VWVortex.com - Ultimate Timing Belt DIY!
    Page 1 of 38 1234511 ... LastLast
    Results 1 to 25 of 948
    Thread: Ultimate Timing Belt DIY!
    1. Member Tim_1.8T's Avatar
      Jan 19th, 2006
      Boynton Beach
      09-24-2006 07:25 PM #1
      I did this for everyone who didn't feel comfortable doing this on their own. After reading this you should feel 100% sure you can accomplish it on your own. I think anyone can do this themselves and save a ton of cash!
      This timing belt change was done on my 2002 GTI 1.8T
      Product Needed
      Timing Belt
      Timing Belt Tensioner
      Timing Belt Idler Pulley
      Water pump (with metal impeller)
      Coolant G12
      Distilled Water
      Accessory belt (optional )
      Thermostat (optional DIY does not cover)
      New engine mount bolts
      *Note* Kits are available from ECStuning.com, from mjm, as well as many other places. Most don't come with new stretch bolts so you need to ask for them. Can't say anything about anyone elses kits because I only dealt with ECS but i would highly recommend them. Make sure you get a metal impeller water pump as well!
      Tools NEEDED
      Jack
      Jack stands
      Phillips head screw driver
      Flat Head screw driver
      T25 Torx bit Screw driver
      8mm allen wrench (Preferably 8mm allen head socket)
      3mm allen wrench
      19mm twelve point, 18mm, 16mm deep, 16mm, 12mm, 10mm deep, and 10mm sockets
      16mm and 13mm wrenches
      2x4 approx. 2 feet long
      small breaker bar (unless you're Bruce Lee then don't worry about it)
      *HINT* For the 13mm wrench go buy a craftsman ratcheting wrench. This is to remove the Accessory belt tensioner and this tool alone will save you at least 30 minutes when taking that stupid thing off and back on. HIGHLY RECOMMENDED
      Step #1
      Jack the Car up, put it on some stands, and remove the passenger side wheel as well as the plastic fender liner. Hopefully your wheel looks as good as this one.
      Step #2
      Remove - Both engine covers, Upper timing belt cover (with the 2 spring clips), and belly pan.
      ^Belly pan
      Step #3
      Remove the lower charge pipe (pancake pipe) using a flat head screw driver or a 7mm socket to losen the clamps and a 10mm socket to remove the nut holding the bracket in place. I suggest removing the clamp on the intercooler and pulling the silicon connection off the IC with the pipe, much easier then removing the clamp on the pipe and trying to pull the pipe out.
      ^ pancake pipe
      Step #4
      Remover the sound dampening shield behind the lower IC pipe by prying each one of those little tabs back with a flat head screwdriver then pull straight done. OR get violent and just pull down super hard.
      Step #5
      Remove the timing plug on the transmission so that you can visibly see the flywheel TDC mark. The Plug is located here.
      Step #6
      Release tension on the accessory belt using a 16mm wrench to pull back the tensioner enough to align the two holes so that you can slip a 3mm allen wrench through both of them. As Illustated.
      Now the accessory belt tensioner is locked in place and you can easily remove the belt. Then remove the intake pipe to the throttle body hose. When finished with all that, use your ratcheting 13mm wrench to remove the accessory belt tensioner and place that out of the way.
      *Note* The Black Bracket goes between the bolts and the tensioner not the tensioner and the head! Remeber this or your belt will not be aligned properly.
      Step #7
      Remove the harmonic balancer pulley. Then crank the engine to TDC with a 19mm twelve point socket. I looked at the cam gear mark to see when i was getting close, then went super slow to align the flywheel mark perfectly.
      ^ Here is where the cam gear lines up with the valve cover. You can also see the mark on my cam gear and my new belt from the nail polish. They don't line up because the car has been running.
      ^ Here is where you will see the TDC mark on the flywheel (Behind the timing plug on the Trans) You can't see the mark on mine cause it's not on TDC. Your flywheel may look a little different as mine is a new lightweight one with that sexy blue spec clutch as you can see.
