#36
Would it be possible to switch the projector housings with aftermarket units that have halos?
I'd like to use these if possible, I obviously need to mount the extra power units, what else do I need to consider?
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
#37
Please don't send me technical questions via IM - instead, post your questions onto the end of the most appropriate thread in the FAQ, so that everyone can benefit from the answer, and everyone can assist in providing the answer. Thanks, Michael
#38
Yeah, I know. I hate the cars I see that have aftermarket lights that blind all oncoming traffic, and that's why I asked. I would really like to have halo rings as my DRL's, like the BMW's, and burn the HID's only at night. Since I'm going to do the headlight retrofit anyways, I figured I'd ask how complicated it would be to do correctly and keep the beams in line with the safety standard. I don't want to be the guy that looks like I have my brights on all the time. Unfortunately The new LED lights seem to have a hard time syncing with an 04 model, so I'm trying a different route.
#39
#40
Bobby:
I would like to help, but I am out of the country right now (in the Seychelles, which is on the opposite side of the world to North America) and I will be working every day from now to Feb 12 training pilots.
I will do my best to try and dig up some information that I can post in text format, but I won't be available for back-and-forth text conversation until I get back to Canada, which is foreseen for about mid-February.
Michael
#41
#42
Hi Bobby,
You might as well have it done by the dealer since your headlamps will have been set up for the UK so will probably need to be aligned anyway.
Harry
#44
WHAT??? You have installed UK spec headlights on a North American car? That is NOT going to work. The European spec headlights (both left or right hand drive) have a beam pattern that provides about a 15 degree uptick towards the curb side of the car. If you put RHD headlights on a LHD car, that uptick is going to go towards the eyes of the oncoming driver, not towards the curbside.
This cannot be corrected by headlight alignment. The internal construction of the headlights is very different between RHD and LHD cars. The headlight casings are welded shut, I don't think it would be possible to modify the internal design of the headlights even if you had a very well equipped machine shop and considerable expertise in tool-making.
Michael
#45
Michael,
No, I am NOT installing RHD headlamps "as is" on my NAR Phaeton. As demonstrated by Harry and as stated in my post (linked below), I will be swapping out the beam cutouts so that the beam pattern conforms to U.S. regulations.
http://forums.vwvortex.com/showthrea...1#post69571956
I will be removing my NAR headlamps tonight and making the cutout swap.
Bobby
#46
Ah - OK, sorry, I have not been following the post that closely - I did not realize you were doing that.
Michael
#47
Michael,
Is the procedure for coding the dual xenons in the VW Repair Manual? I seem to recall seeing something in there about this. If so, is the procedure the same on the VAG-COM or is it a different animal? I'd like to do this part myself as I already have the VAG-COM and may as well use it. Also, if the dealer has to clear fault codes, code the headlamps, AND align them then they'll charge me (as they well should). My service adviser indicated to me a few weeks ago, after my telling him about my dual xenon retrofit project, that I could just bring my car in anytime to have them align the headlamps free of charge.
Bobby
#48
Bobby:
The dual xenon headlights don't have to be "coded" per se, because when you install the two headlight assemblies, you also install new controllers for the high beams at the same time. The low beam controllers on dual xenon headlights are the same as the low beam controllers on single xenon headlights In a dual xenon installation, these controllers don't interact with the car any differently than single xenon installation. It is actually the same controller for the low beam circuit - and the only interaction with other systems that involves that controller is watching the suspension system to see how the car is sitting, for the purpose of keeping the low beam lights correctly positioned in the vertical range of movement.
There is a "basic settings" or "adaptation" script (I'm not sure which) that is invoked when you align the headlights. I carried this work out using the VAS 5052 diagnostic scan tool at my VW dealer, and using the Hella Beamsetter (headlight alignment tool) at my VW dealer. I used the "guided functions" capability of the VAS 5052 to put the headlights into the alignment mode - this whole process is well explained in the VW service manual documentation and in the guided functions portion of the VAS 5052.
