VWVortex.com - Recommended oil change 1.8T 2003 Passat
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 74
    Thread: Recommended oil change 1.8T 2003 Passat
    1. Junior Member
      Jan 30th, 2006
      Hudson, Quebec
      09-29-2006 09:15 AM #1
      Should oil changes be done at every 8,000 km's or 5,000 km,s?
    2. 09-29-2006 09:26 AM #2
      according to VW, 5000 miles. which is about 8000 km. i would take that as a maximum.
    3. Junior Member
      Jan 30th, 2006
      Hudson, Quebec
      09-29-2006 09:31 AM #3
      Thank you
    4. 09-29-2006 09:37 AM #4
      For a 1.8T, 5K is way too long - especially if driving in the city and geographic regions with extreme temperatures (Northeast, for example).
      To be safe, and what I do, is to change the oil, with VW approved synthetic, at a 3 month/3K interval.
    5. 09-29-2006 09:49 AM #5
      Quote, originally posted by shadowblue »
      shadowblue, you should consider doing an oil analysis, when I ran them in the past 5k was ok for me (M1 0W-40). your method is ok but you could save a bit of $$ (and oil) by sticking to the 5k, or 4k if you want to be conservative. An analysis is inexpensive if you want to test based on your driving conditions. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    6. 09-29-2006 10:17 AM #6
      For me, it's every 6 months or 4,250 miles (6,800 km) or 200 gallons (757 litres) of fuel burned, which ever comes first. Mobil 1 0w-40 in the sump.
    7. 09-29-2006 02:52 PM #7
      For mostly-city driving, I have our 1.8T on a 6 month or 3k mi = 5k km OCI, which is conveniently about the same thing, since we currently accumulate about 6k mi = 10k km per year. I have my Blackstone Labs kit ready for a UOA at the next oil change, to see whether this is indeed overkill with Mobil 1 0W-40 and the Purolator L40316 mega-filter.
      By the way, after the first 10k mi / 16k km, the 2006 2.0T's recommended OCI rises to 10k mi / 16k km.
      Modified by John_E at 11:54 AM 9-29-2006
    8. 09-29-2006 03:18 PM #8
      Quote, originally posted by John_E »
      John, I'll be interested in hearing your UOA results. I think I'm in the same situation as you are, driving-wise, but I've stretched it out to my 4,250 miles. Plus, I'm using the diesel filter from my dealer.
      BTW, do you know the volume of oil that the 2.0T takes? Is it much more than the 1.8T? Or have they tamed some of the characteristics that degraded the oil in the 1.8T?
      I'd also be curious how the owner's manual reads on the 2.0T models...have they addressed the need to be a mystic to discern what oil is required and have they addressed a severe usage maintenance schedule?
    9. 09-29-2006 05:05 PM #9
      Thats what I do. Did it in my corrado, my old 1.8T Jetta, and my S4. I do it in my sister's 1.8T jetta. I guess I'm just old school. What I really don't understand is all the new models going 10k mileage intervals.
    10. 09-29-2006 09:06 PM #10
      i waited 4,000 and used synthetic blend.
    11. 10-01-2006 12:16 AM #11
      Quote, originally posted by scpassat03 »
      Why a synth blend? Are there any that are 502 approved?
    12. 10-02-2006 09:46 AM #12
      Quote, originally posted by hang_tin »
      Not last time I checked.
    13. 10-02-2006 10:29 AM #13
      Quote, originally posted by CorradoG60 »
      We're both old school, I guess.
    14. 10-02-2006 10:32 AM #14
      the 2.0T takes 4.4 qts, and has a 7.6 qt cooling system capacity.
      A 1.8T Passat with the big filter is about 4.2 qts, the early 1.8T with small filter was just 3.9 qts.
      Quote, originally posted by Altair 4 »
    15. 10-02-2006 07:46 PM #15
      Quote, originally posted by scotty_passat »
      2.0T (bpy) takes 6.3 qts. Cooling system capacity is 8.5 qts for passat, gti, jetta. Regular 2.0 (aeg, bbw, bev, avh.....)which they don't make anymore is 4.4qts
    16. 10-07-2006 11:13 AM #16
      Here in the UK, the standard service interval is 10000miles/12 months or up to double that for extended servicing using long-life oil. There are no significant issues with oil sludging here or in Europe. Why are the US service intervals so different??
