VWVortex.com - DIY: COMPLETE, very detailed airbox/intake modification write-up.
    Page 1 of 19 1234511 ... LastLast
    Results 1 to 25 of 473
    Thread: DIY: COMPLETE, very detailed airbox/intake modification write-up.
      Oct 14th, 2005
      NJ ALL DAY.
      09-22-2006 02:39 PM #1
      DISCLAIMER: This is what I did on my vehicle and had great results with it. However, I am not liable if anything happens to your car because of this.
      The airbox/intake modification:
      I did this for the performance of course, but the sound that comes with it is unbelievable. You will have heads turning left and right when they hear it. I have not heard another naturally aspirated 12V VR6 that sounds as incredible as this.
      Some sound clips:
      http://smg.photobucket.com/alb...1.flv
      http://smg.photobucket.com/alb...4.flv
      http://smg.photobucket.com/alb...2.flv
      To prove the gains for this airbox modification, I provided a link of my dyno with such minimal modifications (176whp/177wtq)(http://forums.vwvortex.com/zerothread?id=2899452). My track times also show the success from modifying the airbox. (It's a 14.4 second car and it's near stock).
      You are almost definitely losing power with a cone filter, instead of the airbox in place, because of all the hot air that the cone filter is exposed to. Cone filters work on either a cold air intake or when being used with a heat shield. To further prove to you the power loss of a cone filter in place of an airbox, here is a dyno test from Techtonics Tuning of an open-element conical filter versus an airbox. There is quite a drastic loss in power with the conical filter. http://www.techtonicstuning.co...7.JPG
      First, buy a high-flow drop-in air filter of your choice.
      What I did, and what many others do, is modify the stock airbox. All you really need is a dremel, or maybe a utility knife, if that may work [I used a dremel].
      Next, is cutting out part of the front/fender side of the airbox. I used a ruler and straight blade to slightly draw out where I wanted to cut exactly. I used many of the airbox’s lines to cut the cleanest looking cut. Some people swiss cheese the airbox, which in my opinion, is not the best method to go about this. You can just cut a whole clean piece out of the airbox. It will allow more air and look much more professional and clean. You honestly can't tell the airbox is modified if you do it in this manner.
      Here is my setup:
      Here with K&N panel filter inside...
      In the upper airbox, there is a velocity stack'd duct in the upper section of the airbox that I removed. The difference in diameter after removing the duct is noticeable. The bore is quite bigger and the intake pipe now receives more air from the entire airbox panel, rather than a portion before.
      To remove air duct, take two flatheads and stick them in between the duct and upper airbox, unplugging the tabs. Leave the flatheads in there after unplugging the tabs. Then, take small pliers and grab a nice hold of the duct and pull out with some force.
      NOTICE: Some people say this duct basically acts like a velocity stack and that it helps directs air to the MAF. Velocity stacks do amazing things for air flow, but in this case, I'm willing to sacrifice this piece by looking at the bore of the intake after removing it.
      With the velocity stack in the upper airbox...
      Without the velocity stack. Notice the difference?
      And the velocity stack removed from the airbox.
      I removed this plastic honeycomb piece from the MAF. It's there to give the MAF the most accurate readings, but I’ve been running without this piece for a long time without any problems. If anything, I would say it helped. Remember, this piece pops right out, so you can always push it back in if you ever want to re-attach it. It is not a permanent modification to the MAF.
      Take the following from someone on the 300zxclub.com forums:
      "Removing the mesh on the mass airflow sensor (MAS) will up the boost on turbo'd vehicles a couple pounds....this allows for more air to enter with less restriction...did this on my skyline...probably do some good for NA too.
      But... the mesh is there for a reason....the mesh channels the air through the MAS and onto the sensor...without it, there is an argument that the sensor may be getting an incorrect reading...but it worked for me....its up to you...
      On the 300ZX if you do the mesh removal, you will increase air volume from 300cfm to about 700cfm. It will increase your boost and your response, and will get rid of most of your hesitation problems...... oh, and it should lean her out a bit too, good for those of you with hight boost.
      And iv'e seen articles where LS1's are being dyno tuned with the mesh removed."
      That plastic piece removed gives you a straight through MAF…
      Remove this duct from the front of the airbox. This piece is pointless now that the airbox is opened up and there is no velocity sucking air from it anymore (imagine a house vacuum with a hole in the pipe...it will lose much of the air velocity that picks up dirt). This pipe just blocks air from the front of the airbox. I removed it completely.
      Remove this piece from the fender area. There is no point of it now that the duct is removed. It also gives a little more air from the fender area.
      And the result of that being removed is more air from the fender area…
      And some shots of how the airbox sits…
      Modified by Breezy. at 1:28 PM 9-17-2008
    2. 09-22-2006 02:42 PM #2
      nice write up, but dont you think thats a lot of work for an extra 1.3 hp?
      just sayin
    3. 09-22-2006 02:45 PM #3
      Horsepower to the wheels isn't cheap.. but this is, so no big deal [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Nice write up, and thanks for the pics
    4. Member
      Oct 14th, 2005
      NJ ALL DAY.
      09-22-2006 02:46 PM #4
      Quote, originally posted by Golfmk3_18 »
      just sayin
      I have track times to prove these gains. You were the same guy in my old thread. Believe what you want.
      Click this...
      http://forums.vwvortex.com/zerothread?id=2835172
    5. 09-22-2006 02:49 PM #5
      Quality write-up. Clean install. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    6. Member relmonte's Avatar
      Dec 7th, 2005
      Orlando, FL
      09-22-2006 02:50 PM #6
      Nice Breezy!