Once the alignment is complete - and the alignment itself is accomplished manually, using adjustment screws on the headlights - the two low beam controllers are then set back to normal operations mode. The whole low beam alignment process is identical to what is done with Phaetons that have only single xenon headlights. Alignment of the high beams (xenon or halogen, doesn't matter) is strictly a manual process, like it would be on any 1960s car with four headlights.
You can probably invoke the alignment setting using a VAG-COM, but I didn't bother even looking into how to do that, because although I have a VAG-COM, I don't have a Hella Beamsetter...so, I had to go to the dealership to use the Beamsetter, and it was much easier for me to just use the VAS 5052, complete with guided functions.
Michael
#49
#50
Michael,
early on in this thread you point out that you can pull the washer nozzle cover open and it locks in place, true, but how do you then close it? Mine is now just flapping around when previously all was well
Cheers
Stu
#51
Hi Stu:
If you put the headlight washer nozzles in the service position by using the appropriate command available from the Front Display Screen, the nozzle doors will be about 85% of the way open (they will be 'fully open' in the sense that that is as far as they ever open during normal operations).
You can then take hold of the nozzle door and move it forward about another 1 cm (3/8 of an inch) and it will mechanically 'latch' in the fully open position. It rides over a small cam when it does this.
But... if there is any degradation in the mechanism that normally drives the door to the fully closed position when the nozzle is extended, then it probably won't lock in the fully extended position.
In the photo below, the red arrow points at a U-shaped assembly that provides the spring force needed to return the door to the closed position, or, if you pull the door fully open, the force that is needed to hold it in the fully open position. Click on the image to enlarge it.
Michael
#52
Archival Note:
Another post describing dual xenon retrofit, but with greater detail about the construction of the headlight assemblies: My Dual Xenon Adventure.
Michael
#53
Photos re-hosted.
Michael
#54
Michael,
Reading over your wonderfull extensive thread including photo's and based on my job to renew my both dead controllers due to use of bad quality 8000k xenons, i just have a question. As i destroyed both my controllers using these 8000k xenons I had to renew both lower beam ballasts/controllers.
The lower beam controllers in my 2007 V6 TDI dual Xenon however were located on the side (behind the adjustment extension), not on extended back part as we should expect and as showed on the first picture. Perhaps there is a difference between ROW and NAR?
3D0907391 seems the right version for lower beam , 4 pins or 12 pins version (depending year of built). These controllers are very sensitive for non OEM Xenons, and very expensive.
Wouter
#55
Hello Wouter:
Dual xenon headlamps were never offered in NAR. I purchased the ones I installed in my car in Europe, prior to 2007.
It is possible that the headlamp assembly went through a change of design between 2003-2006 and 2007. The headlamps I purchased likely came from a MY 2003, 04, or 05 car.
Michael
#56
I wanna change my low beam xenon bulbs with Osram d1s 66144CBI Cool blue intense Xenarc 5000k... i wanna know if they will work whith my low beam controler because the oem osram instaled are 4150k ... or will give me some problem... i must change the low beam bulbs because they areflickering
Regards!
#57
I hope they work, because i have a set of four to install with the quad projector retrofit!
Cheers,
Andrew
#58
I don't know what to buy ...i must change the low beam bulbs because are flickering.
1- the oem osram 4150k
2- osram 5000k 66144CBI Cool blue intense
3- philips 6000k 002208WX
4 -philips 6000k Ultra Blue 85410
all bulbs are D1S model, any suggestion .
Thanks!
#59
D1S 6000k is a real nice white color, which really suits the Pheaton in appearance. Standard OEM xenons are color 4300k (a boring yellow) color) or 5000k, and these OEM's seems well adapted to the Phaetons lowbeam ballast/controller 3D0909157/158. Other xenons might damage the ballast and the aint cheap, 500 Euro each.. And i know :-(. These ballast seems very sensitive for cheap Chinese xenons, so be prepared. Dont use 30 euro xenons.
Wouter
#60
For 6000k i found Philips 002208 WX aka "Ultinon", or Philips Ultra blue 85410UB.... the philips 002208WX ultinon are not road legal "not for use in EUROPE/USA." but who cares![]()
#61
#62
Archival Note: See also this very interesting illustrated description of the same project by another forum member - My Dual Xenon Adventure.
Michael