      Step #8
      Using a jack and a 2x4 crank the jack just so that the engine has support. Make sure the release valve on your jack is tight so that the jack doesn't slowly lose pressure.
      Step #9
      Remove two screws holding the colant reservoir down as well as the bolt holding down the power steering reservoir (10mm deep socket needed there).
      ^ unclip that black clamp and take it off the bolt
      *Note* Removal of the coolant res and power steering res and/or lines is not necessary but would make the job easier. I didn't remove anything just pushed everything around.
      Step #10
      Remove the six bolts holding the mount to the body and the bracket located here.Then slide the mount out from the top.
      ^ The bolts are close to those circles
      Step #11
      Jack the engine up a couple of inches. Then remove the rest of the engine mount which is attached to the block by removing 3 bolts. You will need the deep 16mm socket to remove at least one of them. After removing the bolts if you can't find a way to get that other piece of the mount out from the bottom don't sweat it. I just left it in there and moved it around as needed, as many others have done it this was as well.
      Step #12
      Remove the 5 - 10mm bolts holding the middle and lower timing belt covers on.
      Step #13
      At lucky step thirteen you get to take the timing belt off, but FIRST...
      make sure you mark the position of the belt on the crank gear and the cam gear. I used nail polish to do this and i made two marks on the bottom (crank gear) and 1 mark on the top (cam gear) so that it was impossible to screw it up.
      ^ Here is what my belt looked like after i took it off and it was marked
      Now remove the little timing belt tensioner pulley. Then remove the whole Tensioner and finally remove the tensioner idler pulley. Now slip the belt off.
      Step #14
      Remove the water pump. It is held in with 3 10mm bolts. At this point it's not just gonna fall out. Wrap a rag around the gear and get two hands down in there. Wiggle the pump while pulling as hard a you can. When it starts to leak you're almost there. In the end your prize will be a mess of coolant on the floor and ,if you're doing this timing belt swap because your waterpump broke like me, a cracked plastic waterpump impeller which you will need to reach into the block to retrieve.
      Step #15
      Replace the water pump. Make sure to moisten the O-ring with some coolant before bolting it back up.
      Step #16
      Get your new timing belt out and transfer the marks to the new belt from the old belt. Before throwing it in there put the new tensioner idler pulley in there. Now align the mark on the cam gear with the belt. Next route it down to the crank gear and line those marks up. Most difficult part of the whole job right here. Put the New tensioner in. I noticed my old one left an imprint on the block which helped me out with the way it was oriented in there. Then i put that 3mm allen wrench to good use and stuck it through the top bolt hole on the tensioner to line that one up. Then I put the bolt in the bottom hole and shifted the tensioner around until i got it to screw in. Then i bolted in the top one. Make sure the marks on the cam gear and the crank gear haven't moved and when you're confident that you've got that belt on perfect pull the pin on the tensioner. After you pull that pin there is no turning back unless you have the blot to untension the tensioner.
      Step #17
      Crank the engine over, by hand, at least two times so that you can match up the flywheel TDC mark and the Cam Gear TDC mark, They should match perfectly.
      Step #18
      Install the middle and lower timing belt covers and bolt the mount back the the block. Then replace the harmonic balancer pulley and the accessory tension pulley.
      Step #19
      Attach the engine back to the mount and bolt it down.
      Step #20
      Repeat the steps in Step #6 to get the accessory belt back on. Make sure you have a space between the pulley and the timing belt cover. I didn't the first time, had to tear everything down again to fix it, And got the fright of my life the first time i turned the car on and heard that.
      ^ Blury picture but you need a space there
      Step #21
      Finish up by putting the belly pan and the sound dampening shroud back in place, as well as the lower IC pipe. Also reinstall the TB hose and bolt down the coolant reservior and the power steering res. Put your wheel back on and lower the car.
