VWVortex.com - P1136 17544 - Fuel Trim: Bank 1 (Add): System too Lean??
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 32
    Thread: P1136 17544 - Fuel Trim: Bank 1 (Add): System too Lean??
    1. 09-20-2006 12:46 PM #1
      Hi,
      My chipped 2002 1.8T 180bhp TT has recently been feeling a bit sluggish - It's like the acceleration is gone back to pretty much what it used to be without me feeling any of the power that was once there when it was initially remapped. When i accellerate fully now it feels like the car is being restricted in some way.. like it CAN go faster, but something isn't letting it!
      During some light traffic the other day the CEL came on, I used a vag-com cable to read the fault:
      P1136 - 35-00 -
      This is the second time this fault has appeared.
      I suspected it was the MAF - i used vag-com to take a reading from the MAF while redlining the car in 1st and 2nd gear - in both gears it read 169g/s which I think is about right for a chipped 1.8T right?? I also drove the car with the MAF disconnected and didn't really notice any change in performance.
      Can anyone tell me what else it could be?? I did two 0-100 tests last night for the sake of curiosity and they were 7.75 and 7.45 respesctively (the second time i just launched off a bit faster). This 0-100 time seems to confirm the car is running almost like a non-remapped stock 180bhp.
      I'm gonna tear my hair out!! Please someone help me before I end up balding myself!
      Modified by DaFlip at 8:48 AM 9-20-2006
      Modified by DaFlip at 8:50 AM 9-20-2006
    2. Forum Sponsor Andy@Ross-Tech.com's Avatar
      Jun 5th, 2002
      2015 GTI SE 6MT
      09-20-2006 12:49 PM #2
      Try logging group 115 for a full throttle run from idle to redline in a single gear and post the results.
    3. 09-20-2006 02:18 PM #3
      Hi - thanks for the reply!
      I couldn't go from idle stright to the redline because of traffic but the most relevant bit is attached below. The general trend here is seems to be at low loads the cmd pressure & intercooler pressure are almost the same.. once the engine load increases they start differing quite alot - does this mean I've some sort of leak somewhere?
    4. Forum Sponsor Andy@Ross-Tech.com's Avatar
      Jun 5th, 2002
      2015 GTI SE 6MT
      09-20-2006 02:44 PM #4
      Could be - that looks like an awfully big difference between requested and delivered boost.
    5. 09-20-2006 02:46 PM #5
      Awh damn .. that sounds serious! Where should I look? The N75/DV?
    6. Forum Sponsor Andy@Ross-Tech.com's Avatar
      Jun 5th, 2002
      2015 GTI SE 6MT
      09-20-2006 02:54 PM #6
      Check the whole intake tract from the turbo to the throttle body including the intercooler connections.
    7. 09-21-2006 05:15 AM #7
      Hmm.. this sounds a bit beyond me! I'm only new to all this but I am trying to learn about all this stuff while i'm at it
      If i bring it in to a garage and get them to do it they'll know what i'm talking about right?
      I've also been told that I still may have a faulty MAF or it could also be dirty injectors and some injector cleaning fluid could sort it out??
      Is the normal procedure here something along the lines of check the tracts from the intake if they all look ok start replacing parts until you get the right one? I don't really wanna order a new MAF unless I know it's broken, but at the same time if there's a chance it'd fix my problem then I'd be a happy man!
      I appreciate your help on this.
      Thanks
    8. 10-24-2006 03:51 PM #8
      My problem still exists.
      I now also get these faults thrown every so often:
      16804 - Catalyst System: Bank 1: Efficiency Below Threshold
      P0420 - 35-10 - - - Intermittent
      and this is more common:
      P1136 - 35-00 - -17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
      P1297 - 35-10 - - - Intermittent
      I have replaced the MAF, I have also replaced the divertor valve with an aftermarket one (hyperboost dx). I've checked the piping around the DV valve and don't see any cracks or leaks anywhere. I've gotten the pressure drop between turbo and throttle before and after i swapped the DV valve.
      The car is getting slower and slower overtime.. it now doesn't even feel like a 180bhp anymore. Also, from the passenger side i hear a whoosh of air that i didn't hear before.. it's strange.
      A friend of mine who knows a thing or two about this sort of thing tried to help me out by doing a process of elimination - he got me to take the hose which goes to the top of the DV valve and plug it into another metal pipe which stems from the same place the DV valve pipe goes to - this would supposedly give me full boost again but the result of me doing that was nothing changed - the car performed the same except for an even weirder "blow off" type sound. Could it be the oxygen/lambda sensor?
      I've brought the car to a vw/audi tuner and he's blaming the map but i really, really don't think this could be so - the car ran flawlessly at one stage. I am convinced this has to be a "hardware" related thing.
      Can anyone help me out any further? I am totally stuck
      Thanks in advance
    9. 10-24-2006 03:53 PM #9
      Also i may aswell add that i have a FMIC kit to be installed - the mechanic in the vw/tuner company said that it may be better not to install this until i fix the existing problems. I do suspect that this guy is blaming the map because it's easy to blame (he also claimed he couldn't read it because of different software and that the problem is a fueling problem)
      I am thinking if i get the kit installed then while the bumper is off he can also try swapping the lambda probe, since he'll be installing the FMIC kit then that will also rule out IC connectors - would this be a good plan??
      Thanks!
      Modified by DaFlip at 11:56 AM 10-24-2006
    10. Forum Sponsor Uwe's Avatar
      Jan 16th, 2000
      Lansdale, PA
      Too Many
      10-24-2006 05:10 PM #10
      I'd suspect a leak in your intake somewhere.
      Even the original code: Fuel Trim: Bank 1 (Add): System too Lean can be the result of an intake leak.