    7. Member 2.0lover's Avatar
      Aug 16th, 2006
      minnesota
      98 cabrio VR6
      09-22-2006 03:08 PM #7
      Quote, originally posted by Breezy. »
      Remove this plastic honeycomb piece from the MAF. There is no point in this piece since there is an air filter. I’ve been running without this piece for a long time without any problems.
      first let me say nice write up and thank you very much for taking your time to do this for us.
      just have one question, will removing that honeycomb piece really make a difference?...i can see how all of the other things you did would, but that honeycomb piece just doesn't seem like it would affect air flow very much at all.
      it may not hurt anything to remove it, but it may not need to be removed either...just a thought.
    8. 09-22-2006 03:08 PM #8
      just sayin
      hahah a lot of work ? Modding an airbox takes all of 20 minutes..
    9. 09-22-2006 03:11 PM #9
      that honey comb is used to straighten the air that reaches the maf. i'd put that back in, no? also does having a straight pipe limit the sound you get from this mod? i've done the same, and my intake sounds the same, just a slight 'psst' when im on the throttle
      Modified by ctuagent117 at 12:13 PM 9-22-2006
    10. Member
      Jun 4th, 2005
      Milwaukee, WI
      2008 Rabbit (Previous: 1998 GLS, 279,000 miles)
      09-22-2006 03:15 PM #10
      Correct, the honeycomb piece reduces turbulence and creates more laminar air flow.
    11. 09-22-2006 03:16 PM #11
      Quote, originally posted by ctuagent117 »
      You have no idea what you are talking about [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    12. Senior Member Dan J Reed's Avatar
      Jul 26th, 2004
      NJ - AKA - Earth's armpit.
      Too many
      09-22-2006 03:20 PM #12
      Is this a repost?
      I feel like I saw this 6 months ago?
    13. 09-22-2006 03:24 PM #13
      haha what, a drilled airbox write-up? you've probably seen more than just one in the past couple months.
    14. Senior Member tdogg74's Avatar
      Mar 1st, 2002
      In a tea cup
      Previous: 1997 8v Golf. Current: 2000 1.8t Passat
      09-22-2006 03:28 PM #14
      Quote, originally posted by bmxdubdub »
      Yes he does because thats what its for.
    15. Member bikerbill2021's Avatar
      Oct 7th, 2004
      Phoenix AZ
      E46
      09-22-2006 03:33 PM #15
      exactly what my box looks like [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    16. Member DaddyOfPayton's Avatar
      Feb 24th, 2004
      Hilliard/Columbus, OH
      09-22-2006 03:39 PM #16
      Nice write-up! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      My name is...Shake-Zula. The mic-rula, The old schoolah, Ya wanna trip? I'll bring it to ya. Frylock and I'm on top Rock you like a cop Meatwad you up next with your knock-knock. Meatwad make the money, see. Meatwad get the honeys, G. Drivin in my car, livin' like a star. Ice on my fingers and my toes and I'm a Taurus. Check it. Check, check it. 'Cuz we drive the Cabrios, make the homies say ho! and the girlies wanna scream.
    17. Member B4WrNd's Avatar
      Nov 15th, 2004
      West Michigan
      In Signature
      09-22-2006 04:21 PM #17
      Breezy I had those exact same mods but holes drilled on the side of the box away from the engine. I still believe that I free'd up a few hp up top with the cold air. nice write up though.
      75 TVR 2500M - 98 M3/4/5 Rotrex C38 - 91 GTI VRT - 02 Xterra SE - 97 E420 - 95 Saab 900se Convertible
    18. 09-22-2006 04:32 PM #18
      Is this the same for a 2.slow? Just wondering cause i'm interested. Any concerns about rain/snow getting all up in your filter?
    19. 09-22-2006 05:25 PM #19
      yup same for 2 liter. no worrys about rain /snow
    20. 09-22-2006 05:35 PM #20
      nice [IMG]http://*****************.com/smile/emthup.gif[/IMG] I currently have a neuspeed p flow with no heat shield and I dont want to pay 80$ for one so I am looking into doing the same thing that you did because it looks clan and performs better...Only problem I have is I dont have a stock airbox anymore so anyone that has one for a OBD 1 shoot me a pm
    21. 09-22-2006 05:36 PM #21
      Quote, originally posted by FloGwagen »
      same here..
      only if anyone has obd2 airbox hit me up
    22. 09-22-2006 05:42 PM #22
      ill give you my stock air box, already modified in the ways shown above, in exhange for you intake.
    23. 09-22-2006 05:52 PM #23
      I did the same exacty thing, except for the honeycomb removal and the circle fender plastic thingy two months ago. I did all the cutting with a dremel and then sanded the edges for a better look. I'll try the honeycomb and plastic thiny on the fender removal since you added it. IMO the sound is great espeically on WOT, because the sound is not muffeled anymore. Sounds similar to my friend's VR with a eurosport short ram intake.
      Another + for this mod is the improved gas milage I got!!! And btw thanks for putting in the time to write and rewrite this diy.
    24. 09-22-2006 05:56 PM #24
      Don't do the honey comb. More harm- no good.
    25. 09-22-2006 05:57 PM #25
      Quote, originally posted by tdogg74 »
      Anybody that knows anything about fluid dynamics knows that air flows in the path of the enclosure its in. The only thing that honeycomb will do is make the flow more turbulent.