      Step #22
      Fill your car with coolant before starting. You may want to fill the res about 3/4 full because the engine is going to suck alot in when you start it.
      *Note* Mix coolant with distilled water only
      Step #23
      Start the car and check for belt alignment as well as top off your car with coolant. If you did everything right it's time to give yourself a pat on the back. You did good [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Torque specs
      Engine mount to cylinder block - 45Nm
      Engine mount to Body - 40Nm + 90
      Engine mount Bracket - 25Nm
      Engine mount to Engine Mount on Block - 100Nm
      Timing Belt cover bolts - 10Nm
      Vibration damper/belt pulley - 25Nm
      Timing Belt Tensioner - 25Nm
      Coolant pump - 15Nm
      If I left anything out or you have suggestions please let me know I'd like to make this as 100% complete as I possibly can!
      Modified by Tim_1.8T at 2:41 PM 12-16-2006
    2. Member trbochrgm02's Avatar
      Dec 10th, 2002
      piman , nj
      2011 fx50s, 2005 G35x, 04 Jeep 4.0 Sold 02 gti 1.8t gt28rs 314whp
      09-24-2006 07:32 PM #2
      Nice work [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    3. Banned under boost's Avatar
      Apr 22nd, 2006
      09-24-2006 07:34 PM #3
      this should be a sticky. excellent write up! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    4. 09-24-2006 07:37 PM #4
      Good job!Although I recommend putting reference marks on the cam/valve cover,and crank gear/engine block,since things may get messed up putting marks on "the belt".If you use the correct service tool,then you can lift the motor enough to completely remove the motor mount bracket,which makes things a lot easier.
      A word of warning to those reading this.....although the OP makes this look "easy",it is not,if you do not have a modicum of engine knowledge (crank/cam timing)and are easily frustrated,do not attempt this yourself,even though the internet post makes it seem like a breeze,which it is NOT.
      I say this,since this job is similar to a brake job,it seems "easy" but you HAVE to do it correctly the first time or you will encounter dire consequence (just like F'ing up a brake job),if you are going to attempt this,atleast know a little about wrenching!
      Modified by VWAUDITECH at 4:39 PM 9-24-2006
    5. Member O2VW1.8T's Avatar
      Jul 9th, 2003
      2015 GTi 6speed
      09-24-2006 07:43 PM #5
      Quote, originally posted by VWAUDITECH »
      Yep put a peice of wood block under the engine and lower the car until you can unscrew all bolts from the engine mount. No need to take off the wheel and stuff
      02 GTi 1.8T haldex'd w/35r-SOLD 7.3@102mph 27psi on 93 octane--04 A4 1.8T converted to AWD also- SOLD--'11 JSW Tdi 6speed Manual- Gone--
      13' BMW 335i M-sport EBII
    6. Member Tim_1.8T's Avatar
      Jan 19th, 2006
      Boynton Beach
      09-24-2006 07:58 PM #6
      Well i got all the bolts out of the mount just couldn't jockey it out of there, as for the wheel It's not 100% needed but its a 2 second deal
    7. Member Ken_C's Avatar
      Nov 19th, 2005
      Austin, TX
      09-24-2006 08:21 PM #7
      Wow, I wish you would have done this a few months earlier. Woulda saved me about 800 bucks.
      Good write up [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    8. 09-24-2006 08:21 PM #8
      Good write up sir. It's nice when Vortex can be helpful for people! [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    9. 09-25-2006 12:56 AM #9
      How much would this ordinarily cost to get done at a dealership or garage?
