Jettaboy1884, Thanks for the comments!It was a slow day at work, so i basacaly got paid to work on my own car
What I did:
Painted the hood all silver
Painted the rear spoiler silver
Lowered the hight of the spoiler (sits almost flush with the trunk now)
Re installed the door cards (still out from all the welding)And this is probly the most functional thing i did: Ever since i put the spoiler on, the trunk would not stay up on its own, well i got hit in the head to many times and finaly solved that issue. I found an old gas strut out of a cellica gt-s, it still worked, but not enough to keep up the cellicas huge hatch so we kept it. Well i decided to use it, i made custom hinged brackets, so now upon opening the trunk it just goes up on its own and stays there
Ill update with pics some time soon...
Looks great as always...
I also travel on a dirt/rock road (if you want to call it a road, it’s an old logging trail) 2 miles to my girlfriends house. This is very harsh terrain dips and bumps 6”+ if you go slow and over them in the right manner your fine, air dam is grinding along the entire way, but nothing vital even close to hitting.
. No issue with the tie rods, lots of room. Also if you cut, I would recommend doing a front end alignment. Lots of info out there on how to DIY with some simple household tools, save some $$. I did mine on a machine, my lower ball joint is adjusted inward almost the entire way (another thing to think of, camber, you may run into issues if you go lower then 3 coils)… Have fun! P.S I made the strut tool using a 14mm socket, worked great
. Im still under $650 for this project, including the price of the car, mite as well see how far I can go for under $1,000, with bone yard parts, a little ingenuity, and lots of tools
I would recess it inside the bottom of the door mirror for easy access and low visability.
