VWVortex.com - will mk3 gti seats fit in my mk2 golf?
    Results 1 to 12 of 12
    Thread: will mk3 gti seats fit in my mk2 golf?
    1. 10-04-2006 02:18 PM #1
      any input will help.
    2. Banned UdubVdub's Avatar
      Jun 30th, 2004
      10-04-2006 02:25 PM #2
      Search. Use it.
      But yes, they CAN fit if you know how to weld and tweak them. It's not a bolt-in affair. I had them in my GLI.
    3. 10-04-2006 02:28 PM #3
      mk3 rails are 2" wider than a mk2.
    4. Banned A2Euro's Avatar
      May 18th, 2006
      10-04-2006 02:34 PM #4
      so you bent the arm in 2 inches.........Voila....it works.
    5. Banned UdubVdub's Avatar
      Jun 30th, 2004
      10-04-2006 02:45 PM #5
      Umm, it's not quite that easy. You need to do some cutting and welding of the mounts to be able to move them in two inches and to keep the seat level..
    6. Banned A2Euro's Avatar
      May 18th, 2006
      10-04-2006 02:48 PM #6
      then bang each side in 1 inch.....Voila....it works...
      all im saying is I have done it without welding anything with no problems.
    7. 10-04-2006 03:19 PM #7
      I know that you can swap mk2 lower base to mk3 pads
    8. 10-04-2006 03:21 PM #8
      in the FAQ page 6 iirc
      just swap the seat rails. Simple, quick, done. Seat rails are easy to take off. Seats might be a bear to get out. But swap your old ones onto the mkiii seats, instal, done.
    9. Banned A2Euro's Avatar
      May 18th, 2006
      10-04-2006 03:25 PM #9
      true
    10. 10-04-2006 03:52 PM #10
      correct me if I'm wrong but I have a Mk2 seat and a Mk3 seat side by side right in front of me and the rails seem to be welded into the actual frame of the seat.
    11. 10-04-2006 04:07 PM #11
      you remove the entire frame. Flip it over and you will see some bolts into the bottom. Take them out and the entire frame pops off.
    12. 10-05-2006 11:33 AM #12
      http://forums.vwvortex.com/zerothread?id=2827431
      Thats a DIY for the seats, it seems pretty easy actually
    « Back