    10. Member O2VW1.8T's Avatar
      Jul 9th, 2003
      2015 GTi 6speed
      09-25-2006 01:03 AM #10
      Quote, originally posted by Craig King »
      dealer is around 500 for labor plus parts
    11. Former Advertiser
      Oct 20th, 2003
      T E X A S
      VAG Toys
      09-25-2006 08:23 PM #11
      Quote, originally posted by Tim_1.8T »
      Our kits do come with the 4-piece stretch bolts. No need to ask for them.
      http://www.mjmautohaus.com
    12. 10-03-2006 03:39 AM #12
      this is indeed a very nice write-up, thanks for taking the time to do it, im sure you will save a lot of people a lot of money (or in some cases give them the opprotunity to spend a great deal more )
      I will definitely use this as a reference when doing mine!
    13. 10-03-2006 09:56 AM #13
      "9mm twelve point"
      - may i ask why 12 pint. may sound lame, but why is that prefered? easier to get the socket on the bolt? is this a must, a 6 point wont work?
      thanks for the diy
    14. Member oj1480's Avatar
      Jun 6th, 2006
      NYC
      2010/VW/GTI/CW
      10-03-2006 10:13 AM #14
      looks easy, but i know it isn't so.
    15. Member Tim_1.8T's Avatar
      Jan 19th, 2006
      Boynton Beach
      10-03-2006 03:11 PM #15
      If you're talking about the 19mm twelve point it is required because thats what it is to turn the engine over. The DIY i used said he used a 21mm socket i quote him " i don't know if this is the right tool" but he said it worked fine for him. Here is a pic off Audiworld of the crank, you can see its a 12 point.
    16. 10-03-2006 04:09 PM #16
      ok, wow.. didnt realize that could be. thanks for the explanation and the pic!!! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    17. Member rod_farva02's Avatar
      Jan 19th, 2004
      Littleton
      74 Bus tdi, 80 Rabbit Diesel
      12-16-2006 05:18 PM #17
      thanks this really helped [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      http://johnsupertramp.blogspot.com/ TDI Bus build blog. It's for killin zombies.
    18. 12-16-2006 05:40 PM #18
      excellent DIY, definatley going to print this out when i do mine
    19. Member Tim_1.8T's Avatar
      Jan 19th, 2006
      Boynton Beach
      12-16-2006 05:41 PM #19
      Your welcome [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    20. 12-16-2006 07:47 PM #20
      nice [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    21. 12-17-2006 11:53 AM #21
      No need to put the car at TDC if you mark the belt and the pulleys.
      Also, there is a TDC reference on the crank pulley.
      Modified by 1.BillyT at 10:56 AM 12-17-2006
      I was a man... I was a good man... Selling insurance...
    22. Member Tim_1.8T's Avatar
      Jan 19th, 2006
      Boynton Beach
      12-17-2006 12:17 PM #22
      Well you can't see the TDC mark on the pulley unless you remove the passenger head light which means removing the front bumper; extra work. As for the TDC in the first place when you crank the car over by hand twice the marks on the belt will no longer line up however the TDC marks will so if you don't like to make sure you did it right then you don't have to move the motor to TDC center. Otherwise i'd advise it considering it's a 2 second deal and it could potentially save you thousands [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    23. 12-17-2006 12:31 PM #23
      You can see it right from the top straight down between the powersteering resivour and the engine.
      I never use the flywheel especially on aftermarket setups since I have way to many that are not marked correctly or marked at all.
      The factory manuals don't even reference using the flywheel on any new cars just the crank pulley and cam gear.
      your method does work but is not as reliable as using the actual crank.
      No need to even mark anything, there is a notch on the valve cover and mark on the cam gear. And a mark on the crank pulley and notch on the lower engine cover.
      Never done it any other way.
      excellent detailed writeup [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    24. Member skydaman's Avatar
      Dec 16th, 2005
      NoVa
      12-17-2006 01:36 PM #24
      Nice writeup! This will save people hundreds of $$.
    25. 12-17-2006 09:18 PM #25
      Quote, originally posted by PD Performance »
      This is me, agreeing with Chris... hell must be freezing over.
      we mark the belt and pulleys instead of putting the motor at TDC. Different path to the same place.
