| Quote, originally posted by M1LUM » |
| • Sounds like you had a learning experience with removing the rear seat back... |
Hi Terry:
Yes, from a mechanical point of view, removing the rear seat backrest was probably the most difficult task in the whole process. The NAR Phaetons are coded such that the rear seat headrests lift up when the corresponding rear door is opened. This is to allow a child seat tether strap to be passed underneath the headrest to the upper anchor point on the hat-shelf that is provided on the NAR cars. I forgot to pull fuse 85 up at the front fuse panel before opening the rear doors, as a result, both headrests were up when the rear seat-back was removed - making it very difficult to get the seat out of the car. There is more info about this issue at this post: Automatic Movement of Rear Seat Headrest.
Removing and installing the rear seat backrest (and the rear seat lower cushion, for that matter) is a two-person job, and there is definitely a 'trick' to both un-latching and re-latching these two different pieces onto their retaining hooks. It took a while to learn the trick. Next time I get to Dresden, I will try to take some pictures of the experienced craftspeople at the factory installing these parts, so that we have a better 'how-to' guide for future reference.
| • What is, in your considered opinion, the best way of splicing into the CAN bus? |
Well, strictly speaking, it's very easy to do - the CAN bus wires are just twisted pairs, so all you have to do is splice a couple of wires together. However - one thing I have learned about the Phaeton is that it is critical that you follow the wiring diagrams exactly, right to the centimeter, when adding services. In the case of the CAN bus, even though the CAN bus is basically nothing more than a star-pattern two wire network (see this diagram: Controller Area Network (CAN) topology), following the wiring diagrams exactly means identifying the exact same junction point that VW uses in their wiring harness when you add a new controller. It's easy to find the junction point on the wiring diagram - in the case of the TV tuner, this controller (controller 57, component R78) connects at junction points B423 and B417. You can see this by looking at tracks 4 and 5 of the attached wiring diagram.
The difficult part is physically locating B423 and B417. Often, these junction points are actually inside the wiring bundle, not visible to the eye. In my case, I could see that the TV tuner made a 'T' junction into the Infotainment CAN bus somewhere between the Telematics (Telephone) controller and the main wiring harness. So, I located the existing CAN bus twisted pair coming from the telematics controller, and spliced into it just before it disappeared into the main wiring harness (the spinal cord, so to speak) of the car.
Working with the CAN bus is not difficult, as long as you remember that there are three different CAN buses (Drivetrain, Comfort, and Infotainment), and you make sure you are splicing into the correct one. Fortunately, the colour codes of the wires for the three different busses are different, and the colour codes are consistent throughout the vehicle for each bus. Polarity is critical and must be respected, but again, the wire colour codes make this easy to follow.
Michael
