Results 1 to 27 of 27
Thread: Modifying/shortening NA bumper "bracket not shock." Need advice
  1. 09-28-2006 08:47 PM #1
    First some humor. So I'm at work today and the guys were asking me about the rocco, I was telling them about the bumper mod and since it was slow I pulled it in and took it off with the impact, took more time finding the 4 bolts than taking them off . I drove it home without the bumper and parked it, when I jumped out I was shocked to believe I came so close to smacking my lower front GFX I mean 1-2 cm from contact.
    Onto buisness, here is a picture of the bracket, now what am I supposed to shorten or cut???
    Modified by Finsol at 5:50 PM 9-28-2006
  2. Senior Member Chris16vRocco's Avatar
    Apr 29th, 2006
    W123
    09-28-2006 09:02 PM #2
    OK, first, you're gonna have to lose the tow hooks. You need to remove the covers from the bumpers, they have tabs on the back that pop through the metal. On the back, you might as well break them off, as they won't line up later. Then remove the bolts that attach the bumper to the brackets. There's one on each side. Decide how much you want to shorten them. I shortened mine about 1 1/2", IIRC. Mark the locations for you new holes now, before you cut anything off. Take a sawzall/hacksaw/angle grinder and cut off the proper amout (mark it first) off each side. Make sure you cut the same amount off each side. Then it's time to drill ze holes. Bolt the brackets back on to the bumpers and put them back on the car. On the rear, you need to flip the bumper upside down (with the brackets normal) so the bumper isn't too low. This renders the tabs on the cover useless. You need to screw the cover on in discreet locations, or come up with an alternative method .
    Here's the after pics of mine:
    rear:
    front:
    Deal with it.
  3. 09-28-2006 09:08 PM #3
    So you shortened yours 1 1/2 inches "from the bolt hole" correct? Or did you use another reffernce point for shortening. I'm gona go for 2 1/2 inches.
    The upper bumper skin that's still on the car "visible in pics looks like a mustach lol" can be removed without effects? could it be left on the car to help blend in or better off removing it? I'm worried it's gonna affect the grill because the lower tabs are busted.
  4. Senior Member Chris16vRocco's Avatar
    Apr 29th, 2006
    W123
    09-28-2006 09:19 PM #4
    Yes that measurement was from the center of the bolt hole. I didn't have very much room left to shorten it farther.
    Those filler pieces are just for looks, you really don't need them with the bumpers closer to the car, my car had Euros on it before, and so those pieces were gone when I got it.
    Deal with it.
  5. 10-05-2006 12:51 AM #5
    For anyone interested in doing this mod these are probably the best how to pics there is for the bracket method "that I've found."
    I hacked off the tow brackets and cut down 2 1/4 inches from bolt hole to bolt hole, I decided to leave the hole drilling to a local machine shop, I don't want to screw it up and they charged my like 10 bucks + I started to drillt he holes at it tok me 15 minutes to get it that big then I ran out of sizes lol. I test fitted the naked bumper and it sits much further back than before, way closer to the body. 2 1/4 inches doesn't sound like much but trust me it's more than you think.
    brackets shaved
    Modified by Finsol at 9:56 PM 10-4-2006
  6. Senior Member Chris16vRocco's Avatar
    Apr 29th, 2006
    W123
    10-05-2006 06:12 PM #6
    Yep, that's exactly what I did. Looks like it's coming along nicely.
    Deal with it.
  7. Member jettasella's Avatar
    Nov 24th, 2004
    2012 GTI, 86 Scirocco 16v
    10-07-2006 09:50 AM #7
    Thanks for the link!
    Can you keep posting pics of your progress? I want to see how yours turn out.
  8. 10-07-2006 10:25 AM #8
    Sure, catch is I work 11 hrs. a day and my next day off is Wednsday so I wont be able to pick the brackets up from the shop until then.
    Once the bumper is done I plan on shaving/shortening the sides and paingint the bumper satin black.
  9. Member jettasella's Avatar
    Nov 24th, 2004
    10-08-2006 11:19 AM #9
    i work 6 out of 7 myself... i can relate to wanting more personal time....
    however long it takes for you to finish this one, if you could post step-by-step pics along the way i'd be really interested the process... cheers!
  10. 10-11-2006 03:52 PM #10
    UPDATE:
    I picked up the brackets, my local machine shop did a better job drilling out the holes than I ever could lol, charged me 15 for both wich was a very good deal.
    Brackets once bolted on fit like a glove, I'll post the pic of the bumper with the skin in a fe wminutes, I need to go to the store and pick up a nw bolt, my rocco ate one .
