Page 1 of 2 1 2 LastLast
Results 1 to 35 of 52
Thread: Boostvalve's Latest Dual Stage MBC Installed!!
  1. Banned SAVwKO's Avatar
    Mar 8th, 2003
    09-04-2006 04:55 PM #1
    Many of you have heard of Boostvalve, some of you have actually used Ric's products, and others may want some more info. Well I just got my hands on his latest dual stage boost controller. Yes, for awhile I believe he had available a setup to use two Boostvalves with an electronic solenoid, but he just released a distribution block for them to clean up the install. I also decided to take it a step or two above just the simple low-high boost with the flip of a switch.
    What I chose to do is rig up a 3-way switch that could flip from low boost, to high boost, to low boost in 1st gear and high boost in all others.
    Here is the heart of it all...what a beaut!
    Boost from the turbo goes in thru the right side of that block. Not shown is the nylon barb that I didn't have screwed in when I took the picture. The air then goes thru either the low boost or high boost Boostvalves, controlled via the solenoid, and then out the bottom to the wastegate actuator. Pretty simple.
    This isn't gonna be a step-by-step DIY as I don't believe that this is a mod someone just getting into this should do. I highly suggest that you're someone who's actually done some mods to your car by yourself, and are familiar with wiring and taking off interior panels. You also need to have some technical know-how, unless you just want to G-rig it all up. But since this is my girls car , the install was done cleanly and "professionally."
    First I just gathered up some tools. Here's a lil pile of all my shtuff:
    First thing's first, take off the steering column panels and also the center console. There are threads on this in the Mk4 DIY section so go there if you need to. You'll need to pop up the shifter cover also.
    Here is where I decided to mount the MBC.
    Pick whereever works best for you. Used the supplied screws and also some 3M molding tape. Run your vac lines and connect them properly to the solenoid and Boostvalves.
    Start running your wires according to this diagram:
    I brought them thru the shifter console as shown here. Red is power and just goes straight to where I'll have my switch mounted. The yellow and black wires will be used with the 1st gear switch:
    Here's the 3-way rocker switch I used. I measured and used a dremel to cut out the square. The switch just snaps right into place:
    Here's the underside with the wires connected:
    Final mounting orientation and what the hoses and wiring looks like. The loom is used to keep it looking clean but there's no need to really use it.
    I hid the power and ground wires inside the loom I'm already using on the stereo power wire. I positioned the fuse right next to the stereo fuse.
    Now the trickier part. The 1st gear switch. You need to mount in in such a way that only 1st gear will click the switch, but 3rd won't. Reverse is fine since who needs 20+ psi in R? I had some spare metal and just cut and drilled and stuck together with 3M molding and bolted to the shifter ring. Made sure the switch was oriented correctly and screwed it into the metal. Then I made the connections:
    Here's 1st gear, and you can see the switch is clicked or in it's CLOSED position.
    And here's the finished product inside:
    Pretty straight forward install, just time consuming. I just leave it in low boost driving around to save gas. Also with the part throttle spikes you may see, it's not as bad when it only goes to like 11psi instead of 20+. Then if someone wants to play, I switch it to the right, the II symbol for all high boost. And then when I go to the track, I'll switch it to the I symbol for low boost in 1st to help with traction and then it'll go right into high boost upon shifting into 2nd.
    I tested it all out and now it's just a matter of tuning the boost levels, more so the low boost for 1st gear. Very nice upgrade to have, especially if you're used to flooring it on open roads and also hate filling up every 4 days.
    If anyone is interested, the switches were sourced from Mouser Electronics online...www.mouser.com. The part numbers are as following:
    3-way Rocker Switch : 612-R5DBLKBLKCF0
    $3.15
    Snap-Action Switch : 540-E21-50K
    $6.46
    Go check out Boostvalve.com and tell Ric you really want this new setup.
    One last thing to add: Even if you do not plan on going with this extravagant of a setup, Ric provideds EVERYTHING you'll need for a low/high boost setup. The switch, DIRECTIONS, wiring, connectors, hell even the zipties are included. He'll hook ya up! I was a satisfied customer when I bought my first boostvalve for my GTI, and now I'm satisfied 10-fold with this new dual stage.
    Cheers!
  2. 09-04-2006 05:10 PM #2
    awesome writeup
    the 1st gear switch looks kinda fragile, like if it could slip if you don't engage consistently.
    The install looks perfectly clean
  3. 09-04-2006 05:11 PM #3
    great write up and product! I am running the stage2 for 1 1/2 years now without any problems. I just wrote Ric an e-mail because I want to upgrade my old style installation to the new block version. Looks much cleaner.