      -Uwe-
      VCDS® -- Satisfaction guaranteed or double your fault codes back!
      I reserve the right to be a prick if people make unreasonable demands.
    11. 10-25-2006 05:55 PM #11
      My MAF is reading the correct readings according to vag-com- does this matter?
      Could a leak in the intake also be the cause of the pressure drop fault?
    12. Forum Sponsor Uwe's Avatar
      Jan 16th, 2000
      Lansdale, PA
      Too Many
      10-25-2006 07:55 PM #12
      Quote »
      Yes.
      -Uwe-
    13. 10-26-2006 06:14 AM #13
      Thanks - I appreciate your help.
      I've ordered a new front lambda probe.. I'll let ye know what happens when it's swapped out.
    14. Forum Sponsor Andy@Ross-Tech.com's Avatar
      Jun 5th, 2002
      2015 GTI SE 6MT
      10-26-2006 10:10 AM #14
      Quote, originally posted by DaFlip »
      That's among the least likely causes for the problems you reported, but it's your money. What about the tests that were suggested to you?
    15. 10-27-2006 10:00 PM #15
      I've checked every hose i can find - they all seem fine.
      That still doesn't explain why the car performed just fine when the map was first installed - the software doesn't change (except for the fuel trim learning) - some piece of hardware must have failed or i have a leak somewhere right?? Please correct me if i'm wrong here ...
      I expressed these thoughts to the guy in the tuning company and all he said was that the ecu does some learning after a new map's installed - isn't that all reset when you clear the fault codes ? This whole thing is driving me crazy!
      The guy in the tuning company appears to have no faith (or much experience) in remaps and his idea of increasing performance is all strictly performance upgrades like larger turbos etc. Then on the other hand the guy who's done the remap keeps telling me it's not the map and it's possibly the MAF or the DV or the lambda probe etc.. between these two guys I cannot find anyone who's capable of finding out what's wrong with the car!
      The tuning company is local and the remapping company is up the country from where I am. The guy in the tuning company is blaming everything (including the pressure drop fault code) on the remap. I have searched the 'net far and wide for information on the faults i'm having and anyone I find never has a solution. The remap guy is telling me the front lambda probe is reading incorrectly and the ecu is blowing off air in an attempt to meet the required air/fuel ratio's.
      Up to 3k RPM really is fine then you hit a flat spot and everything beyond there feels anything but smooth. It's because it's fine accellerating in lower rpm's that the guy in the tuning company believes it's a fueling problem with the map.
      I am going to check the intake for leaks tomorrow.
      Is there anything else I can do? I am all out of ideas Any suggestions at all would be greatly appreciated.
      Modified by DaFlip at 6:03 PM 10-27-2006
    16. 10-27-2006 10:08 PM #16
      The only other thing I'm going to do which i suspect is take a look at the throttle body - this wasn't cleaned at the last service. If it's not a leak could this be the culprit?
    17. 10-28-2006 12:47 AM #17
      I had that same CEL on my 12v. I replaced my entire exhaust, dp back and O2 sensors and the code disappeared. Dunno if that will help you or not. Pretty sure it was just the O2 sensors though, they had 177k on them and were toast.
    18. 10-28-2006 08:11 AM #18
      I've only 55k miles/88k km on my clock
      I checked all hose connections i could see this morning can couldn't find anything.
      I did a vagcom log of a few small runs just now ...
      http://www.dot-ie.com/LOG-01-002-031-032.CSV
      http://www.dot-ie.com/LOG-01-115-002-032.CSV
      The fault codes were reset on monday by the tuning company - no CEL's have come back yet, it usually takes a few days before the system too lean CEL comes on.
    19. 10-30-2006 10:22 AM #19
      Sorry for asking this question in your thread but what does it mean when the engine load is greater than 100%? That doesn't make sense to me but I see it all the time including on my own car. Is that 100% of some calibrated measure for the power made by a stock (1.8T in your case) car?
      BTW I feel your pain with the car not running right. I'm having problems with my R32 feeling sluggish (and pulling loads of timing) and I haven't had the time to really look into it yet. Good luck!
    20. Forum Sponsor Andy@Ross-Tech.com's Avatar
      Jun 5th, 2002
      2015 GTI SE 6MT
      10-30-2006 10:59 AM #20
      Quote, originally posted by barmato »
      The convention seems to be 100% would be complete cylinder filling with atmospheric pressure. Since forced induction engines cram in more than atmospheric, the % is over 100 when they are boosting.
    21. 11-01-2006 08:46 AM #21
      i had this same fault code in my V6 4motion. The code popped up after i found out i was leaking coolant, and then had the leak fixed. Then had the fault code reset and hasn't popped up again. Don't know if that was the main problem.
    22. Forum Sponsor Andy@Ross-Tech.com's Avatar
      Jun 5th, 2002
      2015 GTI SE 6MT
      11-01-2006 10:21 AM #22
      I can't see the correlation between leaking coolant and a fuel trim error, but good for you.
    23. 11-25-2006 10:25 AM #23
      Just to put this one to bed.
      My new FMIC came with a new inlet manifold. While replacing the manifold they discovered a hose underneath it which was split. They have replaced the hose and now the car's pulling like a train! No CEL's or anything.
      Unless they took off the manifold they'd have never been able to spot it! Tricky one!
      Thanks for all your help
    24. 12-04-2006 11:21 PM #24
      Would you mind letting us know which hose was split?
      I started throwing that code after an FMIC install and will try tightening all the hoses again this weekend to see if it helps.
    25. 06-30-2008 01:39 PM #25
      Please, add a photo to show the problem. I'm having the same problem as you.