    17. Member
      Jun 21st, 2000
      2003 Passat Variant GLS 1.8t 5MT (and a bunch of VWs before that)
      10-07-2006 10:25 PM #17
      That is totally insane.
    18. 10-08-2006 05:21 PM #18
      US oil change intervals are so short because MOST Amercan drivers go for the cheapest oil changes that they can and think that synthetic oil is overkill or snake-oil. Also, American drivers have been conditioned to change their oil at 3 month or 3,000 mile intervals (probably good since nobody is using synthetic oil). Most Americans freak out when they hear about Mercedes or Porsche and their 10K mile changes done at the dealerships.
      The 1.8T engine is designed to use synthetic only (small oil capacity, turbo, etc.), but when I bought my car (in 2004), the dealer was selling "special" oil for the turbo that wasn't even a synthetic blend (100% dinosaur)! I'm willing to bet that the "1.8T sludge problem" was non-existant in Europe. Who the hell would even THINK of using non-synthetic oil in a turbo engine?
    19. 10-08-2006 07:26 PM #19
      I change it every 5000 miles using Amsoil oil and filters. Last week I got a oil pressure light. The light comes on only if the car is in gear. At idle it won't come on.
      The dealer said it is the oil pump. He wanted to see the records for the oil changes which if forwarded to him. He now wants more proof of oil changes even though I documented the changes as per VW requirements. I'm still waiting to hear back from them on the warrenty issue. It seems to me VW is trying to get out of paying for the repair.
      I'm getting to the point of never considering a VW again at this rate.
    20. 10-08-2006 08:06 PM #20
      There's a VW tech on PW that had written on a forum there that performing your own oil change would invalid the "Sludge" warranty.
      I'm guessing that your original warranty is still intact, though. How many miles on your vehicle? I assume you performed the oil changes yourself? What was the nature of the documentation that you provided to your dealer? Receipts of purchases, installation dates?
      You might get a chance to see how well Amsoil stands behind their warranty. Good luck to ya.
      Modified by Altair 4 at 8:29 PM 10-8-2006
    21. 10-08-2006 09:50 PM #21
      Quote, originally posted by rscalzo »
      I change it every 5000 miles using Amsoil oil and filters. ... The dealer said it is the oil pump.
      Please keep us posted. There are lots of folks who started with dino oil, then switched to synthetic, and ended up with blocked oil pumps, because coke had already built up in their turbos and gradually found its way to the pump's inlet screen. If your engine was on synthetic oil from Day One, then your experience is pretty scary. How is your PCV system? Problems there can cause traditional oil sludging, even with synthetic oil, and I suspect sludge turns readily into coke when baked in the turbo.
      You evidently have lots of company. I am on the fence, myself. Everything depends on my ownership experience over the next 5 to 10 years.
    22. 10-08-2006 09:55 PM #22
      I should start a poll. The current Mobil 1 0W-40 oil has been in there for 2500 mostly city miles and almost 7 months. I am thinking of going a few hundred more miles before changing, and I do have my Blackstone Labs UOA kit ready to go. I use the Purolator L40316 monster filter, and the oil still LOOKS very clean this time around.
    23. 10-08-2006 10:40 PM #23
      I had the oil changes done locally at a mechanic who is a Amsoil dealer. I provided bills from every oil change to the dealer. The only time dino oil was ever used in the vehicle was when the VW dealer changed the oil.
      The car has 41k on it.
    24. 10-08-2006 11:59 PM #24
      Damn. Sludge / coke at 41K with synthetic oil? You have my sympathies. I'm pushing 60K, all on dino; so far, so good. I'm in the ARX rinse phase now and will be putting in German Castrol in a couple of weeks. I sure hope the ARX has dissolved any coke...
    25. Senior Member nm+'s Avatar
      Jan 6th, 2006
      Land of Bro-Dozer Ya Yas
      2005 Legacy GT Wagon 5MT w/overnight diffs from Japan; 2013 Mazda 2 5MT
      10-09-2006 12:18 AM #25
      Damn, did you do turbo cool downs or anything?
