Page 3 of 18 FirstFirst 1 2 3 4 5 6 7 13 ... LastLast
Results 71 to 105 of 628
Thread: Project Build: sc2020
  1. Member sdezego's Avatar
    Apr 23rd, 2004
    Hurricane Central FL
    01-10-2007 11:08 PM #71
    This weekend or so...
    Build: Project sc2020
    My G60 now on MS3 | 4Cyl Torque Plate Rental | 02M Mounts
  2. Member sdezego's Avatar
    Apr 23rd, 2004
    02-06-2007 11:05 PM #72
    A little update...
    I finished the welding. The head was preheated and slow cooled in my oven. You should have seen my wife's face when she opened the oven to cook some pork chops I also did some rough machining and had it shaved for a finished HG surface. I went with the plan from the previous page (See Pic) and ended up creating the interconnecting oil drains to the corners. Welding this buildup was not fun due to the tight spaces and trying to get the TIG torch in there, but I managed.
    One Key note is that I was so focused on the oil drains that I noticed that the crush zones on the head gasket between the back of the head and the Cylinders impeded into/near/too close to the cooling jackets for my satisfaction. So, I ended up bridge welding those as well. (see annotated pic below)
    Pics after the machining will be up tomorrow. (click to enlarge)
    Drilling the Oil Galleys
    Plugging the Oil Drains machined from AL Rod to aid in Plug Welding
    The HG Crush Zone I was referring to
    One of the corner drains welded but not yet machined (very poor pic I know)
  3. Member sdezego's Avatar
    Apr 23rd, 2004
    02-07-2007 02:07 PM #73
    Teaser Pic. Notice the build up areas on the Exhaust side for the new Oil Drain Galley(s) interconnecting the 3 center drains to the corners respectively. Also, notice the now bridged area between the Cyls and the rear (exhaust side) of the head.
    Have not finished the machining here:
    - Corner Block Drains have not been redrilled
    - Rear Coolant passages, not opened up yet to match Headgasket.
    - Large offset front drain not remachined
    - Head has not been PnP'ed yet
    Click to enlarge
    Before and after:
    Modified by sdezego at 2:12 PM 2-7-2007
  4. 02-07-2007 07:36 PM #74
    Meticulous attention to detail
  5. 02-07-2007 07:42 PM #75
    Quote, originally posted by leebro61 »
    It is good to see people do things right for a change
  6. 02-08-2007 02:40 AM #76
    how much did you machine off after the welding?
    sure your pistons aren't gonna hit the valves?
    why so much buildup in the galleys?
    Modified by Urieal at 12:13 AM 2-8-2007
  7. Member sdezego's Avatar
    Apr 23rd, 2004
    02-08-2007 07:50 AM #77
    Quote, originally posted by Urieal »
    .010" to clean things up and re-true
    Yes
    Not sure what you mean by "So Much Buildup". There was a bit more welding there than I initially planned, but it was necessary because of limited space in trying to get the Tig torch in there to flow material.
    I mentioned in the 20v thread that if I had to do it over again, I probably would not do the oil galleys again. Just because of the amount of work involved for something that is questionably needed. Technically, having the drains will prevent oil pooling by #2 &#3 cyl's exhaust valves. The other mods and the bridging are necessary IMO.
    Shawn
  8. Member d-bot's Avatar
    Sep 6th, 2004
    Par 5 from the Space Needle, PNW.
    80 Storm 20vSC Syncro, 93 Corrado VR6
    02-08-2007 01:12 PM #78
    Quote, originally posted by brilliantyellowg60 »
    definitely. Keep this baby rockin!
  9. Member sdezego's Avatar
    Apr 23rd, 2004
    02-12-2007 10:47 AM #79
    Head Modifications progression recap. (Before-During-After)
    - Welded and block 3 rear oil drains
    - Welded and re-machined 2 rear corner drains
    - Welded and re-machined Front left Oil Drain
    - Bridge welded rear head to cyls and modified rear cooling circuits
    - Welded material on rear of head to interconnect Oil Drains that were blocked off to each corner drain via Drilled oil galleys
    - welded and redrilled head dowel Line up holes
    Before and after:
    Click to enlarge
    Modified by sdezego at 11:03 AM 2-12-2007
  10. Member sdezego's Avatar
    Apr 23rd, 2004
    02-12-2007 10:49 AM #80
    Now that the head modifications are pretty much done on to other head work
    Teaser - Click for larger pic
    Edit: I should add, the left two intake ports are unmodified in that pic. Look at the transitions to the bowl area. If the head flows as well as it does stock, imagine what it will do with a little port work.
