VWVortex.com - How do I remove shift knob on 2001 VW Jetta
    Results 1 to 17 of 17
    Thread: How do I remove shift knob on 2001 VW Jetta
    1. 09-28-2006 09:18 PM #1
      I have a 2001 Volkswagen Jetta 1.8T Wolfsburg Edition 5spd transmission.
      How does the shifter knob come off? I tried to twist it off but it appears to have some type of metal ring around the shaft under the boot. can anyone guide me through this I recently bought a pool ball set and am going to use my lathe and the number "13" ball and make my own shifter knob
    2. 09-28-2006 09:19 PM #2
      get pliars and snip the crimped end untill it comes off
      its a ***** but youll get it after a min or two
    3. 09-28-2006 09:20 PM #3
      you need to cut that ring and good luck finding a way to attach your ball there are no threads
    4. 09-28-2006 09:22 PM #4
      would epoxy hold it on good enough?? since there are no threads?
    5. Member DetailJohnny's Avatar
      Dec 10th, 2004
      Central New York
      too many to list
      09-28-2006 09:34 PM #5
      Get yourself a tap & die set and you'll be all set
      Detail Johnny | Auto Detailing ▪ Paint Correction ▪ Restoration ▪ Paint Coatings
      Phone: 315.286.3868 | detailjohnny@gmail.com| www.detailjohnny.com
    6. 09-28-2006 09:35 PM #6
      instead of 13 make the ball say 1.8
    7. 01-11-2007 04:50 PM #7
      Anyone know of a recent DIY with pictures that work? The last one has pics from 2004 that I believe expired on the host server. Also, I'm not sure of the process yet, but I keep hearing about a brass ring that needs to get clipped. Does this need to get replaced later? Also, how does that affect the new knob? Can't it just pop off at any time?
    8. 01-11-2007 05:09 PM #8
      By the way, I was looking into seeing if an .:R32 would fit properly into the stock 2001 Jetta boot, due to the fact that the .:R32 knob has that diagonal slant where it connects to the boot. Also, would I need to cut the wire tie and unplug the power source assembly by the ash tray?
    9. 01-11-2007 05:13 PM #9
      Quote, originally posted by MidNightDrift »
      Yes it needs to get replaced. Use a hose clamp.
      If you keep the rod the same length and use a VW knob, there shouldn't be any worry.
      If you shorten it the knob won't have a groove to slid into, so it may twist around, just tighten that clamp down like mad and it should be sturdy enough.
      ░░░░░░ .. R13 5
      ░░░░░░ .... 24
    10. 01-11-2007 05:17 PM #10
      Awesome, because I wasn't thinking when I saw a good deal for a mint .:R32 knob, and didn't notice the knob was at a diagonal angle. I was just a little worried because the stock 2001 shift knob/boot are parallel to one another [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    11. Member MikeWire's Avatar
      Oct 20th, 2003
      Montana
      Air and water
      01-11-2007 05:17 PM #11
      Quote, originally posted by -Khaos- »
      x2 - hose clamp works fine.
      2014 VW Passat TDI SEL Premium 6sp DSG | 2010 VW Jetta TDI 6sp DSG | 1992 VW Montana Green GTI | 1982 VW Caddy 1.8 | 1980 VW Lago Caddy 1.8 JH swap | 1972 VW Kombi 9 Passenger Deluxe w/ 2.0L F.I. VWAC
    12. Member vendetta_black's Avatar
      Jan 18th, 2007
      south jersey & DC
      03' GTI 1.8T
      01-18-2007 12:58 AM #12
      i have an 01' too and i cant figure it out.. i took off the ring, but theres this white apparatus type thing attached to the shaft. cant figure out how to get it off.. maybe its because i had a woodgrain knob??
    13. Member SenorBrandon's Avatar
      Jan 4th, 2007
      Sheridan,OR
      88 Triple white cabby,87 16v gti,91 jetta auto, 96 jetta 2.0l, 97 jetta 2.0, 99.5 jetta 2.0
      01-18-2007 01:03 AM #13
      a pool ball?!?! thats gonna be huge
    14. Member vendetta_black's Avatar
      Jan 18th, 2007
      south jersey & DC
      03' GTI 1.8T
      01-18-2007 02:10 PM #14
      did anyone else have that white plastic apparatus thing attached to the shaft like i did (above 2 posts)? if so, howd u get it off?or is it even safe/supposed to come off?
    15. Member RussellsGTI's Avatar
      Sep 2nd, 2005
      Long Island
      03' VW GTI 1.8T
      01-18-2007 02:25 PM #15
      theres a DIY on here that helped me out a ton!
      - love it.
    16. Member SurferbobGolf's Avatar
      Aug 10th, 2005
      Tallahassee, Florida
      2012 VW CC R-Line
      01-18-2007 02:43 PM #16
      http://www.roadsleeper.com/gti/
      Go to the left side of the page and click on 'Shift Knob'
      Flickr
    17. Member vendetta_black's Avatar
      Jan 18th, 2007
      south jersey & DC
      03' GTI 1.8T
      01-18-2007 04:50 PM #17
      perfect!!
