VWVortex.com - VAG HELP P2279, Leak in Air Intake System?
    Results 1 to 15 of 15
    Thread: VAG HELP P2279, Leak in Air Intake System?
    1. Member 20VTBORA's Avatar
      Nov 2nd, 2004
      Miami,FL
      MK6 Golf TDI
      09-18-2006 02:06 PM #1
      I have a MKV GTI and I am having a problem with boost. As soon as the car hits 1 or 2psi the engine starts to bog and cylinders begin to missfire. I ran the vag-com and receive missfire codes for all cylinders and the got--Leak in Air Intake System P2279-002-Lower Limit Exceeded. Could this have anything to do with the faulty Diverter valves? Or should I be looking for Something else?
      PS: I have an EVOMS Intake installed but I checked all the connections and i DO NOT have a leak from my intake to MAF to turbo.
      Any Info would be great.
      www.DurtyDecals.com
      Vinyl decals and signs. Check out our designs or send us one of your own!
    2. Member 93VR6Passat's Avatar
      Jan 26th, 2005
      Hagerstown MD
      1998 Jetta, 1983 GTI
      09-18-2006 03:22 PM #2
      I had almost the same problem, leak in air intake, It turned out to be a valve assembly on the top of the engine, my car misfired on every cylinder at idle only, and after getting warm a very loud wining/whistling noise started. It took VW 2 tries to find the problem. If you need I can get the paperwork out for the part number. Hope it helps let me know.
    3. Member 20VTBORA's Avatar
      Nov 2nd, 2004
      Miami,FL
      MK6 Golf TDI
      09-18-2006 05:31 PM #3
      Thanx for the info. Hopefully I can get it taken care of before the drive to H2O
      www.DurtyDecals.com
    4. 08-02-2009 12:05 PM #4
      i think i have the same problem...how hard/complicated was it for them to fix? or would i be able to fix it myself
    5. Member wazzap1101's Avatar
      May 1st, 2009
      Long Island
      APR STG 3 2007 VW MKV GTi DSG
      08-02-2009 01:42 PM #5
      Quote, originally posted by 20VTBORA »
      check from Turbo to Intercooler all the way up to the throttle body. Possibly you have a hose paritally undone that is leaking.
    6. Member elpaisacq's Avatar
      Jul 1st, 2004
      Fort Lauderdale, FL
      2014 GLI 30th Edition Stg 2, GLI BMP 2008 Stage 2 Revo (old)
      01-11-2010 08:45 AM #6
      i am having the same problem... tthe MIL is on car does not idle but it still holds boost and it drives normal... it started after putting gas on the car on saturday
      2014 GLi 30th Edition. APR Stg 2, Usp Downpipe, Custom 3" Cat Back, Spulen Turbo Outlet Pipe, Spulen Intake 2.25" Pine, Forge Twin Cooler, USP Dogmount, Snow Performance Water/Meth Kit with VC-50 Controller, Custom Carbonio/USP intake, FK Coils, ALzor 629 19", Blinder HP-905 Laser jammers, Valentine 1 Radar Detector
    7. Member danniboi's Avatar
      Jun 19th, 2007
      Ocala, Florida
      '06 Passat 2.0T
      01-17-2011 10:23 PM #7
      I'm having the exact same problem as you and this is getting very annoying.
      Dec 3rd, 2000
      2015 CC
      01-18-2011 08:28 AM #8
      my brothers car did the same code and issue PCV valve had to be replaced..
      start there..
      is your car louder then normal have someone rev the engine a bit and listen near the valve see if you can hear air from the area..
      my brother also had the DV go bad at the same time but after replacing the DV we still got the air leak code and found the bad PCV valve (thanks to this forum )..
      2015 VW CC Mods so far 19x9.5 35et 3mm spacers in rear square niche veronas 235 35 nitto tires.
      Mar 12th, 2007
      Maryland
      b6 a4 avant, mk2 jetta coupe, 1990 g60 Corrado
      08-26-2011 09:35 AM #9
      it seems to be the c/r valve . i believe thats the breather valve off the valve cover most will b covered under audi warranty they go bad all the time
    10. 11-09-2012 01:49 PM #10
      hello 2ovtbora,
      can you send me the part number and can u please tell me what is the part called "is it called a valve" on top of the engine.?
      thank
      Yah.
    11. n00b
      Aug 8th, 2013
      France
      Subaru Impreza 2.0 GT AM2000
      08-09-2013 02:58 AM #11
      Can you please tell the parts number for your problem 93VR6Passat ?
      Thanks
    12. 01-28-2015 12:31 PM #12
      I currently have exactly the same problem, also after filling up with fuel, with my Golf 2.0 fsi gti b.j. 2006. Just back from the garage with 10 'faults' which seem to all stem from a faulty air intake (fault code p2279) what was the solution, any help would be massively appreciated!!!Thanks in advance.
    13. 04-16-2015 05:58 AM #13
      Hello together,
      hope I can help here a little bit, because I actually do have the same Problem.
      After my research the "valve on top of the motor" should be the PCV.
      Here in this thread
      http://www.motor-talk.de/forum/tfsi-...-t1924809.html
      you can see a pic of it
      http://www.motor-talk.de/forum/aktio...hmentId=545519
      I have a Passat from 2006 with the 2.0 200 hp fsi-Motor Type BWA and I am just back from buying this PCV and the Part-Number here in Germany is:
      06F 129 101 R
      Price is round about 38,- Euro
      If you want you could also change the seals
      06F 103 483 E about 15,- Euro
      Now I will install the valve and I hope to get rid of these failures like P2279 an all the misfires like P0300, P00301, P00302, P00303, P00304.
      But I also DO HAVE a question, maybe it is because of the language, but please WHAT IS a DV and where can I find it??? (Part-No.? maybe I have to change that either!?)
      Thanks in advance ( and sorry for my bad english)
      Best
      Michael
    14. 08-09-2015 12:46 PM #14
      Forgot to update on the problem I had, changed the PCV, (from what I understood it tends to stick open because of the amount of oil that goes through it) took the car through a complete cycle, took a couple of days and a long sprint on the Autobahn! and the light went off. All running good since!
    15. Member TCFGLI08's Avatar
      Apr 6th, 2011
      IN A 08 GLI
      08-11-2015 06:23 AM #15
      D.v. = diverter valve
      ATTACHED TO THE TURBO
      HOW DO I KNOW I'M ALIVE...I HEAR A TURBO!!!