    Modified by sdezego at 10:57 AM 2-12-2007
  11. Member Retrographic's Avatar
    Aug 11th, 2005
    Salem, WI
    90 Corrado G60 / 81 Rabbit Diesel
    02-12-2007 10:50 AM #81
    to make this project even better you should add a t to the end of the title.... like
    sc2020t
    that
  12. Member Shawn M.'s Avatar
    Oct 15th, 2002
    Brentwood, MO
    1998 GTi VR6 Ginster
    02-12-2007 10:53 AM #82
    wow
    amazing buildwork.
  13. 02-23-2007 02:04 AM #83
    any way you could post up a pic of the head with the ABA head gasket sitting on it, so we can see how it matches up
    thx
  14. Member sdezego's Avatar
    Apr 23rd, 2004
    02-23-2007 08:27 AM #84
    thx
    Not really sure what you are asking for. You want to see the how the HG lined up before the mods or after?
    The HG Lines up perfect with the corner drains and is the exact same diameter now. All cooling holes line up. So, If I place the HG on the head an take a pic you won't see much. Also, laying the HG on the head is deceiving because a lot of the issues were with the HG crush zones, so that is/was hard to illustrate with a pic.
    Let me know what exactly what you want to see and I can take a pic.
  15. 03-20-2007 03:03 PM #85
    wow
    massive props!
    Quote Originally Posted by Pineapplegti ! View Post
    Brand enthusiasts are idiots.
    Klutch Republik - Live Fast , Drive Hard
    SCCH Cylinder Heads & Suspension Components
    OSD #16
  16. Member nomad1721's Avatar
    Apr 4th, 2005
    Fort Collins, CO
    2012 Golf TDI, 1990 Corrado G60, 1988 Jetta Coupé (Gone but not forgotten)
    03-20-2007 07:55 PM #86
    Quote, originally posted by golf198v3.0 »
    wow
    massive props!
    X2
    They ended up buying my Corrado, I offered to sell them my Bentley. But they didn't want to spend the $40 I was selling it for. Poor bastards.
    SpoonfedTuningdubNationColorado Junk Yards
  17. Member sdezego's Avatar
    Apr 23rd, 2004
    03-20-2007 08:46 PM #87
    Thanks guys! If there were 30hrs in the day life would be good
    Too many projects that are taking precedence which is why there is not much progress in the last few weeks
    Like this one for example (Not related to this build).
  18. 04-04-2007 03:05 PM #88
    its time for updates! lets see how it's going!!!
  19. 04-04-2007 05:01 PM #89
    Ditto.... What have you been up to?
    Turn the heat OFF!
  20. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    04-04-2007 10:06 PM #90
    Quote, originally posted by 32176G60 »
    Busy doing NADA...
  21. Member sdezego's Avatar
    Apr 23rd, 2004
    04-04-2007 10:13 PM #91
    Just too damn busy in general. I spent the last 36hrs alone in Tax preparation hell
    And, as usual, other people stuff takes precedence over my own. But that is done and here are some pics of some 8v love (full thread to come).
    ...Letting the owner do the fine finishing inside if desired.
    However, with all that said, last weekend I made good progress on the head and have all of the intake ports ported (Yes all 12 of them :bandhead: ). Not all polished yet, but I will take some update pics.
    I am also questioning my Trans heavily and am seriously thinking about an 02m with maybe a 3.94 of 4.11 'ish Ring and Pinion. I hate the G60 gearing. I just need to find someone that will either make some form of a trade trade for my Silver Corrado or buy it outright, etc.
    Shawn
    Modified by sdezego at 10:53 PM 4-4-2007
  22. 04-04-2007 10:20 PM #92
    Quote, originally posted by sdezego »
    Shawn
    just get some VR gearing and a diff
  23. Member sdezego's Avatar
    Apr 23rd, 2004
    04-04-2007 10:42 PM #93
    I am most certainly considering that as an option. Unfortunately, I sold the Vr trans that I had as part of the swap Might need to look what I can get the gears for. In addition, if I stay 5spd, I definitely want a .72ish 5th. I miss that from my Turbo Scirocco.
