VWVortex.com - 01045 - Tiptronic switch (F189), implausible signal - info here!
    Results 1 to 15 of 15
    Thread: 01045 - Tiptronic switch (F189), implausible signal - info here!
    1. Member penclnck's Avatar
      Jan 26th, 2003
      Knuxville
      2004 Jetta, Jetta and R32
      09-06-2006 08:57 PM #1
      Learned something new today....
      For those of you with tiptronic trans, if your PRNDL display blocks out and you have the inplausible signal DTC, here is something to check (for what it is worth, I seem to only run into this with the NB)...
      The tiptronic switch asm uses HAL sensors and magnets. There are two magnets, a very tiny brick shapped one, a cyclinder shaped one. The cyclinder shaped one is in a little bracket that slides/snaps to a plastic carrier strip. What will happen is the bracket that holds the cyclinder magnet will pop loose and move back about 1mm, just enough to screw with you.
      I had a brand new car with that DTC, my wiring tested out perfect. I order a new Tip switch and install... same issue. Hmmm... maybe I got a dud out of the box, order another switch... again, same problem. Turns out ALL THREE OF THEM had the same problem. I took the tiptronic switch asm all apart (simple, just snapped together) and put a dot of superglue on the cyclinder magent bracket and snapped it into place. Did this to all three of the tip switches, now they all work perfect.
      So, before you run off and replace said switch, check that cyclinder shaped magnet, see if you can push it in (the bracket is kind of "wedge" shape), if you push in on it (towards the center of the asm), you should feel it click into place and the edge will be even/flush with the part it is fitted to.
      You will understand this when you see if first hand. I should of snapped a pic but I forgot my camera.
      Enjoy.
      Pencilneck blah blah blah
      The largest collection of VW OEM wheels!
      http://www.4130-products.com/wheels
    2. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      09-10-2006 12:03 AM #2
      On this same topic, Phaeton and Touareg owners have discovered that the little sliding plastic plate that holds the magnets can be very, very easily broken if the technician is not careful when inserting the chrome plastic base of the shift lever handle.
      There are some photos of the part, and discussion about how it gets broken, at this post: Retrofitting Keyless Start to a North American Phaeton - look about halfway down the second page of the thread.
      Michael
    3. Member spkn^GRMN's Avatar
      Jul 24th, 2002
      Charlotte, NC
      Segway turbo
      11-12-2006 09:19 AM #3
      I know where the magnets are, but can you take a few pics of your spare switches of the area that needs this fix?
      thx
      -Wes
      2015
    4. Member vr6jettajay's Avatar
      Oct 29th, 2006
      Titsville, FL
      81 rabbit diesel 4dr, 00 golf gls tdi 4dr
      01-18-2010 10:02 PM #4
      Quote, originally posted by spkn^GRMN »
      thx
      ^ anyone?
      2003 Jetta GLX VR6 - sold
      1984 Cabriolet Wolfsburg - traded
      1981 Cabriolet - traded
      1986 Golf GL sold
    5. 12-28-2010 08:07 PM #5
      where is the tiptronic solenoid located on the shifter?
    6. Junior Member
      Jan 4th, 2011
      01 jetta t1.8
      01-04-2011 11:34 PM #6
      just get the whole new tip switch assem
    7. 04-19-2012 08:21 AM #7
      looking for the locaton of these magnets. I have an 04 vw touareg and only see 1 magnet on the rubber slid piece
    8. 04-27-2012 04:11 PM #8
      just figured this damn thing out. message me if anyone ever needs help :
      Apr 18th, 2012
      San Diego CA
      89 Jetta 8v
      04-27-2012 04:48 PM #9
      Quote Originally Posted by dub703 View Post
      I pm'd you.
      1142 Generator Mechanic.
      USMC
      '09 - Now.
    10. Member
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      04-27-2012 08:53 PM #10
      Good tip, but this is probably the wrong forum for the thread. I suggest moving it to the Automatic Transmission forum.
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
    11. 08-12-2013 04:54 AM #11
      good day. Read your post regarding the tiptronic fault on the vw new beetle convertible. How did you get to fix it?
      thanks!
      gelogarcia@gmail.com
    12. 11-19-2013 12:32 PM #12
      Hey how's it going. I saw your post on a thread here on this website and you wrote that you could and are willing to help out with the tiptronic switch issue. I am currently having a problem with this and I have little to no experience with things like this.
      I'm getting the 01045 code
      I was told the tiptronic switch is inside the transmission and to repair it would require taking out the entire thing.
      Any help would be great thanks a lot.
    13. 08-30-2015 06:02 AM #13
      Hi there,
      This is James from down in Australia. I need help as I have replaced the Multi function switch & T-Bar printed circuit Bord & still no luck
      When taking the shifter from P to D all the segments in the dash display light up & when scanned the fault code reads 'Tiptronic switch (F189) Implausible signal'.
      If I was to start the vehicle in N then move the T-Bar to D everything works fine. This thing is driving me crazy!
    14. 09-01-2015 12:30 PM #14
      This is exactly the problem I'm having with my 2002 A6 Allroad.
      Start up in Park, move to Drive, solid red bar. Car still drives normally but no manual or Tiptronic function.
      Fault code for F189 Implausible Signal.
      Switch ignition on, move to Neutral. Switch off, then start up in Neutral and shift to Drive - car drives normally and Manual + Tip buttons work.
      So far:
      The F189 switch has been overhauled, magnets glued in place. VCDS Lite acknowledges the stick in every position (and half-positions), so I'm reasonably happy this is working correctly.
      Tiptronic buttons and manual gearstick both indicate correctly on VCDS Lite, as do throttle, kick-down and brake switches.
      The F125 on the side of the box has been replaced.
      I've fitted a second-hand TCU (this has improved the driving but hasn't cured the above fault).
      I've chased the wiring through as best I can, no sign of any dry/corroded/bent pins, no water ingress into the footwells.
      Although this isn't a major fault, its a PITA and I'm out of ideas on what to check next.
      Any ideas?
    15. 03-02-2017 09:12 AM #15
      Quote Originally Posted by cieranc View Post
      So far:
      Any ideas?
      i have the same problem , diagnostics read ( Tiptronic Switch (f189) implausible Signal P1753 , 18161)
      I have had three different people tell me three different things.
      1. tiptronic switch under the gear stick ( green board) which the latest gearbox specialist tested for me.. he is convinced its the switch only.
      2. the gear control arm ( transmission control unit )
      3. loose wiring etc
      my question is there any way of really testing which one is faulty?
      taking my board out and taking it to a guy that can test it .