  11. 10-11-2006 04:54 PM #11
    Ok here it is with the skin put on, final product as of now total amount shortened I'd say 2 1/2 inches. On my next day off "Friday" I'm tking the skin back of and seeing just how much more i can gut from the inner skin to shirtn it even more, then I'm gonna trim the sides off.
    I think it's a great improvment over the stock length.
    unfortunatly i do not have a before bumper length pic.
    Modified by Finsol at 1:55 PM 10-11-2006
  12. Senior Member Chris16vRocco's Avatar
    Apr 29th, 2006
    W123
    10-11-2006 04:57 PM #12
    looks good.
    Deal with it.
  13. 10-11-2006 08:03 PM #13
    Looking good so far. I shortened the bumper by cutting the brackets also. I noticed if you really want that euro look you have to get rid of the bumper bar otherwise the bumper will still stick out too much. I used pressure treated wood instead of the metal and I trimmed the plastic off where the bumper meets the body as well as the sides. Good luck
    Current 1991 audi 200 20v turbo waggen, 1990 vw cabby 16v, 1980 bmw 745i turbo, 1987 mitsu starion esi-r
    Past- 82 vw scirocco, 93 mitsu mirage, 83 vw GTI, 79 BMW 733i euro, 86 mercedes 16v cosworth, 1988 bmw 325 IC, 1990 saab 900 turbo,
  14. Member jettasella's Avatar
    Nov 24th, 2004
    10-11-2006 08:32 PM #14
    any shots of the rear?
  15. 10-11-2006 08:45 PM #15
    Mik:
    Do you have a pictureof your front bumper I can use as a refference??? Also when you say "pressure treated wood" do you mean so it has a curver like the metal bumper?
    Jetta:
    Here is a pic of the Hideous rear, my next mod is shortening the rear bumper, these are both going on future Scirocco I'm planning on purchasing if all goes well.
  16. Member jettasella's Avatar
    Nov 24th, 2004
    10-11-2006 08:54 PM #16
    i'm pretty impressed with how the front turned out! let me know how much you intend to shave off the sides. every time i see a US S2 with euro bumpers, you always see the where the US bumpers were "supposed" to be... any way around that outside of filling it in at a body shop?
  17. 10-11-2006 08:58 PM #17
    Actually I shortened the rear bumper, I have a big bumper in the front which was already short. That could be another avenue, using a newer vw brace which does not stick out as much and drilling the mounts so it goes in further. The wood I used is not curved. Because the curve is so slight it does not make a difference in how far the bumper sticks out. I also wanted less weight. Hope that helps
  18. Member jettasella's Avatar
    Nov 24th, 2004
    10-11-2006 09:12 PM #18
    mik:
    got a link to pics of yours?
  19. Member mr lee's Avatar
    Jan 31st, 2005
    misery
    Don't you know I sold them all...
    10-11-2006 09:43 PM #19
    click my gallery for pics of my shortened bumpers.
    Mine are held on by 6-8 custom aluminum brackets. I'll take some undershots if anyone is interested.
    lmk
    p.s. there is no rebar.. no nothing, except the plastic covers.
    Modified by mr lee at 6:44 PM 10-11-2006
    Quote Originally Posted by Amsterdam087 View Post
    its not your car...
  20. 10-11-2006 10:01 PM #20
    holy crap dude your bumper sits way further back lol, I'm totally down to see the underside. please take some pics.
    On friday I am planning on doing some more modding ot the frotn bumper and removign the rear so anything to help me make it shorter will help.
  21. 10-11-2006 10:30 PM #21
    http://65.55.131.124/cgi-bin/g...33b85
    ok, here is the link to how far the bumper sticks out, I cut off and added the side piece after the pic
  22. 10-11-2006 11:26 PM #22
    im not sure whats going on witht ha link, can ya host the pics on imageshack?
  23. Member jettasella's Avatar
    Nov 24th, 2004
    10-12-2006 12:55 AM #23
    definitely want to see undershots of what it looks like without the rebar....
  24. 10-12-2006 08:47 PM #24
    this should work now, I added the end pieces so they line up with that trim piece, I could have reduced it more but I like it better this way
  25. 04-17-2007 12:30 AM #25
    bump
  26. 04-17-2007 11:10 AM #26
    DANG you got that rear short!
  27. Member JonnyPhenomenon's Avatar
    Jan 27th, 2005
    Lewiston, Maine (USA)
    88 Scirocco, 78 bus, 91 Vanagon
    04-17-2007 11:30 AM #27
    Man, I would really like to know how this came out. I got a zero dollar budget and gigantic bumpers I really want to resize.
    www.rikerstardresser.com - I'm a donor, are you? - www.marrow.org