    ..the 02m though, adds just enough complications that could quench my OCD briefly Realistically, the 02a with Vr gears makes the most sense.
    LSD is happening regardless of the choice.
  24. 04-04-2007 10:45 PM #94
    i got 2 sets of vr gears for free
    there are plenty of vr trannys with blown diffs out there
    my .7 5th cost me $300, well worth it, i will save that in fuel eventually
  25. Member sdezego's Avatar
    Apr 23rd, 2004
    04-04-2007 10:52 PM #95
    LOL nice. For that price, problem would be solved and decision finalized
  26. 04-04-2007 10:53 PM #96
    i'll give you one of my old sets
    just needs third gear
  27. 04-05-2007 10:25 AM #97
    How's the header coming along - looking forward to seeing some pics of it with the 20v flange. I was wondering, if the Supersprint 16v header is Stainless, how are you going to unstress the primaries? so there is no added force on them when they heat up, because stainless likes to expand.
    Modified by SameoldVW at 7:27 AM 4-5-2007
  28. Member sdezego's Avatar
    Apr 23rd, 2004
    04-05-2007 01:41 PM #98
    are both the Main and Counter 3rds toasted? That's close to $300 alone no? Maybe that's the reason for the LOL
    If you have a good complete set that you might be interested in selling, LMK. I would need the shafts, etc too though (at least the mainshaft I know) since they are different than the ATA/AYL. If the set only needs one gear, I may be interested and have something that may be of interest to you
  29. Member sdezego's Avatar
    Apr 23rd, 2004
    04-05-2007 01:52 PM #99
    Quote, originally posted by SameoldVW »
    I won't be getting to that for a little while. I may even wait until last so that the engine is in the car and I can get it positioned precisely. I am not one that like exhausts hitting the tunnel or Rack
    The Supersprint header is SS and super high quality. They use separate Mild steel flanges on each primary as pictured earlier. The Flange I have is actually SS and one big piece as you can see from the pics. I assumed that Supersprint used Mild steel for cost savings, but that may not be the whole case. I am undecided and have read a lot of conflicting opinions on the latter in regards to Turbo Manifolds. I am always open to opinions and suggestions from experience. All of the headers I have ever made were all Mild steel. The welding will no doubt be back purged and TIGed regardless.
    Shawn
  30. Moderator WolfGTI's Avatar
    Jun 16th, 1999
    Some where down the islands.
    2.0 NA 20v, 2.0T 16v, 1.6 16v SC
    04-05-2007 02:21 PM #100
    Cool work Shawn, looking forward to seeing your project all done, my header doesn't rub the tunnel or rack.
    R.I.P Barbaro
    I'm all for a clean car, and lowering for performance reasons, decent wheels, etc... but this "stance" crap sucks.
    Quote Originally Posted by 302W View Post
    lol wut? You can have the baddest carbon brakes straight of an Enzo, it doesn't mean jack **** when your contact patch is 1/3 the size it would otherwise be, and partially the sidewall
  31. 04-05-2007 05:40 PM #101
    yeah both are toasted
  32. 04-23-2007 12:09 AM #102
    Quit it with the yardwork and get back on this project, we want updates!
  33. Member sdezego's Avatar
    Apr 23rd, 2004
    04-23-2007 10:46 AM #103
    haha, yea no doubt. I have some updated pics that I need to post, but was hoping to get all of the PnP finished...
    As it stands, everything is now ported. I just need to sand and then polish.
  34. 04-23-2007 11:21 AM #104
    i hope you have a flowbench
    Quote Originally Posted by MotownSVT View Post
    There's a larger collective IQ in the load I blew down the shower drain this morning than behind the counter at any Starbucks within a 10-mile radius of my house.
  35. Member sdezego's Avatar
    Apr 23rd, 2004
    04-23-2007 05:15 PM #105
    Quote, originally posted by skaterhernandez4 »
    Why do you hope so? ..and why the sad face before even asking?
    flowbench provides validation to you and others that I know what I am doing, and I don't need that sort of validation. Lets just say, that I am not new at this.
    Look above at the one finished port on the right, and if you see any flaws in my work, please be sure to comment.
    Shawn