  4. Member 1.8tizzle's Avatar
    May 22nd, 2003
    VA
    TL Type-S
    09-04-2006 05:18 PM #4
    thats my boy. good job dude. very clean.
  5. 09-04-2006 05:31 PM #5
    yeah man, good deal.
    MK4 Junker : PAG 50trim Kit : AEB : RMR : Eurodyne
    P.P.T. - Pag Parts Turbo
    B6 A4 : Slow
  6. Banned SAVwKO's Avatar
    Mar 8th, 2003
    09-04-2006 05:37 PM #6
    Quote, originally posted by 27psiBoom »
    awesome writeup
    It does look that way but as long as everything is tight it works everytime. But if it WOULD miss, all I have to do is pop the shifter cover, turn the assembly a lil and retighten the bolt. No problem.
    Tizzle, you know how I do.
  7. Member 1.8tizzle's Avatar
    May 22nd, 2003
    VA
    TL Type-S
    09-04-2006 07:32 PM #7
    Quote, originally posted by SAVwKO »
    haha word to that..... hows it workin' out so far?
  8. 09-04-2006 07:51 PM #8
    nice find on the WOT switch, i know many companies put their logo on them and sell them for 35+ when they are on there for 3-6$.
    FFE Racing
    FFE Parts
    1015whp 20v on Gasoline - 9.61 lifting.
    "ignorance can be temporary, stupidity is forever"
  9. Banned k0mpresd's Avatar
    Mar 17th, 2005
    09-04-2006 09:07 PM #9
    ive bought led's from mouser before....they have tons of stuff
  10. 09-04-2006 10:29 PM #10
    Looks very interesting!
  11. Banned SAVwKO's Avatar
    Mar 8th, 2003
    09-04-2006 10:30 PM #11
    Quote, originally posted by k0mpresd »
    Yes they do! Got their catalog and it weighs probably 10lbs! Enginerd pointed me in the right direction on the 1st gear switch, just looked one up in the catalog and ordered it lol.
    So far, the drag setup does like it should every time. Switch is working perfect. Was driving home from my buddy's house tonight and thought of something that needs changed...I wanna find a 3-way rocker that will illuminate red, and rig it to the dimmer switch. I think it'd be cool to see the I, O, and II lit up on that. I don't want just a whole switch lit up, just the letters. The search begins
    Jul 28th, 2004
    2007 United Grey GTI
    09-04-2006 10:30 PM #12
    Mouser is the electronics supply god.
    07 United Gray GTI
    Quote Originally Posted by veedubtek
    ...I am very meticulous in my inspections (vw master certified, finalist in the world service qualification championships last year).
    Quote Originally Posted by mk2vdubber
    walt - what are the torque specs on a vr6 head?
    1/2" impact gun on the 3rd setting.
  13. Member T-Boy's Avatar
    Jul 16th, 2003
    ATL
    09-04-2006 10:34 PM #13
    nice setup....Rick didn't have that block setup wheni was messing with the boostvalve.....pretty cool.
    APR Stage 3071R+
  14. 09-05-2006 07:15 AM #14
    Looks good.
    Pretty funny how first can only hold 12 psi before you break the tires loose.
  15. Banned SAVwKO's Avatar
    Mar 8th, 2003
    09-05-2006 07:41 AM #15
    Quote, originally posted by enginerd »
    Looks good.
    Looks good.
    It holds 10-11 in first (low), but as soon as it hits 4k rpm, it rises to 16 or so. It's b/c the WG rod is cranked and it wants to hold 15 at redline so it's pretty nice, get some extra boost at the top of 1st.
  16. Banned SAVwKO's Avatar
    Mar 8th, 2003
    09-05-2006 11:22 AM #16
    Bump for more to see.
    Going draggin Friday at a good track. We'll see what it does.
  17. Member SnowGTI2003's Avatar
    Jan 7th, 2004
    Guelph, Ontario
    10 cylinders, 6L, 600hp
    09-05-2006 11:24 AM #17
    I'm sure you can use more than 11psi in first gear....
    What tires are on there?
  18. 09-05-2006 11:54 AM #18
    thumbs up to you man. thanks this will come in handy one day.
  19. Banned under boost's Avatar
    Apr 22nd, 2006
    09-05-2006 11:59 AM #19
    nice work mike.
  20. Member Junk T.I.'s Avatar
    Sep 17th, 2003
    central NJ
    09-05-2006 01:02 PM #20
    me likey.....
    01 GTI 1.8T big turbo ghost...
    02 Jetta GLX
    VW/AUDI MASTER GUILD WRENCH
  21. Member theAntiRiced's Avatar
    May 6th, 2005
    Baltimore
    09-05-2006 01:09 PM #21
    Very nice, only thing I would change is the location of the switch.
