of 16
    Thread: 4x100 to 5x205 adapters???
    1. 08-31-2006 12:33 AM #1
      I had pics of the adapters, but I can't find them...
      Anyone know where these adapters can be purchased...
    2. Member 4doorhoor's Avatar
      Aug 31st, 2005
      Shanghai, OR
      08-31-2006 12:43 AM #2
      2 by what?
      Thanks Brain!
    3. 08-31-2006 12:50 AM #3
      Found the pic... Where might I be able to get them?
    4. Banned 91gl's Avatar
      Aug 11th, 2004
      08-31-2006 01:08 AM #4
      ive never heard of anyone making 5x205 adapters, i had not even ever heard of that pattern before , im sure you can get them custom made at any machine chop.
    5. 08-31-2006 01:33 AM #5
      Quote, originally posted by Grand Admiral Thrawn »
      can't see that being balanced.....
    6. Member jonny_breakz's Avatar
      Jul 26th, 2002
      Wpg Mb Canada
      99 Ford Ranger XLT
      08-31-2006 01:34 AM #6
      Quote, originally posted by 91gl »
      common early air cooled bolt pattern..hence the air cooled steel wheels on the red golf above..
      the ones you have pictured seem to be of 25 or so mm thick but to me that might be to thick to run an air cooled steel wheel on...as they genreal offset of the wheels are ET19 IIRC..
      Im guessing that they are much thinner than that on the red car.
      a few years ago in a vw trends mag a dood had a low light ghia with porsche 924 breaks (4x108 lug pattern) and had a 1/2" place made with the wide 5 to run the stock wheels..
      1/2" is is 12.7mm
      12.7 - 19 is et of 6.3 which would work
      with those adaptors pictured above you would have some neg offset and they would stick out to far...but that is only if the offset of the wheel is correct..(from what I read in CIP1 catalog and vw trends.
      LUNAR LOUNGE
      MID CENTURY FURNISHINGS AND DESIGN
      www.lunarloungedesign.com
    7. Banned
      Jun 22nd, 2006
      08-31-2006 01:36 AM #7
      The wheels on that car are 5x130 Porsche steel wheels. There were on some cars in the US. Ive seen a set in the junkyard. The regular ole Porsche adpaters everyone uses will work for those wheels.
    8. Member jonny_breakz's Avatar
      Jul 26th, 2002
      Wpg Mb Canada
      99 Ford Ranger XLT
      08-31-2006 01:44 AM #8
      Are yo certian? by the pattern of the holes they look standard beetle wheel to me...not doubting you..but it would make fittin easier...that is of course if the porshe steels were in the ET 40-50 range..
      LUNAR LOUNGE
    9. Banned
      Jun 22nd, 2006
      08-31-2006 01:47 AM #9
      Quote, originally posted by jonny_breakz »
      Well ive seen 15" steel wheels just like that on a 924 in the junkyard and they even had the same hub caps with the P logo. They were 52.Xet.
      Theyre still in the yard. There are only 2 hubcaps and thats why i never got them. Maybe i someday ill go get em. They aint going anywhere in that place. Theyve been there for years.
    10. 08-31-2006 01:50 AM #10
      jonny_breakz: Thanks for the info...
      DefHare: Thanks for pointing that out!!! I swore those were pre-'67 5-wides... I have a set of 5x130 adaptors laying around so the Porsche wheels could be a viable option...
    11. 08-31-2006 03:35 AM #11
      Quote, originally posted by Digital-K »
      Why would that not be balanced? As lonfg as the machining is 100% on, the balance should be pefect. The 4 lugs are evenly spaced, and so are the 5 lugs, as bad as it looks in theory, it should be 100% balanced with parfect machining.
    12. Banned
      May 27th, 2002
      08-31-2006 03:47 AM #12
      this is gonna be good
    13. Banned
      Nov 10th, 2005
      08-31-2006 09:55 AM #13
      Mr. Breakz don't forget with a steel wheel you have the option to make it any et and width you want. You just gotta send em to that old dood Harley.
    14. Member jonny_breakz's Avatar
      Jul 26th, 2002
      Wpg Mb Canada
      99 Ford Ranger XLT
      08-31-2006 10:13 AM #14
      Quote, originally posted by FrameSparks »
      true...one can modify the wheel to virtually any offset so I suppose this is an option.
      I spoke to the owner of that car, he was on here last winter , he is german and spoke some english and I tried to find out more info on his set up and he said it was adaptors but didnt get back to me on lug pattern or width..
      a shame really....have not seen or heard from him since..
      I never really ventured into this as I am rocking fox steels on fancy and have been asked a number of times what air cooled model they are from.
      mk2's have a 14" steel wheel that resemble a bug steel quite a bit with the hole pattern and shape, that would also be viable option as well...Im sure you can fit some sort of bug cap on there..
      LUNAR LOUNGE
    15. 08-31-2006 10:13 AM #15
      do you have any idea what yer talking about?
      try giving the guys at http://www.motorsport-tech.com a call they make custom adapters for pretty cheap/decent quality. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    16. 08-31-2006 10:52 PM #16
      Quote, originally posted by Mr.golf »
      hee hee hee... jonny knows...
      where're you at this weekend???