    I sold my bagged VW and bought a 5.0?
  22. Banned SAVwKO's Avatar
    Mar 8th, 2003
    09-05-2006 01:13 PM #22
    Nice spot! I actually wanted it to be as close to the shifter and as accessible as possible while still looking OEM. That way you just drop your hand off the shifter and tap the switch ya know.
    As for the 11psi in 1st, that's only down low. B/c the WG is cranked, it holds 15 at redline so once I'm at 4k, it's at 16psi, not 11 anymore. We'll see but so far looks like I'll be able to about dump the clutch and not spin out.
    Oh and they're the OEM F1's right now. When I drag on go the 16in steelies with Falken Ziex 512 tires...not sure on the measurements.
    Modified by SAVwKO at 1:15 PM 9-5-2006
  23. Member theAntiRiced's Avatar
    May 6th, 2005
    Baltimore
    09-05-2006 01:19 PM #23
    Yea, your switch is really easy to get to. The ones I put in are easy to hit, but sometimes I need to pull a CD or junk out of the way. My switches aren't for boost, so I didn't need them as prominent (you can't even see them when sitting).
  24. Member quiksilverGTI's Avatar
    Feb 25th, 2004
    Orlando, Fl
    99 BMW M3
    09-05-2006 03:44 PM #24
    you are the man, very nice install and writeup. thanks for the part #s for the switches, this is something i'll be doing in a few months after i install the k04-20 among other things.
    two for you!
  25. Banned SAVwKO's Avatar
    Mar 8th, 2003
    09-05-2006 05:31 PM #25
    Quote, originally posted by quiksilverGTI »
    two for you!
    Gracias! I'm still looking but if anyone knows where to source a 3-way rocker that looks exactly like the one I used, but will light up red, let me know. In daylight it looks like an OEM switch because the white and the font of the symbols resembles all the switches on the dash. If they could light up red like the dash, perfect at night!
  26. Member SleepyGTI's Avatar
    Dec 22nd, 2002
    Youngstown, OH
    '09 CC Luxury, '93 Civic Si
    09-05-2006 11:22 PM #26
    What's up newb?! lol
    I love my Turbo XS DSMBC but your setup is sweet!! Switch color also blends nicely with the factory panel coloring!!
    Gotta love anyone who can do tech/DIY posts
    P.S.- I joined b4 j00!
    And by the way, get some good times!!!! I wanna have to get another mod to stay ontop of the game muahahahaha
  27. Senior Member mujjuman's Avatar
    Jul 29th, 2004
    New York
    2001 VW Jetta VR6, 2006 VW Jetta 2.5
    10-20-2006 06:43 AM #27
    bravo! what an ingenius idea!!
    mujjuman
  28. Banned SAVwKO's Avatar
    Mar 8th, 2003
    10-20-2006 12:38 PM #28
    Quote, originally posted by mujjuman »
    Thanks! Def helps at the track...otherwise 1st gear is useless.
  29. 10-20-2006 12:56 PM #29
    clean install, looks nice
  30. 10-20-2006 01:09 PM #30
    great writeup
  31. Banned SAVwKO's Avatar
    Mar 8th, 2003
    10-20-2006 01:15 PM #31
    Quote, originally posted by Tetzuoe »
    great writeup
    I'm getting good at em lemme tell ya. Stock turbo intake testing, this, water/meth...
  32. 10-20-2006 01:19 PM #32
    btw the circuit symbol for a fuse is this:
    http://epb.lbl.gov/xfig/librar....html
  33. Member O2VW1.8T's Avatar
    Jul 9th, 2003
    2013 335I, 2012 Tundra 4x4
    10-20-2006 01:56 PM #33
    stage 4 like whoa. I might try this one later in the future
    http://turboelements.com/index...Id=75
    02 GTi 1.8T haldex'd w/35r-SOLD 7.3@102mph 27psi on 93 octane--04 A4 1.8T converted to AWD also- SOLD--'11 JSW Tdi 6speed Manual- Gone--
    13' BMW 335i M-sport EBII
  34. 10-20-2006 01:56 PM #34
    Im looking for a good bullet proof boost controller. I might have to consider going for somethin like this. My kinetic mbc died because the adjustable screw fell out while i was driving and gave me a 28spi + spike which scared the hell out of me (only for a split second).
    Its either something like this or ill go with an electronic controller, but im not sure how reliable they are...
    Modified by Public-Enemy at 6:59 PM 10-20-2006
  35. Member O2VW1.8T's Avatar
    Jul 9th, 2003
    10-20-2006 01:58 PM #35
    turboelements has been on 9 sec cars.. I dont think i'd recommend it for stock turbo or even some big turbos. Unless you have traction issue's all the way to 3rd
